Hello, I got a error flag from dmesg:
[ 471.802783] tegra194-vi5 15c10000.vi: vi_capture_ivc_status_callback: status chan_id 0 msg_id 2
[ 471.802794] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 0, err_data 131072
[ 471.802809] tegra194-vi5 15c10000.vi: descr->status.status: 14 frameid:0 flags:0, err_data:131072
[ 471.802839] tegra194-vi5 15c10000.vi: clay vi5_capture_dequeue: start
[ 471.802847] tegra194-vi5 15c10000.vi: vi_capture_status: waiting for status, timeout:7500 ms
[ 479.312339] tegra194-vi5 15c10000.vi: no reply from camera processor
[ 479.312541] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 7500 ms
[ 479.312742] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[ 479.315777] tegra194-vi5 15c10000.vi: vi_capture_shutdown--
[ 479.315813] tegra194-vi5 15c10000.vi: vi_capture_ivc_send_control: sending chan_id 0 msg_id 18
[ 479.316202] clay tegra_hsp_mailbox_notify **
Checked descr->status.status: 14 in the code, as it is
#define CAPTURE_STATUS_FALCON_ERROR U32_C(14)
What’s this mean of CAPTURE_STATUS_FALCON_ERROR? I cannot find more description on it.
Attached my trace log
# tracer: nop
# entries-in-buffer/entries-written: 473/473 #P:8
# _-----=> irqs-off
# / _----=> need-resched
# | / _---=> hardirq/softirq
# || / _--=> preempt-depth
# ||| / delay
# TASK-PID CPU# |||| TIMESTAMP FUNCTION
kworker/0:5-4013 [000] .... 459.900308: rtos_queue_peek_from_isr_failed: tstamp:15280722997 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 460.068280: rtos_queue_peek_from_isr_failed: tstamp:15285723005 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 460.180349: rtos_queue_peek_from_isr_failed: tstamp:15290723005 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 460.348299: rtos_queue_peek_from_isr_failed: tstamp:15295723001 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 460.516282: rtos_queue_peek_from_isr_failed: tstamp:15300723005 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 460.684313: rtos_queue_peek_from_isr_failed: tstamp:15305723001 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 460.852283: rtos_queue_peek_from_isr_failed: tstamp:15310723000 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 461.020284: rtos_queue_peek_from_isr_failed: tstamp:15315723000 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 461.188301: rtos_queue_peek_from_isr_failed: tstamp:15320723001 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 461.300292: rtos_queue_peek_from_isr_failed: tstamp:15325723003 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 461.468291: rtos_queue_peek_from_isr_failed: tstamp:15330723000 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 461.636304: rtos_queue_peek_from_isr_failed: tstamp:15335723004 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 461.804286: rtos_queue_peek_from_isr_failed: tstamp:15340723000 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 461.972307: rtos_queue_peek_from_isr_failed: tstamp:15345723003 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 462.140278: rtos_queue_peek_from_isr_failed: tstamp:15350723001 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 462.308281: rtos_queue_peek_from_isr_failed: tstamp:15355723005 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 462.420302: rtos_queue_peek_from_isr_failed: tstamp:15360723001 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 462.588278: rtos_queue_peek_from_isr_failed: tstamp:15365723001 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 462.756275: rtos_queue_peek_from_isr_failed: tstamp:15370723001 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 462.924291: rtos_queue_peek_from_isr_failed: tstamp:15375723001 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 463.092289: rtos_queue_peek_from_isr_failed: tstamp:15380723010 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 463.260285: rtos_queue_peek_from_isr_failed: tstamp:15385723000 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 463.428393: rtos_queue_peek_from_isr_failed: tstamp:15390723005 queue:0x0bcbbbb8
v4l2-ctl-9324 [002] .... 463.432097: tegra_channel_open: vi-output, DS5 mux 34-0010
v4l2-ctl-9324 [002] .... 463.432128: tegra_channel_set_power: DS5 mux 34-0010 : 0x1
v4l2-ctl-9324 [002] .... 463.432132: tegra_channel_set_power: 15a00000.nvcsi--4 : 0x1
v4l2-ctl-9324 [002] .... 463.432138: csi_s_power: enable : 0x1
v4l2-ctl-9324 [002] .... 463.438802: tegra_channel_capture_setup: vnc_id 0 W 1280 H 720 fmt 11
v4l2-ctl-9324 [002] .... 463.441513: tegra_channel_set_stream: enable : 0x1
v4l2-ctl-9324 [002] .... 463.441520: tegra_channel_set_stream: 15a00000.nvcsi--4 : 0x1
v4l2-ctl-9324 [002] .... 463.441525: csi_s_stream: enable : 0x1
v4l2-ctl-9324 [002] .... 463.441540: tegra_channel_set_stream: DS5 mux 34-0010 : 0x1
kworker/0:5-4013 [000] .... 463.484354: rtos_queue_send_from_isr_failed: tstamp:15392717103 queue:0x0bcb2e38
kworker/0:5-4013 [000] .... 463.484361: rtos_queue_send_from_isr_failed: tstamp:15392717404 queue:0x0bcb76a0
kworker/0:5-4013 [000] .... 463.484362: rtos_queue_send_from_isr_failed: tstamp:15392717704 queue:0x0bcb9220
kworker/0:5-4013 [000] .... 463.484364: rtos_queue_send_from_isr_failed: tstamp:15392718001 queue:0x0bcb9fe0
kworker/0:5-4013 [000] .... 463.484365: rtos_queue_send_from_isr_failed: tstamp:15392718298 queue:0x0bcbada0
kworker/0:5-4013 [000] .... 463.484369: rtcpu_string: tstamp:15392719091 id:0x04010000 str:"Configuring VI GoS.
kworker/0:5-4013 [000] .... 463.484418: rtcpu_string: tstamp:15392719533 id:0x04010000 str:"VM GOS[#0] addr=0xc2100000
kworker/0:5-4013 [000] .... 463.484479: rtcpu_string: tstamp:15392719954 id:0x04010000 str:"VM GOS[#1] addr=0xc2101000
kworker/0:5-4013 [000] .... 463.484489: rtcpu_string: tstamp:15392720365 id:0x04010000 str:"VM GOS[#2] addr=0xc2102000
kworker/0:5-4013 [000] .... 463.484499: rtcpu_string: tstamp:15392720776 id:0x04010000 str:"VM GOS[#3] addr=0xc2103000
kworker/0:5-4013 [000] .... 463.484507: rtcpu_string: tstamp:15392721243 id:0x04010000 str:"VM GOS[#4] addr=0xc2104000
kworker/0:5-4013 [000] .... 463.484515: rtcpu_string: tstamp:15392721649 id:0x04010000 str:"VM GOS[#5] addr=0xc2105000
kworker/0:5-4013 [000] .... 463.484523: rtcpu_string: tstamp:15392732943 id:0x04010000 str:"vi5_hwinit: firmware CL2018101701 protocol vers"
kworker/0:5-4013 [000] .... 463.484526: rtcpu_string: tstamp:15392733210 id:0x04010000 str:"on 2.2
kworker/0:5-4013 [000] .... 463.484535: rtos_queue_send_from_isr_failed: tstamp:15392790850 queue:0x0bcb2e38
kworker/0:5-4013 [000] .... 463.484564: rtos_queue_send_from_isr_failed: tstamp:15392791207 queue:0x0bcb76a0
kworker/0:5-4013 [000] .... 463.484565: rtos_queue_send_from_isr_failed: tstamp:15392791510 queue:0x0bcb9220
kworker/0:5-4013 [000] .... 463.484566: rtos_queue_send_from_isr_failed: tstamp:15392791806 queue:0x0bcb9fe0
kworker/0:5-4013 [000] .... 463.484567: rtos_queue_send_from_isr_failed: tstamp:15392792101 queue:0x0bcbada0
kworker/0:5-4013 [000] .... 463.484568: rtos_queue_send_from_isr_failed: tstamp:15392792454 queue:0x0bcb2dd0
kworker/0:5-4013 [000] .... 463.484569: rtos_queue_send_from_isr_failed: tstamp:15392792742 queue:0x0bcb2e38
kworker/0:5-4013 [000] .... 463.484570: rtos_queue_send_from_isr_failed: tstamp:15392793027 queue:0x0bcb7638
kworker/0:5-4013 [000] .... 463.484572: rtos_queue_send_from_isr_failed: tstamp:15392793319 queue:0x0bcb76a0
kworker/0:5-4013 [000] .... 463.484573: rtos_queue_send_from_isr_failed: tstamp:15392793607 queue:0x0bcb91b8
kworker/0:5-4013 [000] .... 463.484574: rtos_queue_send_from_isr_failed: tstamp:15392793888 queue:0x0bcb9220
kworker/0:5-4013 [000] .... 463.484575: rtos_queue_send_from_isr_failed: tstamp:15392794176 queue:0x0bcb9f78
kworker/0:5-4013 [000] .... 463.484576: rtos_queue_send_from_isr_failed: tstamp:15392794459 queue:0x0bcb9fe0
kworker/0:5-4013 [000] .... 463.484577: rtos_queue_send_from_isr_failed: tstamp:15392794744 queue:0x0bcbad38
kworker/0:5-4013 [000] .... 463.484578: rtos_queue_send_from_isr_failed: tstamp:15392795025 queue:0x0bcbada0
kworker/0:5-4013 [000] .... 463.484579: rtcpu_string: tstamp:15392800819 id:0x04010000 str:"VI GOS[#0] set to VM GOS[4] base 0xc2104000
kworker/0:5-4013 [000] .... 463.484594: rtcpu_vinotify_event: tstamp:15393045728 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:15828306560 data:0x10000000
kworker/0:5-4013 [000] .... 463.484595: rtcpu_vinotify_event: tstamp:15393046036 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:15828313408 data:0x31000001
kworker/0:5-4013 [000] .... 463.484597: rtcpu_vinotify_event: tstamp:15393046391 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:15828314400 data:0x07020001
kworker/0:5-4013 [000] .... 463.484598: rtcpu_vinotify_event: tstamp:15393046677 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:15828425792 data:0x10000000
kworker/0:5-4013 [000] .... 463.484599: rtcpu_vinotify_event: tstamp:15393047026 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:15828432672 data:0x31000002
kworker/0:5-4013 [000] .... 463.540304: rtos_queue_peek_from_isr_failed: tstamp:15395723001 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 463.708296: rtos_queue_peek_from_isr_failed: tstamp:15400723001 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 463.880420: rtos_queue_peek_from_isr_failed: tstamp:15405723000 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 463.992329: rtcpu_vinotify_event: tstamp:15409947970 tag:FS channel:0x02 frame:0 vi_tstamp:15409920163 data:0x00000010
kworker/0:5-4013 [000] .... 463.992337: rtcpu_vinotify_event: tstamp:15409948320 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:15409920163 data:0x00000000
kworker/0:5-4013 [000] .... 464.048310: rtcpu_vinotify_event: tstamp:15410573948 tag:FE channel:0x02 frame:0 vi_tstamp:15410325817 data:0x00000020
kworker/0:5-4013 [000] .... 464.048317: rtcpu_vinotify_event: tstamp:15410574356 tag:CHANSEL_SHORT_FRAME channel:0x81 frame:0 vi_tstamp:15410325817 data:0x01000000
kworker/0:5-4013 [000] .... 464.048319: rtcpu_vinotify_event: tstamp:15410574644 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:16389058336 data:0x01020001
kworker/0:5-4013 [000] .... 464.048321: rtcpu_vinotify_event: tstamp:15410574993 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:15410325817 data:0x00000000
kworker/0:5-4013 [000] .... 464.048326: rtos_queue_peek_from_isr_failed: tstamp:15410723000 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 464.216421: rtos_queue_peek_from_isr_failed: tstamp:15415723000 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 464.216437: rtcpu_vinotify_event: tstamp:15416207986 tag:FS channel:0x02 frame:0 vi_tstamp:15416131933 data:0x00000010
kworker/0:5-4013 [000] .... 464.216438: rtcpu_vinotify_event: tstamp:15416208337 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:15416131933 data:0x00000000
kworker/0:5-4013 [000] .... 464.216439: rtcpu_vinotify_event: tstamp:15416576428 tag:FE channel:0x02 frame:0 vi_tstamp:15416575718 data:0x00000020
kworker/0:5-4013 [000] .... 464.216441: rtcpu_vinotify_event: tstamp:15416576781 tag:CHANSEL_SHORT_FRAME channel:0x81 frame:0 vi_tstamp:15416575718 data:0x01000000
kworker/0:5-4013 [000] .... 464.216442: rtcpu_vinotify_event: tstamp:15416577069 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:16589055200 data:0x01020001
kworker/0:5-4013 [000] .... 464.216443: rtcpu_vinotify_event: tstamp:15416865335 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:15416575718 data:0x00000000
kworker/0:5-4013 [000] .... 464.388347: rtos_queue_peek_from_isr_failed: tstamp:15420723000 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 464.444305: rtcpu_vinotify_event: tstamp:15422499432 tag:FS channel:0x02 frame:0 vi_tstamp:15422381841 data:0x00000010
kworker/0:5-4013 [000] .... 464.444312: rtcpu_vinotify_event: tstamp:15423125366 tag:FE channel:0x02 frame:0 vi_tstamp:15422825626 data:0x00000020
kworker/0:5-4013 [000] .... 464.500329: rtos_queue_peek_from_isr_failed: tstamp:15425723003 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 464.612385: rtcpu_vinotify_event: tstamp:15428759465 tag:FS channel:0x02 frame:0 vi_tstamp:15428631742 data:0x00000010
kworker/0:5-4013 [000] .... 464.668329: rtcpu_vinotify_event: tstamp:15429385503 tag:FE channel:0x02 frame:0 vi_tstamp:15429075527 data:0x00000020
kworker/0:5-4013 [000] .... 464.668336: rtos_queue_peek_from_isr_failed: tstamp:15430722996 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 464.836278: rtcpu_vinotify_event: tstamp:15435019607 tag:FS channel:0x02 frame:0 vi_tstamp:15434881651 data:0x00000010
kworker/0:5-4013 [000] .... 464.836283: rtcpu_vinotify_event: tstamp:15435332529 tag:FE channel:0x02 frame:0 vi_tstamp:15435325435 data:0x00000020
kworker/0:5-4013 [000] .... 464.836286: rtos_queue_peek_from_isr_failed: tstamp:15435722996 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 465.004281: rtos_queue_peek_from_isr_failed: tstamp:15440723004 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 465.004286: rtcpu_vinotify_event: tstamp:15441279642 tag:FS channel:0x02 frame:0 vi_tstamp:15441131552 data:0x00000010
kworker/0:5-4013 [000] .... 465.004288: rtcpu_vinotify_event: tstamp:15441592665 tag:FE channel:0x02 frame:0 vi_tstamp:15441575343 data:0x00000020
kworker/0:5-4013 [000] .... 465.172291: rtos_queue_peek_from_isr_failed: tstamp:15445722999 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 465.228321: rtcpu_vinotify_event: tstamp:15447539687 tag:FS channel:0x02 frame:0 vi_tstamp:15447381461 data:0x00000010
kworker/0:5-4013 [000] .... 465.228323: rtcpu_vinotify_event: tstamp:15447852715 tag:FE channel:0x02 frame:0 vi_tstamp:15447825246 data:0x00000020
kworker/0:5-4013 [000] .... 465.340276: rtos_queue_peek_from_isr_failed: tstamp:15450722997 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 465.396292: rtcpu_vinotify_event: tstamp:15453799828 tag:FS channel:0x02 frame:0 vi_tstamp:15453631362 data:0x00000010
kworker/0:5-4013 [000] .... 465.452313: rtcpu_vinotify_event: tstamp:15454112856 tag:FE channel:0x02 frame:0 vi_tstamp:15454075154 data:0x00000020
kworker/0:5-4013 [000] .... 465.508287: rtos_queue_peek_from_isr_failed: tstamp:15455723004 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 465.620316: rtcpu_vinotify_event: tstamp:15460059937 tag:FS channel:0x02 frame:0 vi_tstamp:15459881270 data:0x00000010
kworker/0:5-4013 [000] .... 465.620321: rtcpu_vinotify_event: tstamp:15460372903 tag:FE channel:0x02 frame:0 vi_tstamp:15460325055 data:0x00000020
kworker/0:5-4013 [000] .... 465.620324: rtos_queue_peek_from_isr_failed: tstamp:15460723001 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 465.788416: rtos_queue_peek_from_isr_failed: tstamp:15465722999 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 465.844323: rtcpu_vinotify_event: tstamp:15466131823 tag:FS channel:0x02 frame:0 vi_tstamp:15466131172 data:0x00000010
kworker/0:5-4013 [000] .... 465.844326: rtcpu_vinotify_event: tstamp:15466601706 tag:FE channel:0x02 frame:0 vi_tstamp:15466574963 data:0x00000020
kworker/0:5-4013 [000] .... 465.956300: rtos_queue_peek_from_isr_failed: tstamp:15470723000 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 466.012291: rtcpu_vinotify_event: tstamp:15472548836 tag:FS channel:0x02 frame:0 vi_tstamp:15472381080 data:0x00000010
kworker/0:5-4013 [000] .... 466.012294: rtcpu_vinotify_event: tstamp:15472861763 tag:FE channel:0x02 frame:0 vi_tstamp:15472824865 data:0x00000020
kworker/0:5-4013 [000] .... 466.124317: rtos_queue_peek_from_isr_failed: tstamp:15475723003 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 466.236292: rtcpu_vinotify_event: tstamp:15478808927 tag:FS channel:0x02 frame:0 vi_tstamp:15478630981 data:0x00000010
kworker/0:5-4013 [000] .... 466.236295: rtcpu_vinotify_event: tstamp:15479121991 tag:FE channel:0x02 frame:0 vi_tstamp:15479074774 data:0x00000020
kworker/0:5-4013 [000] .... 466.292309: rtos_queue_peek_from_isr_failed: tstamp:15480723000 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 466.404284: rtcpu_vinotify_event: tstamp:15485069004 tag:FS channel:0x02 frame:0 vi_tstamp:15484880889 data:0x00000010
kworker/0:5-4013 [000] .... 466.460321: rtcpu_vinotify_event: tstamp:15485382029 tag:FE channel:0x02 frame:0 vi_tstamp:15485324674 data:0x00000020
kworker/0:5-4013 [000] .... 466.460324: rtos_queue_peek_from_isr_failed: tstamp:15485723000 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 466.628284: rtos_queue_peek_from_isr_failed: tstamp:15490723000 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 466.628289: rtcpu_vinotify_event: tstamp:15491329170 tag:FS channel:0x02 frame:0 vi_tstamp:15491130792 data:0x00000010
kworker/0:5-4013 [000] .... 466.628291: rtcpu_vinotify_event: tstamp:15491642192 tag:FE channel:0x02 frame:0 vi_tstamp:15491574583 data:0x00000020
kworker/0:5-4013 [000] .... 466.740283: rtos_queue_peek_from_isr_failed: tstamp:15495723003 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 466.796317: rtcpu_vinotify_event: tstamp:15497589240 tag:FS channel:0x02 frame:0 vi_tstamp:15497380700 data:0x00000010
kworker/0:5-4013 [000] .... 466.852281: rtcpu_vinotify_event: tstamp:15497902253 tag:FE channel:0x02 frame:0 vi_tstamp:15497824484 data:0x00000020
kworker/0:5-4013 [000] .... 466.908507: rtos_queue_peek_from_isr_failed: tstamp:15500723006 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 467.020317: rtcpu_vinotify_event: tstamp:15503849406 tag:FS channel:0x02 frame:0 vi_tstamp:15503630608 data:0x00000010
kworker/0:5-4013 [000] .... 467.020320: rtcpu_vinotify_event: tstamp:15504162416 tag:FE channel:0x02 frame:0 vi_tstamp:15504074393 data:0x00000020
kworker/0:5-4013 [000] .... 467.076289: rtos_queue_peek_from_isr_failed: tstamp:15505723001 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 467.244291: rtcpu_vinotify_event: tstamp:15510109491 tag:FS channel:0x02 frame:0 vi_tstamp:15509880509 data:0x00000010
kworker/0:5-4013 [000] .... 467.244294: rtcpu_vinotify_event: tstamp:15510422519 tag:FE channel:0x02 frame:0 vi_tstamp:15510324301 data:0x00000020
kworker/0:5-4013 [000] .... 467.244341: rtos_queue_peek_from_isr_failed: tstamp:15510723000 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 467.412285: rtos_queue_peek_from_isr_failed: tstamp:15515723001 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 467.412288: rtcpu_vinotify_event: tstamp:15516131077 tag:FS channel:0x02 frame:0 vi_tstamp:15516130418 data:0x00000010
kworker/0:5-4013 [000] .... 467.412290: rtcpu_vinotify_event: tstamp:15516588691 tag:FE channel:0x02 frame:0 vi_tstamp:15516574203 data:0x00000020
kworker/0:5-4013 [000] .... 467.580357: rtos_queue_peek_from_isr_failed: tstamp:15520723003 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 467.636323: rtcpu_vinotify_event: tstamp:15522535810 tag:FS channel:0x02 frame:0 vi_tstamp:15522380320 data:0x00000010
kworker/0:5-4013 [000] .... 467.636326: rtcpu_vinotify_event: tstamp:15522848830 tag:FE channel:0x02 frame:0 vi_tstamp:15522824111 data:0x00000020
kworker/0:5-4013 [000] .... 467.748300: rtos_queue_peek_from_isr_failed: tstamp:15525723012 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 467.804449: rtcpu_vinotify_event: tstamp:15528795859 tag:FS channel:0x02 frame:0 vi_tstamp:15528630228 data:0x00000010
kworker/0:5-4013 [000] .... 467.804455: rtcpu_vinotify_event: tstamp:15529108879 tag:FE channel:0x02 frame:0 vi_tstamp:15529074013 data:0x00000020
kworker/0:5-4013 [000] .... 467.860400: rtos_queue_peek_from_isr_failed: tstamp:15530722999 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 468.028289: rtcpu_vinotify_event: tstamp:15535056004 tag:FS channel:0x02 frame:0 vi_tstamp:15534880130 data:0x00000010
kworker/0:5-4013 [000] .... 468.028293: rtcpu_vinotify_event: tstamp:15535368939 tag:FE channel:0x02 frame:0 vi_tstamp:15535323921 data:0x00000020
kworker/0:5-4013 [000] .... 468.028295: rtos_queue_peek_from_isr_failed: tstamp:15535722996 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 468.196280: rtos_queue_peek_from_isr_failed: tstamp:15540723003 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 468.196284: rtcpu_vinotify_event: tstamp:15541316056 tag:FS channel:0x02 frame:0 vi_tstamp:15541130038 data:0x00000010
kworker/0:5-4013 [000] .... 468.252289: rtcpu_vinotify_event: tstamp:15541629080 tag:FE channel:0x02 frame:0 vi_tstamp:15541573823 data:0x00000020
kworker/0:5-4013 [000] .... 468.364298: rtos_queue_peek_from_isr_failed: tstamp:15545723000 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 468.420290: rtcpu_vinotify_event: tstamp:15547576203 tag:FS channel:0x02 frame:0 vi_tstamp:15547379940 data:0x00000010
kworker/0:5-4013 [000] .... 468.420293: rtcpu_vinotify_event: tstamp:15547889126 tag:FE channel:0x02 frame:0 vi_tstamp:15547823732 data:0x00000020
kworker/0:5-4013 [000] .... 468.532284: rtos_queue_peek_from_isr_failed: tstamp:15550722999 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 468.644301: rtcpu_vinotify_event: tstamp:15553836244 tag:FS channel:0x02 frame:0 vi_tstamp:15553629848 data:0x00000010
kworker/0:5-4013 [000] .... 468.644303: rtcpu_vinotify_event: tstamp:15554149264 tag:FE channel:0x02 frame:0 vi_tstamp:15554073633 data:0x00000020
kworker/0:5-4013 [000] .... 468.700282: rtos_queue_peek_from_isr_failed: tstamp:15555723003 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 468.812285: rtcpu_vinotify_event: tstamp:15560096296 tag:FS channel:0x02 frame:0 vi_tstamp:15559879750 data:0x00000010
kworker/0:5-4013 [000] .... 468.812288: rtcpu_vinotify_event: tstamp:15560409320 tag:FE channel:0x02 frame:0 vi_tstamp:15560323542 data:0x00000020
kworker/0:5-4013 [000] .... 468.868301: rtos_queue_peek_from_isr_failed: tstamp:15560722996 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 468.980292: rtos_queue_peek_from_isr_failed: tstamp:15565723003 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 469.036312: rtcpu_vinotify_event: tstamp:15566130312 tag:FS channel:0x02 frame:0 vi_tstamp:15566129659 data:0x00000010
kworker/0:5-4013 [000] .... 469.036316: rtcpu_vinotify_event: tstamp:15566575479 tag:FE channel:0x02 frame:0 vi_tstamp:15566573443 data:0x00000020
kworker/0:5-4013 [000] .... 469.148308: rtos_queue_peek_from_isr_failed: tstamp:15570723000 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 469.204292: rtcpu_vinotify_event: tstamp:15572522603 tag:FS channel:0x02 frame:0 vi_tstamp:15572379560 data:0x00000010
kworker/0:5-4013 [000] .... 469.204295: rtcpu_vinotify_event: tstamp:15572835624 tag:FE channel:0x02 frame:0 vi_tstamp:15572823353 data:0x00000020
kworker/0:5-4013 [000] .... 469.316307: rtos_queue_peek_from_isr_failed: tstamp:15575723001 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 469.428357: rtcpu_vinotify_event: tstamp:15578782739 tag:FS channel:0x02 frame:0 vi_tstamp:15578629469 data:0x00000010
kworker/0:5-4013 [000] .... 469.428362: rtcpu_vinotify_event: tstamp:15579095671 tag:FE channel:0x02 frame:0 vi_tstamp:15579073254 data:0x00000020
kworker/0:5-4013 [000] .... 469.484313: rtos_queue_peek_from_isr_failed: tstamp:15580723001 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 469.596393: rtcpu_vinotify_event: tstamp:15585042786 tag:FS channel:0x02 frame:0 vi_tstamp:15584879377 data:0x00000010
kworker/0:5-4013 [000] .... 469.652310: rtcpu_vinotify_event: tstamp:15585355809 tag:FE channel:0x02 frame:0 vi_tstamp:15585323163 data:0x00000020
kworker/0:5-4013 [000] .... 469.652314: rtos_queue_peek_from_isr_failed: tstamp:15585723001 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 469.820332: rtos_queue_peek_from_isr_failed: tstamp:15590722957 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 469.820345: rtcpu_vinotify_event: tstamp:15591302774 tag:FS channel:0x02 frame:0 vi_tstamp:15591129280 data:0x00000010
kworker/0:5-4013 [000] .... 469.820346: rtcpu_vinotify_event: tstamp:15591615797 tag:FE channel:0x02 frame:0 vi_tstamp:15591573071 data:0x00000020
kworker/0:5-4013 [000] .... 469.988285: rtos_queue_peek_from_isr_failed: tstamp:15595722961 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 470.044305: rtcpu_vinotify_event: tstamp:15597562908 tag:FS channel:0x02 frame:0 vi_tstamp:15597379188 data:0x00000010
kworker/0:5-4013 [000] .... 470.044309: rtcpu_vinotify_event: tstamp:15597875925 tag:FE channel:0x02 frame:0 vi_tstamp:15597822973 data:0x00000020
kworker/0:5-4013 [000] .... 470.100290: rtos_queue_peek_from_isr_failed: tstamp:15600722964 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 470.212286: rtcpu_vinotify_event: tstamp:15603822959 tag:FS channel:0x02 frame:0 vi_tstamp:15603629090 data:0x00000010
kworker/0:5-4013 [000] .... 470.212289: rtcpu_vinotify_event: tstamp:15604135968 tag:FE channel:0x02 frame:0 vi_tstamp:15604072881 data:0x00000020
kworker/0:5-4013 [000] .... 470.268280: rtos_queue_peek_from_isr_failed: tstamp:15605723000 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 470.436288: rtcpu_vinotify_event: tstamp:15610083149 tag:FS channel:0x02 frame:0 vi_tstamp:15609878998 data:0x00000010
kworker/0:5-4013 [000] .... 470.436294: rtcpu_vinotify_event: tstamp:15610396082 tag:FE channel:0x02 frame:0 vi_tstamp:15610322783 data:0x00000020
kworker/0:5-4013 [000] .... 470.436297: rtos_queue_peek_from_isr_failed: tstamp:15610723000 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 470.604294: rtos_queue_peek_from_isr_failed: tstamp:15615722997 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 470.604299: rtcpu_vinotify_event: tstamp:15616129556 tag:FS channel:0x02 frame:0 vi_tstamp:15616128900 data:0x00000010
kworker/0:5-4013 [000] .... 470.604301: rtcpu_vinotify_event: tstamp:15616593608 tag:FE channel:0x02 frame:0 vi_tstamp:15616572693 data:0x00000020
kworker/0:5-4013 [000] .... 470.772313: rtos_queue_peek_from_isr_failed: tstamp:15620723000 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 470.828345: rtcpu_vinotify_event: tstamp:15622540713 tag:FS channel:0x02 frame:0 vi_tstamp:15622378809 data:0x00000010
kworker/0:5-4013 [000] .... 470.828350: rtcpu_vinotify_event: tstamp:15622853731 tag:FE channel:0x02 frame:0 vi_tstamp:15622822594 data:0x00000020
kworker/0:5-4013 [000] .... 470.940318: rtos_queue_peek_from_isr_failed: tstamp:15625723001 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 470.996304: rtcpu_vinotify_event: tstamp:15628800759 tag:FS channel:0x02 frame:0 vi_tstamp:15628628711 data:0x00000010
kworker/0:5-4013 [000] .... 471.052313: rtcpu_vinotify_event: tstamp:15629113783 tag:FE channel:0x02 frame:0 vi_tstamp:15629072503 data:0x00000020
kworker/0:5-4013 [000] .... 471.108299: rtos_queue_peek_from_isr_failed: tstamp:15630723001 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 471.220319: rtcpu_vinotify_event: tstamp:15635060898 tag:FS channel:0x02 frame:0 vi_tstamp:15634878620 data:0x00000010
kworker/0:5-4013 [000] .... 471.220322: rtcpu_vinotify_event: tstamp:15635373827 tag:FE channel:0x02 frame:0 vi_tstamp:15635322405 data:0x00000020
kworker/0:5-4013 [000] .... 471.220359: rtos_queue_peek_from_isr_failed: tstamp:15635723000 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 471.388276: rtos_queue_peek_from_isr_failed: tstamp:15640723001 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 471.444302: rtcpu_vinotify_event: tstamp:15641320946 tag:FS channel:0x02 frame:0 vi_tstamp:15641128521 data:0x00000010
kworker/0:5-4013 [000] .... 471.444305: rtcpu_vinotify_event: tstamp:15641633975 tag:FE channel:0x02 frame:0 vi_tstamp:15641572313 data:0x00000020
kworker/0:5-4013 [000] .... 471.556338: rtos_queue_peek_from_isr_failed: tstamp:15645723001 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 471.612300: rtcpu_vinotify_event: tstamp:15647580990 tag:FS channel:0x02 frame:0 vi_tstamp:15647378430 data:0x00000010
kworker/0:5-4013 [000] .... 471.612304: rtcpu_vinotify_event: tstamp:15647894020 tag:FE channel:0x02 frame:0 vi_tstamp:15647822215 data:0x00000020
vi-output, DS5 -9326 [002] .... 471.637598: tegra_channel_capture_setup: vnc_id 0 W 1280 H 720 fmt 11
kworker/0:5-4013 [000] .... 471.668353: rtos_queue_send_from_isr_failed: tstamp:15648846082 queue:0x0bcb2e38
kworker/0:5-4013 [000] .... 471.668359: rtos_queue_send_from_isr_failed: tstamp:15648846387 queue:0x0bcb76a0
kworker/0:5-4013 [000] .... 471.668360: rtos_queue_send_from_isr_failed: tstamp:15648846693 queue:0x0bcb9220
kworker/0:5-4013 [000] .... 471.668362: rtos_queue_send_from_isr_failed: tstamp:15648846995 queue:0x0bcb9fe0
kworker/0:5-4013 [000] .... 471.668363: rtos_queue_send_from_isr_failed: tstamp:15648847293 queue:0x0bcbada0
kworker/0:5-4013 [000] .... 471.668364: rtos_queue_send_from_isr_failed: tstamp:15648847651 queue:0x0bcb2dd0
kworker/0:5-4013 [000] .... 471.668365: rtos_queue_send_from_isr_failed: tstamp:15648847940 queue:0x0bcb2e38
kworker/0:5-4013 [000] .... 471.668367: rtos_queue_send_from_isr_failed: tstamp:15648848230 queue:0x0bcb7638
kworker/0:5-4013 [000] .... 471.668368: rtos_queue_send_from_isr_failed: tstamp:15648848517 queue:0x0bcb76a0
kworker/0:5-4013 [000] .... 471.668369: rtos_queue_send_from_isr_failed: tstamp:15648848808 queue:0x0bcb91b8
kworker/0:5-4013 [000] .... 471.668370: rtos_queue_send_from_isr_failed: tstamp:15648849093 queue:0x0bcb9220
kworker/0:5-4013 [000] .... 471.668371: rtos_queue_send_from_isr_failed: tstamp:15648849421 queue:0x0bcb9f78
kworker/0:5-4013 [000] .... 471.668372: rtos_queue_send_from_isr_failed: tstamp:15648849714 queue:0x0bcb9fe0
kworker/0:5-4013 [000] .... 471.668373: rtos_queue_send_from_isr_failed: tstamp:15648849999 queue:0x0bcbad38
kworker/0:5-4013 [000] .... 471.668374: rtos_queue_send_from_isr_failed: tstamp:15648850283 queue:0x0bcbada0
kworker/0:5-4013 [000] .... 471.668416: rtos_queue_send_from_isr_failed: tstamp:15648883813 queue:0x0bcb2e38
kworker/0:5-4013 [000] .... 471.668417: rtos_queue_send_from_isr_failed: tstamp:15648884115 queue:0x0bcb76a0
kworker/0:5-4013 [000] .... 471.668419: rtos_queue_send_from_isr_failed: tstamp:15648884417 queue:0x0bcb9220
kworker/0:5-4013 [000] .... 471.668420: rtos_queue_send_from_isr_failed: tstamp:15648884718 queue:0x0bcb9fe0
kworker/0:5-4013 [000] .... 471.668421: rtos_queue_send_from_isr_failed: tstamp:15648885015 queue:0x0bcbada0
kworker/0:5-4013 [000] .... 471.668422: rtos_queue_send_from_isr_failed: tstamp:15648913721 queue:0x0bcb2e38
kworker/0:5-4013 [000] .... 471.668423: rtos_queue_send_from_isr_failed: tstamp:15648914024 queue:0x0bcb76a0
kworker/0:5-4013 [000] .... 471.668424: rtos_queue_send_from_isr_failed: tstamp:15648914329 queue:0x0bcb9220
kworker/0:5-4013 [000] .... 471.668425: rtos_queue_send_from_isr_failed: tstamp:15648914627 queue:0x0bcb9fe0
kworker/0:5-4013 [000] .... 471.668426: rtos_queue_send_from_isr_failed: tstamp:15648914928 queue:0x0bcbada0
kworker/0:5-4013 [000] .... 471.668427: rtos_queue_send_from_isr_failed: tstamp:15648929727 queue:0x0bcb2e38
kworker/0:5-4013 [000] .... 471.668462: rtos_queue_send_from_isr_failed: tstamp:15648930028 queue:0x0bcb76a0
kworker/0:5-4013 [000] .... 471.668463: rtos_queue_send_from_isr_failed: tstamp:15648930337 queue:0x0bcb9220
kworker/0:5-4013 [000] .... 471.668464: rtos_queue_send_from_isr_failed: tstamp:15648930634 queue:0x0bcb9fe0
kworker/0:5-4013 [000] .... 471.668465: rtos_queue_send_from_isr_failed: tstamp:15648930930 queue:0x0bcbada0
kworker/0:5-4013 [000] .... 471.668469: rtcpu_string: tstamp:15648931738 id:0x04010000 str:"Configuring VI GoS.
kworker/0:5-4013 [000] .... 471.668512: rtcpu_string: tstamp:15648932187 id:0x04010000 str:"VM GOS[#0] addr=0xc2100000
kworker/0:5-4013 [000] .... 471.668523: rtcpu_string: tstamp:15648932614 id:0x04010000 str:"VM GOS[#1] addr=0xc2101000
kworker/0:5-4013 [000] .... 471.668533: rtcpu_string: tstamp:15648933026 id:0x04010000 str:"VM GOS[#2] addr=0xc2102000
kworker/0:5-4013 [000] .... 471.668541: rtcpu_string: tstamp:15648933442 id:0x04010000 str:"VM GOS[#3] addr=0xc2103000
kworker/0:5-4013 [000] .... 471.668551: rtcpu_string: tstamp:15648933915 id:0x04010000 str:"VM GOS[#4] addr=0xc2104000
kworker/0:5-4013 [000] .... 471.668559: rtcpu_string: tstamp:15648934364 id:0x04010000 str:"VM GOS[#5] addr=0xc2105000
kworker/0:5-4013 [000] .... 471.668567: rtos_queue_send_from_isr_failed: tstamp:15648940098 queue:0x0bcb2e38
kworker/0:5-4013 [000] .... 471.668569: rtos_queue_send_from_isr_failed: tstamp:15648940396 queue:0x0bcb76a0
kworker/0:5-4013 [000] .... 471.668570: rtos_queue_send_from_isr_failed: tstamp:15648940697 queue:0x0bcb9220
kworker/0:5-4013 [000] .... 471.668571: rtos_queue_send_from_isr_failed: tstamp:15648940993 queue:0x0bcb9fe0
kworker/0:5-4013 [000] .... 471.668572: rtos_queue_send_from_isr_failed: tstamp:15648941288 queue:0x0bcbada0
kworker/0:5-4013 [000] .... 471.668575: rtcpu_vinotify_event: tstamp:15648947441 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:15434900288 data:0x10000000
kworker/0:5-4013 [000] .... 471.668577: rtcpu_vinotify_event: tstamp:15648947809 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:15434907104 data:0x31000001
kworker/0:5-4013 [000] .... 471.668578: rtcpu_vinotify_event: tstamp:15648948106 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:15434908096 data:0x07020001
kworker/0:5-4013 [000] .... 471.668579: rtcpu_vinotify_event: tstamp:15648948463 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:15434984640 data:0x10000000
kworker/0:5-4013 [000] .... 471.668581: rtcpu_vinotify_event: tstamp:15648948748 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:15434991552 data:0x31000002
kworker/0:5-4013 [000] .... 471.724285: rtos_queue_peek_from_isr_failed: tstamp:15650723000 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 471.836366: rtcpu_vinotify_event: tstamp:15653653329 tag:FS channel:0x02 frame:0 vi_tstamp:15653628332 data:0x00000010
kworker/0:5-4013 [000] .... 471.836372: rtcpu_vinotify_event: tstamp:15653653626 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:15653628332 data:0x00000000
kworker/0:5-4013 [000] .... 471.836373: rtcpu_vinotify_event: tstamp:15654279347 tag:FE channel:0x02 frame:0 vi_tstamp:15654072124 data:0x00000020
kworker/0:5-4013 [000] .... 471.836375: rtcpu_vinotify_event: tstamp:15654279643 tag:CHANSEL_SHORT_FRAME channel:0x81 frame:0 vi_tstamp:15654072124 data:0x01000000
kworker/0:5-4013 [000] .... 471.836376: rtcpu_vinotify_event: tstamp:15654279996 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:15599005568 data:0x01020001
kworker/0:5-4013 [000] .... 471.836377: rtcpu_vinotify_event: tstamp:15654280290 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:15654072124 data:0x00000000
kworker/0:5-4013 [000] .... 471.892302: rtos_queue_peek_from_isr_failed: tstamp:15655723004 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 472.004303: rtcpu_vinotify_event: tstamp:15659913397 tag:FS channel:0x02 frame:0 vi_tstamp:15659878240 data:0x00000010
kworker/0:5-4013 [000] .... 472.004308: rtcpu_vinotify_event: tstamp:15659913695 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:15659878241 data:0x00000000
kworker/0:5-4013 [000] .... 472.060320: rtcpu_vinotify_event: tstamp:15660539442 tag:FE channel:0x02 frame:0 vi_tstamp:15660322026 data:0x00000020
kworker/0:5-4013 [000] .... 472.060323: rtcpu_vinotify_event: tstamp:15660539739 tag:CHANSEL_SHORT_FRAME channel:0x81 frame:0 vi_tstamp:15660322026 data:0x01000000
kworker/0:5-4013 [000] .... 472.060325: rtcpu_vinotify_event: tstamp:15660540099 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:15799002464 data:0x01020001
kworker/0:5-4013 [000] .... 472.060326: rtcpu_vinotify_event: tstamp:15660540388 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:15660322026 data:0x00000000
kworker/0:5-4013 [000] .... 472.060329: rtos_queue_peek_from_isr_failed: tstamp:15660723003 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 472.228301: rtos_queue_peek_from_isr_failed: tstamp:15665723003 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 472.228307: rtcpu_vinotify_event: tstamp:15666173456 tag:FS channel:0x02 frame:0 vi_tstamp:15666128148 data:0x00000010
kworker/0:5-4013 [000] .... 472.228309: rtcpu_vinotify_event: tstamp:15666799489 tag:FE channel:0x02 frame:0 vi_tstamp:15666571934 data:0x00000020
kworker/0:5-4013 [000] .... 472.340294: rtos_queue_peek_from_isr_failed: tstamp:15670723005 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 472.396297: rtcpu_vinotify_event: tstamp:15672433586 tag:FS channel:0x02 frame:0 vi_tstamp:15672378052 data:0x00000010
kworker/0:5-4013 [000] .... 472.452281: rtcpu_vinotify_event: tstamp:15672822488 tag:FE channel:0x02 frame:0 vi_tstamp:15672821836 data:0x00000020
kworker/0:5-4013 [000] .... 472.508298: rtos_queue_peek_from_isr_failed: tstamp:15675723004 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 472.620333: rtcpu_vinotify_event: tstamp:15678631063 tag:FS channel:0x02 frame:0 vi_tstamp:15678627960 data:0x00000010
kworker/0:5-4013 [000] .... 472.620338: rtcpu_vinotify_event: tstamp:15679257007 tag:FE channel:0x02 frame:0 vi_tstamp:15679071745 data:0x00000020
kworker/0:5-4013 [000] .... 472.676297: rtos_queue_peek_from_isr_failed: tstamp:15680723004 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 472.844308: rtcpu_vinotify_event: tstamp:15684891112 tag:FS channel:0x02 frame:0 vi_tstamp:15684877862 data:0x00000010
kworker/0:5-4013 [000] .... 472.844314: rtcpu_vinotify_event: tstamp:15685517139 tag:FE channel:0x02 frame:0 vi_tstamp:15685321653 data:0x00000020
kworker/0:5-4013 [000] .... 472.844317: rtos_queue_peek_from_isr_failed: tstamp:15685723003 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 473.012297: rtos_queue_peek_from_isr_failed: tstamp:15690723041 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 473.012304: rtcpu_vinotify_event: tstamp:15691151246 tag:FS channel:0x02 frame:0 vi_tstamp:15691127771 data:0x00000010
kworker/0:5-4013 [000] .... 473.012306: rtcpu_vinotify_event: tstamp:15691777196 tag:FE channel:0x02 frame:0 vi_tstamp:15691571556 data:0x00000020
kworker/0:5-4013 [000] .... 473.180285: rtos_queue_peek_from_isr_failed: tstamp:15695723001 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 473.236289: rtcpu_vinotify_event: tstamp:15697411296 tag:FS channel:0x02 frame:0 vi_tstamp:15697377672 data:0x00000010
kworker/0:5-4013 [000] .... 473.236291: rtcpu_vinotify_event: tstamp:15698037330 tag:FE channel:0x02 frame:0 vi_tstamp:15697821465 data:0x00000020
kworker/0:5-4013 [000] .... 473.348315: rtos_queue_peek_from_isr_failed: tstamp:15700723001 queue:0x0bcbbbb8
v4l2-ctl-9324 [001] .... 473.404177: tegra_channel_close: vi-output, DS5 mux 34-0010
kworker/0:5-4013 [000] .... 473.404475: rtcpu_vinotify_event: tstamp:15703671357 tag:FS channel:0x02 frame:0 vi_tstamp:15703627581 data:0x00000010
kworker/0:5-4013 [000] .... 473.460286: rtcpu_vinotify_event: tstamp:15704297385 tag:FE channel:0x02 frame:0 vi_tstamp:15704071366 data:0x00000020
kworker/0:5-4013 [000] .... 473.460291: rtos_queue_peek_from_isr_failed: tstamp:15705722997 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 473.628277: rtcpu_vinotify_event: tstamp:15709931493 tag:FS channel:0x02 frame:0 vi_tstamp:15709877483 data:0x00000010
kworker/0:5-4013 [000] .... 473.628282: rtcpu_vinotify_event: tstamp:15710557441 tag:FE channel:0x02 frame:0 vi_tstamp:15710321275 data:0x00000020
kworker/0:5-4013 [000] .... 473.628284: rtos_queue_peek_from_isr_failed: tstamp:15710723005 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 473.796274: rtos_queue_peek_from_isr_failed: tstamp:15715723003 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 473.796278: rtcpu_vinotify_event: tstamp:15716191541 tag:FS channel:0x02 frame:0 vi_tstamp:15716127392 data:0x00000010
kworker/0:5-4013 [000] .... 473.852272: rtcpu_vinotify_event: tstamp:15716817570 tag:FE channel:0x02 frame:0 vi_tstamp:15716571177 data:0x00000020
kworker/0:5-4013 [000] .... 473.964280: rtos_queue_peek_from_isr_failed: tstamp:15720723012 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 474.020280: rtcpu_vinotify_event: tstamp:15722451676 tag:FS channel:0x02 frame:0 vi_tstamp:15722377294 data:0x00000010
kworker/0:5-4013 [000] .... 474.020283: rtcpu_vinotify_event: tstamp:15722821736 tag:FE channel:0x02 frame:0 vi_tstamp:15722821086 data:0x00000020
kworker/0:5-4013 [000] .... 474.132307: rtos_queue_peek_from_isr_failed: tstamp:15725723000 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 474.244279: rtcpu_vinotify_event: tstamp:15728649159 tag:FS channel:0x02 frame:0 vi_tstamp:15728627203 data:0x00000010
kworker/0:5-4013 [000] .... 474.244281: rtcpu_vinotify_event: tstamp:15729275098 tag:FE channel:0x02 frame:0 vi_tstamp:15729070987 data:0x00000020
kworker/0:5-4013 [000] .... 474.300279: rtos_queue_peek_from_isr_failed: tstamp:15730723003 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 474.412288: rtcpu_vinotify_event: tstamp:15734909202 tag:FS channel:0x02 frame:0 vi_tstamp:15734877104 data:0x00000010
kworker/0:5-4013 [000] .... 474.412291: rtcpu_vinotify_event: tstamp:15735535234 tag:FE channel:0x02 frame:0 vi_tstamp:15735320897 data:0x00000020
kworker/0:5-4013 [000] .... 474.468272: rtos_queue_peek_from_isr_failed: tstamp:15735723010 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 474.580286: rtos_queue_peek_from_isr_failed: tstamp:15740722996 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 474.636288: rtcpu_vinotify_event: tstamp:15741169255 tag:FS channel:0x02 frame:0 vi_tstamp:15741127013 data:0x00000010
kworker/0:5-4013 [000] .... 474.636291: rtcpu_vinotify_event: tstamp:15741795295 tag:FE channel:0x02 frame:0 vi_tstamp:15741570798 data:0x00000020
kworker/0:5-4013 [000] .... 474.748273: rtos_queue_peek_from_isr_failed: tstamp:15745723000 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 474.804282: rtcpu_vinotify_event: tstamp:15747429395 tag:FS channel:0x02 frame:0 vi_tstamp:15747376921 data:0x00000010
kworker/0:5-4013 [000] .... 474.860280: rtcpu_vinotify_event: tstamp:15748055431 tag:FE channel:0x02 frame:0 vi_tstamp:15747820707 data:0x00000020
kworker/0:5-4013 [000] .... 474.916271: rtos_queue_peek_from_isr_failed: tstamp:15750723014 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 475.028283: rtcpu_vinotify_event: tstamp:15753689452 tag:FS channel:0x02 frame:0 vi_tstamp:15753626824 data:0x00000010
kworker/0:5-4013 [000] .... 475.028286: rtcpu_vinotify_event: tstamp:15754315486 tag:FE channel:0x02 frame:0 vi_tstamp:15754070615 data:0x00000020
kworker/0:5-4013 [000] .... 475.084274: rtos_queue_peek_from_isr_failed: tstamp:15755723005 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 475.196278: rtcpu_vinotify_event: tstamp:15759949596 tag:FS channel:0x02 frame:0 vi_tstamp:15759876732 data:0x00000010
kworker/0:5-4013 [000] .... 475.252300: rtcpu_vinotify_event: tstamp:15760575532 tag:FE channel:0x02 frame:0 vi_tstamp:15760320517 data:0x00000020
kworker/0:5-4013 [000] .... 475.252303: rtos_queue_peek_from_isr_failed: tstamp:15760723001 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 475.420276: rtos_queue_peek_from_isr_failed: tstamp:15765723001 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 475.420279: rtcpu_vinotify_event: tstamp:15766209644 tag:FS channel:0x02 frame:0 vi_tstamp:15766126635 data:0x00000010
kworker/0:5-4013 [000] .... 475.420281: rtcpu_vinotify_event: tstamp:15766835675 tag:FE channel:0x02 frame:0 vi_tstamp:15766570420 data:0x00000020
kworker/0:5-4013 [000] .... 475.588274: rtos_queue_peek_from_isr_failed: tstamp:15770723003 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 475.644280: rtcpu_vinotify_event: tstamp:15772469779 tag:FS channel:0x02 frame:0 vi_tstamp:15772376544 data:0x00000010
kworker/0:5-4013 [000] .... 475.644284: rtcpu_vinotify_event: tstamp:15772820975 tag:FE channel:0x02 frame:0 vi_tstamp:15772820329 data:0x00000020
kworker/0:5-4013 [000] .... 475.700276: rtos_queue_peek_from_isr_failed: tstamp:15775723005 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 475.812279: rtcpu_vinotify_event: tstamp:15778635912 tag:FS channel:0x02 frame:0 vi_tstamp:15778626445 data:0x00000010
kworker/0:5-4013 [000] .... 475.812282: rtcpu_vinotify_event: tstamp:15779261935 tag:FE channel:0x02 frame:0 vi_tstamp:15779070237 data:0x00000020
kworker/0:5-4013 [000] .... 475.868290: rtos_queue_peek_from_isr_failed: tstamp:15780723013 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 476.036301: rtcpu_vinotify_event: tstamp:15784896038 tag:FS channel:0x02 frame:0 vi_tstamp:15784876355 data:0x00000010
kworker/0:5-4013 [000] .... 476.036304: rtcpu_vinotify_event: tstamp:15785521983 tag:FE channel:0x02 frame:0 vi_tstamp:15785320140 data:0x00000020
kworker/0:5-4013 [000] .... 476.036306: rtos_queue_peek_from_isr_failed: tstamp:15785723000 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 476.204271: rtos_queue_peek_from_isr_failed: tstamp:15790723000 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 476.204274: rtcpu_vinotify_event: tstamp:15791156089 tag:FS channel:0x02 frame:0 vi_tstamp:15791126256 data:0x00000010
kworker/0:5-4013 [000] .... 476.260300: rtcpu_vinotify_event: tstamp:15791782122 tag:FE channel:0x02 frame:0 vi_tstamp:15791570049 data:0x00000020
kworker/0:5-4013 [000] .... 476.372306: rtos_queue_peek_from_isr_failed: tstamp:15795723003 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 476.428283: rtcpu_vinotify_event: tstamp:15797416226 tag:FS channel:0x02 frame:0 vi_tstamp:15797376165 data:0x00000010
kworker/0:5-4013 [000] .... 476.428286: rtcpu_vinotify_event: tstamp:15798042166 tag:FE channel:0x02 frame:0 vi_tstamp:15797819950 data:0x00000020
kworker/0:5-4013 [000] .... 476.540277: rtos_queue_peek_from_isr_failed: tstamp:15800723000 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 476.596317: rtcpu_vinotify_event: tstamp:15803676278 tag:FS channel:0x02 frame:0 vi_tstamp:15803626067 data:0x00000010
kworker/0:5-4013 [000] .... 476.652283: rtcpu_vinotify_event: tstamp:15804302314 tag:FE channel:0x02 frame:0 vi_tstamp:15804069859 data:0x00000020
kworker/0:5-4013 [000] .... 476.708272: rtos_queue_peek_from_isr_failed: tstamp:15805723005 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 476.820270: rtcpu_vinotify_event: tstamp:15809936357 tag:FS channel:0x02 frame:0 vi_tstamp:15809875976 data:0x00000010
kworker/0:5-4013 [000] .... 476.820273: rtcpu_vinotify_event: tstamp:15810562389 tag:FE channel:0x02 frame:0 vi_tstamp:15810319761 data:0x00000020
kworker/0:5-4013 [000] .... 476.820275: rtos_queue_peek_from_isr_failed: tstamp:15810722997 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 476.988279: rtos_queue_peek_from_isr_failed: tstamp:15815723000 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 477.044280: rtcpu_vinotify_event: tstamp:15816196527 tag:FS channel:0x02 frame:0 vi_tstamp:15816125878 data:0x00000010
kworker/0:5-4013 [000] .... 477.044283: rtcpu_vinotify_event: tstamp:15816822554 tag:FE channel:0x02 frame:0 vi_tstamp:15816569670 data:0x00000020
kworker/0:5-4013 [000] .... 477.156319: rtos_queue_peek_from_isr_failed: tstamp:15820723003 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 477.212276: rtcpu_vinotify_event: tstamp:15822456591 tag:FS channel:0x02 frame:0 vi_tstamp:15822375787 data:0x00000010
kworker/0:5-4013 [000] .... 477.212279: rtcpu_vinotify_event: tstamp:15822820217 tag:FE channel:0x02 frame:0 vi_tstamp:15822819572 data:0x00000020
kworker/0:5-4013 [000] .... 477.324286: rtos_queue_peek_from_isr_failed: tstamp:15825723000 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 477.436277: rtcpu_vinotify_event: tstamp:15828654114 tag:FS channel:0x02 frame:0 vi_tstamp:15828625695 data:0x00000010
kworker/0:5-4013 [000] .... 477.436280: rtcpu_vinotify_event: tstamp:15829280146 tag:FE channel:0x02 frame:0 vi_tstamp:15829069481 data:0x00000020
kworker/0:5-4013 [000] .... 477.492273: rtos_queue_peek_from_isr_failed: tstamp:15830723004 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 477.604279: rtcpu_vinotify_event: tstamp:15834914260 tag:FS channel:0x02 frame:0 vi_tstamp:15834875598 data:0x00000010
kworker/0:5-4013 [000] .... 477.660272: rtcpu_vinotify_event: tstamp:15835540203 tag:FE channel:0x02 frame:0 vi_tstamp:15835319389 data:0x00000020
kworker/0:5-4013 [000] .... 477.660276: rtos_queue_peek_from_isr_failed: tstamp:15835722996 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 477.828281: rtos_queue_peek_from_isr_failed: tstamp:15840723003 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 477.828285: rtcpu_vinotify_event: tstamp:15841174316 tag:FS channel:0x02 frame:0 vi_tstamp:15841125506 data:0x00000010
kworker/0:5-4013 [000] .... 477.828287: rtcpu_vinotify_event: tstamp:15841800348 tag:FE channel:0x02 frame:0 vi_tstamp:15841569292 data:0x00000020
kworker/0:5-4013 [000] .... 477.940287: rtos_queue_peek_from_isr_failed: tstamp:15845723000 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 477.996274: rtcpu_vinotify_event: tstamp:15847434495 tag:FS channel:0x02 frame:0 vi_tstamp:15847375408 data:0x00000010
kworker/0:5-4013 [000] .... 478.052295: rtcpu_vinotify_event: tstamp:15848060399 tag:FE channel:0x02 frame:0 vi_tstamp:15847819194 data:0x00000020
kworker/0:5-4013 [000] .... 478.108271: rtos_queue_peek_from_isr_failed: tstamp:15850723003 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 478.220290: rtcpu_vinotify_event: tstamp:15853694521 tag:FS channel:0x02 frame:0 vi_tstamp:15853625318 data:0x00000010
kworker/0:5-4013 [000] .... 478.220292: rtcpu_vinotify_event: tstamp:15854320565 tag:FE channel:0x02 frame:0 vi_tstamp:15854069102 data:0x00000020
kworker/0:5-4013 [000] .... 478.276276: rtos_queue_peek_from_isr_failed: tstamp:15855723008 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 478.444285: rtcpu_vinotify_event: tstamp:15859954586 tag:FS channel:0x02 frame:0 vi_tstamp:15859875219 data:0x00000010
kworker/0:5-4013 [000] .... 478.444289: rtcpu_vinotify_event: tstamp:15860580619 tag:FE channel:0x02 frame:0 vi_tstamp:15860319012 data:0x00000020
kworker/0:5-4013 [000] .... 478.444291: rtos_queue_peek_from_isr_failed: tstamp:15860723001 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 478.612279: rtos_queue_peek_from_isr_failed: tstamp:15865723005 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 478.612282: rtcpu_vinotify_event: tstamp:15866214725 tag:FS channel:0x02 frame:0 vi_tstamp:15866125128 data:0x00000010
kworker/0:5-4013 [000] .... 478.612284: rtcpu_vinotify_event: tstamp:15866840802 tag:FE channel:0x02 frame:0 vi_tstamp:15866568913 data:0x00000020
kworker/0:5-4013 [000] .... 478.780275: rtos_queue_peek_from_isr_failed: tstamp:15870723005 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 478.836272: rtcpu_vinotify_event: tstamp:15872474782 tag:FS channel:0x02 frame:0 vi_tstamp:15872375030 data:0x00000010
kworker/0:5-4013 [000] .... 478.836274: rtcpu_vinotify_event: tstamp:15872819473 tag:FE channel:0x02 frame:0 vi_tstamp:15872818822 data:0x00000020
kworker/0:5-4013 [000] .... 478.948284: rtos_queue_peek_from_isr_failed: tstamp:15875723000 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 479.004271: rtcpu_vinotify_event: tstamp:15878640998 tag:FS channel:0x02 frame:0 vi_tstamp:15878624940 data:0x00000010
kworker/0:5-4013 [000] .... 479.060273: rtcpu_vinotify_event: tstamp:15879267035 tag:FE channel:0x02 frame:0 vi_tstamp:15879068725 data:0x00000020
kworker/0:5-4013 [000] .... 479.060276: rtos_queue_peek_from_isr_failed: tstamp:15880722996 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 479.228274: rtcpu_vinotify_event: tstamp:15884901055 tag:FS channel:0x02 frame:0 vi_tstamp:15884874841 data:0x00000010
kworker/0:5-4013 [000] .... 479.228277: rtcpu_vinotify_event: tstamp:15885527087 tag:FE channel:0x02 frame:0 vi_tstamp:15885318633 data:0x00000020
kworker/0:5-4013 [000] .... 479.228279: rtos_queue_peek_from_isr_failed: tstamp:15885723000 queue:0x0bcbbbb8
vi-output, DS5 -9326 [002] .... 479.317592: tegra_channel_capture_setup: vnc_id 0 W 1280 H 720 fmt 11
v4l2-ctl-9324 [002] .... 479.318759: tegra_channel_set_stream: enable : 0x0
v4l2-ctl-9324 [002] .... 479.318765: tegra_channel_set_stream: DS5 mux 34-0010 : 0x0
kworker/0:5-4013 [000] .... 479.340395: rtos_queue_send_from_isr_failed: tstamp:15888861970 queue:0x0bcb2e38
kworker/0:5-4013 [000] .... 479.340401: rtos_queue_send_from_isr_failed: tstamp:15888862275 queue:0x0bcb76a0
kworker/0:5-4013 [000] .... 479.340402: rtos_queue_send_from_isr_failed: tstamp:15888862577 queue:0x0bcb9220
kworker/0:5-4013 [000] .... 479.340403: rtos_queue_send_from_isr_failed: tstamp:15888862873 queue:0x0bcb9fe0
kworker/0:5-4013 [000] .... 479.340404: rtos_queue_send_from_isr_failed: tstamp:15888863167 queue:0x0bcbada0
kworker/0:5-4013 [000] .... 479.340405: rtos_queue_send_from_isr_failed: tstamp:15888863525 queue:0x0bcb2dd0
kworker/0:5-4013 [000] .... 479.340406: rtos_queue_send_from_isr_failed: tstamp:15888863809 queue:0x0bcb2e38
kworker/0:5-4013 [000] .... 479.340407: rtos_queue_send_from_isr_failed: tstamp:15888864094 queue:0x0bcb7638
kworker/0:5-4013 [000] .... 479.340409: rtos_queue_send_from_isr_failed: tstamp:15888864378 queue:0x0bcb76a0
kworker/0:5-4013 [000] .... 479.340410: rtos_queue_send_from_isr_failed: tstamp:15888864666 queue:0x0bcb91b8
kworker/0:5-4013 [000] .... 479.340411: rtos_queue_send_from_isr_failed: tstamp:15888864948 queue:0x0bcb9220
kworker/0:5-4013 [000] .... 479.340412: rtos_queue_send_from_isr_failed: tstamp:15888865234 queue:0x0bcb9f78
kworker/0:5-4013 [000] .... 479.340413: rtos_queue_send_from_isr_failed: tstamp:15888865517 queue:0x0bcb9fe0
kworker/0:5-4013 [000] .... 479.340414: rtos_queue_send_from_isr_failed: tstamp:15888865801 queue:0x0bcbad38
kworker/0:5-4013 [000] .... 479.340470: rtos_queue_send_from_isr_failed: tstamp:15888866082 queue:0x0bcbada0
kworker/0:5-4013 [000] .... 479.340471: rtos_queue_send_from_isr_failed: tstamp:15888880435 queue:0x0bcb2e38
kworker/0:5-4013 [000] .... 479.340472: rtos_queue_send_from_isr_failed: tstamp:15888880793 queue:0x0bcb76a0
kworker/0:5-4013 [000] .... 479.340473: rtos_queue_send_from_isr_failed: tstamp:15888881095 queue:0x0bcb9220
kworker/0:5-4013 [000] .... 479.340474: rtos_queue_send_from_isr_failed: tstamp:15888881406 queue:0x0bcb9fe0
kworker/0:5-4013 [000] .... 479.340475: rtos_queue_send_from_isr_failed: tstamp:15888881703 queue:0x0bcbada0
kworker/0:5-4013 [000] .... 479.340477: rtos_queue_send_from_isr_failed: tstamp:15888913533 queue:0x0bcb2e38
kworker/0:5-4013 [000] .... 479.340478: rtos_queue_send_from_isr_failed: tstamp:15888913890 queue:0x0bcb76a0
kworker/0:5-4013 [000] .... 479.340479: rtos_queue_send_from_isr_failed: tstamp:15888914194 queue:0x0bcb9220
kworker/0:5-4013 [000] .... 479.340480: rtos_queue_send_from_isr_failed: tstamp:15888914492 queue:0x0bcb9fe0
kworker/0:5-4013 [000] .... 479.340482: rtos_queue_send_from_isr_failed: tstamp:15888914789 queue:0x0bcbada0
kworker/0:5-4013 [000] .... 479.340514: rtos_queue_send_from_isr_failed: tstamp:15888931938 queue:0x0bcb2e38
kworker/0:5-4013 [000] .... 479.340515: rtos_queue_send_from_isr_failed: tstamp:15888932297 queue:0x0bcb76a0
kworker/0:5-4013 [000] .... 479.340516: rtos_queue_send_from_isr_failed: tstamp:15888932595 queue:0x0bcb9220
kworker/0:5-4013 [000] .... 479.340517: rtos_queue_send_from_isr_failed: tstamp:15888932892 queue:0x0bcb9fe0
kworker/0:5-4013 [000] .... 479.340518: rtos_queue_send_from_isr_failed: tstamp:15888933206 queue:0x0bcbada0
kworker/0:5-4013 [000] .... 479.340523: rtcpu_string: tstamp:15888934027 id:0x04010000 str:"Configuring VI GoS.
kworker/0:5-4013 [000] .... 479.340572: rtcpu_string: tstamp:15888934480 id:0x04010000 str:"VM GOS[#0] addr=0xc2100000
kworker/0:5-4013 [000] .... 479.340583: rtcpu_string: tstamp:15888934900 id:0x04010000 str:"VM GOS[#1] addr=0xc2101000
kworker/0:5-4013 [000] .... 479.340595: rtcpu_string: tstamp:15888935312 id:0x04010000 str:"VM GOS[#2] addr=0xc2102000
kworker/0:5-4013 [000] .... 479.340603: rtcpu_string: tstamp:15888935718 id:0x04010000 str:"VM GOS[#3] addr=0xc2103000
kworker/0:5-4013 [000] .... 479.340611: rtcpu_string: tstamp:15888936179 id:0x04010000 str:"VM GOS[#4] addr=0xc2104000
kworker/0:5-4013 [000] .... 479.340619: rtcpu_string: tstamp:15888936585 id:0x04010000 str:"VM GOS[#5] addr=0xc2105000
kworker/0:5-4013 [000] .... 479.396289: rtos_queue_peek_from_isr_failed: tstamp:15890723001 queue:0x0bcbbbb8
v4l2-ctl-9324 [000] .... 479.421556: tegra_channel_set_stream: 15a00000.nvcsi--4 : 0x0
v4l2-ctl-9324 [000] .... 479.421565: csi_s_stream: enable : 0x0
v4l2-ctl-9324 [000] .... 479.425476: tegra_channel_set_power: DS5 mux 34-0010 : 0x0
v4l2-ctl-9324 [000] .... 479.425481: tegra_channel_set_power: 15a00000.nvcsi--4 : 0x0
v4l2-ctl-9324 [000] .... 479.425487: csi_s_power: enable : 0x0
kworker/0:5-4013 [000] .... 479.452461: rtos_queue_send_from_isr_failed: tstamp:15892167611 queue:0x0bcb2e38
kworker/0:5-4013 [000] .... 479.452469: rtos_queue_send_from_isr_failed: tstamp:15892167914 queue:0x0bcb76a0
kworker/0:5-4013 [000] .... 479.452470: rtos_queue_send_from_isr_failed: tstamp:15892168219 queue:0x0bcb9220
kworker/0:5-4013 [000] .... 479.452473: rtos_queue_send_from_isr_failed: tstamp:15892168519 queue:0x0bcb9fe0
kworker/0:5-4013 [000] .... 479.452474: rtos_queue_send_from_isr_failed: tstamp:15892168818 queue:0x0bcbada0
kworker/0:5-4013 [000] .... 479.564324: rtos_queue_peek_from_isr_failed: tstamp:15895723005 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 479.732303: rtos_queue_peek_from_isr_failed: tstamp:15900722999 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 479.900281: rtos_queue_peek_from_isr_failed: tstamp:15905723005 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 480.068304: rtos_queue_peek_from_isr_failed: tstamp:15910723001 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 480.180280: rtos_queue_peek_from_isr_failed: tstamp:15915723005 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 480.348276: rtos_queue_peek_from_isr_failed: tstamp:15920723000 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 480.516273: rtos_queue_peek_from_isr_failed: tstamp:15925723005 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 480.684304: rtos_queue_peek_from_isr_failed: tstamp:15930723000 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 480.852339: rtos_queue_peek_from_isr_failed: tstamp:15935723003 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 481.020286: rtos_queue_peek_from_isr_failed: tstamp:15940723004 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 481.188276: rtos_queue_peek_from_isr_failed: tstamp:15945723004 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 481.300273: rtos_queue_peek_from_isr_failed: tstamp:15950723001 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 481.468273: rtos_queue_peek_from_isr_failed: tstamp:15955722996 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 481.636317: rtos_queue_peek_from_isr_failed: tstamp:15960723000 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 481.804276: rtos_queue_peek_from_isr_failed: tstamp:15965723000 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 481.972272: rtos_queue_peek_from_isr_failed: tstamp:15970722997 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 482.140273: rtos_queue_peek_from_isr_failed: tstamp:15975723005 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 482.308271: rtos_queue_peek_from_isr_failed: tstamp:15980723000 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 482.420297: rtos_queue_peek_from_isr_failed: tstamp:15985723000 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 482.588274: rtos_queue_peek_from_isr_failed: tstamp:15990723000 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 482.756271: rtos_queue_peek_from_isr_failed: tstamp:15995723000 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 482.924276: rtos_queue_peek_from_isr_failed: tstamp:16000723010 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 483.092272: rtos_queue_peek_from_isr_failed: tstamp:16005722999 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 483.260291: rtos_queue_peek_from_isr_failed: tstamp:16010722996 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 483.428322: rtos_queue_peek_from_isr_failed: tstamp:16015723000 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 483.540287: rtos_queue_peek_from_isr_failed: tstamp:16020723000 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 483.708276: rtos_queue_peek_from_isr_failed: tstamp:16025723000 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 483.876306: rtos_queue_peek_from_isr_failed: tstamp:16030722997 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 484.044289: rtos_queue_peek_from_isr_failed: tstamp:16035722997 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 484.212361: rtos_queue_peek_from_isr_failed: tstamp:16040723000 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 484.380280: rtos_queue_peek_from_isr_failed: tstamp:16045723005 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 484.548283: rtos_queue_peek_from_isr_failed: tstamp:16050723001 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 484.660275: rtos_queue_peek_from_isr_failed: tstamp:16055723005 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 484.828271: rtos_queue_peek_from_isr_failed: tstamp:16060723005 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 484.996295: rtos_queue_peek_from_isr_failed: tstamp:16065722999 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 485.164273: rtos_queue_peek_from_isr_failed: tstamp:16070723005 queue:0x0bcbbbb8
kworker/0:5-4013 [000] .... 485.220298: rtos_queue_peek_from_isr_failed: tstamp:16071753201 queue:0x0bcbbbb8
