We would like to ask about AGX Orin network specifications. According to the application, we would like to modify the ethernet port MTU value to more than the default 1500 on my carrier board.
But we can’t modify the eth0 to 9000, it shows the max value on 1500 from the dmesg, although eth1 can do it.
From the datasheet, AGX Orin has 1GbE / 10GbE. Is it due to the eth0 using the standard frame type of frame-level bandwidth efficiency? Not the jumbo frame type?
The carrier board configuration. eth0 = 1GbE eth1 = 10GbE
The command to set up the MTU. sudo ifconfig eth0 down sudo ifconfig eth0 mtu 9000 SIOCSIFMTU: Invalid argument sudo ifconfig eth0 mtu 1000
(Just to set up a low value to finish the command) sudo ifconfig eth0 up
MTU log (1.8 KB)
From the log can see that eth0 can be the max value1500, and eth1 can be the max value 16383.
Is this the specification from AGX Orin? If not, how can I modify it?
Thanks, looking forward to your reply.
Thanks for your reply.
Ok, we will follow your advice to try it.
But just want to know if there is a limitation or a hardware specification. Because we didn’t see the configuration on the 1G port setup, so does NVIDIA not recommend the developer modify this configuration of the 1G port? Thanks in advance.
We did, and it works.
We just put the same configuration on the 1G setup, that’s it.
Currently, 1G port can set up the MTU to the max 16383.
For the network layer of MTU, we think if the 1G port can be set up to 16383 bytes there is a risk, we are not able to test does the 1g port can work with this specification.
If you have any idea, please share them with us, thank you.
