Kimi K2.5 Function error
When trying to use Kimi K2.5 using an API call, it returns the error: “Not Found {“status”:404,“title”:“Not Found”,“detail”:“Function ‘2f5cfeda-5c53-4160-a1bc-8e1f8ad57e35’: Not found for account ‘…”}”
Have you used a valid API to authenticate? Alo make check if the base_api is set correctly. You can find a sample example at kimi-k2.5 Model by Moonshotai | NVIDIA NIM
