Hi Everyone,
I have a jetson Xavier and I was installing The Jetson inference software from Dusty-NV to train some detection networks. After this I restarted the OS, updated the system and restarted again the system. After this the screen is always black but I have been able ssh into the system. I restarted the system in command line mode and I am able to logging into the system.
When I try to update the system on command line I get this error below, any idea what is it happening? thank you for your time in advance
mrg@xnx:~$ sudo apt-get upgrade
Reading package lists… Done
Building dependency tree
Reading state information… Done
You might want to run ‘apt --fix-broken install’ to correct these.
The following packages have unmet dependencies:
python3.9 : Depends: libpython3.9-stdlib (= 3.9.13-1+bionic1) but 3.9.7-1+bionic1 is installed
python3.9-minimal : Depends: libpython3.9-minimal (= 3.9.13-1+bionic1) but 3.9.7-1+bionic1 is installed
E: Unmet dependencies. Try ‘apt --fix-broken install’ with no packages (or specify a solution).
mrg@xnx:~$ sudo apt --fix-broken install
Correcting dependencies… Done
The following packages were automatically installed and are no longer required:
apt-clone archdetect-deb bogl-bterm busybox-static cryptsetup-bin dpkg-repack
gir1.2-timezonemap-1.0 gir1.2-xkl-1.0 grub-common kde-window-manager kinit kio
kpackagetool5 kwayland-data kwin-common kwin-data kwin-x11 libdebian-installer4
libkdecorations2-5v5 libkdecorations2private5v5 libkf5activities5 libkf5attica5
libkf5completion-data libkf5completion5 libkf5declarative-data
libkf5declarative5 libkf5doctools5 libkf5globalaccel-data libkf5globalaccel5
libkf5globalaccelprivate5 libkf5idletime5 libkf5jobwidgets-data
libkf5jobwidgets5 libkf5kcmutils-data libkf5kcmutils5 libkf5kiocore5
libkf5kiontlm5 libkf5kiowidgets5 libkf5newstuff-data libkf5newstuff5
libkf5newstuffcore5 libkf5package-data libkf5package5 libkf5plasma5
libkf5quickaddons5 libkf5solid5 libkf5solid5-data libkf5sonnet5-data
libkf5sonnetcore5 libkf5sonnetui5 libkf5textwidgets-data libkf5textwidgets5
libkf5waylandclient5 libkf5waylandserver5 libkf5xmlgui-bin libkf5xmlgui-data
libkf5xmlgui5 libkscreenlocker5 libkwin4-effect-builtins1 libkwineffects11
libkwinglutils11 libkwinxrenderutils11 libqgsttools-p1 libqt5designer5
libqt5help5 libqt5multimedia5 libqt5multimedia5-plugins libqt5multimediaquick-p5
libqt5multimediawidgets5 libqt5quickwidgets5 libxcb-composite0 libxcb-cursor0
libxcb-damage0 os-prober python3-dbus.mainloop.pyqt5 python3-icu python3-pam
python3-pyqt5 python3-pyqt5.qtsvg python3-pyqt5.qtwebkit python3-sip
qml-module-org-kde-kquickcontrolsaddons qml-module-qtmultimedia
qml-module-qtquick2 rdate tasksel tasksel-data
Use ‘sudo apt autoremove’ to remove them.
The following additional packages will be installed:
libpython3.9-minimal libpython3.9-stdlib
The following packages will be upgraded:
2 to upgrade, 0 to newly install, 0 to remove and 149 not to upgrade.
133 not fully installed or removed.
Need to get 0 B/2,426 kB of archives.
After this operation, 38.9 kB of additional disk space will be used.
Do you want to continue? [Y/n] y
debconf: delaying package configuration, since apt-utils is not installed
(Reading database … 184742 files and directories currently installed.)
Preparing to unpack …/libpython3.9-stdlib_3.9.13-1+bionic1_arm64.deb …
Unpacking libpython3.9-stdlib:arm64 (3.9.13-1+bionic1) over (3.9.7-1+bionic1) …
dpkg: error processing archive /var/cache/apt/archives/libpython3.9-stdlib_3.9.13-1+bionic1_arm64.deb (–unpack):
trying to overwrite ‘/usr/lib/python3.9/_sysconfigdata__linux_aarch64-linux-gnu.py’, which is also in package libpython3.9-minimal:arm64 3.9.7-1+bionic1
Preparing to unpack …/libpython3.9-minimal_3.9.13-1+bionic1_arm64.deb …
Unpacking libpython3.9-minimal:arm64 (3.9.13-1+bionic1) over (3.9.7-1+bionic1) …
dpkg: error processing archive /var/cache/apt/archives/libpython3.9-minimal_3.9.13-1+bionic1_arm64.deb (–unpack):
trying to overwrite ‘/usr/lib/python3.9/typing.py’, which is also in package libpython3.9-stdlib:arm64 3.9.7-1+bionic1
dpkg-deb: error: paste subprocess was killed by signal (Broken pipe)
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
