JetPack 4.5.1 + Nano + Headless Setup Occurred debconf config.dat is locked by another process
Occurs the first time in a headless setup
debconf: DbDriver “config”: /var/cache/debconf/config.dat is locked by another process: Resource temporarily unavailable
System configuration setup wasn’t completed. Please reboot device and try again.
ClipImage_20210301_124111_112
And I Reset Nano , Then Enter Headless Setup .
ClipImage_20210301_124108_167
Before JetPack 4.5.1(JetPack 4.4~4.5) I didn’t seen This Problem .
And will this initial configuration pass ?
Yes, Headless Setup is successful, so there is no problem.
But I care that the “config.dat is locked” occurs first.
If “don’t worry, you can ignore it”, Then I don’t care.
I think no need to worry at this moment.
