Hi
I’m following this doc to setup multi-lora on AWS EKS and it’s working. Now I’d like to evaluate its performance based on this doc
The warm-up evaluation goes well, but I encounter an issue in the phase of “sweeping through all the use cases”.
Although genai-perf complete the evaluation with various use cases and concurrency, there are missing files of “input_output_genai_perf.csv” in each folder.
Here is my first level file structure:
In each folder, I got the same file structure as follows:
here is the script I used to run benchmark
declare -A useCases
# Populate the array with use case descriptions and their specified input/output lengths
useCases["Translation"]="200/200"
useCases["Text classification"]="200/5"
useCases["Text summary"]="1000/200"
# Function to execute genAI-perf with the input/output lengths as arguments
runBenchmark() {
local description="$1"
local lengths="${useCases[$description]}"
IFS='/' read -r inputLength outputLength <<< "$lengths"
echo "Running genAI-perf for $description with input length $inputLength and output length $outputLength"
#Runs
for concurrency in 1 2 5 10 50 100 250; do
local INPUT_SEQUENCE_LENGTH=$inputLength
local INPUT_SEQUENCE_STD=0
local OUTPUT_SEQUENCE_LENGTH=$outputLength
local CONCURRENCY=$concurrency
local MODEL=llama3-8b-instruct-lora_vhf-squad-v1
genai-perf \
-m $MODEL \
--endpoint-type chat \
--service-kind openai \
--streaming \
-u 10.100.59.31:8000 \
--synthetic-input-tokens-mean $INPUT_SEQUENCE_LENGTH \
--synthetic-input-tokens-stddev $INPUT_SEQUENCE_STD \
--concurrency $CONCURRENCY \
--output-tokens-mean $OUTPUT_SEQUENCE_LENGTH \
--extra-inputs max_tokens:$OUTPUT_SEQUENCE_LENGTH \
--extra-inputs min_tokens:$OUTPUT_SEQUENCE_LENGTH \
--extra-inputs ignore_eos:true \
--tokenizer meta-llama/Meta-Llama-3-8B-Instruct \
--measurement-interval 10000 \
--profile-export-file ${INPUT_SEQUENCE_LENGTH}_${OUTPUT_SEQUENCE_LENGTH}.json \
-v \
--max-threads=256
done
# Iterate over all defined use cases and run the benchmark script for each
for description in "${!useCases[@]}"; do
runBenchmark "$description"
done
I only have one csv file called profile_export_genai_perf.csv, but I expect to have multiple csf files for each use cases, which should be something like this:
I intend to use these csv files to conduct basic data analysis to generate plots, but the missing csv files in each folder block the way, is there anyone who could help provide some tips to better address this issue?
