I’m having trouble making jet racers using Jetson Nano.
In basic motion, the throttle is adjusted to a value between -1 and 1.
In my case, if I enter a negative value, the jetracer go forward and positive values work the opposite way.
At first, I thought it would be fine to adjust the reverse on the transmitter.
But it only works when controlled by the transmitter, It was not related to basic motion.
how can i solve this problem?
Can I simply put a negative sign before the throttle value x?
In road_following.ipynb, I just give -0.2 to car.throttle. but the jetracer did not drive along the learned route.
I also had a hard time trying to use this track to learn the path. Are there any precautions when learning on planar tracks?
