Thanks for reporting,
Code translated from a link unit is randomly missing code for added entities
Fixed in the next release
Trying to create a target argument block for code generated from a link unit results in a crash
For link units, no target argument blocks / layouts were generated. Fixed in the next release
The LLVM backend always translates link units to IR, even when bitcode is requested.
Missing API for enumerating and specifying the source material of function when creating a target argument block
Maybe this is a misunderstanding of the API. To get the offset of an element, one has to use get_layout() after choosing the according subelement with get_nested_state(). The m_data_offset field in the layout state is only for internal use.
Example:
MDL:
export struct sub_struct
bool a;
bool b;
color c;
float d;
export struct top_struct
float a;
double x;
sub_struct b;
int c;
sub_struct d;
float e;
export material test_mat(float p = 0.3,
top_struct s = top_struct(
0.1,
0.2,
sub_struct(false, true, color(0.3, 0.5, 0.7), 0.6),
17,
sub_struct(true, false, color(0.8, 0.3, 0.1), 0.3),
1.3))
= let {
float3 uvw = state::texture_coordinate(0);
// Evaluate bools
float a = s.b.a ? 0.5 : 0;
float b = s.b.b ? 0.25 : 0;
float c = s.d.a ? 0.125 : 0;
float d = s.d.b ? 0.0625 : 0;
float sum = a + b + c + d;
// Evaluate numbers
float e = s.a * 0.1 + s.c / 100.0 * 0.2 + s.b.d * 0.3 + s.x * 0.5;
float f = s.e * 0.5 + s.c / 100.0 * 0.3 + s.d.d * 0.2 + s.x * 0.1;
// Evaluate colors
float3 col_b = float3(s.b.c);
float3 col_d = float3(s.d.c);
float g = col_b.x * 2 + col_b.y * 0.3 + col_b.z * 0.2;
float h = col_d.x * 0.2 + col_d.y * 0.3 + col_d.z * 0.5;
color params_res = color(
sum + p * 0.7,
math::lerp(e, f, uvw.x),
math::lerp(g, h, uvw.y));
color color_expr = params_res * math::sin(uvw.x * math::PI * 8);
float float_expr = float3( color_expr).x;
} in material(
surface: material_surface(scattering: df::diffuse_reflection_bsdf(
tint: color_expr))
C++ code:
// find the material parameter "s"
mi::Size s_param_index, num_params = compiled_material->get_parameter_count();
for (s_param_index = 0; s_param_index < num_params; ++s_param_index) {
if (!strcmp(compiled_material->get_parameter_name(s_param_index), "s"))
break;
if (s_param_index >= num_params) return;
mi::base::Handle<const mi::neuraylib::ITarget_value_layout> layout(
code_cuda_ptx->get_argument_block_layout());
// access the "top_struct s" parameter
mi::neuraylib::Target_value_layout_state state(layout->get_nested_state(s_param_index));
mi::neuraylib::IValue::Kind kind;
mi::Size size;
mi::Size offset = layout->get_layout(kind, size, state);
std::cout << "s: offset = " << offset << ", size = " << size << std::endl;
// access the forth element of top_struct (int c)
mi::neuraylib::Target_value_layout_state state_x(layout->get_nested_state(3, state));
offset = layout->get_layout(kind, size, state_x);
std::cout << "s.c: offset = " << offset << ", size = " << size << std::endl;
// access the third element of top_struct (sub_struct b)
mi::neuraylib::Target_value_layout_state state_b(layout->get_nested_state(2, state));
offset = layout->get_layout(kind, size, state_b);
std::cout << "s.b: offset = " << offset << ", size = " << size << std::endl;
// access the third element of sub_struct (color c)
mi::neuraylib::Target_value_layout_state state_b_c(layout->get_nested_state(2, state_b));
offset = layout->get_layout(kind, size, state_b_c);
std::cout << "s.b.c: offset = " << offset << ", size = " << size << std::endl;
// access the green element of color
mi::neuraylib::Target_value_layout_state state_b_c_g(layout->get_nested_state(1, state_b_c));
offset = layout->get_layout(kind, size, state_b_c_g);
std::cout << "s.b.c.g: offset = " << offset << ", size = " << size << std::endl;
// access the non-existing first element of the green element
mi::neuraylib::Target_value_layout_state state_b_c_g_0(layout->get_nested_state(0, state_b_c_g));
if (state_b_c_g_0.m_state_offs == ~mi::Uint32(0)) {
std::cout << "No subelement available for s.b.c.g!" << std::endl;
Output:
s: offset = 0, size = 144
s.c: offset = 64, size = 4
s.b: offset = 16, size = 48
s.b.c: offset = 32, size = 12
