We’ve recently bought RTX 3090Ti and installed Ubuntu 20.04 on the PC.
PC config is following:
- ASUS PRIME Z690-P D4
- Intel Core i9 12900
- AiO LCS Arctic Liquid Freezer II 360
- DDR4 128GB (4x32GB) 3200MHz Kingston
- SSD 2TB Samsung 980PRO M.2 NVMe + HS
- Thermaltake Toughpower GF3 1000W Gold
I’ve connected GPU with 1x450W PCI gen5 cable.
| NVIDIA-SMI 470.141.03 Driver Version: 470.141.03 CUDA Version: 11.4 |
| | | MIG M. |
| 0 NVIDIA GeForce ... Off | 00000000:01:00.0 On | Off |
| 52% 26C P8 173W / 450W | 359MiB / 24247MiB | 5% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 1092 G /usr/lib/xorg/Xorg 35MiB |
| 0 N/A N/A 1592 G /usr/lib/xorg/Xorg 92MiB |
| 0 N/A N/A 1717 G /usr/bin/gnome-shell 43MiB |
| 0 N/A N/A 2690 G /usr/lib/firefox/firefox 170MiB |
Output of nvidia-smi -q is:
nvidia-smi -q
==============NVSMI LOG==============
Timestamp : Wed Nov 30 16:14:02 2022
Driver Version : 470.141.03
CUDA Version : 11.4
Attached GPUs : 1
GPU 00000000:01:00.0
Product Name : NVIDIA GeForce RTX 3090 Ti
Product Brand : GeForce
Display Mode : Enabled
Display Active : Enabled
Persistence Mode : Disabled
MIG Mode
Current : N/A
Pending : N/A
Accounting Mode : Disabled
Accounting Mode Buffer Size : 4000
Driver Model
Current : N/A
Pending : N/A
Serial Number : N/A
GPU UUID : GPU-25dbaeb1-06fd-9cc5-edb0-af1e35453b51
Minor Number : 0
VBIOS Version : 94.02.A0.00.36
MultiGPU Board : No
Board ID : 0x100
GPU Part Number : N/A
Module ID : 0
Inforom Version
Image Version : G002.0000.00.03
OEM Object : 2.0
ECC Object : 6.16
Power Management Object : N/A
GPU Operation Mode
Current : N/A
Pending : N/A
GSP Firmware Version : N/A
GPU Virtualization Mode
Virtualization Mode : None
Host VGPU Mode : N/A
IBMNPU
Relaxed Ordering Mode : N/A
PCI
Bus : 0x01
Device : 0x00
Domain : 0x0000
Device Id : 0x220310DE
Bus Id : 00000000:01:00.0
Sub System Id : 0x88741043
GPU Link Info
PCIe Generation
Max : 4
Current : 1
Link Width
Max : 16x
Current : 8x
Bridge Chip
Type : N/A
Firmware : N/A
Replays Since Reset : 0
Replay Number Rollovers : 0
Tx Throughput : 0 KB/s
Rx Throughput : 6000 KB/s
Fan Speed : 52 %
Performance State : P8
Clocks Throttle Reasons
Idle : Active
Applications Clocks Setting : Not Active
SW Power Cap : Not Active
HW Slowdown : Not Active
HW Thermal Slowdown : Not Active
HW Power Brake Slowdown : Not Active
Sync Boost : Not Active
SW Thermal Slowdown : Not Active
Display Clock Setting : Not Active
FB Memory Usage
Total : 24247 MiB
Used : 350 MiB
Free : 23897 MiB
BAR1 Memory Usage
Total : 32768 MiB
Used : 15 MiB
Free : 32753 MiB
Compute Mode : Default
Utilization
Gpu : 3 %
Memory : 14 %
Encoder : 0 %
Decoder : 0 %
Encoder Stats
Active Sessions : 0
Average FPS : 0
Average Latency : 0
FBC Stats
Active Sessions : 0
Average FPS : 0
Average Latency : 0
Ecc Mode
Current : Disabled
Pending : Disabled
ECC Errors
Volatile
SRAM Correctable : N/A
SRAM Uncorrectable : N/A
DRAM Correctable : N/A
DRAM Uncorrectable : N/A
Aggregate
Retired Pages
Single Bit ECC : N/A
Double Bit ECC : N/A
Pending Page Blacklist : N/A
Remapped Rows
Correctable Error : 0
Uncorrectable Error : 0
Pending : No
Remapping Failure Occurred : No
Bank Remap Availability Histogram
Max : 192 bank(s)
High : 0 bank(s)
Partial : 0 bank(s)
Low : 0 bank(s)
None : 0 bank(s)
Temperature
GPU Current Temp : 26 C
GPU Shutdown Temp : 97 C
GPU Slowdown Temp : 94 C
GPU Max Operating Temp : 92 C
GPU Target Temperature : 83 C
Memory Current Temp : N/A
Memory Max Operating Temp : N/A
Power Readings
Power Management : Supported
Power Draw : 172.68 W
Power Limit : 450.00 W
Default Power Limit : 450.00 W
Enforced Power Limit : 450.00 W
Min Power Limit : 100.00 W
Max Power Limit : 516.00 W
Clocks
Graphics : 210 MHz
SM : 210 MHz
Memory : 405 MHz
Video : 555 MHz
Applications Clocks
Graphics : N/A
Memory : N/A
Default Applications Clocks
Graphics : N/A
Memory : N/A
Max Clocks
Graphics : 2115 MHz
SM : 2115 MHz
Memory : 10501 MHz
Video : 1950 MHz
Max Customer Boost Clocks
Graphics : N/A
Clock Policy
Auto Boost : N/A
Auto Boost Default : N/A
Voltage
Graphics : 745.000 mV
Processes
GPU instance ID : N/A
Compute instance ID : N/A
Process ID : 1092
Type : G
Used GPU Memory : 35 MiB
Process ID : 1592
Type : G
Used GPU Memory : 92 MiB
Process ID : 1717
Type : G
Used GPU Memory : 44 MiB
Process ID : 2690
Type : Gnvidia-smi -q
CUDA Version : 11.4
Attached GPUs : 1
MIG Mode
Current : N/A
Pending : N/A
Driver Model
Current : N/A
Pending : N/A
Serial Number : N/A
Minor Number : 0
MultiGPU Board : No
Board ID : 0x100
Module ID : 0
Inforom Version
OEM Object : 2.0
ECC Object : 6.16
GPU Operation Mode
Current : N/A
Pending : N/A
IBMNPU
PCI
Bus : 0x01
Device : 0x00
Domain : 0x0000
GPU Link Info
PCIe Generation
Max : 4
Current : 1
Link Width
Max : 16x
Current : 8x
Bridge Chip
Type : N/A
Firmware : N/A
Fan Speed : 52 %
Idle : Active
FB Memory Usage
Total : 24247 MiB
Used : 350 MiB
Free : 23897 MiB
BAR1 Memory Usage
Total : 32768 MiB
Used : 15 MiB
Free : 32753 MiB
Utilization
Gpu : 3 %
Memory : 14 %
Encoder : 0 %
Decoder : 0 %
Encoder Stats
Active Sessions : 0
Average FPS : 0
Average Latency : 0
FBC Stats
Active Sessions : 0
Average FPS : 0
Average Latency : 0
Ecc Mode
Current : Disabled
Pending : Disabled
ECC Errors
Volatile
Aggregate
Retired Pages
CUDA Version : 11.4
Attached GPUs : 1
MIG Mode
Current : N/A
Pending : N/A
Driver Model
Current : N/A
Pending : N/A
Serial Number : N/A
Minor Number : 0
MultiGPU Board : No
Board ID : 0x100
Module ID : 0
Inforom Version
OEM Object : 2.0
ECC Object : 6.16
GPU Operation Mode
Current : N/A
Pending : N/A
IBMNPU
PCI
Bus : 0x01
Device : 0x00
Domain : 0x0000
GPU Link Info
PCIe Generation
Max : 4
Current : 1
Link Width
Max : 16x
Current : 8x
Bridge Chip
Type : N/A
Firmware : N/A
Fan Speed : 52 %
Idle : Active
FB Memory Usage
Total : 24247 MiB
Used : 350 MiB
Free : 23897 MiB
BAR1 Memory Usage
Total : 32768 MiB
Used : 15 MiB
Free : 32753 MiB
Utilization
Gpu : 3 %
Memory : 14 %
Encoder : 0 %
Decoder : 0 %
Encoder Stats
Active Sessions : 0
Average FPS : 0
Average Latency : 0
FBC Stats
Active Sessions : 0
Average FPS : 0
Average Latency : 0
Ecc Mode
Current : Disabled
Pending : Disabled
ECC Errors
Volatile
Aggregate
Retired Pages
Remapped Rows
Pending : No
Max : 192 bank(s)
High : 0 bank(s)
Partial : 0 bank(s)
Low : 0 bank(s)
None : 0 bank(s)
Temperature
Power Readings
Clocks
Graphics : 210 MHz
SM : 210 MHz
Memory : 405 MHz
Video : 555 MHz
Applications Clocks
Graphics : N/A
Memory : N/A
Graphics : N/A
Memory : N/A
Max Clocks
Graphics : 2115 MHz
SM : 2115 MHz
Memory : 10501 MHz
Video : 1950 MHz
Graphics : N/A
Clock Policy
Auto Boost : N/A
Voltage
Processes
Process ID : 1092
Type : G
Process ID : 1592
Type : G
Process ID : 1717
Type : G
Process ID : 2690
Type : G
Used GPU Memory : 160 MiB
Remapped Rows
Pending : No
Max : 192 bank(s)
High : 0 bank(s)
Partial : 0 bank(s)
Low : 0 bank(s)
None : 0 bank(s)
Temperature
Power Readings
Clocks
Graphics : 210 MHz
SM : 210 MHz
Memory : 405 MHz
Video : 555 MHz
Applications Clocks
Graphics : N/A
Memory : N/A
Graphics : N/A
Memory : N/A
Max Clocks
Graphics : 2115 MHz
SM : 2115 MHz
Memory : 10501 MHz
Video : 1950 MHz
Graphics : N/A
Clock Policy
Auto Boost : N/A
Voltage
Processes
Process ID : 1092
Type : G
Process ID : 1592
Type : G
Process ID : 1717
Type : G
Process ID : 2690
Type : G
What bothers me:
Idle : Active
Where PC basically alternates in between SW Power Cap and Idle power cap thus limiting GPU to P5 or P8 performance mode. In P8 GPU runs at max 210 MHz clock, which is quite sad.
Any help would be appreciated cause in this form, card is basically useless, ty, cheers :)
