I’m trying to build a stereoscopic camera using a Jetson Nano dev kit and two CSI cameras.
The example pipelines from the accelerated gstreamer chapter of the docs have worked at 1920x1080 60fps if I use nvoverlaysink, but when I use a filesink example the video files are saved at less than 1fps.
The most successful attempt was using nvgstcapture which did produce a 1280x720 30fps video, but failed when I tried to increase the resolution to 1920x1080.
Ideally I’d like to sync, composite and encode the left and right eye cameras input in the same file. I’m new to developing on jetson and any advice or further resources is much appreciated.
When I run the first two I get this error:
ARGUS_ERROR: Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, execute: 679 Frame Rate specified is greater than supported
GST_ARGUS: Running with following settings:
Camera index = 0
Camera mode = 2
Output Stream W = 1920 H = 1080
seconds to Run = 0
Frame Rate = 29.999999
If I change framerate to 30/1 they run fine. When I make the same change to the compositor pipeline it closes after ~10 seconds and the file it produces is ~1fps.
I tried 30 fps and it works fine for the overlaysink pipelines, but the compositor pipeline still fails. The clip it produces is ~.5 fps and the pipeline closes on its own after ~10 seconds without an error
