Hi everyone,
I’m working on a university project to build an AI-Photobooth running fully on a Jetson AGX Orin (64GB). The core task is: Take a photo (Img2Img) → Apply style transform while preserving the face. I’m new to the Jetson Universe.
🚨 Direct Question: Speed & Quality on Edge Hardware
Has anyone achieved fast and efficient Img2Img processing on the Jetson without loss of facial identity?
We need near real-time performance (5s-30s), and any proven solutions for face preservation that run quickly and don’t balloon the memory footprint.
My Debugging Roadmap (Why I’m Struggling)
Here is a summary of the methods and models I have already attempted, which have led to roadblocks:
SDXL-Turbo / SDXL: Failed due to the size of the model and Unified Memory (VRAM/RAM) limitations on the Jetson. Or it failed because there was no functional IP-Adapter for SDXL-turbo (at least I didn’t found one)
SD 1.5 Base Model: Successfully loaded after optimization (
torch.float16and usingdevice_map="balanced"to avoid OOM errors). -
IP-Adapter Loading (via Hub): Failed repeatedly due to persistent Hugging Face Naming/Cache Conflicts, as the official
pipe.load_ip_adapter()could not locate the weight file. -
IP-Adapter Loading (Local Bypass): Failed even after manually downloading the
ip-adapter-plus_sd15.binfile to a local folder .
If you have experience with optimized pipelines or alternative methods, please share your workflow!
Thank you for your help!
