Jetpack 6.2.1 l4t-36.4.4 just downloaded via apt update && apt upgrade
It seems like you’ve just updated your Jetson device to Jetpack 6.2.1 with L4T (Linux for Tegra) version 36.4.4 using the apt update and apt upgrade commands.
To confirm, Jetpack is a development package for NVIDIA’s Jetson platform, which includes the Jetson Linux Driver Package (L4T) and other tools for developing AI and computer vision applications. The L4T package provides the Linux kernel, device drivers, and other software components for the Jetson platform.
The version numbers you mentioned, r36.4.4, refer to the specific version of the L4T package. The r prefix indicates that it’s a release version, and the numbers that follow represent the version number.
As you’ve updated to the latest version, you should now have the latest Jetson Linux release package, which includes the latest kernel, device drivers, and other software components.
To verify the update, you can check the kernel version by running the uname -r command in the terminal. This should display the version number of the kernel, which should match the version number of the L4T package you just updated to.
Additionally, you can check the version of the Jetpack and L4T packages by running the dpkg -l | grep jetpack and dpkg -l | grep l4t commands, respectively. These commands will display the version numbers of the packages installed on your system.
It’s also a good idea to reboot your system after updating to ensure that all changes take effect.
If you’re looking for documentation or guides on using the updated Jetpack and L4T packages, you can refer to the NVIDIA Developer Guide, which should be available on the NVIDIA website or through the DeveloperGuide package you mentioned.
Please let me know if you have any further questions or concerns!
Yes, it was uploading, and we have JetPAck 6.2.1 release today, see JetPack 6.2.1/Jetson Linux 36.4.4 is now live - Jetson & Embedded Systems / Jetson AGX Orin - NVIDIA Developer Forums
