Hi
As title really.
I have a Linux VM with 7.13 VDA installed. Does anyone know how to enable H.264 Encode?
I’ll caveat this by stating I’m not a Linux guy, so have more than likely misunderstood something …
I have an M60 8Q profile assigned so CUDA is available. GRID 4.1 drivers are installed and it’s licensed.
I’m following this guide: Linux Virtual Delivery Agent 2207
However, when I try and run this on the VDA:
sudo ctxreg create -k "HKLM\System\CurrentControlSet\Control\Citrix\Thinwire" -t "REG_DWORD" -v "AdvertiseH264" -d "0x00000001" --force
I get this in response:
sudo: ctxreg: command not found
My initial thoughts were, I’m trying to install a Windows registry key on a Linux VM, of course it won’t work. However, as a non-Linux guy, I actually don’t know.
Instructions as usual aren’t as clear as they should be. So any guidance is appreciated
Many thanks
