I wrote this kernel here:
[url=“http://codepad.org/MGZYtNRO”]http://codepad.org/MGZYtNRO[/url]
and i ran it on a gtx280 device, where it makes crash the graphics driver (video driver has stopped working and has been recovered)
the problem arises when i raise the dimension of the parameters of gsizeXY and gsizeT above 2.
as far as i understand gpus are some sort of SIMD processors and execute all branches.
In my case, with gsizeXY =3 and gsizeT=2 i would have something like 1000 iterations
is it simply too much?
another thing i dont understand exactly is when that error is supposed to happen.
I always tought that it happens when a single program takes more than 2 seconds to execute.
But in my case here, i made a small mistake in the beginning , and i had the line 53 as following:
|| (ct < 0) || (ct >= zres)) {
since zres in my tests was always 0, it executed some meaningful code only for the first 3 or 4 images (depending on gsizeT), but it DID work with a gsizeXY of 3, even tho it branched into //do nothing for most of the times
is there something else i am missing?
