when I connect IR Infrared Obstacle Avoidance Sensor with NANO and set GPIO mode into INPUT function, the result is always ‘LOW’ i don’t why
hello violentbaseballbat1202,
had you already finish customize configurations?
you might also refer to developer guide, please check Configuring the 40-pin Expansion Header.
thanks
Related topics
| Jetson Nano GPIO example problem | 30 | 23272 | September 23, 2021 | |
| Read Sensor OUT data (PIR) from GPIO pins Jets Nano | 5 | 1771 | September 11, 2020 | |
| GPIO of Jetson Nano not working with simple speed sensor | 8 | 2068 | September 6, 2021 | |
| pySX127x on Jetson Nano 4gb | 36 | 3004 | September 30, 2021 | |
| Jetson Orin Nano Developer Kit (Super) GPIO Input Issue | 15 | 256 | September 11, 2026 | |
| Jetson Nano GPIO setting LOW or HIGH problem | 7 | 3482 | April 26, 2021 | |
| Jetson nano gpio enable and interrupt enable | 1 | 627 | March 22, 2021 | |
| I need a help about PIR Sensor Connected with Jetson nano | 3 | 2108 | December 15, 2020 | |
| Jetson Nano GPIO goes high, but not low | 9 | 4593 | June 25, 2021 | |
| How to set up IR control using LIRC (through GPIO on Jetson board) still not answered | 1 | 545 | March 22, 2023 |
