Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.6 and DriveWorks 4.0
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.7.1.8928
other
Host Machine Version
native Ubuntu 18.04
other
I am trying to run the sample_lidar_replay with velodyne lidar VLP16 but getting failed. I am able to run the lidar with ROS using the same ip address, Can anyone help me with that? Thank you.
sudo ./sample_lidar_replay --protocol=lidar.socket --params=ip=192.168.100.3,port=2368,scan-frequency=10,device=VELO_VLP16
[sudo] password for nvidia:
Starting my sample application…
[04-03-2022 12:35:15] Platform: Detected DDPX - Tegra A
[04-03-2022 12:35:15] TimeSource: monotonic epoch time offset is 1646329245562661
[04-03-2022 12:35:15] TimeSource Nvpss : PTP ioctl returned error. Synchronized time will not be available from this timesource.
[04-03-2022 12:35:15] TimeSource: Could not detect valid PTP time source at nvpps. Fallback to eth0
[04-03-2022 12:35:15] TimeSource Eth: Lost PTP time synchronizaton. Synchronized time will not be available from this timesource.
[04-03-2022 12:35:15] TimeSource: Could not detect valid PTP time source at ‘eth0’. Fallback to CLOCK_MONOTONIC.
[04-03-2022 12:35:15] Platform: number of GPU devices detected 1
[04-03-2022 12:35:15] Platform: currently selected GPU device integrated ID 0
[04-03-2022 12:35:15] Context::mountResourceCandidateDataPath resource FAILED to mount from ‘/usr/local/driveworks-4.0/bin/data/’: VirtualFileSystem: Failed to mount ‘/usr/local/driveworks-4.0/bin/data/[.pak]’
[04-03-2022 12:35:15] Context::findDataRootInPathWalk data/DATA_ROOT found at: /usr/local/driveworks-4.0/bin/…/data
[04-03-2022 12:35:15] Context::mountResourceCandidateDataPath resource FAILED to mount from ‘/usr/local/driveworks-4.0/bin/…/data/’: VirtualFileSystem: Failed to mount ‘/usr/local/driveworks-4.0/bin/…/data/[.pak]’
[04-03-2022 12:35:15] Context::findDataRootInPathWalk data/DATA_ROOT found at: /usr/local/driveworks-4.0/data
[04-03-2022 12:35:15] Context::mountResourceCandidateDataPath resource FAILED to mount from ‘/usr/local/driveworks-4.0/data/’: VirtualFileSystem: Failed to mount ‘/usr/local/driveworks-4.0/data/[.pak]’
[04-03-2022 12:35:15] SDK: No resources(.pak) mounted, some modules will not function properly
[04-03-2022 12:35:15] SDK: Create NvMediaDevice
[04-03-2022 12:35:15] SDK: Create NvMedia2D
[04-03-2022 12:35:15] SDK: use EGL display as provided
[04-03-2022 12:35:16] TimeSource: monotonic epoch time offset is 1646329245562662
[04-03-2022 12:35:16] TimeSource Nvpss : PTP ioctl returned error. Synchronized time will not be available from this timesource.
[04-03-2022 12:35:16] TimeSource: Could not detect valid PTP time source at nvpps. Fallback to eth0
[04-03-2022 12:35:16] TimeSource Eth: Lost PTP time synchronizaton. Synchronized time will not be available from this timesource.
[04-03-2022 12:35:16] TimeSource: Could not detect valid PTP time source at ‘eth0’. Fallback to CLOCK_MONOTONIC.
[04-03-2022 12:35:16] Initialize DriveWorks SDK v4.0.0
[04-03-2022 12:35:16] Release build with GNU 7.3.1 from no-gitversion-build against Drive PDK v5.2.6.0
[04-03-2022 12:35:16] SensorFactory::createSensor() → lidar.socket, ip=192.168.100.3,port=2368,scan-frequency=10,device=VELO_VLP16
[04-03-2022 12:35:16] LidarSocket::getParameters, return-mode not specified. Using default value 2
[04-03-2022 12:35:16] hfov-start is empty, default value 0 will be used
[04-03-2022 12:35:16] hfov-end is empty, default value 360 will be used
[04-03-2022 12:35:16] Destination IP address, Horizontal Resolution is used only by OUSTER Lidar
[04-03-2022 12:35:16] Return Mode is used only by Velodyne Lidar
[04-03-2022 12:35:16] Horizontal FOV is used only by Ouster and Velodyne Lidars
[04-03-2022 12:35:16] , Device magic number = 3405770240
[04-03-2022 12:35:31] Driveworks exception thrown: DW_SAL_CANNOT_INITIALIZE: LidarSocket::checkDeviceData, 192.168.100.3:2368 is not connected
terminate called after throwing an instance of ‘std::runtime_error’
what(): [2022-03-04 12:35:31] DW Error DW_SAL_CANNOT_INITIALIZE executing DW function:
dwSAL_createSensor(&m_lidarSensor, params, m_sal)
at samples/sensors/lidar/lidar_replay/main.cpp:124
Aborted
