Hello, so I’m currently trying to port my c++ code to GPUs using OpenACC as opposed to CUDA to save some time on the port. I’m following this document to port my classes into OpenACC https://www.pgroup.com/lit/brochures/openacc_sc14.pdf
However when the code is linked I get the undefined symbols in both the class and where the class is called. I’ll provide a dump of all output I have. I’m not that familiar with Open ACC, so there may be a lot of irrelevant information. Any help with this would be much appreciated. Many thanks in advance!
The linker error in the class is:
Solution.o: In function
Solution::devcopyin()': /usr/include/c++/5/cmath:292: undefined reference to__pgi_uacc_dataenterstart’
/usr/include/c++/5/cmath:292: undefined reference to__pgi_uacc_dataonb' /usr/include/c++/5/cmath:292: undefined reference to__pgi_uacc_dataenterdone’
and from where the class is called:
Solver.o: In function
Solver::General_Purpose_Solver_mk_i(unstructured_mesh&, Solution&, Boundary_Conditions&, external_forces&, global_variables&, domain_geometry&, initial_conditions&, unstructured_bcs&, int, Solution&, int, post_processing&)': /usr/include/c++/5/bits/stl_uninitialized.h:301: undefined reference to__pgi_uacc_dataenterstart’
/usr/include/c++/5/bits/stl_uninitialized.h:301: undefined reference to__pgi_uacc_dataonb' /usr/include/c++/5/bits/stl_uninitialized.h:301: undefined reference to__pgi_uacc_dataonb’
/usr/include/c++/5/bits/stl_uninitialized.h:301: undefined reference to__pgi_uacc_dataonb' /usr/include/c++/5/bits/stl_uninitialized.h:301: undefined reference to__pgi_uacc_dataenterdone’
/usr/include/c++/5/bits/stl_uninitialized.h:301: undefined reference to__pgi_uacc_enter' /usr/include/c++/5/bits/stl_uninitialized.h:301: undefined reference to__pgi_uacc_dataenterstart’
/usr/include/c++/5/bits/stl_uninitialized.h:301: undefined reference to__pgi_uacc_dataenterdone' /usr/include/c++/5/bits/stl_uninitialized.h:301: undefined reference to__pgi_uacc_computestart’
/usr/include/c++/5/bits/stl_uninitialized.h:301: undefined reference to__pgi_uacc_launch' /usr/include/c++/5/bits/stl_uninitialized.h:301: undefined reference to__pgi_uacc_computedone’
/usr/include/c++/5/bits/stl_uninitialized.h:301: undefined reference to__pgi_uacc_dataexitstart' /usr/include/c++/5/bits/stl_uninitialized.h:301: undefined reference to__pgi_uacc_dataoffb2’
/usr/include/c++/5/bits/stl_uninitialized.h:301: undefined reference to__pgi_uacc_dataoffb2' /usr/include/c++/5/bits/stl_uninitialized.h:301: undefined reference to__pgi_uacc_dataexitdone’
/usr/include/c++/5/bits/stl_uninitialized.h:301: undefined reference to__pgi_uacc_noversion' /usr/include/c++/5/bits/stl_uninitialized.h:301: undefined reference to__pgi_uacc_dataexitstart’
/usr/include/c++/5/bits/stl_uninitialized.h:301: undefined reference to__pgi_uacc_dataoffb2' /usr/include/c++/5/bits/stl_uninitialized.h:301: undefined reference to__pgi_uacc_dataoffb2’
The class constructor and devcopyin function are given as:
Solution::Solution(int _total_nodes)
//ctor
total_nodes = _total_nodes;
rho = new double [total_nodes ];
if (rho==NULL) exit (1);
u = new double [total_nodes];
if (u==NULL) exit (1);
v = new double [total_nodes ];
if (v==NULL) exit (1);
w = new double [total_nodes ];
if (w==NULL) exit (1);
error = new double [total_nodes ];
if (error==NULL) exit (1);
Initialise();
void Solution::devcopyin(){
#pragma acc enter data copyin (this)
#pragma acc enter data copyin(rho[0:total_nodes])
#pragma acc enter data copyin(u[0:total_nodes])
#pragma acc enter data copyin(v[0:total_nodes])
#pragma acc enter data copyin(w[0:total_nodes])
#pragma acc enter data copyin(error[0:total_nodes])
The parallel kernel stripped down to scalers and the above class is:
soln.devcopyin();
soln_t1.devcopyin();
soln_t0.devcopyin();
residual_worker.devcopyin();
temp_soln.devcopyin();
#pragma acc kernels present(soln , soln_t1, soln_t0 , residual_worker, temp_soln)
double f1,f2,f3,f4;
f1 = 0.0;
f2 = 0.0;
f3 = 0.0;
f4 = 0.0;
double d_t_temp = 1.0;
//update RK values
for( int i=0; i < Mesh.get_n_cells(); i++){
// update intermediate macroscopic variables for next Runge Kutta Time Step
f1 = soln_t0.get_rho(i) + residual_worker.get_rho(i)* d_t_temp ;
f2 = soln_t0.get_u(i) + (residual_worker.get_u(i)) * d_t_temp;
f3 = soln_t0.get_v(i) + residual_worker.get_v(i) * d_t_temp;
f4 = soln_t0.get_w(i) + residual_worker.get_w(i) * d_t_temp;
// change momentum to velocity
f2 = f2/f1;
f3 =f3/f1;
f4=f4/f1;
temp_soln.update(f1,f2,f3,f4, i);
//temp_soln.update(1.0,f2,0.0,0.0, i);
//add contributions to
soln_t1.add_rho(i, d_t_temp * residual_worker.get_rho(i));
soln_t1.add_u(i, d_t_temp * (residual_worker.get_u(i)));
soln_t1.add_v(i, d_t_temp* residual_worker.get_v(i));
soln_t1.add_w(i, d_t_temp * residual_worker.get_w(i));
f1 = soln_t1.get_rho(i);
f2 = soln_t1.get_u(i)/soln_t1.get_rho(i);
f3 = soln_t1.get_v(i)/soln_t1.get_rho(i);
f4= soln_t1.get_w(i)/soln_t1.get_rho(i);
//soln.update(1.0,f2,0.0,0.0, i);
This is the makefile:
CC = pgc++
src = $(wildcard *.cpp)
obj = $(src:.cpp=.o)
CCFLAGS = -O2 -Kieee -std=c++11 -Mprof=ccff -Iinclude -I/home/brendan/boost_1_64_0/prefix/include -I/usr/local/tecplot/360ex_2018r1/include -I/home/brendan/Eigen -I/home/brendan/CGNS/CGNS-3.3.1/src -I/usr/include/
ACCFLAGS = -acc -ta=tesla -Minfo=accel
LDFLAGS = /usr/local/tecplot/360ex_2017r2/bin/libtecio.so /home/brendan/boost_1_64_0/prefix/lib/libboost_system.a /home/brendan/boost_1_64_0/prefix/lib/libboost_filesystem.a /home/brendan/CGNS/CGNS-3.3.1/src/lib/libcgns.a
myprog: $(obj)
$(CC) -o $@ $^ -v $(LDFLAGS)
%.o : %.cpp
$(CC) $(CCFLAGS) $(ACCFLAGS) -o $@ -c $<
.PHONY: clean
clean:
rm -f $(obj) myprog
and finally this is the command line output of the linker:
pgc++ -o myprog RungeKutta.o Mesh.o residuals.o quad_bcs.o vector_var.o initial_conditions.o quad_bcs_plus.o unstructured_mesh.o gradients.o artificial_dissipation.o program.o external_forces.o domain_geometry.o preprocessor.o global_variables.o tecplot_output.o Boundary_Conditions.o tinyxml2.o post_processing.o flux_var.o main.o unstructured_bcs.o Solver.o Solution.o -v /usr/local/tecplot/360ex_2017r2/bin/libtecio.so /home/brendan/boost_1_64_0/prefix/lib/libboost_system.a /home/brendan/boost_1_64_0/prefix/lib/libboost_filesystem.a /home/brendan/CGNS/CGNS-3.3.1/src/lib/libcgns.a
Export PGI=/opt/pgi
/usr/bin/ld /usr/lib/x86_64-linux-gnu/crt1.o /usr/lib/x86_64-linux-gnu/crti.o /opt/pgi/linux86-64/18.4/lib/trace_init.o /usr/lib/gcc/x86_64-linux-gnu/5/crtbegin.o /opt/pgi/linux86-64/18.4/lib/initmp.o --eh-frame-hdr -m elf_x86_64 -dynamic-linker /lib64/ld-linux-x86-64.so.2 /opt/pgi/linux86-64/18.4/lib/pgi.ld -L/opt/pgi/linux86-64/18.4/lib -L/usr/lib64 -L/usr/lib/gcc/x86_64-linux-gnu/5 RungeKutta.o Mesh.o residuals.o quad_bcs.o vector_var.o initial_conditions.o quad_bcs_plus.o unstructured_mesh.o gradients.o artificial_dissipation.o program.o external_forces.o domain_geometry.o preprocessor.o global_variables.o tecplot_output.o Boundary_Conditions.o tinyxml2.o post_processing.o flux_var.o main.o unstructured_bcs.o Solver.o Solution.o /usr/local/tecplot/360ex_2017r2/bin/libtecio.so /home/brendan/boost_1_64_0/prefix/lib/libboost_system.a /home/brendan/boost_1_64_0/prefix/lib/libboost_filesystem.a /home/brendan/CGNS/CGNS-3.3.1/src/lib/libcgns.a -rpath /opt/pgi/linux86-64/18.4/lib -rpath /usr/lib/gcc/x86_64-linux-gnu/5/../../../../lib64 -o myprog -L/usr/lib/gcc/x86_64-linux-gnu/5/../../../../lib64 -latomic -lpgatm -lstdc++ -lpgmp -lnuma -lpthread --start-group -lpgmath -lnspgc -lpgc --end-group -lm -lgcc -lc -lgcc -lgcc_s /usr/lib/gcc/x86_64-linux-gnu/5/crtend.o /usr/lib/x86_64-linux-gnu/crtn.o
