I am able to log in through the serial over USB (USB-C) alternative using the username/password created using the script l4t_create_default_user.sh.
~$ ifconfig
l4tbr0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.55.1 netmask 255.255.255.0 broadcast 192.168.55.255
inet6 fe80::b840:d9ff:fe63:15bd prefixlen 64 scopeid 0x20<link>
inet6 fe80::1 prefixlen 128 scopeid 0x20<link>
ether ba:40:d9:63:15:bd txqueuelen 1000 (Ethernet)
RX packets 413 bytes 42565 (42.5 KB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 15 bytes 2378 (2.3 KB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 1000 (Local Loopback)
RX packets 80 bytes 5992 (5.9 KB)
TX packets 80 bytes 5992 (5.9 KB)
rndis0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
RX packets 242 bytes 24163 (24.1 KB)
TX packets 227 bytes 37328 (37.3 KB)
usb0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet6 fe80::b840:d9ff:fe63:15bf prefixlen 64 scopeid 0x20<link>
ether ba:40:d9:63:15:bf txqueuelen 1000 (Ethernet)
RX packets 234 bytes 24459 (24.4 KB)
TX packets 146 bytes 35648 (35.6 KB)
dhclient is also not starting automatically. When I start it manually, eth0 and wlan0 comes up. eth0 succesfully gets an IP through DHCP.
I couldn’t find any of the common network configuration systems used in Ubuntu:
- /etc/network/interfaces
- netplan
- NetworkManager
I’m not sure if I’m missing a step when creating the rootfs or the rootfs downloaded with the SDK scripts are flawed.
