Issues Installing pytorch through jetson inference install script
After several attempts, several SD card reflashes, and lot’s of googling - i am still unable to successfully install pytorch through the inference install script on my Jetson Nano 4gb. Here is my jetpack version:
chace@chace:~/jetson-inference/build$ sudo apt-cache show nvidia-jetpack
Package: nvidia-jetpack
Version: 4.6.4-b39
Architecture: arm64
Maintainer: NVIDIA Corporation
Installed-Size: 194
Depends: nvidia-l4t-jetson-multimedia-api (>> 32.7-0), nvidia-l4t-jetson-multimedia-api (<< 32.8-0), nvidia-cuda (= 4.6.4-b39), nvidia-tensorrt (= 4.6.4-b39), nvidia-nsight-sys (= 4.6.4-b39), nvidia-cudnn8 (= 4.6.4-b39), nvidia-opencv (= 4.6.4-b39), nvidia-container (= 4.6.4-b39), nvidia-visionworks (= 4.6.4-b39), nvidia-vpi (= 4.6.4-b39)
Homepage: http://developer.nvidia.com/jetson
Priority: standard
Section: metapackages
Filename: pool/main/n/nvidia-jetpack/nvidia-jetpack_4.6.4-b39_arm64.deb
SHA256: adf7a6660f73cdc4f95bc15c48d8588688e3afa5ee18bfd5b3a3caa3a458aa02
SHA1: 5abbe0df74f71579c1a0ee30ab7c2c236e1bcdbb
MD5sum: ec293a56d17f2b2793448d621811330d
Description: NVIDIA Jetpack Meta Package
Description-md5: ad1462289bdbc54909ae109d1d32c0a8
Version: 4.6.3-b17
Architecture: arm64
Installed-Size: 194
Depends: nvidia-l4t-jetson-multimedia-api (>> 32.7-0), nvidia-l4t-jetson-multimedia-api (<< 32.8-0), nvidia-cuda (= 4.6.3-b17), nvidia-tensorrt (= 4.6.3-b17), nvidia-nsight-sys (= 4.6.3-b17), nvidia-cudnn8 (= 4.6.3-b17), nvidia-opencv (= 4.6.3-b17), nvidia-container (= 4.6.3-b17), nvidia-vpi (= 4.6.3-b17)
Homepage: Jetson - Embedded AI Computing Platform | NVIDIA Developer
Priority: standard
Filename: pool/main/n/nvidia-jetpack/nvidia-jetpack_4.6.3-b17_arm64.deb
SHA256: 694254a8667ebbf13852548bdd13a5b8ae61481ac059845b706398eefdcb9e01
SHA1: 67140fc8463ec61fd69352b225244b639c799edd
MD5sum: afa1382b6caded6b736d494fc481bab4
Version: 4.6.2-b5
Architecture: arm64
Installed-Size: 194
Depends: nvidia-cuda (= 4.6.2-b5), nvidia-opencv (= 4.6.2-b5), nvidia-cudnn8 (= 4.6.2-b5), nvidia-tensorrt (= 4.6.2-b5), nvidia-visionworks (= 4.6.2-b5), nvidia-container (= 4.6.2-b5), nvidia-vpi (= 4.6.2-b5), nvidia-l4t-jetson-multimedia-api (>> 32.7-0), nvidia-l4t-jetson-multimedia-api (<< 32.8-0)
Priority: standard
Filename: pool/main/n/nvidia-jetpack/nvidia-jetpack_4.6.2-b5_arm64.deb
SHA256: 925f4abff97e6024d86cff3b9e132e7c7554d05fb83590487381b7e925d5b2bb
SHA1: e3ef727e87df5c331aece34508c110d57d744fe9
MD5sum: 7cb2e387af41bc8143ac7b6525af7794
Version: 4.6.1-b110
Architecture: arm64
Installed-Size: 194
Depends: nvidia-cuda (= 4.6.1-b110), nvidia-opencv (= 4.6.1-b110), nvidia-cudnn8 (= 4.6.1-b110), nvidia-tensorrt (= 4.6.1-b110), nvidia-visionworks (= 4.6.1-b110), nvidia-container (= 4.6.1-b110), nvidia-vpi (= 4.6.1-b110), nvidia-l4t-jetson-multimedia-api (>> 32.7-0), nvidia-l4t-jetson-multimedia-api (<< 32.8-0)
Priority: standard
Filename: pool/main/n/nvidia-jetpack/nvidia-jetpack_4.6.1-b110_arm64.deb
SHA256: acfd9e75af780eab165361d61de4b4fe4974890864fe191060b402ac4c2f54d5
SHA1: a016568ac53705acc145a9f7e60505707bea259f
MD5sum: 79be976b184a8c885bd9169ea5b7fb7b
And here is the error message I am getting when trying to execute the script (and after following the other steps in the procedure leading up to this):
Command “/usr/bin/python3 -u -c “import setuptools, tokenize;file=‘/tmp/pip-build-yfzvgbyx/grpcio/setup.py’;f=getattr(tokenize, ‘open’, open)(file);code=f.read().replace(‘\r\n’, ‘\n’);f.close();exec(compile(code, file, ‘exec’))” install --record /tmp/pip-b0li_63y-record/install-record.txt --single-version-externally-managed --compile --user --prefix=” failed with error code 1 in /tmp/pip-build-yfzvgbyx/grpcio/
Command “/usr/bin/python3 -u -c “import setuptools, tokenize;file=‘/tmp/pip-build-qi1bxm78/numpy/setup.py’;f=getattr(tokenize, ‘open’, open)(file);code=f.read().replace(‘\r\n’, ‘\n’);f.close();exec(compile(code, file, ‘exec’))” install --record /tmp/pip-jve_f0v9-record/install-record.txt --single-version-externally-managed --compile --user --prefix=” failed with error code 1 in /tmp/pip-build-qi1bxm78/numpy/
[jetson-inference] failed to install torch-1.6.0-cp36-cp36m-linux_aarch64.whl
[jetson-inference] – command: pip3 install torch-1.6.0-cp36-cp36m-linux_aarch64.whl
[jetson-inference] – error code: 1
[jetson-inference] failed to install PyTorch v1.6.0 (Python 3.6)
[jetson-inference] installation complete, exiting with status code 0
[jetson-inference] to run this tool again, use the following commands:
$ cd <jetson-inference>/build
$ ./install-pytorch.sh
More debug info:
Exception information:
File “/usr/lib/python3/dist-packages/pip/basecommand.py”, line 215, in main
status = self.run(options, args)
File “/usr/lib/python3/dist-packages/pip/commands/install.py”, line 360, in run
prefix=options.prefix_path,
File “/usr/lib/python3/dist-packages/pip/req/req_set.py”, line 784, in install
**kwargs
File “/usr/lib/python3/dist-packages/pip/req/req_install.py”, line 878, in install
spinner=spinner,
File “/usr/lib/python3/dist-packages/pip/utils/init.py”, line 725, in call_subprocess
% (command_desc, proc.returncode, cwd))
pip.exceptions.InstallationError: Command “/usr/bin/python3 -u -c “import setuptools, tokenize;file=‘/tmp/pip-build-yfzvgbyx/grpcio/setup.py’;f=getattr(tokenize, ‘open’, open)(file);code=f.read().replace(‘\r\n’, ‘\n’);f.close();exec(compile(code, file, ‘exec’))” install --record /tmp/pip-b0li_63y-record/install-record.txt --single-version-externally-managed --compile --user --prefix=” failed with error code 1 in /tmp/pip-build-yfzvgbyx/grpcio/
torch-1.6.0-cp36-cp36m-li 100%[==================================>] 256.58M 3.45MB/s in 66s
Processing ./torch-1.6.0-cp36-cp36m-linux_aarch64.whl
Collecting numpy (from torch==1.6.0)
Using cached https://files.pythonhosted.org/packages/51/60/3f0fe5b7675a461d96b9d6729beecd3532565743278a9c3fe6dd09697fa7/numpy-1.19.5.zip
Collecting future (from torch==1.6.0)
Using cached https://files.pythonhosted.org/packages/8f/2e/cf6accf7415237d6faeeebdc7832023c90e0282aa16fd3263db0eb4715ec/future-0.18.3.tar.gz
Building wheels for collected packages: numpy, future
Running setup.py bdist_wheel for numpy … error
Complete output from command /usr/bin/python3 -u -c “import setuptools, tokenize;file=‘/tmp/pip-build-qi1bxm78/numpy/setup.py’;f=getattr(tokenize, ‘open’, open)(file);code=f.read().replace(‘\r\n’, ‘\n’);f.close();exec(compile(code, file, ‘exec’))” bdist_wheel -d /tmp/tmp1wvtuzvqpip-wheel- --python-tag cp36:
Running from numpy source directory.
Cythonizing sources
Error compiling Cython file:
cdef sfc64_state rng_state
  def __init__(self, seed=None):
      BitGenerator.__init__(self, seed)
      self._bitgen.state = <void *>&self.rng_state
      self._bitgen.next_uint64 = &sfc64_uint64
_sfc64.pyx:90:35: Cannot assign type ‘uint64_t (*)(void ) except? -1 nogil’ to 'uint64_t ()(void *) noexcept nogil’. Exception values are incompatible. Suggest adding ‘noexcept’ to type ‘uint64_t (void *) except? -1 nogil’.
Processing numpy/random/_bounded_integers.pxd.in
Processing numpy/random/_common.pyx
Processing numpy/random/mtrand.pyx
Processing numpy/random/_sfc64.pyx
File “/tmp/pip-build-qi1bxm78/numpy/tools/cythonize.py”, line 235, in
main()
File “/tmp/pip-build-qi1bxm78/numpy/tools/cythonize.py”, line 231, in main
find_process_files(root_dir)
File “/tmp/pip-build-qi1bxm78/numpy/tools/cythonize.py”, line 222, in find_process_files
process(root_dir, fromfile, tofile, function, hash_db)
File “/tmp/pip-build-qi1bxm78/numpy/tools/cythonize.py”, line 188, in process
processor_function(fromfile, tofile)
File “/tmp/pip-build-qi1bxm78/numpy/tools/cythonize.py”, line 78, in process_pyx
[sys.executable, ‘-m’, ‘cython’] + flags + [“-o”, tofile, fromfile])
File “/usr/lib/python3.6/subprocess.py”, line 311, in check_call
raise CalledProcessError(retcode, cmd)
subprocess.CalledProcessError: Command ‘[’/usr/bin/python3’, ‘-m’, ‘cython’, ‘-3’, ‘–fast-fail’, ‘-o’, ‘_sfc64.c’, ‘_sfc64.pyx’]’ returned non-zero exit status 1.
File “”, line 1, in
File “/tmp/pip-build-qi1bxm78/numpy/setup.py”, line 508, in
setup_package()
File “/tmp/pip-build-qi1bxm78/numpy/setup.py”, line 488, in setup_package
generate_cython()
File “/tmp/pip-build-qi1bxm78/numpy/setup.py”, line 285, in generate_cython
raise RuntimeError(“Running cythonize failed!”)
RuntimeError: Running cythonize failed!
Failed building wheel for numpy
Running setup.py clean for numpy
Complete output from command /usr/bin/python3 -u -c “import setuptools, tokenize;file=‘/tmp/pip-build-qi1bxm78/numpy/setup.py’;f=getattr(tokenize, ‘open’, open)(file);code=f.read().replace(‘\r\n’, ‘\n’);f.close();exec(compile(code, file, ‘exec’))” clean --all:
setup.py clean is not supported, use one of the following instead:
- `git clean -xdf` (cleans all files)
- `git clean -Xdf` (cleans all versioned files, doesn't touch
                    files that aren't checked into the git repo)
Add --force to your command to use it anyway if you must (unsupported).
Failed cleaning build dir for numpy
Running setup.py bdist_wheel for future … error
Complete output from command /usr/bin/python3 -u -c “import setuptools, tokenize;file=‘/tmp/pip-build-qi1bxm78/future/setup.py’;f=getattr(tokenize, ‘open’, open)(file);code=f.read().replace(‘\r\n’, ‘\n’);f.close();exec(compile(code, file, ‘exec’))” bdist_wheel -d /tmp/tmpq7xdp2b6pip-wheel- --python-tag cp36:
usage: -c [global_opts] cmd1 [cmd1_opts] [cmd2 [cmd2_opts] …]
or: -c --help [cmd1 cmd2 …]
or: -c --help-commands
or: -c cmd --help
error: invalid command ‘bdist_wheel’
Failed building wheel for future
Running setup.py clean for future
Failed to build numpy future
Installing collected packages: numpy, future, torch
Running setup.py install for numpy … error
Complete output from command /usr/bin/python3 -u -c “import setuptools, tokenize;file=‘/tmp/pip-build-qi1bxm78/numpy/setup.py’;f=getattr(tokenize, ‘open’, open)(file);code=f.read().replace(‘\r\n’, ‘\n’);f.close();exec(compile(code, file, ‘exec’))” install --record /tmp/pip-jve_f0v9-record/install-record.txt --single-version-externally-managed --compile --user --prefix=:
Note: if you need reliable uninstall behavior, then install
with pip instead of using `setup.py install`:
  - `pip install .`       (from a git repo or downloaded source
                           release)
  - `pip install numpy`   (last NumPy release on PyPi)
Cythonizing sources
_sfc64.pyx:90:35: Cannot assign type 'uint64_t (*)(void *) except? -1 nogil' to 'uint64_t (*)(void *) noexcept nogil'. Exception values are incompatible. Suggest adding 'noexcept' to type 'uint64_t (void *) except? -1 nogil'.
numpy/random/_bounded_integers.pxd.in has not changed
numpy/random/_common.pyx has not changed
numpy/random/mtrand.pyx has not changed
  File "/tmp/pip-build-qi1bxm78/numpy/tools/cythonize.py", line 235, in <module>
    main()
  File "/tmp/pip-build-qi1bxm78/numpy/tools/cythonize.py", line 231, in main
  File "/tmp/pip-build-qi1bxm78/numpy/tools/cythonize.py", line 222, in find_process_files
  File "/tmp/pip-build-qi1bxm78/numpy/tools/cythonize.py", line 188, in process
  File "/tmp/pip-build-qi1bxm78/numpy/tools/cythonize.py", line 78, in process_pyx
    [sys.executable, '-m', 'cython'] + flags + ["-o", tofile, fromfile])
  File "/usr/lib/python3.6/subprocess.py", line 311, in check_call
subprocess.CalledProcessError: Command '['/usr/bin/python3', '-m', 'cython', '-3', '--fast-fail', '-o', '_sfc64.c', '_sfc64.pyx']' returned non-zero exit status 1.
  File "<string>", line 1, in <module>
  File "/tmp/pip-build-qi1bxm78/numpy/setup.py", line 508, in <module>
    setup_package()
  File "/tmp/pip-build-qi1bxm78/numpy/setup.py", line 488, in setup_package
    generate_cython()
  File "/tmp/pip-build-qi1bxm78/numpy/setup.py", line 285, in generate_cython
    raise RuntimeError("Running cythonize failed!")
Hi @chace.medeiros, can you try running pip3 install 'Cython<3' first?
Also, you only need PyTorch for training your own models. You can run all the inferencing stuff by skipping it. You can also run the jetson-inference docker container and that will have PyTorch/ect already installed in it.
You can also run the procedure manually like in PyTorch for Jetson or here in the script:
Hi Dusty,
That did the trick! Thank you for the quick feedback and working solution.
My one follow up question is why? Is it because the packages associated with the working nano jet pack versions are getting stale?
Please let me know, thank you.
-Chace
It’s because Cython, one of the most widely used C-to-Python libraries, released a new major version (v3) that was not backwards-compatible and pip’s default behavior is to pull the latest. In the process, it broke a ton of other packages that haven’t yet migrated to Cython3 (or might never). But yes, I need to update jetson-inference’s PyTorch installer script (and in the larger sense, should probably revisit having that script at all, in lieu of just using container if/when someone wants to train with PyTorch)
Anyways, sorry about that!, and glad you got it working :)
Hey Dusty,
Thanks for the insight. Is it possible to use the train_sad script to fine tune an existing model I tuned using that same script?
If so what is the best way?
-Chace
Hi Chance, yes you should be able to use the --resume or --pretrained-ssd arguments to train_ssd.py, and specify the path to the .pth checkpoint that you want to load. Note that the epoch count will appear to have restarted from zero. I also recommend saving resumed models to a different --model-dir to keep them straight.
