Dear Shubhi,
We don’t made any changes in the kernel. We install all stuff as described through SDK Manager connected through USB in recovery mode. No files were changed.
lsmod
Module Size Used by
mttcan 66251 0
can_dev 13306 1 mttcan
can_raw 10388 0
can 46600 1 can_raw
fuse 103841 3
bnep 16562 2
bcmdhd 934210 0
zram 26166 6
cfg80211 589351 1 bcmdhd
spidev 13282 0
ov5693 29772 0
overlay 48691 0
binfmt_misc 13103 1
nvgpu 1579891 46
bluedroid_pm 13912 0
ip_tables 19441 0
x_tables 28951 1 ip_tables
ip -d -s link show can0
8: can0: <NOARP,UP,LOWER_UP,ECHO> mtu 16 qdisc pfifo_fast state UNKNOWN mode DEFAULT group default qlen 10
link/can promiscuity 0
can state ERROR-ACTIVE (berr-counter tx 0 rx 0) restart-ms 1000
bitrate 500000 sample-point 0.875
tq 25 prop-seg 34 phase-seg1 35 phase-seg2 10 sjw 1
mttcan: tseg1 2…255 tseg2 0…127 sjw 1…127 brp 1…511 brp-inc 1
mttcan: dtseg1 1…31 dtseg2 0…15 dsjw 1…15 dbrp 1…15 dbrp-inc 1
clock 40000000
re-started bus-errors arbit-lost error-warn error-pass bus-off
0 0 0 0 0 0 numtxqueues 1 numrxqueues 1 gso_max_size 65536 gso_max_segs 65535
RX: bytes packets errors dropped overrun mcast
0 0 0 0 0 0
TX: bytes packets errors dropped carrier collsns
0 0 0 0 0 0
ip -d -s link show can1
9: can1: <NOARP,UP,LOWER_UP,ECHO> mtu 16 qdisc pfifo_fast state UNKNOWN mode DEFAULT group default qlen 10
clock 40000000
0 0 0 0 0 0
0 0 0 0 0 0
busybox devmem 0x0c303018
0x00000400
busybox devmem 0x0c303008
0x00000400
busybox devmem 0x0c303010
0x00000458
busybox devmem 0x0c303020
0x00000458
If I have opened two terminals and in one run
candump can1
and in another
cansend can0 123#1122
then i immediately obtain this:
8: can0: <NO-CARRIER,NOARP,UP,ECHO> mtu 16 qdisc pfifo_fast state DOWN mode DEFAULT group default qlen 10
can state BUS-OFF (berr-counter tx 248 rx 0) restart-ms 1000
clock 40000000
8 0 0 9 9 9 numtxqueues 1 numrxqueues 1 gso_max_size 65536 gso_max_segs 65535
280 35 0 0 0 0
0 0 0 0 0 0
and this
can state ERROR-PASSIVE (berr-counter tx 0 rx 127) restart-ms 1000
clock 40000000
0 0 0 1 1 0 numtxqueues 1 numrxqueues 1 gso_max_size 65536 gso_max_segs 65535
16 2 0 0 0 0
0 0 0 0 0 0
though i send data only from can0 to can1. All wires are connected as described in How to use CAN on JETSON TX2? - #2 by spatra
Is is looks like data from CAN0 TX immediately goes to CAN0 RX due to EMI interference or some other error in board routing. Or error deep inside the kernel/driver.
Thank you for quick answer!
Kind regards,
Alexander
