Hello
I’m trying to test out if mediapipe sample works fine on Jetson Nano.
I installed Mediapipe with python3 -m pip install mediapipe on Jetson but it throws an error whenever I try to test it with import mediapipe or run the sample given in mediapipe-bin.
Here’s what I see on the nano terminal:
dayeon@dayeon-desktop:~/mediapipe-python-sample$ python3 sample_hand.py
File "sample_hand.py", line 8, in <module>
import mediapipe as mp
File "/home/dayeon/.local/lib/python3.7/site-packages/mediapipe/__init__.py", line 17, in <module>
import mediapipe.python.solutions as solutions
File "/home/dayeon/.local/lib/python3.7/site-packages/mediapipe/python/solutions/__init__.py", line 17, in <module>
import mediapipe.python.solutions.drawing_styles
File "/home/dayeon/.local/lib/python3.7/site-packages/mediapipe/python/solutions/drawing_styles.py", line 20, in <module>
from mediapipe.python.solutions.drawing_utils import DrawingSpec
File "/home/dayeon/.local/lib/python3.7/site-packages/mediapipe/python/solutions/drawing_utils.py", line 22, in <module>
import matplotlib.pyplot as plt
File "/usr/lib/python3/dist-packages/matplotlib/pyplot.py", line 32, in <module>
import matplotlib.colorbar
File "/usr/lib/python3/dist-packages/matplotlib/colorbar.py", line 32, in <module>
import matplotlib.artist as martist
File "/usr/lib/python3/dist-packages/matplotlib/artist.py", line 16, in <module>
from .path import Path
File "/usr/lib/python3/dist-packages/matplotlib/path.py", line 25, in <module>
from . import _path, rcParams
ImportError: cannot import name '_path' from 'matplotlib' (/usr/lib/python3/dist-packages/matplotlib/__init__.py)
Please help me solve this problem – I’m working on this for two days now :,)…
Thank you in advance.
