Issues Building Custom Kernel 36.4 new Jetson Orin Nano Dev Kit
I have tried to build a custom kernel with some networking and virtualization options enabled (=Y), making sure both .config and defconfig are the same, and following all the steps detailed in the developer guide documentation for the last jetson linux kernel release (36.4).
I first started building the kernel and modules natively in my new “Jetson Orin Nano Developer Kit 8GB”, and now, as some people say it is better using the NVIDIA SDK Manager scripts, I am using now this tool, in a Ubuntu 22.04 (WSL2) using cross compilation with the recommended toolchain for the release.
For both ways, I notice the output kernel is smaller than the default kernel (always 29MB), even if I enable more modules, and when using the SDK Manager happens again. Also there is always a compilation error of the “nvidia-oot” module, specifically this one “clk/tegra/clk-bpmp.c:673:5: error: redefinition of ‘tegra_bpmp_init_clocks’”, or this one “/reset/tegra/reset-bpmp.c:67:5: error: redefinition of ‘tegra_bpmp_init_resets’”. I have also used the “nv_public_src_build.sh” and “nvbuild.sh” scripts for building, but I get the same results.
What am I missing?
Looking forward to your response, thank you!
I am now trying to compile the kernel and the modules in a real virtual machine, not with WSL2, with Ubuntu 22.04 using SDK Manager, as I have recently read that WSL might be a problem.
After trying this, I will give another update on this issue…
Yo may check the posts for customizing kernel:
Building the kernel from kernel source jetpack 6 , jetson orin nx 16GB - #5 by DaneLLL
Jetson/L4T/r36.3.x patches - eLinux.org
Kernel Customization
It does not seem to be the issue, I have executed the make as recommended in the post and the resulting kernel image is again 29MB.
Toolchain:
/home/ubuntu/aarch64--glibc--stable-2022.08-1/bin/aarch64-buildroot-linux-gnu-cc --version
aarch64-buildroot-linux-gnu-cc.br_real (Buildroot 2022.08) 11.3.0
Copyright (C) 2021 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
Executed command (in source directory):
~/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source$ sudo CROSS_COMPILE=/home/ubuntu/aarch64--glibc--stable-2022.08-1/bin/aarch64-buildroot-linux-gnu- make -C kernel
Final output of make command:
  LD [M]  sound/pci/trident/snd-trident.ko
  LD [M]  sound/pci/ymfpci/snd-ymfpci.ko
  LD [M]  sound/synth/snd-util-mem.ko
Kernel Image: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/kernel/kernel-jammy-src/arch/arm64/boot/Image
Kernel sources compiled successfully.
make: Leaving directory '/home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/kernel'
Image generated:
ls -lah /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/kernel/kernel-jammy-src/arch/arm64/boot/Image
-rw-r--r-- 1 root root 29M Oct 11 09:35 /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/kernel/kernel-jammy-src/arch/arm64/boot/Image
We would suggest use host PC in Ubuntu OS. It is a complete system for further development.
I also have a machine with Ubuntu 22.04 as native OS by hand at work, I’ll will give it a try and let you know when I get to try it again, thank you.
I have tried it again in a machine with a native Ubuntu 22.04 OS installed, and I get the same results.
After modifying the defconfig and .config, when I do the first command:
sudo CROSS_COMPILE=/home/my-user/aarch64--glibc--stable-2022.08-1/bin/aarch64-buildroot-linux-gnu- make -C kernel
It is generated again an “Image” that is 29MB, and also when I do the make install:
sudo ARCH=arm64 CROSS_COMPILE=/home/my-user/kernel/aarch64--glibc--stable-2022.08-1/bin/aarch64-buildroot-linux-gnu- INSTALL_MOD_PATH=/home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs make install -C kernel
The output has many warnings like these, a lot of them related to Tegra it seems (even though a lot of modules are installed correctly):
depmod: WARNING: /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/video/tegra/host/nvdla/nvhost-nvdla.ko needs unknown symbol bpf_trace_run3
depmod: WARNING: /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/video/tegra/host/nvdla/nvhost-nvdla.ko needs unknown symbol tegra_sku_info
depmod: WARNING: /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/video/tegra/host/nvdla/nvhost-nvdla.ko needs unknown symbol _mcount
depmod: WARNING: /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/misc/nvsciipc/nvsciipc.ko needs unknown symbol _mcount
depmod: WARNING: /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/bluetooth/realtek/rtk_btusb.ko needs unknown symbol _mcount
depmod: WARNING: /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/video/tegra/host/isp/nvhost-isp5.ko needs unknown symbol _mcount
depmod: WARNING: /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/video/tegra/dc/bridge/ti_fpdlink_dp_serializer.ko needs unknown symbol _mcount
depmod: WARNING: /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/media/i2c/nv_imx318.ko needs unknown symbol _mcount
depmod: WARNING: /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/platform/tegra/aon/tegra-aon-ivc-echo.ko needs unknown symbol _mcount
Then I try to compile the OOT modules, with:
sudo ARCH=arm64 CROSS_COMPILE=/home/my-user/kernel/aarch64--glibc--stable-2022.08-1/bin/aarch64-buildroot-linux-gnu- KERNEL_HEADERS=/home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/kernel/kernel-jammy-src make modules
And I get an output like this:
make modules - conftest ...
mkdir -p /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/out/nvidia-conftest/nvidia;
cp -av /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/scripts/conftest/* /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/out/nvidia-conftest/nvidia/;
'/home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/scripts/conftest/Makefile' -> '/home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/out/nvidia-conftest/nvidia/Makefile'
'/home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/scripts/conftest/conftest.h' -> '/home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/out/nvidia-conftest/nvidia/conftest.h'
'/home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/scripts/conftest/conftest.sh' -> '/home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/out/nvidia-conftest/nvidia/conftest.sh'
make -j 12 ARCH=arm64 \
        src=/home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/out/nvidia-conftest/nvidia obj=/home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/out/nvidia-conftest/nvidia \
        CC=/home/my-user/kernel/aarch64--glibc--stable-2022.08-1/bin/aarch64-buildroot-linux-gnu-gcc LD=/home/my-user/kernel/aarch64--glibc--stable-2022.08-1/bin/aarch64-buildroot-linux-gnu-ld \
        NV_KERNEL_SOURCES=/home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/kernel/kernel-jammy-src \
        NV_KERNEL_OUTPUT=/home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/kernel/kernel-jammy-src \
        -f /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/out/nvidia-conftest/nvidia/Makefile
make[1]: se entra en el directorio '/home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source'
make[1]: se sale del directorio '/home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source'
make modules - hwpm ...
        -C /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/kernel/kernel-jammy-src \
        M=/home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/hwpm/drivers/tegra/hwpm \
        CONFIG_TEGRA_OOT_MODULE=m \
        srctree.hwpm=/home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/hwpm \
        srctree.nvconftest=/home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/out/nvidia-conftest \
        modules
make[1]: se entra en el directorio '/home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/kernel/kernel-jammy-src'
make[1]: se sale del directorio '/home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/kernel/kernel-jammy-src'
make modules - nvidia-oot ...
        M=/home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot \
        srctree.nvidia-oot=/home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot \
        KBUILD_EXTRA_SYMBOLS=/home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/hwpm/drivers/tegra/hwpm/Module.symvers \
        modules
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/nvpmodel/nvpmodel-clk-cap.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/firmware/tegra/../../clk/tegra/clk-bpmp.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/mtd/devices/tegra_hv_mtd.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/nv-p2p/nvidia-p2p.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/ethernet/nvidia/pcie/tegra_vnet.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/can/mttcan/native/m_ttcan_linux.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/pci/controller/tegra-pcie-edma.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/nvpps/nvpps_main.o
  DTC     /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/misc/mods/mods.dtb
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/misc/mods/mods_irq.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/nvpps/ptp-notifier.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/misc/mods/mods_krnl.o
/home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/firmware/tegra/../../clk/tegra/clk-bpmp.c:673:5: error: redefinición de ‘tegra_bpmp_init_clocks’
  673 | int tegra_bpmp_init_clocks(struct tegra_bpmp *bpmp)
En el fichero incluido desde /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/firmware/tegra/../../clk/tegra/clk-bpmp.c:9:
./include/soc/tegra/bpmp.h:177:19: nota: previous definition of ‘tegra_bpmp_init_clocks’ with type ‘int(struct tegra_bpmp *)’
  177 | static inline int tegra_bpmp_init_clocks(struct tegra_bpmp *bpmp)
make[4]: *** [scripts/Makefile.build:295: /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/firmware/tegra/../../clk/tegra/clk-bpmp.o] Error 1
make[3]: *** [scripts/Makefile.build:559: /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/firmware/tegra] Error 2
make[3]: *** Se espera a que terminen otras tareas....
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/misc/mods/mods_mem.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/misc/mods/mods_clock.o
/home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/nv-p2p/nvidia-p2p.c: En la función ‘nvidia_p2p_mn_invl_range_start_legacy’:
/home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/nv-p2p/nvidia-p2p.c:89:17: error: declaración implícita de la función ‘mmu_notifier_put’; ¿quiso decir ‘mmu_notifier_release’? [-Werror=implicit-function-declaration]
   89 |                 mmu_notifier_put(&page_table->mn);
/home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/nv-p2p/nvidia-p2p.c: En la función ‘nvidia_p2p_get_pages’:
/home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/nv-p2p/nvidia-p2p.c:171:15: error: declaración implícita de la función ‘mmu_notifier_register’; ¿quiso decir ‘mmu_notifier_release’? [-Werror=implicit-function-declaration]
  171 |         ret = mmu_notifier_register(&(*page_table)->mn, (*page_table)->mm);
/home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/nv-p2p/nvidia-p2p.c: En la función ‘nvidia_p2p_put_pages’:
/home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/nv-p2p/nvidia-p2p.c:195:9: error: declaración implícita de la función ‘mmu_notifier_unregister’; ¿quiso decir ‘mmu_notifier_release’? [-Werror=implicit-function-declaration]
  195 |         mmu_notifier_unregister(&page_table->mn, page_table->mm);
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/can/mttcan/native/m_ttcan_sys.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/can/mttcan/hal/m_ttcan.o
cc1: todos los avisos se tratan como errores
make[4]: *** [scripts/Makefile.build:295: /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/nv-p2p/nvidia-p2p.o] Error 1
make[3]: *** [scripts/Makefile.build:559: /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/nv-p2p] Error 2
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/can/mttcan/hal/m_ttcan_intr.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/pci/controller/pcie-tegra-vf.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/can/mttcan/hal/m_ttcan_list.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/misc/mods/mods_debugfs.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/ethernet/nvidia/nvethernet/ether_linux.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/ethernet/nvidia/nvethernet/osd.o
  LD [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/nvpps/nvpps.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/misc/mods/mods_dma.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/ethernet/marvell/oak/oak.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/misc/mods/mods_dmabuf.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/misc/nvsciipc/nvsciipc.o
En el fichero incluido desde ./include/linux/module.h:22,
                 desde /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/misc/nvsciipc/nvsciipc.c:13:
./include/linux/module.h:183:43: error: expected ‘,’ or ‘;’ before ‘KBUILD_MODFILE’
  183 | #define MODULE_FILE     MODULE_INFO(file, KBUILD_MODFILE);
./include/linux/moduleparam.h:26:61: nota: en definición de macro ‘__MODULE_INFO’
   26 |                 = __MODULE_INFO_PREFIX __stringify(tag) "=" info
./include/linux/module.h:183:25: nota: en expansión de macro ‘MODULE_INFO’
./include/linux/module.h:230:34: nota: en expansión de macro ‘MODULE_FILE’
  230 | #define MODULE_LICENSE(_license) MODULE_FILE MODULE_INFO(license, _license)
/home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/misc/nvsciipc/nvsciipc.c:865:1: nota: en expansión de macro ‘MODULE_LICENSE’
  865 | MODULE_LICENSE("GPL v2");
make[5]: *** [scripts/Makefile.build:295: /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/misc/nvsciipc/nvsciipc.o] Error 1
make[4]: *** [scripts/Makefile.build:559: /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/misc/nvsciipc] Error 2
make[4]: *** Se espera a que terminen otras tareas....
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/ethernet/nvidia/nvethernet/ethtool.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/ethernet/marvell/oak/oak_net.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/can/mttcan/hal/m_ttcan_ram.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/ethernet/microchip/5.15/lan743x_main.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/ethernet/marvell/oak/oak_irq.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/can/mttcan/hal/m_ttcan_tt.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/ethernet/marvell/oak/oak_ethtool.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/ethernet/marvell/oak/oak_unimac.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/ethernet/marvell/oak/oak_debug.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/ethernet/marvell/oak/oak_chksum.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/ethernet/marvell/oak/oak_dpm.o
  LD [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/can/mttcan/mttcan.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/ethernet/nvidia/nvethernet/ether_tc.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/misc/mods/mods_netdevice.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/misc/mods/mods_pci.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/ethernet/nvidia/nvethernet/sysfs.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/ethernet/nvidia/nvethernet/ioctl.o
  DTB     /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/misc/mods/mods.dtb.S
  AS [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/misc/mods/mods.dtb.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/ethernet/nvidia/nvethernet/ptp.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/ethernet/nvidia/nvethernet/macsec.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/ethernet/nvidia/nvethernet/selftests.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/ethernet/nvidia/nvethernet/nvethernetrm/osi/core/osi_core.o
  LD [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/ethernet/marvell/oak/oak_pci.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/ethernet/nvidia/nvethernet/nvethernetrm/osi/core/osi_hal.o
  LD [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/misc/mods/mods.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/ethernet/realtek/r8168/r8168_n.o
make[3]: *** [scripts/Makefile.build:559: /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/misc] Error 2
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/ethernet/nvidia/nvethernet/nvethernetrm/osi/core/macsec.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/ethernet/realtek/r8126/r8126_n.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/ethernet/realtek/r8126/rtl_eeprom.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/ethernet/microchip/5.15/lan743x_ethtool.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/ethernet/nvidia/nvethernet/nvethernetrm/osi/common/osi_common.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/ethernet/nvidia/nvethernet/nvethernetrm/osi/common/eqos_common.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/ethernet/microchip/5.15/lan743x_ptp.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/ethernet/nvidia/nvethernet/nvethernetrm/osi/common/mgbe_common.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/ethernet/nvidia/nvethernet/nvethernetrm/osi/dma/osi_dma.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/ethernet/realtek/r8126/rtltool.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/ethernet/nvidia/nvethernet/nvethernetrm/osi/dma/osi_dma_txrx.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/ethernet/realtek/r8168/r8168_asf.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/ethernet/nvidia/nvethernet/nvethernetrm/osi/core/eqos_core.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/ethernet/realtek/r8168/rtl_eeprom.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/ethernet/realtek/r8168/rtltool.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/ethernet/nvidia/nvethernet/nvethernetrm/osi/core/ivc_core.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/ethernet/nvidia/nvethernet/nvethernetrm/osi/core/mgbe_core.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/ethernet/nvidia/nvethernet/nvethernetrm/osi/core/core_common.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/ethernet/nvidia/nvethernet/nvethernetrm/osi/core/xpcs.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/ethernet/nvidia/nvethernet/nvethernetrm/osi/dma/mgbe_dma.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/ethernet/realtek/r8126/r8126_ptp.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/ethernet/nvidia/nvethernet/nvethernetrm/osi/core/eqos_mmc.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/ethernet/nvidia/nvethernet/nvethernetrm/osi/dma/eqos_dma.o
  LD [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/ethernet/microchip/lan743x.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/ethernet/nvidia/nvethernet/nvethernetrm/osi/dma/eqos_desc.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/ethernet/realtek/r8126/r8126_rss.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/core/rtw_cmd.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/core/rtw_security.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/ethernet/nvidia/nvethernet/nvethernetrm/osi/dma/mgbe_desc.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/ethernet/nvidia/nvethernet/nvethernetrm/osi/dma/debug.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/ethernet/nvidia/nvethernet/nvethernetrm/osi/core/mgbe_mmc.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/core/rtw_debug.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/core/rtw_io.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/ethernet/nvidia/nvethernet/nvethernetrm/osi/core/frp.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/core/rtw_ioctl_query.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/ethernet/nvidia/nvethernet/nvethernetrm/osi/core/vlan_filter.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/ethernet/nvidia/nvethernet/nvethernetrm/osi/core/debug.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/core/rtw_ioctl_set.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/core/rtw_ieee80211.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/core/rtw_mlme.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/core/rtw_mlme_ext.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/core/rtw_mi.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/core/rtw_wlan_util.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/core/rtw_vht.o
  LD [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/ethernet/nvidia/nvethernet/nvethernet.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/core/rtw_pwrctrl.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/core/rtw_rf.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/core/rtw_chplan.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/core/monitor/rtw_radiotap.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/core/rtw_recv.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/core/rtw_sta_mgt.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/core/rtw_ap.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/core/wds/rtw_wds.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/core/mesh/rtw_mesh.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/core/mesh/rtw_mesh_pathtbl.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/core/mesh/rtw_mesh_hwmp.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/core/rtw_xmit.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/core/rtw_p2p.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/core/rtw_rson.o
  LD [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/ethernet/realtek/r8126/r8126.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/core/rtw_tdls.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/core/rtw_br_ext.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/core/rtw_iol.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/core/rtw_sreset.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/core/rtw_btcoex_wifionly.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/core/rtw_btcoex.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/core/rtw_beamforming.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/core/rtw_odm.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/core/rtw_rm.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/core/rtw_rm_fsm.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/core/rtw_ft.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/core/rtw_wnm.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/core/rtw_mbo.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/core/rtw_rm_util.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/core/efuse/rtw_efuse.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/core/rtw_roch.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/core/crypto/aes-internal.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/core/crypto/aes-internal-enc.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/core/crypto/aes-gcm.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/core/crypto/aes-ccm.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/core/crypto/aes-omac1.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/core/crypto/ccmp.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/core/crypto/gcmp.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/core/crypto/aes-siv.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/core/crypto/aes-ctr.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/core/crypto/sha256-internal.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/core/crypto/sha256.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/core/crypto/sha256-prf.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/core/crypto/rtw_crypto_wrap.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/core/rtw_swcrypto.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/os_dep/osdep_service.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/os_dep/linux/os_intfs.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/os_dep/linux/pci_intf.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/os_dep/linux/pci_ops_linux.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/os_dep/linux/ioctl_linux.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/os_dep/linux/xmit_linux.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/os_dep/linux/mlme_linux.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/os_dep/linux/recv_linux.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/os_dep/linux/ioctl_cfg80211.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/os_dep/linux/rtw_cfgvendor.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/os_dep/linux/wifi_regd.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/os_dep/linux/rtw_android.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/os_dep/linux/rtw_proc.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/os_dep/linux/nlrtw.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/os_dep/linux/rtw_rhashtable.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/os_dep/linux/ioctl_mp.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/hal_intf.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/hal_com.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/hal_com_phycfg.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/hal_phy.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/hal_dm.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/hal_dm_acs.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/hal_btcoex_wifionly.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/hal_btcoex.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/hal_mp.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/hal_mcc.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/hal_hci/hal_pci.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/led/hal_led.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/led/hal_pci_led.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/rtl8822c/rtl8822c_halinit.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/rtl8822c/rtl8822c_mac.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/rtl8822c/rtl8822c_cmd.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/rtl8822c/rtl8822c_phy.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/rtl8822c/rtl8822c_ops.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/rtl8822c/hal8822c_fw.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/rtl8822c/pci/rtl8822ce_halinit.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/rtl8822c/pci/rtl8822ce_halmac.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/rtl8822c/pci/rtl8822ce_io.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/rtl8822c/pci/rtl8822ce_xmit.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/rtl8822c/pci/rtl8822ce_recv.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/rtl8822c/pci/rtl8822ce_led.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/rtl8822c/pci/rtl8822ce_ops.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/efuse/rtl8822c/HalEfuseMask8822C_PCIE.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/hal_halmac.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/halmac/halmac_api.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/halmac/halmac_dbg.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/halmac/halmac_88xx/halmac_bb_rf_88xx.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/halmac/halmac_88xx/halmac_cfg_wmac_88xx.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/halmac/halmac_88xx/halmac_common_88xx.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/halmac/halmac_88xx/halmac_efuse_88xx.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/halmac/halmac_88xx/halmac_flash_88xx.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/halmac/halmac_88xx/halmac_fw_88xx.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/halmac/halmac_88xx/halmac_gpio_88xx.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/halmac/halmac_88xx/halmac_init_88xx.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/halmac/halmac_88xx/halmac_mimo_88xx.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/halmac/halmac_88xx/halmac_pcie_88xx.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/halmac/halmac_88xx/halmac_8822c/halmac_cfg_wmac_8822c.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/halmac/halmac_88xx/halmac_8822c/halmac_common_8822c.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/halmac/halmac_88xx/halmac_8822c/halmac_gpio_8822c.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/halmac/halmac_88xx/halmac_8822c/halmac_init_8822c.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/halmac/halmac_88xx/halmac_8822c/halmac_phy_8822c.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/halmac/halmac_88xx/halmac_8822c/halmac_pwr_seq_8822c.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/halmac/halmac_88xx/halmac_8822c/halmac_pcie_8822c.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/phydm/phydm_debug.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/phydm/phydm_antdiv.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/phydm/phydm_soml.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/phydm/phydm_smt_ant.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/phydm/phydm_antdect.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/phydm/phydm_interface.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/phydm/phydm_phystatus.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/phydm/phydm_hwconfig.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/phydm/phydm.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/phydm/phydm_dig.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/phydm/phydm_pathdiv.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/phydm/phydm_rainfo.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/phydm/phydm_dynamictxpower.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/phydm/phydm_adaptivity.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/phydm/phydm_cfotracking.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/phydm/phydm_noisemonitor.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/phydm/phydm_beamforming.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/phydm/phydm_direct_bf.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/phydm/phydm_dfs.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/phydm/txbf/halcomtxbf.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/phydm/txbf/haltxbfinterface.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/phydm/txbf/phydm_hal_txbf_api.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/phydm/phydm_adc_sampling.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/phydm/phydm_ccx.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/phydm/phydm_psd.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/phydm/phydm_primary_cca.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/phydm/phydm_cck_pd.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/phydm/phydm_rssi_monitor.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/phydm/phydm_auto_dbg.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/phydm/phydm_math_lib.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/phydm/phydm_api.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/phydm/phydm_pow_train.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/phydm/phydm_lna_sat.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/phydm/phydm_pmac_tx_setting.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/phydm/phydm_mp.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/phydm/phydm_cck_rx_pathdiv.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/phydm/halrf/halrf.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/phydm/halrf/halrf_debug.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/phydm/halrf/halphyrf_ce.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/phydm/halrf/halrf_powertracking_ce.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/phydm/halrf/halrf_powertracking.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/phydm/halrf/halrf_kfree.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/phydm/halrf/halrf_psd.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/phydm/rtl8822c/halhwimg8822c_bb.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/phydm/rtl8822c/phydm_hal_api8822c.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/phydm/rtl8822c/phydm_regconfig8822c.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/phydm/rtl8822c/phydm_rtl8822c.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/phydm/halrf/rtl8822c/halrf_8822c.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/phydm/halrf/rtl8822c/halrf_iqk_8822c.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/phydm/halrf/rtl8822c/halrf_tssi_8822c.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/phydm/halrf/rtl8822c/halrf_dpk_8822c.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/phydm/halrf/rtl8822c/halrf_txgapk_8822c.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/phydm/halrf/rtl8822c/halrf_rfk_init_8822c.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/phydm/halrf/rtl8822c/halhwimg8822c_rf.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/btc/halbtc8822cwifionly.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/btc/halbtccommon.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/hal/btc/halbtc8822c.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/platform/platform_ops.o
  CC [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/core/rtw_mp.o
  LD [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/wireless/realtek/rtl8822ce/rtl8822ce.o
  LD [M]  /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers/net/ethernet/realtek/r8168/r8168.o
make[2]: *** [scripts/Makefile.build:559: /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot/drivers] Error 2
make[1]: *** [Makefile:1912: /home/my-user/kernel/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/source/nvidia-oot] Error 2
make: *** [Makefile:75: nvidia-oot] Error 2
The same compilation error in nvidia-oot, with tegra_bpmp_init_clocks or tegra_bpmp_init_resets.
I hope we can locate where is the problem with this, thank you so much!
Hi @azulu
I think there is a misunderstanding on how to compile the kernel sources.
You have to get the JetPack kernel sources from https://developer.nvidia.com/downloads/embedded/l4t/r36_release_v4.0/sources/public_sources.tbz2
Install the following dependencies if you did not have installed them yet:
sudo apt install wget lbzip2 build-essential bc zip libgmp-dev libmpfr-dev libmpc-dev vim-common libncurses-dev bison flex libssl-dev libelf-dev
Here are some instructions and how compile the kernel-based sources so you can take it as a reference:
Go to the Linux_for_Tegra directory
cd ~/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra
Copy the file public_sources.tbz2 to the Linux_for_Tegra directory and extract the files. For extracting the kernel and the NVIDIA out-of-tree modules from the public sources:
tar -xjf public_sources.tbz2 Linux_for_Tegra/source/kernel_src.tbz2 --strip-components 2
tar -xjf public_sources.tbz2 Linux_for_Tegra/source/kernel_oot_modules_src.tbz2 --strip-components 2
tar -xjf public_sources.tbz2 Linux_for_Tegra/source/nvidia_kernel_display_driver_source.tbz2 --strip-components 2
Export the following environment variables:
export DEVDIR=~/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra
# Use your CROSS_COMPILE toolchain path
export CROSS_COMPILE=$HOME/l4t-gcc/aarch64--glibc--stable-2022.08-1/bin/aarch64-buildroot-linux-gnu-
export INSTALL_MOD_PATH=$DEVDIR/rootfs/
export KERNEL_HEADERS=$DEVDIR/sources/kernel/kernel-jammy-src
Create inside Linux_for_Tegra a sources directory. Then extract the kernel and the NVIDIA out-of-tree modules sources in the sources directory
cd $DEVDIR
mkdir sources
tar -xjf kernel_src.tbz2 -C sources tar -xjf kernel_oot_modules_src.tbz2 -C sources
tar -xjf nvidia_kernel_display_driver_source.tbz2 -C sources
Compile the kernel, device tree and modules. Go to the kernel directory
cd $DEVDIR/sources/kernel/kernel-jammy-src
Execute the default configuration. You can enable any kernel configuration if you wish.
make menuconfig
Go to the sources directory
cd $DEVDIR/sources
Compile the kernel
make -C kernel
Install the kernel
sudo -E make install -C kernel
Compile the dtb
make dtbs
Install the dtb
cp nvidia-oot/device-tree/platform/generic-dts/dtbs/* $DEVDIR/kernel/dtb/
Compile the Out-of-Tree modules
make modules
Install the modules
sudo -E make modules_install
After these steps are done you will have compiled the base kernel, device tree and modules for JetPack6.1
@azulu
If the compile steps are not the issue. Could you please share which are the custom modifications that you are doing to the kernel sources?
Regards,
Eduardo Salazar
Embedded SW Engineer at RidgeRun
Contact us: support@ridgerun.com
Developers wiki: https://developer.ridgerun.com/
Website: www.ridgerun.com
I have run all the commands except of the make menuconfig, because I already had generated a config file with the required selection, and replaced the defconfig file with it, and when executing make -C kernel, it generates .config from defconfig by default:
make[1]: Entering directory '/home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/sources/kernel/kernel-jammy-src'
*** Default configuration is based on 'defconfig'
# No change to .config
I don’t know if this is important, but I had the following warnings in the execution of make -C kernel:
security/security.c: In function ‘security_binder_transaction’:
security/security.c:908:45: warning: passing argument 1 of ‘lsm_cred_display’ discards ‘const’ qualifier from pointer target type [-Wdiscarded-qualifiers]
  908 |         int from_display = lsm_cred_display(from);
In file included from security/security.c:20:
./include/linux/lsm_hooks.h:1719:49: note: expected ‘struct cred *’ but argument is of type ‘const struct cred *’
 1719 | static inline int lsm_cred_display(struct cred *cred)
security/security.c:909:43: warning: passing argument 1 of ‘lsm_cred_display’ discards ‘const’ qualifier from pointer target type [-Wdiscarded-qualifiers]
  909 |         int to_display = lsm_cred_display(to);
fs/nfs/dir.c: In function ‘nfs_access_get_cached_locked’:
fs/nfs/dir.c:2728:9: warning: ISO C90 forbids mixed declarations and code [-Wdeclaration-after-statement]
 2728 |         struct nfs_access_entry *cache;
fs/nfs/dir.c: In function ‘nfs_access_get_cached_rcu’:
fs/nfs/dir.c:2781:9: warning: ISO C90 forbids mixed declarations and code [-Wdeclaration-after-statement]
 2781 |         struct nfs_access_entry *cache;
drivers/irqchip/irq-gic.c:1125:13: warning: ‘gic_ipi_send_mask’ defined but not used [-Wunused-function]
 1125 | static void gic_ipi_send_mask(struct irq_data *d, const struct cpumask *mask)
drivers/usb/storage/realtek_cr.c: In function ‘rts51x_lun_is_mmc_xd’:
drivers/usb/storage/realtek_cr.c:496:20: warning: this statement may fall through [-Wimplicit-fallthrough=]
  496 |                 if (chip->status[lun].detailed_type.detailed_type1 & 0x08)
drivers/usb/storage/realtek_cr.c:498:9: note: here
  498 |         default:
And when executing sudo -E make modules_install, I get these warnings:
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/media/i2c/nv_imx274.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/pci/controller/tegra-pcie-edma.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/gpu/host1x/host1x.ko needs unknown symbol bpf_trace_run2
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/gpu/host1x/host1x.ko needs unknown symbol bpf_trace_run5
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/gpu/host1x/host1x.ko needs unknown symbol host1x_context_device_bus_type
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/gpu/host1x/host1x.ko needs unknown symbol bpf_trace_run1
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/gpu/host1x/host1x.ko needs unknown symbol bpf_trace_run3
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/gpu/host1x/host1x.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra210-dmic.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/video/tegra/host/vi/nvhost-vi5.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/media/i2c/nv_hawk_owl.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/video/tegra/tsec/tsecriscv.ko needs unknown symbol tegra_mc_get_carveout_info
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/video/tegra/tsec/tsecriscv.ko needs unknown symbol devm_tegra_memory_controller_get
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/video/tegra/tsec/tsecriscv.ko needs unknown symbol arch_invalidate_pmem
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/video/tegra/tsec/tsecriscv.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/nvgpu.ko needs unknown symbol bpf_trace_run8
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/nvgpu.ko needs unknown symbol hsierrrpt_dereg_cb
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/nvgpu.ko needs unknown symbol bpf_trace_run6
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/nvgpu.ko needs unknown symbol bpf_trace_run5
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/nvgpu.ko needs unknown symbol tegra_bpmp_transfer
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/nvgpu.ko needs unknown symbol bpf_trace_run2
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/nvgpu.ko needs unknown symbol bpf_trace_run1
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/nvgpu.ko needs unknown symbol bpf_trace_run4
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/nvgpu.ko needs unknown symbol tegra_bpmp_get
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/nvgpu.ko needs unknown symbol alloc_pages
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/nvgpu.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/nvgpu.ko needs unknown symbol tegra_sku_info
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/nvgpu.ko needs unknown symbol epl_get_misc_ec_err_status
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/nvgpu.ko needs unknown symbol epl_report_misc_ec_error
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/nvgpu.ko needs unknown symbol hsierrrpt_reg_cb
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/nvgpu.ko needs unknown symbol devfreq_cooling_unregister
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/nvgpu.ko needs unknown symbol of_devfreq_cooling_register
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/nvgpu.ko needs unknown symbol tegra_fuse_readl
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/video/tegra/camera/tegra_camera_platform.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra210-admaif.ko needs unknown symbol tegra_pcm_pointer
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra210-admaif.ko needs unknown symbol snd_dmaengine_pcm_trigger
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra210-admaif.ko needs unknown symbol tegra_pcm_construct
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra210-admaif.ko needs unknown symbol tegra_pcm_close
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra210-admaif.ko needs unknown symbol tegra_pcm_open
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra210-admaif.ko needs unknown symbol tegra_pcm_hw_params
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra210-admaif.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/misc/tegra-pcie-dma-test.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/gpu/drm/tegra/tegra-drm.ko needs unknown symbol dev_pm_genpd_set_performance_state
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/gpu/drm/tegra/tegra-drm.ko needs unknown symbol mipi_dsi_host_register
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/gpu/drm/tegra/tegra-drm.ko needs unknown symbol mipi_dsi_create_packet
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/gpu/drm/tegra/tegra-drm.ko needs unknown symbol cec_notifier_set_phys_addr
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/gpu/drm/tegra/tegra-drm.ko needs unknown symbol tegra_io_pad_power_disable
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/gpu/drm/tegra/tegra-drm.ko needs unknown symbol devm_tegra_core_dev_init_opp_table
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/gpu/drm/tegra/tegra-drm.ko needs unknown symbol tegra_powergate_sequence_power_up
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/gpu/drm/tegra/tegra-drm.ko needs unknown symbol tegra_powergate_power_off
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/gpu/drm/tegra/tegra-drm.ko needs unknown symbol bpf_trace_run5
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/gpu/drm/tegra/tegra-drm.ko needs unknown symbol cec_notifier_conn_register
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/gpu/drm/tegra/tegra-drm.ko needs unknown symbol bpf_trace_run3
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/gpu/drm/tegra/tegra-drm.ko needs unknown symbol cec_notifier_set_phys_addr_from_edid
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/gpu/drm/tegra/tegra-drm.ko needs unknown symbol mipi_dsi_host_unregister
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/gpu/drm/tegra/tegra-drm.ko needs unknown symbol tegra_io_pad_power_enable
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/gpu/drm/tegra/tegra-drm.ko needs unknown symbol devm_tegra_memory_controller_get
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/gpu/drm/tegra/tegra-drm.ko needs unknown symbol cec_fill_conn_info_from_drm
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/gpu/drm/tegra/tegra-drm.ko needs unknown symbol drm_compat_ioctl
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/gpu/drm/tegra/tegra-drm.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/gpu/drm/tegra/tegra-drm.ko needs unknown symbol cec_notifier_conn_unregister
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/media/i2c/nv_ov5693.ko needs unknown symbol bpf_trace_run3
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/media/i2c/nv_ov5693.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/devfreq/governor_pod_scaling.ko needs unknown symbol bpf_trace_run2
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/devfreq/governor_pod_scaling.ko needs unknown symbol bpf_trace_run5
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/devfreq/governor_pod_scaling.ko needs unknown symbol bpf_trace_run3
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/devfreq/governor_pod_scaling.ko needs unknown symbol bpf_trace_run7
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/devfreq/governor_pod_scaling.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/opensrc-disp/nvidia-modeset.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra186-asrc.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/mfd/nvidia-vrs-pseq.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra210-ope.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/platform/tegra/mc-hwpm.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/gpu/host1x-nvhost/host1x-nvhost.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra210-afc.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra210-mvc.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/platform/tegra/rtcpu/tegra-camera-rtcpu.ko needs unknown symbol bpf_trace_run4
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/platform/tegra/rtcpu/tegra-camera-rtcpu.ko needs unknown symbol pm_genpd_remove_device
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/platform/tegra/rtcpu/tegra-camera-rtcpu.ko needs unknown symbol bpf_trace_run6
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/platform/tegra/rtcpu/tegra-camera-rtcpu.ko needs unknown symbol bpf_trace_run2
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/platform/tegra/rtcpu/tegra-camera-rtcpu.ko needs unknown symbol bpf_trace_run8
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/platform/tegra/rtcpu/tegra-camera-rtcpu.ko needs unknown symbol bpf_trace_run5
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/platform/tegra/rtcpu/tegra-camera-rtcpu.ko needs unknown symbol bpf_trace_run1
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/platform/tegra/rtcpu/tegra-camera-rtcpu.ko needs unknown symbol bpf_trace_run3
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/platform/tegra/rtcpu/tegra-camera-rtcpu.ko needs unknown symbol bpf_trace_run7
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/platform/tegra/rtcpu/tegra-camera-rtcpu.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra210-amx.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/media/i2c/ar1335_common.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/media/i2c/nv_imx185.ko needs unknown symbol bpf_trace_run3
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/media/i2c/nv_imx185.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/media/i2c/virtual_i2c_mux.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/opensrc-disp/nvidia-drm.ko needs unknown symbol drm_compat_ioctl
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/opensrc-disp/nvidia-drm.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/platform/tegra/tegra-cactmon-mc-all.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/tty/serial/wch_35x/wch.ko needs unknown symbol logic_insb
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/tty/serial/wch_35x/wch.ko needs unknown symbol logic_inb
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/tty/serial/wch_35x/wch.ko needs unknown symbol logic_outb
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/tty/serial/wch_35x/wch.ko needs unknown symbol logic_inl
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/tty/serial/wch_35x/wch.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/gpu/host1x-fence/host1x-fence.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/platform/tegra/tegra-fsicom.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/platform/tegra/rtcpu/camera-diagnostics.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/media/i2c/nv_imx477.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/media/i2c/nv_imx219.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra210-i2s.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/nvhwpm.ko needs unknown symbol tegra_fuse_readl
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/nvhwpm.ko needs unknown symbol acpi_match_device
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/nvhwpm.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/media/i2c/max9296.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/media/i2c/max929x.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/net/can/mttcan/mttcan.ko needs unknown symbol tegra_prod_set_by_name
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/net/can/mttcan/mttcan.ko needs unknown symbol devm_tegra_prod_get
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/net/can/mttcan/mttcan.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/platform/tegra/aon/tegra234-aon.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/video/tegra/host/nvcsi/nvhost-nvcsi.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/video/tegra/host/pva/nvhost-pva.ko needs unknown symbol bpf_trace_run4
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/video/tegra/host/pva/nvhost-pva.ko needs unknown symbol bpf_trace_run6
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/video/tegra/host/pva/nvhost-pva.ko needs unknown symbol bpf_trace_run12
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/video/tegra/host/pva/nvhost-pva.ko needs unknown symbol bpf_trace_run8
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/video/tegra/host/pva/nvhost-pva.ko needs unknown symbol tegra_fuse_readl
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/video/tegra/host/pva/nvhost-pva.ko needs unknown symbol bpf_trace_run10
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/video/tegra/host/pva/nvhost-pva.ko needs unknown symbol bpf_trace_run3
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/video/tegra/host/pva/nvhost-pva.ko needs unknown symbol tegra_sku_info
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/video/tegra/host/pva/nvhost-pva.ko needs unknown symbol bpf_trace_run7
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/video/tegra/host/pva/nvhost-pva.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/nvpmodel/nvpmodel-clk-cap.ko needs unknown symbol tegra_bpmp_put
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/nvpmodel/nvpmodel-clk-cap.ko needs unknown symbol tegra_bpmp_transfer
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/nvpmodel/nvpmodel-clk-cap.ko needs unknown symbol tegra_bpmp_get
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/nvpmodel/nvpmodel-clk-cap.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/video/tegra/host/nvdla/nvhost-nvdla.ko needs unknown symbol hsierrrpt_dereg_cb
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/video/tegra/host/nvdla/nvhost-nvdla.ko needs unknown symbol bpf_trace_run5
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/video/tegra/host/nvdla/nvhost-nvdla.ko needs unknown symbol tegra_fuse_readl
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/video/tegra/host/nvdla/nvhost-nvdla.ko needs unknown symbol hsierrrpt_reg_cb
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/video/tegra/host/nvdla/nvhost-nvdla.ko needs unknown symbol bpf_trace_run3
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/video/tegra/host/nvdla/nvhost-nvdla.ko needs unknown symbol tegra_sku_info
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/video/tegra/host/nvdla/nvhost-nvdla.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/misc/nvsciipc/nvsciipc.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/bluetooth/realtek/rtk_btusb.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/video/tegra/host/isp/nvhost-isp5.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/video/tegra/dc/bridge/ti_fpdlink_dp_serializer.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/media/i2c/nv_imx318.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/platform/tegra/aon/tegra-aon-ivc-echo.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/net/ethernet/nvidia/nvethernet/nvethernet.ko needs unknown symbol hsierrrpt_dereg_cb
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/net/ethernet/nvidia/nvethernet/nvethernet.ko needs unknown symbol epl_report_error
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/net/ethernet/nvidia/nvethernet/nvethernet.ko needs unknown symbol hsierrrpt_reg_cb
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/net/ethernet/nvidia/nvethernet/nvethernet.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/net/ethernet/realtek/r8126/r8126.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/thermal/thermal-trip-event.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/video/tegra/host/capture/nvhost-capture.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra186-dspk.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/platform/tegra/mc-utils/mc-utils.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra186-arad.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/video/tegra/nvmap/nvmap.ko needs unknown symbol bpf_trace_run4
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/video/tegra/nvmap/nvmap.ko needs unknown symbol bpf_trace_run6
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/video/tegra/nvmap/nvmap.ko needs unknown symbol bpf_trace_run2
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/video/tegra/nvmap/nvmap.ko needs unknown symbol bpf_trace_run8
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/video/tegra/nvmap/nvmap.ko needs unknown symbol numa_node
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/video/tegra/nvmap/nvmap.ko needs unknown symbol bpf_trace_run5
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/video/tegra/nvmap/nvmap.ko needs unknown symbol bpf_trace_run1
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/video/tegra/nvmap/nvmap.ko needs unknown symbol bpf_trace_run9
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/video/tegra/nvmap/nvmap.ko needs unknown symbol bpf_trace_run10
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/video/tegra/nvmap/nvmap.ko needs unknown symbol bpf_trace_run3
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/video/tegra/nvmap/nvmap.ko needs unknown symbol alloc_pages
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/video/tegra/nvmap/nvmap.ko needs unknown symbol arch_invalidate_pmem
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/video/tegra/nvmap/nvmap.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/pci/endpoint/functions/pci-epf-dma-test.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/thermal/tegra234-oc-event.ko needs unknown symbol tegra_bpmp_put
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/thermal/tegra234-oc-event.ko needs unknown symbol tegra_bpmp_transfer
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/thermal/tegra234-oc-event.ko needs unknown symbol tegra_bpmp_get
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/thermal/tegra234-oc-event.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/rtc/nvvrs-pseq-rtc.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/media/platform/tegra/camera/tegra-camera.ko needs unknown symbol bpf_trace_run6
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/media/platform/tegra/camera/tegra-camera.ko needs unknown symbol bpf_trace_run2
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/media/platform/tegra/camera/tegra-camera.ko needs unknown symbol tegra_io_pad_power_disable
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/media/platform/tegra/camera/tegra-camera.ko needs unknown symbol bpf_trace_run5
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/media/platform/tegra/camera/tegra-camera.ko needs unknown symbol bpf_trace_run1
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/media/platform/tegra/camera/tegra-camera.ko needs unknown symbol tegra_io_pad_power_enable
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/media/platform/tegra/camera/tegra-camera.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/firmware/tegra/ivc_ext.ko needs unknown symbol tegra_ivc_read_get_next_frame
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/firmware/tegra/ivc_ext.ko needs unknown symbol tegra_ivc_read_advance
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/firmware/tegra/ivc_ext.ko needs unknown symbol tegra_ivc_write_advance
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/firmware/tegra/ivc_ext.ko needs unknown symbol tegra_ivc_reset
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/firmware/tegra/ivc_ext.ko needs unknown symbol tegra_ivc_write_get_next_frame
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/firmware/tegra/ivc_ext.ko needs unknown symbol tegra_ivc_notified
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/firmware/tegra/ivc_ext.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/video/tegra/dc/bridge/maxim_gmsl_dp_serializer.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/platform/tegra/uncore_pmu/tegra23x_perf_uncore.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/platform/tegra/rtcpu/hsp-mailbox-client.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/platform/tegra/rtcpu/camchar.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra210-ahub.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/nvpps/nvpps.ko needs unknown symbol devm_hte_request_ts_ns
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/nvpps/nvpps.ko needs unknown symbol hte_ts_get
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/nvpps/nvpps.ko needs unknown symbol hte_init_line_attr
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/nvpps/nvpps.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra210-sfc.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/devfreq/tegra_wmark.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/hwmon/f75308.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/net/ethernet/realtek/r8168/r8168.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra210-iqc.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/crypto/tegra/tegra-se.ko needs unknown symbol crypto_finalize_skcipher_request
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/crypto/tegra/tegra-se.ko needs unknown symbol crypto_engine_exit
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/crypto/tegra/tegra-se.ko needs unknown symbol crypto_finalize_hash_request
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/crypto/tegra/tegra-se.ko needs unknown symbol crypto_transfer_hash_request_to_engine
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/crypto/tegra/tegra-se.ko needs unknown symbol crypto_engine_start
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/crypto/tegra/tegra-se.ko needs unknown symbol crypto_engine_stop
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/crypto/tegra/tegra-se.ko needs unknown symbol crypto_transfer_aead_request_to_engine
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/crypto/tegra/tegra-se.ko needs unknown symbol crypto_finalize_aead_request
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/crypto/tegra/tegra-se.ko needs unknown symbol crypto_engine_alloc_init
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/crypto/tegra/tegra-se.ko needs unknown symbol crypto_transfer_skcipher_request_to_engine
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/crypto/tegra/tegra-se.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra-utils.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/media/i2c/pca9570.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/platform/tegra/rtcpu/capture-ivc.ko needs unknown symbol tegra_ivc_read_get_next_frame
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/platform/tegra/rtcpu/capture-ivc.ko needs unknown symbol tegra_ivc_read_advance
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/platform/tegra/rtcpu/capture-ivc.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/usb/typec/fusb301.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/nv-p2p/nvidia-p2p.ko needs unknown symbol mmu_notifier_put
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/nv-p2p/nvidia-p2p.ko needs unknown symbol mmu_notifier_unregister
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/nv-p2p/nvidia-p2p.ko needs unknown symbol mmu_notifier_register
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/nv-p2p/nvidia-p2p.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/crypto/tegra-se-nvrng.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/pci/endpoint/functions/pci-epf-tegra-vnet.ko needs unknown symbol alloc_pages
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/pci/endpoint/functions/pci-epf-tegra-vnet.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/pwm/pwm-tegra-tachometer.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/spi/spi-tegra210-quad.ko needs unknown symbol is_acpi_device_node
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/spi/spi-tegra210-quad.ko needs unknown symbol tegra_prod_set_by_name
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/spi/spi-tegra210-quad.ko needs unknown symbol devm_tegra_prod_get
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/spi/spi-tegra210-quad.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/i2c/busses/i2c-nvvrs11.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/spi/spi-tegra124-slave.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/opensrc-disp/nvidia.ko needs unknown symbol dmi_get_system_info
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/opensrc-disp/nvidia.ko needs unknown symbol is_acpi_device_node
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/opensrc-disp/nvidia.ko needs unknown symbol acpi_walk_namespace
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/opensrc-disp/nvidia.ko needs unknown symbol tegra_bpmp_put
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/opensrc-disp/nvidia.ko needs unknown symbol acpi_get_next_object
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/opensrc-disp/nvidia.ko needs unknown symbol logic_outw
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/opensrc-disp/nvidia.ko needs unknown symbol tegra_bpmp_transfer
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/opensrc-disp/nvidia.ko needs unknown symbol register_acpi_notifier
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/opensrc-disp/nvidia.ko needs unknown symbol screen_info
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/opensrc-disp/nvidia.ko needs unknown symbol logic_inb
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/opensrc-disp/nvidia.ko needs unknown symbol numa_node
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/opensrc-disp/nvidia.ko needs unknown symbol acpi_get_handle
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/opensrc-disp/nvidia.ko needs unknown symbol efi
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/opensrc-disp/nvidia.ko needs unknown symbol memory_failure
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/opensrc-disp/nvidia.ko needs unknown symbol logic_outl
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/opensrc-disp/nvidia.ko needs unknown symbol unregister_acpi_notifier
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/opensrc-disp/nvidia.ko needs unknown symbol logic_outb
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/opensrc-disp/nvidia.ko needs unknown symbol logic_inl
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/opensrc-disp/nvidia.ko needs unknown symbol acpi_gbl_FADT
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/opensrc-disp/nvidia.ko needs unknown symbol logic_inw
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/opensrc-disp/nvidia.ko needs unknown symbol acpi_evaluate_object
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/opensrc-disp/nvidia.ko needs unknown symbol node_data
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/opensrc-disp/nvidia.ko needs unknown symbol acpi_install_notify_handler
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/opensrc-disp/nvidia.ko needs unknown symbol acpi_evaluate_integer
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/opensrc-disp/nvidia.ko needs unknown symbol tegra_bpmp_get
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/opensrc-disp/nvidia.ko needs unknown symbol vga_set_legacy_decoding
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/opensrc-disp/nvidia.ko needs unknown symbol acpi_remove_notify_handler
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/opensrc-disp/nvidia.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra210-adx.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/platform/tegra/rtcpu/ivc-bus.ko needs unknown symbol tegra_ivc_total_queue_size
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/platform/tegra/rtcpu/ivc-bus.ko needs unknown symbol tegra_ivc_init
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/platform/tegra/rtcpu/ivc-bus.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/net/wireless/realtek/rtl8822ce/rtl8822ce.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/video/tegra/host/nvcsi/nvhost-nvcsi-t194.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/platform/tegra/dce/tegra-dce.ko needs unknown symbol tegra_ivc_total_queue_size
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/platform/tegra/dce/tegra-dce.ko needs unknown symbol tegra_ivc_read_get_next_frame
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/platform/tegra/dce/tegra-dce.ko needs unknown symbol tegra_ivc_read_advance
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/platform/tegra/dce/tegra-dce.ko needs unknown symbol tegra_ivc_write_advance
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/platform/tegra/dce/tegra-dce.ko needs unknown symbol tegra_ivc_reset
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/platform/tegra/dce/tegra-dce.ko needs unknown symbol bpf_trace_run2
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/platform/tegra/dce/tegra-dce.ko needs unknown symbol tegra_ivc_init
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/platform/tegra/dce/tegra-dce.ko needs unknown symbol tegra_ivc_write_get_next_frame
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/platform/tegra/dce/tegra-dce.ko needs unknown symbol tegra_ivc_notified
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/platform/tegra/dce/tegra-dce.ko needs unknown symbol tegra_ivc_align
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/platform/tegra/dce/tegra-dce.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/media/i2c/nv_ar0234.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/platform/tegra/rtcpu/rtcpu-debug.ko needs unknown symbol tegra_ivc_read_advance
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/platform/tegra/rtcpu/rtcpu-debug.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/media/i2c/max9295.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/media/platform/tegra/cdi/cam_cdi_tsc.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/media/i2c/max96712.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/media/i2c/lt6911uxc.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra210-mixer.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/media/i2c/nv_imx390.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/platform/tegra/mce/tegra-mce.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/net/ethernet/nvidia/pcie/tegra_vnet.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/bmi088/bmi088.ko needs unknown symbol devm_hte_request_ts_ns
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/bmi088/bmi088.ko needs unknown symbol hte_ts_get
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/bmi088/bmi088.ko needs unknown symbol hte_init_line_attr
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/bmi088/bmi088.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra-machine-driver.ko needs unknown symbol _mcount
Again, the resulting Image file generated is only 29MB:
ls kernel/kernel-jammy-src/arch/arm64/boot/Image -lah
-rw-rw-r-- 1 ubuntu ubuntu 29M Oct 14 09:46 kernel/kernel-jammy-src/arch/arm64/boot/Image
Then the dtbs for me are generated in the sources/kerne-devicetree/generic-dts/dtbs, instead of nvidia-oot/device-tree/platform/generic-dts/dtbs/, but are compiled and installed correctly.
But when compiling the modules, it still throws error in the execution of make modules, these are the error logs:
/home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/sources/hwpm/drivers/tegra/hwpm/os/linux/soc_utils.c:18:5: warning: "CONFIG_ACPI" is not defined, evaluates to 0 [-Wundef]
   18 | #if CONFIG_ACPI
/home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/sources/hwpm/drivers/tegra/hwpm/os/linux/soc_utils.c: In function ‘tegra_hwpm_init_chip_info’:
/home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/sources/hwpm/drivers/tegra/hwpm/os/linux/soc_utils.c:54:24: warning: unused variable ‘dev’ [-Wunused-variable]
   54 |         struct device *dev = hwpm_linux->dev;
/home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/sources/nvidia-oot/drivers/firmware/tegra/../../clk/tegra/clk-bpmp.c:673:5: error: redefinition of ‘tegra_bpmp_init_clocks’
  673 | int tegra_bpmp_init_clocks(struct tegra_bpmp *bpmp)
In file included from /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/sources/nvidia-oot/drivers/firmware/tegra/../../clk/tegra/clk-bpmp.c:9:
./include/soc/tegra/bpmp.h:177:19: note: previous definition of ‘tegra_bpmp_init_clocks’ with type ‘int(struct tegra_bpmp *)’
  177 | static inline int tegra_bpmp_init_clocks(struct tegra_bpmp *bpmp)
make[4]: *** [scripts/Makefile.build:295: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/sources/nvidia-oot/drivers/firmware/tegra/../../clk/tegra/clk-bpmp.o] Error 1
make[3]: *** [scripts/Makefile.build:559: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/sources/nvidia-oot/drivers/firmware/tegra] Error 2
make[3]: *** Waiting for unfinished jobs....
make[2]: *** [scripts/Makefile.build:559: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/sources/nvidia-oot/drivers] Error 2
make[2]: *** Waiting for unfinished jobs....
make[1]: *** [Makefile:1912: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/sources/nvidia-oot] Error 2
make: *** [Makefile:75: nvidia-oot] Error 2
Also, I attach the configuration file or defconfig below in this post in case you need to replicate it (I gave it txt extension because otherwise it wouldn’t let me upload it to the forum), thank you very much for your help.
defconfig.txt (212.8 KB)
The config file is a combination of the Docker/K8s/K3s optimized Linux Kernel from this blog NVIDIA Jetson Nano - Docker optimized Linux Kernel · Docker Pirates ARMed with explosive stuff (hypriot.io), and the options I enabled for iptables, and nftables are for using a VPN called Tailscale with K3s, because it was giving some errors the Traefik pod due to missing kernel modules related to these utilities for the communication through this VPN. I hope I have explained myself well.
Sorry, but is it possible that I am missing the execution of the apply_binaries.sh script at some point of the customization process, or any other step or script execution that should be required? I am completly new to Linux kernel customization in general, so I have no idea what else should I do…
Thank you very much.
Hi @azulu
Could you please share the changes you have applied for the kernel customization?
The apply_binaries.sh script is intended to prepare the files for a correct flash. So, at this moment, I do not think that not running the script is the issue.
Have you tried compiling kernel binaries for a devkit just as they are? Just for you to get familiar with the compiling steps and environment
Regards!
Hi @EduardoSalazar96
The only changes applied to the kernel are the addition of the aforementioned kernel modules of iptables, nftables, and docker/k8s optimization options of the linked blog post, I uploaded the defconfig file in my previous post, I’m uploading it again just in case in this post.
Already tried with the apply_binaries script, as you say, it does not make the difference, it has to be something else.
I have been like two weeks watching tutorials and doing the examples following the same steps, however for some reason it does not seem to compile or install correctly the modules…
I hope you can replicate this issue with the same defconfig and steps, if you please, so we can sort it out.
Kind regards!
Hi @azulu
I tried the compilation using the defconfig that you provided and I got the same results when trying with the make -C kernel sudo -E make install -C kernel. I also checked that this NVIDIA Jetson Nano - Docker optimized Linux Kernel · Docker Pirates ARMed with explosive stuff is related to the Jetson Nano board.
The Jetson Nano and Jetson Orin Nano boards are different. Here are the layouts so you can check some hardware differences:
For example, the Nano has a microUSB, HDMI and displayport ports. While the Orin Nano only has HDMI and USB-C only. Please, take that into account.
I haven’t checked the link that you shared in-depth, but based on the results it needs to do some more debugging since some CONFIGs are commented or disabled from the kernel defconfig and others are been enabled as built-in (they already part of the Kernel image and you do not have to load them).
The reason why your image is It is lighter is that those CONFIGs are disabled.
If you would like to continue trying to use that defconfig, you need to debug what CONFIGs have to be enabled or disabled for your board, since the config that you shared is for a different target.
I hope this helps to clarify some aspects!
Regards!
Thank you so much for giving it a try!
That makes a lot of sense, it might be some compatibility problem with the config of the other board, I didn’t notice the blog post was intended for a different device…
I will try doing a config file myself with some important options enabled, and let’s see if it is possible to generate an image with those modules built-in or as dynamic loadables, I’ll let you know the results.
Thank you very much!
It seems it was some kind of incompatibility with the config file, now I have done the changes manually, and the Image generated is 41MB.
Now, when I do the sudo -E make install -C kernel, I still get some warnings (much less however):
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/video/tegra/tsec/tsecriscv.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/nvgpu.ko needs unknown symbol preempt_schedule_notrace
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/nvgpu.ko needs unknown symbol hsierrrpt_dereg_cb
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/nvgpu.ko needs unknown symbol tegra_bpmp_transfer
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/nvgpu.ko needs unknown symbol tegra_bpmp_get
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/nvgpu.ko needs unknown symbol _raw_spin_lock
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/nvgpu.ko needs unknown symbol _raw_spin_unlock_irqrestore
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/nvgpu.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/nvgpu.ko needs unknown symbol tegra_sku_info
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/nvgpu.ko needs unknown symbol _raw_spin_lock_irqsave
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/nvgpu.ko needs unknown symbol of_node_put
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/nvgpu.ko needs unknown symbol epl_get_misc_ec_err_status
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/nvgpu.ko needs unknown symbol epl_report_misc_ec_error
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/nvgpu.ko needs unknown symbol hsierrrpt_reg_cb
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/nvgpu.ko needs unknown symbol tegra_fuse_readl
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/video/tegra/camera/tegra_camera_platform.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra210-admaif.ko needs unknown symbol tegra_pcm_pointer
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra210-admaif.ko needs unknown symbol snd_dmaengine_pcm_trigger
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra210-admaif.ko needs unknown symbol tegra_pcm_construct
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra210-admaif.ko needs unknown symbol devm_snd_soc_register_component
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra210-admaif.ko needs unknown symbol snd_soc_info_volsw
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra210-admaif.ko needs unknown symbol tegra_pcm_close
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra210-admaif.ko needs unknown symbol tegra_pcm_open
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra210-admaif.ko needs unknown symbol tegra_pcm_hw_params
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra210-admaif.ko needs unknown symbol snd_soc_info_enum_double
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra210-admaif.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/misc/tegra-pcie-dma-test.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/gpu/drm/tegra/tegra-drm.ko needs unknown symbol mipi_dsi_host_register
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/gpu/drm/tegra/tegra-drm.ko needs unknown symbol of_node_put
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/gpu/drm/tegra/tegra-drm.ko needs unknown symbol mipi_dsi_create_packet
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/gpu/drm/tegra/tegra-drm.ko needs unknown symbol _raw_spin_lock_irqsave
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/gpu/drm/tegra/tegra-drm.ko needs unknown symbol tegra_io_pad_power_disable
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/gpu/drm/tegra/tegra-drm.ko needs unknown symbol devm_tegra_core_dev_init_opp_table
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/gpu/drm/tegra/tegra-drm.ko needs unknown symbol tegra_powergate_sequence_power_up
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/gpu/drm/tegra/tegra-drm.ko needs unknown symbol preempt_schedule_notrace
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/gpu/drm/tegra/tegra-drm.ko needs unknown symbol tegra_powergate_power_off
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/gpu/drm/tegra/tegra-drm.ko needs unknown symbol _raw_spin_unlock_irq
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/gpu/drm/tegra/tegra-drm.ko needs unknown symbol _raw_spin_unlock_irqrestore
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/gpu/drm/tegra/tegra-drm.ko needs unknown symbol mipi_dsi_host_unregister
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/gpu/drm/tegra/tegra-drm.ko needs unknown symbol tegra_io_pad_power_enable
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/gpu/drm/tegra/tegra-drm.ko needs unknown symbol devm_tegra_memory_controller_get
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/gpu/drm/tegra/tegra-drm.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/media/i2c/nv_ov5693.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/devfreq/governor_pod_scaling.ko needs unknown symbol preempt_schedule_notrace
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/devfreq/governor_pod_scaling.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/opensrc-disp/nvidia-modeset.ko needs unknown symbol _raw_spin_lock_irqsave
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/opensrc-disp/nvidia-modeset.ko needs unknown symbol _raw_spin_unlock_irqrestore
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/opensrc-disp/nvidia-modeset.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra186-asrc.ko needs unknown symbol devm_snd_soc_register_component
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra186-asrc.ko needs unknown symbol snd_soc_info_volsw
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra186-asrc.ko needs unknown symbol snd_soc_info_enum_double
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra186-asrc.ko needs unknown symbol snd_soc_info_xr_sx
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra186-asrc.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/mfd/nvidia-vrs-pseq.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra210-ope.ko needs unknown symbol of_node_put
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra210-ope.ko needs unknown symbol devm_snd_soc_register_component
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra210-ope.ko needs unknown symbol snd_soc_component_init_regmap
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra210-ope.ko needs unknown symbol snd_soc_info_volsw
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra210-ope.ko needs unknown symbol snd_soc_info_volsw_range
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra210-ope.ko needs unknown symbol snd_soc_add_component_controls
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra210-ope.ko needs unknown symbol snd_soc_info_enum_double
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra210-ope.ko needs unknown symbol snd_soc_get_volsw
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra210-ope.ko needs unknown symbol snd_soc_put_volsw
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra210-ope.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/platform/tegra/mc-hwpm.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/gpu/host1x-nvhost/host1x-nvhost.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra210-afc.ko needs unknown symbol devm_snd_soc_register_component
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra210-afc.ko needs unknown symbol snd_soc_info_enum_double
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra210-afc.ko needs unknown symbol snd_soc_info_xr_sx
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra210-afc.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra210-mvc.ko needs unknown symbol devm_snd_soc_register_component
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra210-mvc.ko needs unknown symbol snd_soc_info_volsw
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra210-mvc.ko needs unknown symbol snd_soc_info_enum_double
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra210-mvc.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/platform/tegra/rtcpu/tegra-camera-rtcpu.ko needs unknown symbol of_node_put
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/platform/tegra/rtcpu/tegra-camera-rtcpu.ko needs unknown symbol preempt_schedule_notrace
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/platform/tegra/rtcpu/tegra-camera-rtcpu.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra210-amx.ko needs unknown symbol devm_snd_soc_register_component
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra210-amx.ko needs unknown symbol snd_soc_info_volsw
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra210-amx.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/media/i2c/ar1335_common.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/media/i2c/nv_imx185.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/media/i2c/virtual_i2c_mux.ko needs unknown symbol of_node_put
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/media/i2c/virtual_i2c_mux.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/opensrc-disp/nvidia-drm.ko needs unknown symbol _raw_spin_lock_irqsave
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/opensrc-disp/nvidia-drm.ko needs unknown symbol _raw_read_unlock
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/opensrc-disp/nvidia-drm.ko needs unknown symbol _raw_spin_unlock_irqrestore
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/opensrc-disp/nvidia-drm.ko needs unknown symbol _raw_read_lock
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/opensrc-disp/nvidia-drm.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/platform/tegra/tegra-cactmon-mc-all.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/tty/serial/wch_35x/wch.ko needs unknown symbol logic_insb
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/tty/serial/wch_35x/wch.ko needs unknown symbol _raw_spin_lock_irqsave
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/tty/serial/wch_35x/wch.ko needs unknown symbol logic_inb
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/tty/serial/wch_35x/wch.ko needs unknown symbol _raw_spin_unlock_irq
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/tty/serial/wch_35x/wch.ko needs unknown symbol _raw_spin_unlock_irqrestore
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/tty/serial/wch_35x/wch.ko needs unknown symbol logic_outb
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/tty/serial/wch_35x/wch.ko needs unknown symbol logic_inl
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/tty/serial/wch_35x/wch.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/gpu/host1x-fence/host1x-fence.ko needs unknown symbol _raw_spin_lock
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/gpu/host1x-fence/host1x-fence.ko needs unknown symbol _raw_spin_unlock
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/gpu/host1x-fence/host1x-fence.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/platform/tegra/tegra-fsicom.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/platform/tegra/rtcpu/camera-diagnostics.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/media/i2c/nv_imx477.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/media/i2c/nv_imx219.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra210-i2s.ko needs unknown symbol devm_snd_soc_register_component
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra210-i2s.ko needs unknown symbol snd_soc_info_volsw
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra210-i2s.ko needs unknown symbol snd_soc_info_enum_double
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra210-i2s.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/nvhwpm.ko needs unknown symbol tegra_fuse_readl
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/nvhwpm.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/media/i2c/max9296.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/media/i2c/max929x.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/net/can/mttcan/mttcan.ko needs unknown symbol _raw_spin_lock_irqsave
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/net/can/mttcan/mttcan.ko needs unknown symbol _raw_spin_unlock_bh
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/net/can/mttcan/mttcan.ko needs unknown symbol tegra_prod_set_by_name
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/net/can/mttcan/mttcan.ko needs unknown symbol _raw_spin_unlock_irqrestore
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/net/can/mttcan/mttcan.ko needs unknown symbol devm_tegra_prod_get
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/net/can/mttcan/mttcan.ko needs unknown symbol _raw_spin_lock_bh
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/net/can/mttcan/mttcan.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/platform/tegra/aon/tegra234-aon.ko needs unknown symbol of_node_put
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/platform/tegra/aon/tegra234-aon.ko needs unknown symbol _raw_spin_lock
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/platform/tegra/aon/tegra234-aon.ko needs unknown symbol _raw_spin_unlock
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/platform/tegra/aon/tegra234-aon.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/video/tegra/host/nvcsi/nvhost-nvcsi.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/video/tegra/host/pva/nvhost-pva.ko needs unknown symbol preempt_schedule_notrace
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/video/tegra/host/pva/nvhost-pva.ko needs unknown symbol tegra_fuse_readl
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/video/tegra/host/pva/nvhost-pva.ko needs unknown symbol tegra_sku_info
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/video/tegra/host/pva/nvhost-pva.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/nvpmodel/nvpmodel-clk-cap.ko needs unknown symbol tegra_bpmp_put
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/nvpmodel/nvpmodel-clk-cap.ko needs unknown symbol tegra_bpmp_transfer
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/nvpmodel/nvpmodel-clk-cap.ko needs unknown symbol tegra_bpmp_get
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/nvpmodel/nvpmodel-clk-cap.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/video/tegra/host/nvdla/nvhost-nvdla.ko needs unknown symbol hsierrrpt_dereg_cb
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/video/tegra/host/nvdla/nvhost-nvdla.ko needs unknown symbol preempt_schedule_notrace
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/video/tegra/host/nvdla/nvhost-nvdla.ko needs unknown symbol tegra_fuse_readl
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/video/tegra/host/nvdla/nvhost-nvdla.ko needs unknown symbol hsierrrpt_reg_cb
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/video/tegra/host/nvdla/nvhost-nvdla.ko needs unknown symbol tegra_sku_info
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/video/tegra/host/nvdla/nvhost-nvdla.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/misc/nvsciipc/nvsciipc.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/bluetooth/realtek/rtk_btusb.ko needs unknown symbol hci_free_dev
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/bluetooth/realtek/rtk_btusb.ko needs unknown symbol hci_alloc_dev_priv
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/bluetooth/realtek/rtk_btusb.ko needs unknown symbol _raw_spin_lock_irqsave
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/bluetooth/realtek/rtk_btusb.ko needs unknown symbol _raw_spin_unlock_irq
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/bluetooth/realtek/rtk_btusb.ko needs unknown symbol _raw_spin_unlock_irqrestore
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/bluetooth/realtek/rtk_btusb.ko needs unknown symbol hci_unregister_dev
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/bluetooth/realtek/rtk_btusb.ko needs unknown symbol hci_recv_frame
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/bluetooth/realtek/rtk_btusb.ko needs unknown symbol hci_register_dev
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/bluetooth/realtek/rtk_btusb.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/video/tegra/host/isp/nvhost-isp5.ko needs unknown symbol of_node_put
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/video/tegra/host/isp/nvhost-isp5.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/video/tegra/dc/bridge/ti_fpdlink_dp_serializer.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/media/i2c/nv_imx318.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/platform/tegra/aon/tegra-aon-ivc-echo.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/net/ethernet/nvidia/nvethernet/nvethernet.ko needs unknown symbol of_node_put
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/net/ethernet/nvidia/nvethernet/nvethernet.ko needs unknown symbol of_node_get
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/net/ethernet/nvidia/nvethernet/nvethernet.ko needs unknown symbol _raw_spin_lock_irqsave
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/net/ethernet/nvidia/nvethernet/nvethernet.ko needs unknown symbol hsierrrpt_dereg_cb
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/net/ethernet/nvidia/nvethernet/nvethernet.ko needs unknown symbol epl_report_error
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/net/ethernet/nvidia/nvethernet/nvethernet.ko needs unknown symbol preempt_schedule_notrace
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/net/ethernet/nvidia/nvethernet/nvethernet.ko needs unknown symbol hsierrrpt_reg_cb
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/net/ethernet/nvidia/nvethernet/nvethernet.ko needs unknown symbol _raw_spin_unlock_irqrestore
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/net/ethernet/nvidia/nvethernet/nvethernet.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/net/ethernet/realtek/r8126/r8126.ko needs unknown symbol _raw_spin_lock_irqsave
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/net/ethernet/realtek/r8126/r8126.ko needs unknown symbol _raw_spin_unlock_irqrestore
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/net/ethernet/realtek/r8126/r8126.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/thermal/thermal-trip-event.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/video/tegra/host/capture/nvhost-capture.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra186-dspk.ko needs unknown symbol devm_snd_soc_register_component
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra186-dspk.ko needs unknown symbol snd_soc_info_volsw
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra186-dspk.ko needs unknown symbol snd_soc_info_enum_double
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra186-dspk.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/platform/tegra/mc-utils/mc-utils.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra186-arad.ko needs unknown symbol devm_snd_soc_register_component
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra186-arad.ko needs unknown symbol snd_soc_info_volsw
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra186-arad.ko needs unknown symbol snd_soc_info_enum_double
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra186-arad.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/video/tegra/nvmap/nvmap.ko needs unknown symbol of_node_put
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/video/tegra/nvmap/nvmap.ko needs unknown symbol _raw_spin_lock_irqsave
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/video/tegra/nvmap/nvmap.ko needs unknown symbol preempt_schedule_notrace
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/video/tegra/nvmap/nvmap.ko needs unknown symbol _raw_spin_unlock_irqrestore
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/video/tegra/nvmap/nvmap.ko needs unknown symbol arch_invalidate_pmem
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/video/tegra/nvmap/nvmap.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/pci/endpoint/functions/pci-epf-dma-test.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/thermal/tegra234-oc-event.ko needs unknown symbol tegra_bpmp_put
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/thermal/tegra234-oc-event.ko needs unknown symbol tegra_bpmp_transfer
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/thermal/tegra234-oc-event.ko needs unknown symbol tegra_bpmp_get
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/thermal/tegra234-oc-event.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/rtc/nvvrs-pseq-rtc.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/media/platform/tegra/camera/tegra-camera.ko needs unknown symbol of_node_put
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/media/platform/tegra/camera/tegra-camera.ko needs unknown symbol _raw_spin_lock_irqsave
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/media/platform/tegra/camera/tegra-camera.ko needs unknown symbol tegra_io_pad_power_disable
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/media/platform/tegra/camera/tegra-camera.ko needs unknown symbol preempt_schedule_notrace
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/media/platform/tegra/camera/tegra-camera.ko needs unknown symbol _raw_write_lock
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/media/platform/tegra/camera/tegra-camera.ko needs unknown symbol _raw_read_unlock
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/media/platform/tegra/camera/tegra-camera.ko needs unknown symbol _raw_write_unlock
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/media/platform/tegra/camera/tegra-camera.ko needs unknown symbol _raw_spin_unlock_irqrestore
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/media/platform/tegra/camera/tegra-camera.ko needs unknown symbol tegra_io_pad_power_enable
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/media/platform/tegra/camera/tegra-camera.ko needs unknown symbol _raw_read_lock
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/media/platform/tegra/camera/tegra-camera.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/firmware/tegra/ivc_ext.ko needs unknown symbol tegra_ivc_read_get_next_frame
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/firmware/tegra/ivc_ext.ko needs unknown symbol tegra_ivc_read_advance
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/firmware/tegra/ivc_ext.ko needs unknown symbol tegra_ivc_write_advance
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/firmware/tegra/ivc_ext.ko needs unknown symbol tegra_ivc_reset
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/firmware/tegra/ivc_ext.ko needs unknown symbol tegra_ivc_write_get_next_frame
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/firmware/tegra/ivc_ext.ko needs unknown symbol tegra_ivc_notified
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/firmware/tegra/ivc_ext.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/video/tegra/dc/bridge/maxim_gmsl_dp_serializer.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/platform/tegra/uncore_pmu/tegra23x_perf_uncore.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/platform/tegra/rtcpu/hsp-mailbox-client.ko needs unknown symbol of_node_put
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/platform/tegra/rtcpu/hsp-mailbox-client.ko needs unknown symbol _raw_spin_lock_irqsave
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/platform/tegra/rtcpu/hsp-mailbox-client.ko needs unknown symbol _raw_spin_unlock_irqrestore
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/platform/tegra/rtcpu/hsp-mailbox-client.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/platform/tegra/rtcpu/camchar.ko needs unknown symbol _raw_spin_lock
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/platform/tegra/rtcpu/camchar.ko needs unknown symbol _raw_spin_unlock
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/platform/tegra/rtcpu/camchar.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra210-ahub.ko needs unknown symbol snd_soc_dapm_mux_update_power
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra210-ahub.ko needs unknown symbol snd_soc_component_read
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra210-ahub.ko needs unknown symbol snd_soc_component_test_bits
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra210-ahub.ko needs unknown symbol devm_snd_soc_register_component
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra210-ahub.ko needs unknown symbol snd_soc_dapm_kcontrol_dapm
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra210-ahub.ko needs unknown symbol snd_soc_info_enum_double
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra210-ahub.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/nvpps/nvpps.ko needs unknown symbol of_node_put
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/nvpps/nvpps.ko needs unknown symbol _raw_spin_lock_irqsave
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/nvpps/nvpps.ko needs unknown symbol preempt_schedule_notrace
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/nvpps/nvpps.ko needs unknown symbol _raw_spin_unlock_irqrestore
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/nvpps/nvpps.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra210-sfc.ko needs unknown symbol devm_snd_soc_register_component
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra210-sfc.ko needs unknown symbol snd_soc_info_volsw
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra210-sfc.ko needs unknown symbol snd_soc_info_enum_double
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra210-sfc.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/devfreq/tegra_wmark.ko needs unknown symbol _raw_spin_lock_irqsave
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/devfreq/tegra_wmark.ko needs unknown symbol _raw_spin_unlock_irqrestore
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/devfreq/tegra_wmark.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/hwmon/f75308.ko needs unknown symbol of_node_put
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/hwmon/f75308.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/net/ethernet/realtek/r8168/r8168.ko needs unknown symbol _raw_spin_lock
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/net/ethernet/realtek/r8168/r8168.ko needs unknown symbol _raw_spin_unlock
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/net/ethernet/realtek/r8168/r8168.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra210-iqc.ko needs unknown symbol devm_snd_soc_register_component
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra210-iqc.ko needs unknown symbol snd_soc_info_volsw
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra210-iqc.ko needs unknown symbol snd_soc_get_volsw
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra210-iqc.ko needs unknown symbol snd_soc_put_volsw
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra210-iqc.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/crypto/tegra/tegra-se.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra-utils.ko needs unknown symbol of_node_put
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra-utils.ko needs unknown symbol asoc_simple_set_dailink_name
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra-utils.ko needs unknown symbol snd_soc_jack_report
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra-utils.ko needs unknown symbol snd_soc_card_jack_new
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra-utils.ko needs unknown symbol snd_soc_of_parse_audio_routing
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra-utils.ko needs unknown symbol asoc_simple_dai_init
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra-utils.ko needs unknown symbol snd_soc_dai_set_sysclk
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra-utils.ko needs unknown symbol snd_soc_dapm_sync
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra-utils.ko needs unknown symbol asoc_simple_parse_card_name
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra-utils.ko needs unknown symbol snd_soc_runtime_set_dai_fmt
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra-utils.ko needs unknown symbol asoc_simple_canonicalize_platform
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra-utils.ko needs unknown symbol asoc_simple_parse_daifmt
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra-utils.ko needs unknown symbol snd_soc_of_get_dai_name
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra-utils.ko needs unknown symbol snd_soc_info_enum_double
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra-utils.ko needs unknown symbol snd_soc_dai_set_pll
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra-utils.ko needs unknown symbol snd_soc_of_parse_audio_simple_widgets
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra-utils.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/media/i2c/pca9570.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/platform/tegra/rtcpu/capture-ivc.ko needs unknown symbol tegra_ivc_read_get_next_frame
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/platform/tegra/rtcpu/capture-ivc.ko needs unknown symbol tegra_ivc_read_advance
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/platform/tegra/rtcpu/capture-ivc.ko needs unknown symbol _raw_spin_lock
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/platform/tegra/rtcpu/capture-ivc.ko needs unknown symbol preempt_schedule_notrace
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/platform/tegra/rtcpu/capture-ivc.ko needs unknown symbol _raw_spin_unlock
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/platform/tegra/rtcpu/capture-ivc.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/usb/typec/fusb301.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/nv-p2p/nvidia-p2p.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/crypto/tegra-se-nvrng.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/pci/endpoint/functions/pci-epf-tegra-vnet.ko needs unknown symbol _raw_spin_lock_irqsave
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/pci/endpoint/functions/pci-epf-tegra-vnet.ko needs unknown symbol _raw_spin_unlock_irqrestore
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/pci/endpoint/functions/pci-epf-tegra-vnet.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/pwm/pwm-tegra-tachometer.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/spi/spi-tegra210-quad.ko needs unknown symbol _raw_spin_lock_irqsave
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/spi/spi-tegra210-quad.ko needs unknown symbol tegra_prod_set_by_name
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/spi/spi-tegra210-quad.ko needs unknown symbol _raw_spin_unlock_irqrestore
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/spi/spi-tegra210-quad.ko needs unknown symbol devm_tegra_prod_get
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/spi/spi-tegra210-quad.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/i2c/busses/i2c-nvvrs11.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/spi/spi-tegra124-slave.ko needs unknown symbol of_node_put
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/spi/spi-tegra124-slave.ko needs unknown symbol _raw_spin_lock_irqsave
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/spi/spi-tegra124-slave.ko needs unknown symbol _raw_spin_unlock_irqrestore
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/spi/spi-tegra124-slave.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/opensrc-disp/nvidia.ko needs unknown symbol of_node_put
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/opensrc-disp/nvidia.ko needs unknown symbol tegra_bpmp_put
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/opensrc-disp/nvidia.ko needs unknown symbol logic_outw
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/opensrc-disp/nvidia.ko needs unknown symbol _raw_spin_lock_irqsave
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/opensrc-disp/nvidia.ko needs unknown symbol tegra_bpmp_transfer
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/opensrc-disp/nvidia.ko needs unknown symbol logic_inb
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/opensrc-disp/nvidia.ko needs unknown symbol preempt_schedule
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/opensrc-disp/nvidia.ko needs unknown symbol logic_outl
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/opensrc-disp/nvidia.ko needs unknown symbol _raw_spin_unlock_irq
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/opensrc-disp/nvidia.ko needs unknown symbol _raw_spin_unlock_irqrestore
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/opensrc-disp/nvidia.ko needs unknown symbol logic_outb
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/opensrc-disp/nvidia.ko needs unknown symbol logic_inl
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/opensrc-disp/nvidia.ko needs unknown symbol logic_inw
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/opensrc-disp/nvidia.ko needs unknown symbol tegra_bpmp_get
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/opensrc-disp/nvidia.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra210-adx.ko needs unknown symbol devm_snd_soc_register_component
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra210-adx.ko needs unknown symbol snd_soc_info_volsw
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra210-adx.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/platform/tegra/rtcpu/ivc-bus.ko needs unknown symbol of_node_put
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/platform/tegra/rtcpu/ivc-bus.ko needs unknown symbol __rcu_read_lock
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/platform/tegra/rtcpu/ivc-bus.ko needs unknown symbol tegra_ivc_total_queue_size
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/platform/tegra/rtcpu/ivc-bus.ko needs unknown symbol of_node_get
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/platform/tegra/rtcpu/ivc-bus.ko needs unknown symbol tegra_ivc_init
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/platform/tegra/rtcpu/ivc-bus.ko needs unknown symbol __rcu_read_unlock
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/platform/tegra/rtcpu/ivc-bus.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/net/wireless/realtek/rtl8822ce/rtl8822ce.ko needs unknown symbol preempt_schedule_notrace
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/net/wireless/realtek/rtl8822ce/rtl8822ce.ko needs unknown symbol _raw_spin_lock
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/net/wireless/realtek/rtl8822ce/rtl8822ce.ko needs unknown symbol _raw_spin_unlock_irqrestore
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/net/wireless/realtek/rtl8822ce/rtl8822ce.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/net/wireless/realtek/rtl8822ce/rtl8822ce.ko needs unknown symbol _raw_spin_unlock_bh
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/net/wireless/realtek/rtl8822ce/rtl8822ce.ko needs unknown symbol _raw_spin_lock_bh
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/net/wireless/realtek/rtl8822ce/rtl8822ce.ko needs unknown symbol _raw_spin_lock_irqsave
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/net/wireless/realtek/rtl8822ce/rtl8822ce.ko needs unknown symbol __rcu_read_unlock
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/net/wireless/realtek/rtl8822ce/rtl8822ce.ko needs unknown symbol __rcu_read_lock
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/video/tegra/host/nvcsi/nvhost-nvcsi-t194.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/platform/tegra/dce/tegra-dce.ko needs unknown symbol tegra_ivc_total_queue_size
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/platform/tegra/dce/tegra-dce.ko needs unknown symbol tegra_ivc_read_get_next_frame
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/platform/tegra/dce/tegra-dce.ko needs unknown symbol tegra_ivc_read_advance
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/platform/tegra/dce/tegra-dce.ko needs unknown symbol tegra_ivc_write_advance
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/platform/tegra/dce/tegra-dce.ko needs unknown symbol tegra_ivc_reset
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/platform/tegra/dce/tegra-dce.ko needs unknown symbol tegra_ivc_init
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/platform/tegra/dce/tegra-dce.ko needs unknown symbol preempt_schedule_notrace
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/platform/tegra/dce/tegra-dce.ko needs unknown symbol tegra_ivc_write_get_next_frame
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/platform/tegra/dce/tegra-dce.ko needs unknown symbol tegra_ivc_notified
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/platform/tegra/dce/tegra-dce.ko needs unknown symbol tegra_ivc_align
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/platform/tegra/dce/tegra-dce.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/media/i2c/nv_ar0234.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/platform/tegra/rtcpu/rtcpu-debug.ko needs unknown symbol of_node_put
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/platform/tegra/rtcpu/rtcpu-debug.ko needs unknown symbol tegra_ivc_read_advance
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/platform/tegra/rtcpu/rtcpu-debug.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/media/i2c/max9295.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/media/platform/tegra/cdi/cam_cdi_tsc.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/media/i2c/max96712.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/media/i2c/lt6911uxc.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra210-mixer.ko needs unknown symbol devm_snd_soc_register_component
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra210-mixer.ko needs unknown symbol snd_soc_info_volsw
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra210-mixer.ko needs unknown symbol snd_soc_dapm_put_volsw
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra210-mixer.ko needs unknown symbol snd_soc_get_volsw
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra210-mixer.ko needs unknown symbol snd_soc_put_volsw
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra210-mixer.ko needs unknown symbol snd_soc_dapm_get_volsw
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra210-mixer.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/media/i2c/nv_imx390.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/platform/tegra/mce/tegra-mce.ko needs unknown symbol preempt_schedule
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/platform/tegra/mce/tegra-mce.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/net/ethernet/nvidia/pcie/tegra_vnet.ko needs unknown symbol _raw_spin_lock_irqsave
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/net/ethernet/nvidia/pcie/tegra_vnet.ko needs unknown symbol _raw_spin_unlock_irqrestore
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/net/ethernet/nvidia/pcie/tegra_vnet.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/drivers/bmi088/bmi088.ko needs unknown symbol _mcount
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra-machine-driver.ko needs unknown symbol snd_soc_register_card
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra-machine-driver.ko needs unknown symbol snd_soc_dai_set_tdm_slot
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra-machine-driver.ko needs unknown symbol snd_soc_resume
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra-machine-driver.ko needs unknown symbol snd_soc_suspend
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra-machine-driver.ko needs unknown symbol snd_soc_unregister_card
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra-machine-driver.ko needs unknown symbol snd_soc_poweroff
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra-machine-driver.ko needs unknown symbol snd_soc_info_enum_double
depmod: WARNING: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/sound/soc/tegra/snd-soc-tegra-machine-driver.ko needs unknown symbol _mcount
make[1]: Leaving directory '/home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/sources/kernel/kernel-jammy-src'
Kernel and in-tree modules installed successfully.
make: Leaving directory '/home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/sources/kernel'
Then I do the, make dtbs, and I get a DTBs compiled successfully., and I copy the dtbs to kernel/dtb so looks good.
But I still get the same error compiling the modules, same error of a Tegra redefinition:
make modules - nvidia-oot ...
make -j 4 ARCH=arm64 \
        -C /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/sources/kernel/kernel-jammy-src \
        M=/home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/sources/nvidia-oot \
        CONFIG_TEGRA_OOT_MODULE=m \
        srctree.nvidia-oot=/home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/sources/nvidia-oot \
        srctree.hwpm=/home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/sources/hwpm \
        srctree.nvconftest=/home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/sources/out/nvidia-conftest \
        KBUILD_EXTRA_SYMBOLS=/home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/sources/hwpm/drivers/tegra/hwpm/Module.symvers \
        modules
make[1]: Entering directory '/home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/sources/kernel/kernel-jammy-src'
  CC [M]  /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/sources/nvidia-oot/drivers/block/tegra_oops_virt_storage/tegra_hv_vblk_oops.o
  CC [M]  /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/sources/nvidia-oot/drivers/block/tegra_virt_storage/tegra_hv_vblk.o
  CC [M]  /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/sources/nvidia-oot/drivers/cpuidle/cpuidle-tegra-auto.o
  CC [M]  /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/sources/nvidia-oot/drivers/crypto/tegra-se-nvrng.o
  CC [M]  /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/sources/nvidia-oot/drivers/devfreq/tegra_wmark.o
  CC [M]  /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/sources/nvidia-oot/drivers/cpuidle/cpuidle-debugfs.o
  CC [M]  /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/sources/nvidia-oot/drivers/devfreq/governor_pod_scaling.o
  CC [M]  /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/sources/nvidia-oot/drivers/block/tegra_virt_storage/tegra_hv_ioctl.o
  CC [M]  /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/sources/nvidia-oot/drivers/firmware/tegra/ivc_ext.o
  CC [M]  /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/sources/nvidia-oot/drivers/gpio/gpio-max77851.o
  CC [M]  /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/sources/nvidia-oot/drivers/block/tegra_virt_storage/tegra_hv_mmc.o
  CC [M]  /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/sources/nvidia-oot/drivers/hwmon/f75308.o
  CC [M]  /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/sources/nvidia-oot/drivers/block/tegra_virt_storage/tegra_hv_scsi.o
  CC [M]  /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/sources/nvidia-oot/drivers/i2c/busses/i2c-nvvrs11.o
  CC [M]  /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/sources/nvidia-oot/drivers/firmware/tegra/../../clk/tegra/clk-bpmp.o
/home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/sources/nvidia-oot/drivers/firmware/tegra/../../clk/tegra/clk-bpmp.c:673:5: error: redefinition of ‘tegra_bpmp_init_clocks’
  673 | int tegra_bpmp_init_clocks(struct tegra_bpmp *bpmp)
In file included from /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/sources/nvidia-oot/drivers/firmware/tegra/../../clk/tegra/clk-bpmp.c:9:
./include/soc/tegra/bpmp.h:177:19: note: previous definition of ‘tegra_bpmp_init_clocks’ with type ‘int(struct tegra_bpmp *)’
  177 | static inline int tegra_bpmp_init_clocks(struct tegra_bpmp *bpmp)
make[4]: *** [scripts/Makefile.build:295: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/sources/nvidia-oot/drivers/firmware/tegra/../../clk/tegra/clk-bpmp.o] Error 1
make[3]: *** [scripts/Makefile.build:559: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/sources/nvidia-oot/drivers/firmware/tegra] Error 2
make[3]: *** Waiting for unfinished jobs....
  CC [M]  /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/sources/nvidia-oot/drivers/block/tegra_virt_storage/tegra_hv_ufs.o
  LD [M]  /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/sources/nvidia-oot/drivers/block/tegra_virt_storage/tegra_vblk.o
make[2]: *** [scripts/Makefile.build:559: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/sources/nvidia-oot/drivers] Error 2
make[1]: *** [Makefile:1912: /home/ubuntu/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/sources/nvidia-oot] Error 2
make: *** [Makefile:75: nvidia-oot] Error 2
Hi @azulu
Could you please share the new defconfig file?
I think there are still some incompatibilities, so you need to continue debugging and modifying the defconfig file
Regards.
Hi @EduardoSalazar96
Sure, here is the new defconfig:
defconfig.txt (238.7 KB)
It seems that there must still be some incompatibilities yes, something related to Tegra again.
Regards.
You may try to build default defconfig and see if you can successfully build the kernel for Orin Nano developer kit. If the environment is good, following the steps one by one should build out valid kernel image.
Incidentally, if you’ve ever hand edited that defconfig file, and did not use a dependency-aware editor, then this could very well be the issue. If you’ve ever tried to load a module you’ve compiled and it complains of unknown or missing symbols, then you’ve failed to provide a dependency. There are some similar issues possible during a compile, and you might see something related to missing functions, or if you had something different source code versions conflicting, then it might show up as what I see in some of your build as invalid function arguments of the wrong type (because the function signature might have changed in different releases). Sometimes just using the wrong compiler version will cause this as well since warnings differ over releases of compiler.
I don’t know in your case, but:
  • Always make sure any external source code is compatible with that release.
  • Always start with the default defconfig, and make changes only with a dependency-aware editor.
  • Make sure that if the NVIDIA web page for a given release offers a correct compiler release, then to use this (this is only if you are using cross compile from an Ubuntu host PC; you still need correct compiler for use on native compile, but the NVIDIA provided compiler won’t be for native build). If you are natively compiling, then compare your gcc release to what docs want. Even if that release is not a match, it might still work, but possibly someone on the Internet would have posted a need to change a compile option to make it compatible, e.g., you might need to add an option to switch warning/error behavior.
