Jetson AGX Orin Capture Error PHY_INTR0
We are developing a driver for Orin, the sensor provides 9248x6944 video at 4fps, using 4 CSI lanes. We are setting each lane to work at 800Mbps.
dmesg log:
[   44.537434] sensorx123 2-0036: IOVDD enable
[   44.541809] sensorx123 2-0036: 0x3036 Sensor revision ID: 0x42
[   44.554523] bwmgr API not supported
[   44.565351] sensorx123 2-0036: sensorx123: index=0
[   44.593745] sensorx123 2-0036: sensorx123:
[   47.118673] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[   47.128096] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[   47.138034] (NULL device *): vi_capture_control_message: NULL VI channel received
[   47.145743] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[   47.156408] (NULL device *): vi_capture_control_message: NULL VI channel received
[   47.164116] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 0
[   47.174873] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[   49.710684] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[   49.720096] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[   49.730672] (NULL device *): vi_capture_control_message: NULL VI channel received
[   49.738554] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[   49.749477] (NULL device *): vi_capture_control_message: NULL VI channel received
[   49.757217] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 0
[   49.768485] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[   49.778236] sensorx123 2-0036: sensorx123:
[   49.796652] bwmgr API not supported
tracer log:
# tracer: nop
# entries-in-buffer/entries-written: 7480/7480   #P:12
#                                _-----=> irqs-off
#                               / _----=> need-resched
#                              | / _---=> hardirq/softirq
#                              || / _--=> preempt-depth
#                              ||| /     delay
#           TASK-PID     CPU#  ||||   TIMESTAMP  FUNCTION
        v4l2-ctl-1876    [011] ....    44.423349: tegra_channel_open: vi-output, sensorx123 2-0036
        v4l2-ctl-1876    [011] ....    44.533431: tegra_channel_set_power: sensorx123 2-0036 : 0x1
        v4l2-ctl-1876    [011] ....    44.533444: camera_common_s_power: status : 0x1
        v4l2-ctl-1876    [011] ....    44.547812: tegra_channel_set_power: 13e40000.host1x:nvcsi@15a00000- : 0x1
        v4l2-ctl-1876    [011] ....    44.547814: csi_s_power: enable : 0x1
        v4l2-ctl-1876    [011] ....    44.548222: tegra_channel_capture_setup: vnc_id 0 W 9248 H 6944 fmt c4
        v4l2-ctl-1876    [011] ....    44.549475: tegra_channel_set_stream: enable : 0x1
        v4l2-ctl-1876    [011] ....    44.564739: tegra_channel_set_stream: 13e40000.host1x:nvcsi@15a00000- : 0x1
        v4l2-ctl-1876    [011] ....    44.564742: csi_s_stream: enable : 0x1
        v4l2-ctl-1876    [011] ....    44.565343: tegra_channel_set_stream: sensorx123 2-0036 : 0x1
     kworker/3:2-152     [003] ....    44.602026: rtcpu_vinotify_event: tstamp:2246375327 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:71868720736 data:0x399d580010000000
     kworker/3:2-152     [003] ....    44.602029: rtcpu_vinotify_event: tstamp:2246375464 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:71868727232 data:0x0000000031000001
     kworker/3:2-152     [003] ....    44.602029: rtcpu_vinotify_event: tstamp:2246375623 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:71868788480 data:0x399d550010000000
     kworker/3:2-152     [003] ....    44.602030: rtcpu_vinotify_event: tstamp:2246375757 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:71868795072 data:0x0000000031000002
     kworker/3:2-152     [003] ....    44.714046: rtcpu_nvcsi_intr: tstamp:2250655848 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000040
     kworker/3:2-152     [003] ....    44.714049: rtcpu_nvcsi_intr: tstamp:2250655848 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
     kworker/3:2-152     [003] ....    44.714051: rtcpu_nvcsi_intr: tstamp:2250683191 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000040
     kworker/3:2-152     [003] ....    44.714053: rtcpu_nvcsi_intr: tstamp:2250683191 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
     kworker/3:2-152     [003] ....    44.714054: rtcpu_nvcsi_intr: tstamp:2250683999 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000040
     kworker/3:2-152     [003] ....    44.714056: rtcpu_nvcsi_intr: tstamp:2250683999 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
     kworker/3:2-152     [003] ....    44.714057: rtcpu_nvcsi_intr: tstamp:2250720262 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000040
     kworker/3:2-152     [003] ....    44.714059: rtcpu_nvcsi_intr: tstamp:2250720262 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
     kworker/3:2-152     [003] ....    44.714060: rtcpu_nvcsi_intr: tstamp:2250721070 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000040
     kworker/3:2-152     [003] ....    44.714062: rtcpu_nvcsi_intr: tstamp:2250721070 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
     kworker/3:2-152     [003] ....    44.714063: rtcpu_nvcsi_intr: tstamp:2250757330 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000040
     kworker/3:2-152     [003] ....    44.714065: rtcpu_nvcsi_intr: tstamp:2250757330 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
     kworker/3:2-152     [003] ....    44.714066: rtcpu_nvcsi_intr: tstamp:2250758138 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000040
     kworker/3:2-152     [003] ....    44.714067: rtcpu_nvcsi_intr: tstamp:2250758138 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
     kworker/3:2-152     [003] ....    44.714069: rtcpu_nvcsi_intr: tstamp:2250794867 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000040
     kworker/3:2-152     [003] ....    44.714070: rtcpu_nvcsi_intr: tstamp:2250794867 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
     kworker/3:2-152     [003] ....    44.714072: rtcpu_nvcsi_intr: tstamp:2250795674 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000040
     kworker/3:2-152     [003] ....    44.714073: rtcpu_nvcsi_intr: tstamp:2250795674 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
     kworker/3:2-152     [003] ....    44.714075: rtcpu_nvcsi_intr: tstamp:2250831936 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000040
     kworker/3:2-152     [003] ....    44.714076: rtcpu_nvcsi_intr: tstamp:2250831936 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
     kworker/3:2-152     [003] ....    44.714077: rtcpu_nvcsi_intr: tstamp:2250832745 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000040
     kworker/3:2-152     [003] ....    44.714079: rtcpu_nvcsi_intr: tstamp:2250832745 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
     kworker/3:2-152     [003] ....    44.714080: rtcpu_nvcsi_intr: tstamp:2250869006 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000040
     kworker/3:2-152     [003] ....    44.714082: rtcpu_nvcsi_intr: tstamp:2250869006 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
     kworker/3:2-152     [003] ....    44.714084: rtcpu_nvcsi_intr: tstamp:2250869813 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000040
     kworker/3:2-152     [003] ....    44.714085: rtcpu_nvcsi_intr: tstamp:2250869813 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
     kworker/3:2-152     [003] ....    44.714087: rtcpu_nvcsi_intr: tstamp:2250906544 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000040
     kworker/3:2-152     [003] ....    44.714088: rtcpu_nvcsi_intr: tstamp:2250906544 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
     kworker/3:2-152     [003] ....    44.714089: rtcpu_nvcsi_intr: tstamp:2250907352 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000040
     kworker/3:2-152     [003] ....    44.714091: rtcpu_nvcsi_intr: tstamp:2250907352 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
     kworker/3:2-152     [003] ....    44.714092: rtcpu_nvcsi_intr: tstamp:2250943614 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000040
     kworker/3:2-152     [003] ....    44.714094: rtcpu_nvcsi_intr: tstamp:2250943614 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
     kworker/3:2-152     [003] ....    44.714095: rtcpu_nvcsi_intr: tstamp:2250944423 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000040
     kworker/3:2-152     [003] ....    44.714097: rtcpu_nvcsi_intr: tstamp:2250944423 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
     kworker/3:2-152     [003] ....    44.714098: rtcpu_nvcsi_intr: tstamp:2250980686 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000040
     kworker/3:2-152     [003] ....    44.714100: rtcpu_nvcsi_intr: tstamp:2250980686 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
     kworker/3:2-152     [003] ....    44.714101: rtcpu_nvcsi_intr: tstamp:2250981494 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000040
     kworker/3:2-152     [003] ....    44.714103: rtcpu_nvcsi_intr: tstamp:2250981494 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
     kworker/3:2-152     [003] ....    44.714104: rtcpu_nvcsi_intr: tstamp:2251018222 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000040
     kworker/3:2-152     [003] ....    44.714106: rtcpu_nvcsi_intr: tstamp:2251018222 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
     kworker/3:2-152     [003] ....    44.714107: rtcpu_nvcsi_intr: tstamp:2251019030 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000040
     kworker/3:2-152     [003] ....    44.714109: rtcpu_nvcsi_intr: tstamp:2251019030 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
     kworker/3:2-152     [003] ....    44.770680: rtcpu_nvcsi_intr: tstamp:2251055293 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000040
     kworker/3:2-152     [003] ....    44.770690: rtcpu_nvcsi_intr: tstamp:2251055293 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
     kworker/3:2-152     [003] ....    44.770693: rtcpu_nvcsi_intr: tstamp:2251056101 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000040
     kworker/3:2-152     [003] ....    44.770696: rtcpu_nvcsi_intr: tstamp:2251056101 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
     kworker/3:2-152     [003] ....    44.770699: rtcpu_nvcsi_intr: tstamp:2251092364 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000040
     kworker/3:2-152     [003] ....    44.770702: rtcpu_nvcsi_intr: tstamp:2251092364 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
     kworker/3:2-152     [003] ....    44.770705: rtcpu_nvcsi_intr: tstamp:2251093169 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000040
     kworker/3:2-152     [003] ....    44.770708: rtcpu_nvcsi_intr: tstamp:2251093169 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
     kworker/3:2-152     [003] ....    44.770710: rtcpu_nvcsi_intr: tstamp:2251129471 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000040
     kworker/3:2-152     [003] ....    44.770713: rtcpu_nvcsi_intr: tstamp:2251129471 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
     kworker/3:2-152     [003] ....    44.770715: rtcpu_nvcsi_intr: tstamp:2251130279 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000040
     kworker/3:2-152     [003] ....    44.770719: rtcpu_nvcsi_intr: tstamp:2251130279 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
     kworker/3:2-152     [003] ....    44.770721: rtcpu_nvcsi_intr: tstamp:2251166541 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000040
     kworker/3:2-152     [003] ....    44.770724: rtcpu_nvcsi_intr: tstamp:2251166541 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
     kworker/3:2-152     [003] ....    44.770727: rtcpu_nvcsi_intr: tstamp:2251167348 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000040
     kworker/3:2-152     [003] ....    44.770729: rtcpu_nvcsi_intr: tstamp:2251167348 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
     kworker/3:2-152     [003] ....    44.770732: rtcpu_nvcsi_intr: tstamp:2251203611 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000040
     kworker/3:2-152     [003] ....    44.770734: rtcpu_nvcsi_intr: tstamp:2251203611 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
     kworker/3:2-152     [003] ....    44.770736: rtcpu_nvcsi_intr: tstamp:2251204419 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000040
     kworker/3:2-152     [003] ....    44.770739: rtcpu_nvcsi_intr: tstamp:2251204419 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
     kworker/3:2-152     [003] ....    44.770741: rtcpu_nvcsi_intr: tstamp:2251241149 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000040
     kworker/3:2-152     [003] ....    44.770744: rtcpu_nvcsi_intr: tstamp:2251241149 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
     kworker/3:2-152     [003] ....    44.770746: rtcpu_nvcsi_intr: tstamp:2251241956 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000040
     kworker/3:2-152     [003] ....    44.770748: rtcpu_nvcsi_intr: tstamp:2251241956 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
     kworker/3:2-152     [003] ....    44.770750: rtcpu_nvcsi_intr: tstamp:2251278220 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000040
     kworker/3:2-152     [003] ....    44.770753: rtcpu_nvcsi_intr: tstamp:2251278220 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
     kworker/3:2-152     [003] ....    44.770755: rtcpu_nvcsi_intr: tstamp:2251279026 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000040
     kworker/3:2-152     [003] ....    44.770757: rtcpu_nvcsi_intr: tstamp:2251279026 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
     kworker/3:2-152     [003] ....    44.770759: rtcpu_nvcsi_intr: tstamp:2251315288 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000040
     kworker/3:2-152     [003] ....    44.770762: rtcpu_nvcsi_intr: tstamp:2251315288 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
     kworker/3:2-152     [003] ....    44.770764: rtcpu_nvcsi_intr: tstamp:2251316097 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000040
     kworker/3:2-152     [003] ....    44.770766: rtcpu_nvcsi_intr: tstamp:2251316097 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
     kworker/3:2-152     [003] ....    44.770768: rtcpu_nvcsi_intr: tstamp:2251352828 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000040
     kworker/3:2-152     [003] ....    44.770770: rtcpu_nvcsi_intr: tstamp:2251352828 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
     kworker/3:2-152     [003] ....    44.770773: rtcpu_nvcsi_intr: tstamp:2251353633 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000040
     kworker/3:2-152     [003] ....    44.770775: rtcpu_nvcsi_intr: tstamp:2251353633 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
     kworker/3:2-152     [003] ....    44.770777: rtcpu_nvcsi_intr: tstamp:2251389898 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000040
     kworker/3:2-152     [003] ....    44.770779: rtcpu_nvcsi_intr: tstamp:2251389898 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
     kworker/3:2-152     [003] ....    44.770782: rtcpu_nvcsi_intr: tstamp:2251390704 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000040
     kworker/3:2-152     [003] ....    44.770784: rtcpu_nvcsi_intr: tstamp:2251390704 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
     kworker/3:2-152     [003] ....    44.770786: rtcpu_nvcsi_intr: tstamp:2251426967 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000040
     kworker/3:2-152     [003] ....    44.770789: rtcpu_nvcsi_intr: tstamp:2251426967 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
     kworker/3:2-152     [003] ....    44.770791: rtcpu_nvcsi_intr: tstamp:2251427774 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000040
     kworker/3:2-152     [003] ....    44.770793: rtcpu_nvcsi_intr: tstamp:2251427774 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
     kworker/3:2-152     [003] ....    44.770795: rtcpu_nvcsi_intr: tstamp:2251464506 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000040
     kworker/3:2-152     [003] ....    44.770798: rtcpu_nvcsi_intr: tstamp:2251464506 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
     kworker/3:2-152     [003] ....    44.770800: rtcpu_nvcsi_intr: tstamp:2251465313 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000040
     kworker/3:2-152     [003] ....    44.770802: rtcpu_nvcsi_intr: tstamp:2251465313 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
     kworker/3:2-152     [003] ....    44.770804: rtcpu_nvcsi_intr: tstamp:2251501574 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000040
     kworker/3:2-152     [003] ....    44.770807: rtcpu_nvcsi_intr: tstamp:2251501574 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
     kworker/3:2-152     [003] ....    44.770809: rtcpu_nvcsi_intr: tstamp:2251502382 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000040
     kworker/3:2-152     [003] ....    44.770811: rtcpu_nvcsi_intr: tstamp:2251502382 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
     kworker/3:2-152     [003] ....    44.770813: rtcpu_nvcsi_intr: tstamp:2251538645 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000040
     kworker/3:2-152     [003] ....    44.770815: rtcpu_nvcsi_intr: tstamp:2251538645 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
     kworker/3:2-152     [003] ....    44.770818: rtcpu_nvcsi_intr: tstamp:2251539453 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000040
     kworker/3:2-152     [003] ....    44.770820: rtcpu_nvcsi_intr: tstamp:2251539453 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
     kworker/3:2-152     [003] ....    44.770822: rtcpu_nvcsi_intr: tstamp:2251575752 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000040
     kworker/3:2-152     [003] ....    44.770824: rtcpu_nvcsi_intr: tstamp:2251575752 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
     kworker/3:2-152     [003] ....    44.770826: rtcpu_nvcsi_intr: tstamp:2251576560 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000040
     kworker/3:2-152     [003] ....    44.770828: rtcpu_nvcsi_intr: tstamp:2251576560 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
     kworker/3:2-152     [003] ....    44.770831: rtcpu_nvcsi_intr: tstamp:2251612824 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000040
     kworker/3:2-152     [003] ....    44.770833: rtcpu_nvcsi_intr: tstamp:2251612824 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
     kworker/3:2-152     [003] ....    44.770835: rtcpu_nvcsi_intr: tstamp:2251613631 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000040
     kworker/3:2-152     [003] ....    44.770838: rtcpu_nvcsi_intr: tstamp:2251613631 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
     kworker/3:2-152     [003] ....    44.770840: rtcpu_nvcsi_intr: tstamp:2251649894 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000040
     kworker/3:2-152     [003] ....    44.770847: rtcpu_nvcsi_intr: tstamp:2251649894 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
     kworker/3:2-152     [003] ....    44.770852: rtcpu_nvcsi_intr: tstamp:2251650700 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000040
     kworker/3:2-152     [003] ....    44.770854: rtcpu_nvcsi_intr: tstamp:2251650700 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
     kworker/3:2-152     [003] ....    44.770857: rtcpu_nvcsi_intr: tstamp:2251687431 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000040
     kworker/3:2-152     [003] ....    44.770859: rtcpu_nvcsi_intr: tstamp:2251687431 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
     kworker/3:2-152     [003] ....    44.770861: rtcpu_nvcsi_intr: tstamp:2251688239 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000040
     kworker/3:2-152     [003] ....    44.770864: rtcpu_nvcsi_intr: tstamp:2251688239 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
     kworker/3:2-152     [003] ....    44.770866: rtcpu_nvcsi_intr: tstamp:2251724501 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000040
     kworker/3:2-152     [003] ....    44.770868: rtcpu_nvcsi_intr: tstamp:2251724501 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
     kworker/3:2-152     [003] ....    44.770870: rtcpu_nvcsi_intr: tstamp:2251725309 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000040
     kworker/3:2-152     [003] ....    44.770873: rtcpu_nvcsi_intr: tstamp:2251725309 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
     kworker/3:2-152     [003] ....    44.770875: rtcpu_nvcsi_intr: tstamp:2251761569 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000040
     kworker/3:2-152     [003] ....    44.770877: rtcpu_nvcsi_intr: tstamp:2251761569 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
     kworker/3:2-152     [003] ....    44.770880: rtcpu_nvcsi_intr: tstamp:2251762378 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000040
     kworker/3:2-152     [003] ....    44.770882: rtcpu_nvcsi_intr: tstamp:2251762378 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
     kworker/3:2-152     [003] ....    44.770884: rtcpu_nvcsi_intr: tstamp:2251800209 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000040
     kworker/3:2-152     [003] ....    44.770886: rtcpu_nvcsi_intr: tstamp:2251800209 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
     kworker/3:2-152     [003] ....    44.770888: rtcpu_nvcsi_intr: tstamp:2251836181 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000040
     kworker/3:2-152     [003] ....    44.770891: rtcpu_nvcsi_intr: tstamp:2251836181 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
     kworker/3:2-152     [003] ....    44.770893: rtcpu_nvcsi_intr: tstamp:2251836988 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000040
     kworker/3:2-152     [003] ....    44.770895: rtcpu_nvcsi_intr: tstamp:2251836988 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
     kworker/3:2-152     [003] ....    44.770897: rtcpu_nvcsi_intr: tstamp:2251873251 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000040
     kworker/3:2-152     [003] ....    44.770900: rtcpu_nvcsi_intr: tstamp:2251873251 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
     kworker/3:2-152     [003] ....    44.770902: rtcpu_nvcsi_intr: tstamp:2251874056 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000040
     kworker/3:2-152     [003] ....    44.770904: rtcpu_nvcsi_intr: tstamp:2251874056 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
     kworker/3:2-152     [003] ....    44.770906: rtcpu_nvcsi_intr: tstamp:2251910787 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000040
     kworker/3:2-152     [003] ....    44.770909: rtcpu_nvcsi_intr: tstamp:2251910787 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
     kworker/3:2-152     [003] ....    44.770911: rtcpu_nvcsi_intr: tstamp:2251911595 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000040
     kworker/3:2-152     [003] ....    44.770913: rtcpu_nvcsi_intr: tstamp:2251911595 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
     kworker/3:2-152     [003] ....    44.770916: rtcpu_nvcsi_intr: tstamp:2251947858 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000040
     kworker/3:2-152     [003] ....    44.770918: rtcpu_nvcsi_intr: tstamp:2251947858 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
     kworker/3:2-152     [003] ....    44.770920: rtcpu_nvcsi_intr: tstamp:2251948667 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000040
     kworker/3:2-152     [003] ....    44.770922: rtcpu_nvcsi_intr: tstamp:2251948667 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
     kworker/3:2-152     [003] ....    44.770925: rtcpu_nvcsi_intr: tstamp:2251984927 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000040
     kworker/3:2-152     [003] ....    44.770927: rtcpu_nvcsi_intr: tstamp:2251984927 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
     kworker/3:2-152     [003] ....    44.770929: rtcpu_nvcsi_intr: tstamp:2251985735 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000040
     kworker/3:2-152     [003] ....    44.770931: rtcpu_nvcsi_intr: tstamp:2251985735 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
     kworker/3:2-152     [003] ....    44.770933: rtcpu_nvcsi_intr: tstamp:2252022037 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000040
     kworker/3:2-152     [003] ....    44.770936: rtcpu_nvcsi_intr: tstamp:2252022037 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
     kworker/3:2-152     [003] ....    44.770938: rtcpu_nvcsi_intr: tstamp:2252022842 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000040
     kworker/3:2-152     [003] ....    44.770941: rtcpu_nvcsi_intr: tstamp:2252022842 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
     kworker/3:2-152     [003] ....    44.770943: rtcpu_nvcsi_intr: tstamp:2252059104 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000040
     kworker/3:2-152     [003] ....    44.770945: rtcpu_nvcsi_intr: tstamp:2252059104 class:GLOBAL
Some comments:
  1. Since the lanes are < 1.5Gbps, it shouldn’t be a problem with deskew calibration as mentioned in other posts.
  2. We have tested several lane polarities, without any success. However, when setting polarity = 7 or 5, we get only status:0x00000040 continuously (no 44 status at all).
  3. Already boosted the clocks without success.
  4. The issue happens in both Jetpack 5.0.2 and 5.1.1.
  5. If we change cil_settletime to 6, then we get status:0x06000000 and status:0x0e000000.
My understanding is that these errors refer to NVCSI_INTR_FLAG_CIL_INTR0_DATA_LANE_ERR1_SOT_MB (0x00000040), and NVCSI_INTR_FLAG_CIL_INTR0_DPHY_DESKEW_CALIB_ERR_LANE0 (0x06000000), it would be great to have an explanation of what causes the issue in order to debug it further since the TRM and the code are not very explicit.
Also, in terms of getting closer to capture, which error is better? DATA_LANE_ERR1 or DESKEW_CALIB_ERR.
Please let me know any other information I might provide. Thanks.
hello alejandro.solis,
the error code 0x44 (or, 0x40) indicate there’re more than one bit error has detected on data-lane.
it just means there are bunch of interrupts happening, it’s not really an error to crash the capture pipeline.
may I know which CSI brick you’re using? I do see some issues for 4-lane sensor on CSI-C.
Hi, thanks for replying.
We are using the first two CSI blocks (A and B). 2 data lanes of block A, the clock input from block A, and 2 lanes of block B, everything as explained in the D-PHY configurations table of the Orin datasheet.
I see a ton of status:0x00000040 and alike and no frames are grabbed from the sensor. Could you recommend anything to debug that error either from Software or Hardware?
FYI,
the interrupt status 0x40, is toggle by intr_cil_data_lane_sot_mb_err1_b.
as mentioned, this is error due to more than one bit error detected on the lane [A/B] sync word. where the “_b” at the end means its lane B.
so, it’s due to sync words have errors.
could you please double check the data-rate, don’t you mentioned it’s 4-lane config in the beginning?
Thanks for answering.
Yes, the sensor is in a mode that outputs up to 800Mbps per lane. We will try to lower the data rate. But even so, do you know if there is any other configurable parameter (inside the device tree or even internal I2C registers) that could cause the sync word issue?
driver layer is taking pix_clk_hz (or, if you had serdes_pix_clk_hz) to setup CSI configuration internally.
Hi @JerryChang ,
Yes, we are modifying the pix_clk_hz to also match the sensor datarate, but still no success.
Would you know of something else that could help debug what exactly is not being processed by the SoC? We already flashed the image with debug but the information is basically the same as what we know so far.
did you meant the rce debug firmware?
could you please also attach the logs for reference, thanks
Hi @JerryChang ,
Please find attached the trace logs:
v4l-trace-logs.txt (27.8 KB)
And the dmesg logs:
  187.694936] ov64b1b 2-0036: ov64b1b_start_streaming:
[  187.695104] [RCE] VM0 deactivating.VM0 activating.NVCSILP clock rate = 408000000 Hz.
[  187.695162] [RCE] tegra_nvcsi_stream_set_config(vm0, stream=0, csi=0)
[  187.695191] [RCE] MIPI clock = 275000 kHz, tHS-SETTLE = 0, tCLK-SETTLE = 0
[  187.695212] [RCE] ===== NVCSI Stream Configuration =====
[  187.695232] [RCE] stream_id: PP 0, csi_port: PORT A
[  187.695251] [RCE] Brick: PHY 0, Mode: D-PHY
[  187.695271] [RCE] Partition: CIL A, LP bypass: Enabled, Lanes: 4
[  187.695291] [RCE] Clock information:
[  187.695310] [RCE] MIPI clock rate: 275.00 MHz
[  187.695330] [RCE] T_HS settle: 0, T_CLK settle: 0
[  187.695350] [RCE] ======================================
[  187.695369] [RCE] tegra_nvcsi_stream_open(vm0, stream=0, csi=0)
[  187.695389] [RCE] nvcsi_calc_ths_settle ths_settle 69
[  187.695408] [RCE] nvcsi_calc_ths_settle ths_settle 69
[  187.695427] [RCE] nvcsi_calc_ths_settle ths_settle 69
[  187.695446] [RCE] nvcsi_calc_tclk_settle tclk_settle 75
[  187.969001] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 131072
[  187.975508] [RCE] ISR PHY 0 CIL_A 0x110
[  187.979240] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 131072
[  187.989682] [RCE] ISR PHY 0 CIL_B 0x110
[  188.016572] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 131072
[  188.026817] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 131072
[  190.924061] ov64b1b 2-0036: ov64b1b_stop_streaming:
[  190.932863] bwmgr API not supported
[  190.943288] ov64b1b 2-0036: enable XSHUTDOWN
[  190.954818] [RCE] tegra_nvcsi_stream_close(vm0, stream=0, csi=0)
@JerryChang ,
We already changed the embedded metadata height and pixel clock and it did not fix the issue.
Best,
hello jdiegodelgado,
is it possible for moving to the latest Jetpack release, (i.e. JetPack 5.1.2) for verification.
this JP-5.1.2 release includes several camera bug fixes,
please see-also below for reference,
(1) Enhanced error resiliency for improved stability in Argus
(2) Support for multiple camera synchronization. (sample argus_syncstereo has added)
(3) Deskew calibration support for high data rate sensors (i.e. DPHY data-rate > 1.5 Gbps)
(4) Support for alternating exposures in Argus (sample argus_userAlternatingAutoexposure has added)
