I am writing an application that eventually will capture multiple streams from each camera for up to 5 cameras concurrently.
I am currently experimenting with the following:
- nVidia Jetson TX2 EVM with 3-port Leopard Imaging adapter board
- an IMX274 CSI camera and an IMX185 CSI camera connected to the Leopard Imaging adapter board
Consulting the example and the <13_multi_camera> example from the tegra_multimedia_api/samples directory, I was able to get the following to work:
- running IMX274 (enumerated as camera device 1) alone with 4 streams works fine, able to get 30 fps/stream
- running IMX185 (enumerated as camera device 0) alone with 2 streams works fine, able to get 30 fps/stream
- running IMX274 with 1 stream and IMX185 with 1 stream concurrently in 1 single process (i.e. same producer thread) works fine
However, I was not able to get the following to work using the same consumer configurations as above:
- running IMX274 and IMX185 producer in separate processes concurrently (i.e. one process captures camera 0 and another process captures camera 1) will not work, regardless of consumer streams for each camera/producer. IMX274 process reports:
- Using 2 capture sessions (one for camera 0 and one for camera 1) in one process (similar to <13_multi_camera> producer setup) and capturing more than 1 streams from each camera will fail with similar errors.
- ICaptureSession interface can no longer be acquired when multiple camera capture sessions are in progress using repeat capture.
===== MSENC blits (mode: 1) into tiled surfaces =====
SCF: Error Timeout: (propagating from src/services/capture/CaptureServiceEvent.cpp, function wait(), line 59)
Error: Camera HwEvents wait, this may indicate a hardware timeout occured,abort current/incoming cc
Error: waitCsiFrameStart timeout guid 0
SCF: Error Timeout: VI SOF timed out! (in src/services/capture/CaptureServiceDeviceViCsi.cpp, function waitCsiFrameStart(), line 948)
VI Stream Id = 0 Virtual Channel = 0
************VI Debug Registers**********
VI_CSIMUX_STAT_FRAME_0 = 0x00000000
VI_CSIMUX_FRAME_STATUS_0 = 0x00010000
VI_CFG_INTERRUPT_STATUS_0 = 0x3f000000
VI_ISPBUFA_ERROR_0 = 0x00000000
VI_FMLITE_ERROR_0 = 0x00000000
VI_NOTIFY_ERROR_0 = 0x00000000
CSI Stream Id = 0 Brick Id = 0
************CSI Debug Registers**********
CILA_INTR_STATUS_CILA[0x10400] = 0x00000089
CILB_INTR_STATUS_CILB[0x10c00] = 0x00000088
INTR_STATUS[0x100a4] = 0x00000000
ERR_INTR_STATUS[0x100ac] = 0x00000000
ERROR_STATUS2VI_VC0[0x10094] = 0x00000000
ERROR_STATUS2VI_VC1[0x10098] = 0x00000000
ERROR_STATUS2VI_VC2[0x1009c] = 0x00000000
ERROR_STATUS2VI_VC3[0x100a0] = 0x00000000
launchCC abort cc 157 session 0
SCF: Error Timeout: (propagating from src/api/Session.cpp, function capture(), line 830)
(Argus) Error Timeout: (propagating from src/api/ScfCaptureThread.cpp, function run(), line 109)
IMX185 process reports:
launchCC abort cc 104 session 4
launchCC abort cc 105 session 4
launchCC abort cc 106 session 4(Argus) Error InvalidState: MetadataResult callback for unknown capture. (in src/api/CaptureSessionImpl.cpp, function metadataResult(), line 705)
According to what I have read so far, it seems capture sessions for a given camera must be in the same process but it sort of implies independent processes that contain exclusive camera resource can be run concurrently? Although I was not able to get this to work in all the different scenarios I have tried. Is this a valid assumption or a permissible operation mode?
Is there a valid path to capture multiple streams from multiple cameras concurrently? If so, how should I go about reaching this goal?
Best Regards,
Joseph
