I’m stuck migrating a larger software project compiled with pgCC from a SUSE 9.3 Linux build platform
to a SUSE 10.2 Linux build platform.
Using the following compiler and linker versions,
pgCC --version
pgCC 7.1-5 64-bit target on x86-64 Linux -tp k8-64e
/usr/bin/ld --version
GNU ld version 2.15.94.0.2.2 20041220 (SuSE Linux)
the old build system pulls through:
[… snip…]
pgCC -c -tp x64 -O3 -fPIC -mcmodel=small -Minline=levels:10,size:1000 -fastsse -I…/…/include -I/usr/local/rsi/idl/external/include/ shared_memory.cpp -o shared_memory.o
pgCC -c -tp x64 -O3 -fPIC -mcmodel=small -Minline=levels:10,size:1000 -fastsse -I…/…/include -I/usr/local/rsi/idl/external/include/ OpenMP_controls.cpp -o OpenMP_controls.o
ar -rs libsmtk.a shared_memory.o OpenMP_controls.o
ar: creating libsmtk.a
pgCC -tp x64 -mp -O3 -Mipa=fast -fPIC -mcmodel=small -shared -L…/…/lib -L/usr/local/pgi/linux86-64/7.1-5/lib -Wl,–allow-multiple-definition shared_memory.o -lpgftnrtl -lm -o shared_memory.so
IPA inhibited: no main routine
pgCC -tp x64 -mp -O3 -Mipa=fast -fPIC -mcmodel=small -shared -L…/…/lib -L/usr/local/pgi/linux86-64/7.1-5/lib -Wl,–allow-multiple-definition OpenMP_controls.o -lpgftnrtl -lm -o OpenMP_controls.so
[… snip…]
While the new system using the following compiler versions:
pgCC --version
pgCC 7.1-5 64-bit target on x86-64 Linux -tp core2-64
GNU ld version 2.17.50.0.5 20060927 (SUSE Linux)
Does not link:
[… snip…]
/usr/bin/ld: /usr/local/pgi/linux86-64/7.1-5/lib/libstd.a(collate.o): relocation R_X86_64_32S against `a local symbol’ can not be used when making a shared object; recompile with -fPIC
/usr/local/pgi/linux86-64/7.1-5/lib/libstd.a: could not read symbols: Bad value
child process exit status 1: /usr/bin/ld
make: *** [shared_memory.so] Error 2
[… snip…]
Note that the build compiled on the old platform flawlessly executes on the new platform.
Is this a linker problem specific to SUSE 10.2?
Thanks for any hints.
