The post Can’t boot from EMMC when doing reboot stress test with Jetson Linux 35.1 - Jetson & Embedded Systems / Jetson Xavier NX - NVIDIA Developer Forums figure out the root cause as following:
There is a problem in HDMI driver and will cause panic. We are still checking.
And there is a mechanism to put board into recovery boot in rel-35.1. If kernel panic too many times, then it will happen.
[ 6.988564] tegradc 15200000.display: Bootloader disp_param detected. Detected mode: 8x4 (on 0x0mm) pclk=148350937
