Release highlights since 530.41.03:
Added support for the
VK_EXT_memory_priority, andVK_EXT_pageable_device_memoryextensions for Turing+ GPUs. -
Improved the performance of Minecraft Java Edition on RTX 3000 series GPUs.
Fixed a memory leak in the NVIDIA GLX driver, as reported at: ASAN reports memory leak in libnvidia-glcore.so.515.57
Added support for driving very high pixel clock mode timings such as 8K @ 60Hz. Please see the
MaxOneHardwareHeadX11 ModeValidation token in the README for details. -
Extended Dynamic Boost support on notebooks to include older Renoir and Cezanne chipsets, in addition to Rembrandt and newer AMD chipsets.
Fixed a bug that caused Vulkan X11 swapchain creation to fail on GPUs without a display engine when the
VK_KHR_present_idextension is used. -
Fixed console restore on legacy VGA consoles when using the NVIDIA Open GPU Kernel Modules.
Added nvoptix.bin to the driver package. This data file is used by the OptiX ray tracing engine library, libnvoptix.so.1.
Removed libnvidia-compiler.so.VERSION from the driver package. This functionality is now provided by other driver libraries.
Added power usage and power limits information to nvidia-settings PowerMizer page.
Updated
NV_CTRL_GPU_POWER_SOURCENV-CONTROL API to report undersized power source. -
Add support for version 4 of the
linux-dmabufwayland protocol. -
Updated the bundled copy of the GBM EGL external platform library:
GitHub - NVIDIA/egl-gbm: The GBM EGL external platform library
The updated version includes the fix for a bug which caused the number of free GBM surface buffers to be reported incorrectly.
Fixed a bug which prevented running a Wayland compositor in headless mode on GPUs without display hardware.
Fixed a regression in Luxmark performance between 525.89.02 and 525.105.17.
Fixed a bug that could cause an unexpected
VK_ERROR_NATIVE_WINDOW_IN_USE_KHRerror in certain circumstances when recreating Vulkan surfaces. -
Fixed a regression that caused brightness control to not vary smoothly across the range of values.
Improved the reliability of suspend and resume on UEFI systems when using certain display panels.
Fixed a bug that prevented some controls in the nvidia-settings control panel from working when running an X server as an unprivileged user.
Fixed a bug which caused incorrect reporting of presentation times when using the
VK_NV_present_barrierVulkan extension. -
Fixed a bug that could cause fullscreen PRIME Render Offload applications and/or X to crash when an NVIDIA GPU is driving multiple displays with Reverse PRIME.
Added support for console restoration when using simpledrm.
Disabled Fixed Rate Link (FRL) when using passive DisplayPort to HDMI dongles, which are incompatible with FRL.
Updated nvidia-modprobe to create symbolic links in /dev/char when creating the /dev/nvidia* device nodes. This resolves an issue that prevented the device nodes from working with newer versions of runc:
Newer runc versions break support for NVIDIA GPUs · Issue #3708 · opencontainers/runc · GitHub
[README | Linux x86_64 | Solaris | FreeBSD x86_64 | Kernel driver source]
