I did run the sequence
| Configure Jetson AGX CSI Connector |
| Configure for compatible hardware |
| Jetson Camera e3653-dual-Hawk module |
| Back |
| Save pin changes |
I later ran it again and added from the main menu:
| Save and reboot to reconfigure pins |
Got a message
| Configuration saved to file |
/boot/kernel_tegra234-p3701-0000-p3737-0000-user-custom.dtb. |
and rebooted to the custom dtb.
At this time /dev/videoN, N=0…3 were created, however they don’t seem to work:
root@orin:~# v4l2-ctl --list-devices
NVIDIA Tegra Video Input Device (platform:tegra-camrtc-ca):
/dev/media0
vi-output, ar0234 30-0018 (platform:tegra-capture-vi:1):
/dev/video0
/dev/video1
/dev/video2
/dev/video3
root@orin:~# gst-launch-1.0 nvarguscamerasrc sensor-id=0 ! 'video/x-raw(memory:NVMM),width=1920, height=1200, format=NV12' ! nvvidconv ! 'video/x-raw(memory:NVMM),format=I420' ! fakesink
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, execute:751 No cameras available
Got EOS from element "pipeline0".
Execution ended after 0:00:00.002398307
Setting pipeline to NULL ...
Freeing pipeline ...
(Argus) Error EndOfFile: Unexpected error in reading socket (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line 277)
(Argus) Error EndOfFile: Receive worker failure, notifying 1 waiting threads (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line 350)
(Argus) Error InvalidState: Argus client is exiting with 1 outstanding client threads (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line 366)
(Argus) Error EndOfFile: Receiving thread terminated with error (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadWrapper(), line 379)
(Argus) Error EndOfFile: Client thread received an error from socket (in src/rpc/socket/client/ClientSocketManager.cpp, function send(), line 145)
(Argus) Error EndOfFile: (propagating from src/rpc/socket/client/SocketClientDispatch.cpp, function dispatch(), line 91)
root@orin:~#
I also noticed that it doesn’t look like the tegra234-p3737-camera-dual-hawk-ar0234-e3653-overlay.dtbo device tree overlay is included in the BSP.
This is from p3737-0000+p3701-0000.conf:
OVERLAY_DTB_FILE="${OVERLAY_DTB_FILE},tegra234-p3737-camera-dual-imx274-overlay.dtbo,tegra234-p3737-camera-e3331-overlay.dtbo,tegra234-p3737-camera-e3333-overlay.dtbo,tegra234-p3737-camera-imx185-overlay.dtbo,tegra234-p3737-camera-imx390-overlay.dtbo";
