I am confused to use a static library file *.a that compiled from “nvcc” command.
I put the *.cu and *.h in the path : /home/fbg/NVIDIA_CUDA_SDK/projects/interleave_7/
, then I used the below command to produce a *.a file.
nvcc -o libCUDA_interleave_7.a CUDA_interleave_7.cu -L/home/fbg/NVIDIA_CUDA_SDK/common/lib/linux/ -L/home/fbg/NVIDIA_CUDA_SDK/lib -lcudpp -lcutil -lib --compiler-options ‘-fPIC’
It seems ok to get a *.a file, but it cause some problem when I add this *.a into other project and make the execute file.
I don’t know what’s wrong with my steps, or other notes I ignore??? :wacko:
//-------------- error message -----------------------------------------------------------
tmpxft_00003d2e_00000000-11_CUDA_interleave_7.ii:(.text+0x6e22): undefined reference to `__cudaRegisterFatBinary’
tmpxft_00003d2e_00000000-11_CUDA_interleave_7.ii:(.text+0x6e94): undefined reference to `__cudaRegisterFunction’
tmpxft_00003d2e_00000000-11_CUDA_interleave_7.ii:(.text+0x6ed6): undefined reference to `__cudaRegisterTexture’
/home/fbg/work/MyProject/…/libraries/i686-linux/lib_release_client/libCUDA_interleave_7.a(tmpxft_00003d2e_00000000-12_CUDA_interleave_7.o): In function `_device_stub__Z20GPU_interleave_7viewiiiiPhS’:
tmpxft_00003d2e_00000000-11_CUDA_interleave_7.ii:(.text+0x6f59): undefined reference to `cudaSetupArgument’
tmpxft_00003d2e_00000000-11_CUDA_interleave_7.ii:(.text+0x6f81): undefined reference to `cudaSetupArgument’
tmpxft_00003d2e_00000000-11_CUDA_interleave_7.ii:(.text+0x6fa9): undefined reference to `cudaSetupArgument’
/home/fbg/work/MyProject/…/libraries/i686-linux/lib_release_client/libCUDA_interleave_7.a(tmpxft_00003d2e_00000000-12_CUDA_interleave_7.o):tmpxft_00003d2e_00000000-11_CUDA_interleave_7.ii:(.text+0x701f): more undefined references to `cudaSetupArgument’ follow
/home/fbg/work/MyProject/…/libraries/i686-linux/lib_release_client/libCUDA_interleave_7.a(tmpxft_00003d2e_00000000-12_CUDA_interleave_7.o): In function `__ftexfetch’:
tmpxft_00003d2e_00000000-11_CUDA_interleave_7.ii:(.text+0x7be2): undefined reference to `__cudaTextureFetch’
/home/fbg/work/MyProject/…/libraries/i686-linux/lib_release_client/libCUDA_interleave_7.a(tmpxft_00003d2e_00000000-12_CUDA_interleave_7.o): In function `__utexfetch’:
tmpxft_00003d2e_00000000-11_CUDA_interleave_7.ii:(.text+0x7c22): undefined reference to `__cudaTextureFetch’
/home/fbg/work/MyProject/…/libraries/i686-linux/lib_release_client/libCUDA_interleave_7.a(tmpxft_00003d2e_00000000-12_CUDA_interleave_7.o): In function `__itexfetch’:
tmpxft_00003d2e_00000000-11_CUDA_interleave_7.ii:(.text+0x7c62): undefined reference to `__cudaTextureFetch’
tmpxft_00003d2e_00000000-11_CUDA_interleave_7.ii:(.text+0x7ce2): undefined reference to `__cudaTextureFetch’
/home/fbg/work/MyProject/…/libraries/i686-linux/lib_release_client/libCUDA_interleave_7.a(tmpxft_00003d2e_00000000-12_CUDA_interleave_7.o):tmpxft_00003d2e_00000000-11_CUDA_interleave_7.ii:(.text+0x7d22): more undefined references to `__cudaTextureFetch’ follow
/home/fbg/work/MyProject/…/libraries/i686-linux/lib_release_client/libCUDA_interleave_7.a(tmpxft_00003d2e_00000000-12_CUDA_interleave_7.o): In function `__cudaUnregisterBinaryUtil’:
tmpxft_00003d2e_00000000-11_CUDA_interleave_7.ii:(.text+0xa5f0): undefined reference to `__cudaUnregisterFatBinary’
/home/fbg/work/MyProject/…/libraries/i686-linux/lib_release_client/libCUDA_interleave_7.a(tmpxft_00003d2e_00000000-12_CUDA_interleave_7.o): In function `CUDA_7view_interleave_dele(unsigned char**, unsigned char**)':
tmpxft_00003d2e_00000000-11_CUDA_interleave_7.ii:(.text+0xa61c): undefined reference to `cudaFree’
tmpxft_00003d2e_00000000-11_CUDA_interleave_7.ii:(.text+0xa63b): undefined reference to `cudaFree’
/home/fbg/work/MyProject/…/libraries/i686-linux/lib_release_client/libCUDA_interleave_7.a(tmpxft_00003d2e_00000000-12_CUDA_interleave_7.o): In function `CUDA_7view_interleave_proc(int, int, int, int, int, int, unsigned char*, unsigned char*, unsigned char*, unsigned char*, unsigned char*, unsigned char*, unsigned char*, unsigned char*, unsigned char*, unsigned char*)':
tmpxft_00003d2e_00000000-11_CUDA_interleave_7.ii:(.text+0xa6de): undefined reference to `cudaMemcpy’
