Hi, I’m experimenting with CUDA on a VM machine from Microsoft Azure running a single K80 gpu and ubuntu 16.04 with kernel 4.4.0-75-generic. After server restart (or stop and start), dmesg outputs the following:
[ 29.490275] nvidia: module license 'NVIDIA' taints kernel.
[ 29.490278] Disabling lock debugging due to kernel taint
[ 29.494453] nvidia: module verification failed: signature and/or required key missing - tainting kernel
[ 29.499355] nvidia 25bed32b:00:00.0: can't derive routing for PCI INT A
[ 29.499357] nvidia 25bed32b:00:00.0: PCI INT A: no GSI
[ 29.501669] nvidia-nvlink: Nvlink Core is being initialized, major device number 246
[ 29.501679] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 375.51 Wed Mar 22 10:26:12 PDT 2017 (using threaded interrupts)
[ 29.563154] EXT4-fs (sdc1): mounted filesystem with ordered data mode. Opts: (null)
[ 29.633299] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms 375.51 Wed Mar 22 09:00:58 PDT 2017
[ 29.634479] [drm] [nvidia-drm] [GPU ID 0xd32b0000] Loading driver
[ 29.751281] nvidia-uvm: Loaded the UVM driver in 8 mode, major device number 245
[ 29.775289] BUG: unable to handle kernel NULL pointer dereference at 0000000000000340
[ 29.798452] IP: [<ffffffffc075549f>] _nv011745rm+0x1f/0x170 [nvidia]
[ 29.798452] PGD e9c20b067 PUD e9c20c067 PMD 0
[ 29.798452] Oops: 0000 [#1] SMP
[ 29.798452] Modules linked in: nvidia_uvm(POE) nvidia_drm(POE) nvidia_modeset(POE) nvidia(POE) drm_kms_helper drm fb_sys_fops syscopyarea sysfillrect sysimgblt pci_hyperv i2c_piix4 8250_fintek joydev input_leds mac_hid serio_raw hv_balloon ib_iser rdma_cm iw_cm ib_cm ib_sa ib_mad ib_core ib_addr iscsi_tcp libiscsi_tcp li
biscsi scsi_transport_iscsi autofs4 btrfs raid10 raid456 async_raid6_recov async_memcpy async_pq async_xor async_tx xor raid6_pq libcrc32c raid1 raid0 multipath linear hid_generic hv_netvsc hv_storvsc scsi_transport_fc hid_hyperv hid hv_utils hyperv_keyboard crct10dif_pclmul crc32_pclmul ghash_clmulni_intel aesni_intel aes_
x86_64 lrw gf128mul glue_helper ablk_helper hyperv_fb cryptd psmouse pata_acpi hv_vmbus floppy fjes
[ 29.798452] CPU: 5 PID: 931 Comm: nvidia-persiste Tainted: P OE 4.4.0-75-generic #96-Ubuntu
[ 29.798452] Hardware name: Microsoft Corporation Virtual Machine/Virtual Machine, BIOS 090006 01/06/2017
[ 29.798452] task: ffff880e97dd8000 ti: ffff880e9cedc000 task.ti: ffff880e9cedc000
[ 29.798452] RIP: 0010:[<ffffffffc075549f>] [<ffffffffc075549f>] _nv011745rm+0x1f/0x170 [nvidia]
[ 29.798452] RSP: 0018:ffff880e9cedf9d0 EFLAGS: 00010282
[ 29.798452] RAX: 0000000000000000 RBX: ffff880e977dc008 RCX: ffff880e9d322f44
[ 29.798452] RDX: 0000000000000008 RSI: 0000000000000000 RDI: ffff880e977dc008
[ 29.798452] RBP: ffff880e9d322f40 R08: ffffffffc0e70cb0 R09: ffff880e9caa2008
[ 29.798452] R10: ffff880e9caa2000 R11: ffffffffc0915c80 R12: 0000000000000000
[ 29.798452] R13: ffff880e9216c008 R14: ffff880e9c5a2008 R15: ffff880e9b2cc008
[ 29.798452] FS: 00007fc653648700(0000) GS:ffff880ea5740000(0000) knlGS:0000000000000000
[ 29.798452] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 29.798452] CR2: 0000000000000340 CR3: 0000000e9ce0c000 CR4: 00000000001406e0
[ 29.798452] Stack:
[ 29.798452] ffff880e977dc008 ffff880e977dc008 ffff880e9216c008 ffffffffc0748847
[ 29.798452] 0000000000000000 ffffffffc07485c0 0000000000000000 ffff880e9216c008
[ 29.798452] ffff880e977dc008 0000000000000000 ffff880e9c5a2008 ffffffffc09802c7
[ 29.798452] Call Trace:
[ 29.798452] [<ffffffffc0748847>] ? _nv011904rm+0x5f7/0x690 [nvidia]
[ 29.798452] [<ffffffffc07485c0>] ? _nv011904rm+0x370/0x690 [nvidia]
[ 29.798452] [<ffffffffc09802c7>] ? _nv012143rm+0x117/0x290 [nvidia]
[ 32.200006] [<ffffffffc0a24897>] ? _nv017616rm+0x327/0x480 [nvidia]
[ 32.200006] [<ffffffffc0a2606b>] ? _nv000800rm+0xeb/0x6e0 [nvidia]
[ 32.200006] [<ffffffffc0a1a098>] ? rm_init_adapter+0x128/0x130 [nvidia]
[ 32.200006] [<ffffffff810ac515>] ? wake_up_process+0x15/0x20
[ 32.200006] [<ffffffffc04684fd>] ? nv_open_device+0x12d/0x6d0 [nvidia]
[ 32.200006] [<ffffffffc0468d8d>] ? nvidia_open+0x14d/0x2f0 [nvidia]
[ 32.200006] [<ffffffffc0467328>] ? nvidia_frontend_open+0x58/0xa0 [nvidia]
[ 32.200006] [<ffffffff8121384f>] ? chrdev_open+0xbf/0x1b0
[ 32.200006] [<ffffffff8120c96f>] ? do_dentry_open+0x1ff/0x310
[ 32.200006] [<ffffffff81213790>] ? cdev_put+0x30/0x30
[ 32.200006] [<ffffffff8120db04>] ? vfs_open+0x54/0x80
[ 32.200006] [<ffffffff8121983b>] ? may_open+0x5b/0xf0
[ 32.200006] [<ffffffff8121d6b7>] ? path_openat+0x1b7/0x1330
[ 32.200006] [<ffffffff8121fa21>] ? do_filp_open+0x91/0x100
[ 32.200006] [<ffffffff8122d326>] ? __alloc_fd+0x46/0x190
[ 32.200006] [<ffffffff8120ded8>] ? do_sys_open+0x138/0x2a0
[ 32.200006] [<ffffffff8120e05e>] ? SyS_open+0x1e/0x20
[ 32.200006] [<ffffffff8183b972>] ? entry_SYSCALL_64_fastpath+0x16/0x71
[ 32.200006] Code: 90 90 90 90 90 90 90 90 90 90 90 90 41 55 ba 08 00 00 00 41 54 53 48 83 ed 08 4c 8b a7 08 1e 00 00 48 89 fb 48 8d 4d 04 4c 89 e6 <41> ff 94 24 40 03 00 00 85 c0 be 00 00 56 00 75 30 0f b6 45 04
[ 32.200006] RIP [<ffffffffc075549f>] _nv011745rm+0x1f/0x170 [nvidia]
[ 32.200006] RSP <ffff880e9cedf9d0>
[ 32.200006] CR2: 0000000000000340
[ 32.201462] ---[ end trace 755709bc36b69e29 ]---
nvidia-bug-report.log (185 KB)
