We used AGX 64GB devkit
When ORIN enters recovery mode for 1 minute, it will restart and enter the system normally.
The board designed by ourselves is controlled by one recovery button.
This will cause you to re-enter recovery mode after you have finished flashed master. (XAVIER doesn’t have this problem.)
Same problem as this one : Jetson AGX Orin can't turn into force recovery mode
Does same behavior happen on devkit?
Yes …
Which JetPack SW?
Reproduce rate?
JetPack 5.1.2
100% reproduce
If you’re reproducing it, use the orin development version. Use the recovery button to enter recovery mode. Does not insert the burn line, it will automatically restart into the system.
