I have a keras .pb model which i trained with Tensorflow 1.15.0 and Keras 2.3.1. Could you please guide me to convert this model to tensorrt engine?
You can convert using onnx model (pb → onnx → trt)
or
Also you can convert pb → trt using tf-trt.
Thank you.
Hi @spolisetty ,
Thanks for the reply. I was trying to convert with tf-trt. I ran the code,
from tensorflow.python.compiler.tensorrt import trt_convert as trt
input_saved_model_dir = "my_model.pb"
output_saved_model_dir = "my_model.engine"
converter = trt.TrtGraphConverter(input_saved_model_dir=input_saved_model_dir)
converter.convert()
converter.save(output_saved_model_dir)
And i am getting this error,
converter.convert()
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/compiler/tensorrt/trt_convert.py", line 548, in convert
self._convert_saved_model()
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/compiler/tensorrt/trt_convert.py", line 494, in _convert_saved_model
self._input_saved_model_dir)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/util/deprecation.py", line 324, in new_func
return func(*args, **kwargs)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/saved_model/loader_impl.py", line 268, in load
loader = SavedModelLoader(export_dir)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/saved_model/loader_impl.py", line 284, in __init__
self._saved_model = parse_saved_model(export_dir)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/saved_model/loader_impl.py", line 83, in parse_saved_model
constants.SAVED_MODEL_FILENAME_PB))
OSError: SavedModel file does not exist at: my_model.pb/{saved_model.pbtxt|saved_model.pb}
the name of the model is correct and it’s there in the path…
Any guess why i am getting this error?
Hope following similar issue may help you.
Thank you.
Hi @spolisetty ,
Thanks… I have checked it… i have tried the things people suggested there… i am trying to convert in Nvidia TF 1.15 container… so the dependencies like h5py is already installed… and the variable input_saved_model_dir, does it expect a directory? or the full path of the .pb file? in my case i only have the .pb model file… there are no other associated files… so what i gave is the absolute path of the .pb file for the input_saved_model_dir variable…
it’s throwing the error,
@jazeel.jk did you solve the problem can you help me please ?
No it’s not resolved yet @sametyassine88
Have you tried both ways ?
Yes i tried both… As i said i have only a .pb file… so i tried to give the absolute path, and also placed it in a folder and gave the folder path… both didn’t work
Hi @jazeel.jk,
We recommend you to please post your concern on Tensorflow forum to get better help.
Thank you.
@jazeel.jk when you solve the problem please tell me
and if i solve it , i will tell you
sure @sametyassine88 … i have created a topic in Tensorflow forum like @spolisetty suggested… But there is no reply yet…
i think the method tried,
converter.convert()
is expecting a directory which contains an asset folder, variables folder and saved model file… in my case the pb file is a frozen model… which means we should use the second method mentioned in the documentation, to convert the frozen graph to tensorrt engine…
so i tried to read the frozen graph from the frozen model,
import keras
import tensorflow as tf
model = keras.models.load_model(input_saved_model_dir, compile=False)
graph = tf.Graph()
sess = tf.InteractiveSession(graph = graph)
with tf.gfile.GFile(input_saved_model_dir, 'rb') as f:
graph_def = tf.GraphDef()
graph_def.ParseFromString(f.read())
converter = trt.TrtGraphConverter(input_graph_def=graph_def)
frozen_graph = converter.convert()
and i am getting the error,
File "tf_trt_convert.py", line 18, in <module>
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/compiler/tensorrt/trt_convert.py", line 546, in convert
self._convert_graph_def()
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/compiler/tensorrt/trt_convert.py", line 475, in _convert_graph_def
self._run_conversion()
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/compiler/tensorrt/trt_convert.py", line 453, in _run_conversion
graph_id=b"tf_graph")
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/grappler/tf_optimizer.py", line 41, in OptimizeGraph
verbose, graph_id)
tensorflow.python.framework.errors_impl.InvalidArgumentError: Failed to import metagraph, check error log for more info.
here is where i am @sametyassine88
Meanwhile, in case you find this as helpful.
Thanks @spolisetty … yea i used the frozen graph loading method from this article only…
with tf.gfile.GFile(model_filepath, 'rb') as f:
then tried to convert that frozen graph with,
and i was getting the error,
Thanks for the confirmation. Please followup in Tensorflow forum for further assistance.
