Hello.
I found the python script below that should be able to give a realistic humanoid voice to chat gpt,converting the text produced by it into a humanoid voice and using my voice with a mic to talk with it. In short terms I want to do the same thing that the “amazon echo / Alexa” voice assistant does,without buying it,but using only what I already have…the Jetson nano. Why the Jetson nano ? Because I can move it from a place to another one within my home,like a voice assistant and because I’ve already spent some money to buy it and I want to use it. This is the video tutorial where I found it :
This is the code :
import openai
import speech_recognition as sr
import pyttsx3
import time
# Initialize OpenAI API
openai.api_key = "ciao a tutti"
# Initialize the text to speech engine
engine=pyttsx3.init()
def transcribe_audio_to_test(filename):
recogizer=sr.Recognizer()
with sr.AudioFile(filename)as source:
audio=recogizer.record(source)
try:
return recogizer.recognize_google(audio)
except:
print("skipping unkown error")
def generate_response(prompt):
response= openai.completion.create(
engine="text-davinci-003",
prompt=prompt,
max_tokens=4000,
n=1,
stop=None,
temperature=0.5,
return response ["Choices"][0]["text"]
def speak_text(text):
engine.say(text)
engine.runAndWait()
def main():
while True:
#Waith for user say "genius"
print("Say 'Genius' to start recording your question")
with sr.Microphone() as source:
recognizer=sr.Recognizer()
audio=recognizer.listen(source)
try:
transcription = recognizer.recognize_google(audio)
if transcription.lower()=="genius":
#record audio
filename ="input.wav"
print("Say your question")
recognizer=sr.recognize()
source.pause_threshold=1
audio=recognizer.listen(source,phrase_time_limit=None,timeout=None)
with open(filename,"wb")as f:
f.write(audio.get_wav_data())
#transcript audio to test
text=transcribe_audio_to_test(filename)
if text:
print(f"yuo said {text}")
#Generate the response
response = generate_response(text)
print(f"chat gpt 3 say {response}")
#read resopnse using GPT3
speak_text(response)
except Exception as e:
print("An error ocurred : {}".format(e))
if __name__=="__main__":
main()
I tried installing openai with pip :
marietto@marietto:/mnt/fisso/OS/Alexa-ChatGPT# python3 code.py
marietto@marietto:~/Desktop$ python3 code.py
Say ‘Genius’ to start recording your question
ALSA lib confmisc.c:1281:(snd_func_refer) Unable to find definition ‘cards.tegra-hda.pcm.front.0:CARD=0’
ALSA lib conf.c:4732:(_snd_config_evaluate) function snd_func_refer returned error: No such file or directory
ALSA lib conf.c:5220:(snd_config_expand) Evaluate error: No such file or directory
ALSA lib pcm.c:2642:(snd_pcm_open_noupdate) Unknown PCM front
ALSA lib pcm.c:2642:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.rear
ALSA lib pcm.c:2642:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.center_lfe
ALSA lib pcm.c:2642:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.side
ALSA lib pcm.c:2642:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround21
ALSA lib pcm.c:2642:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround40
ALSA lib pcm.c:2642:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround41
ALSA lib pcm.c:2642:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround50
ALSA lib pcm.c:2642:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround51
ALSA lib pcm.c:2642:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround71
ALSA lib pcm.c:2642:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.iec958
ALSA lib pcm.c:2642:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.modem
ALSA lib pcm.c:2642:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.phoneline
ALSA lib pcm_oss.c:377:(_snd_pcm_oss_open) Unknown field port
ALSA lib pcm_usb_stream.c:486:(_snd_pcm_usb_stream_open) Invalid type for card
ALSA lib pcm_dmix.c:1024:(snd_pcm_dmix_open) The dmix plugin supports only playback stream
ALSA lib pcm_dmix.c:1089:(snd_pcm_dmix_open) unable to open slave
ALSA lib pcm_params.c:2226:(snd1_pcm_hw_refine_slave) Slave PCM not usable
Can some one help me to trouble shot where the problem could be ?
On the jetson nano I'm running ubuntu 20.04 and these versions of python :
marietto@marietto:/mnt/fisso/OS/Alexa-ChatGPT# python3 --version
Python 3.8.10
marietto@marietto:/mnt/fisso/OS/Alexa-ChatGPT# python --version
Python 2.7.18
