Latest ubuntu jetson update 5th august 2025 (no web browsers)
After the latest update, there are no web browsers working?
See (there are some workarounds here, just skim until you find those):
https://forums.developer.nvidia.com/t/jetson-orin-nano-browser-issue/338580
The shorter answer is that some apps in snap started individually enabling SElinux despite this not being enabled by the system. Most desktop systems have SElinux support and SElinux filesystem labels, although they don’t necessarily enforce this. Jetsons, by default, have not enabled SElinux and have not added SElinux filesystem labels. Those individual applications are what caused this and are not controlled by Jetsons. One can enable the kernel config to support SElinux or otherwise work around the SElinux changes (which are to chromium, not due to Jetsons). You might find some other individual application running in snap do this as well, although I’ve not heard of any yet.
If you use Jetson Orin Nano, please adopt either solution:
Chromium, other browsers not working after flashing or updating - Here's WHY and QUICK FIX
or
Jetson orin nano - Browser issue - #74 by DaneLLL
