Llama.cpp rpc on dgx spark
hey peeps
Anyone using llama cpp’s specially with two sparks and llama rpc-server for distributed inference? recently I’ve been experiencing significant memory leaks especially with the newer models. The llama rpc-server will constantly consume memory during inference but without releasing it and ultimately resulting in OOM error at some point. Worst still, kill the primary node will not release the memory on the rpc-server node. the only way is to kill the rpc server it self.
did you resolve it? or switched to using vllm, given the recognised and excellent support form eugr?
any pointers will be greatly appreciated, thanks in advance.
I am noticing the same thing. It’s probably safer to use vLLM for more than one Spark. I have to restart both Sparks in my cluster after running Unsloth’s Qwen 3.5 397B GGUF.
llama.cpp RPC doesn’t make much sense on Spark since it doesn’t support RDMA and tensor parallel. With vLLM/SGLang you actually gain performance when running in the cluster, up to ~1.8x on dual cluster with dense models, but with llama.cpp RPC you sacrifice performance for the ability to run larger models.
So, for the cluster, vLLM is the way to go at the moment.
thanks @Eugr,
I’ve been looking at your community build, but not have much luck with the first recipe I tried, gpt-oss mxfp4. Looks like the docker image built was okay. When running vllm getting this error. log below, any thoughts?,
(EngineCore_DP0 pid=1336) (RayWorkerWrapper pid=1459) INFO 03-01 15:08:42 [mxfp4.py:803] [MXFP4] lm_head quantized: torch.Size([100544, 2880]) BF16 -> torch.Size([100544, 1440]) FP4 (4x smaller)
(EngineCore_DP0 pid=1336) (RayWorkerWrapper pid=1459) INFO 03-01 15:08:42 [gpu_model_runner.py:3901] Model loading took 31.9972 GiB memory and 50.021620 seconds
(EngineCore_DP0 pid=1336) (RayWorkerWrapper pid=1459) INFO 03-01 15:08:43 [decorators.py:432] Directly load AOT compilation from path /root/.cache/vllm/torch_aot_compile/fb5f1d6fe83b24616726df86c6bc4bca2d951023b09c3197cd61ac41306ddb9d/rank_0_0/model
(EngineCore_DP0 pid=1336) (RayWorkerWrapper pid=1459) INFO 03-01 15:08:44 [backends.py:644] Using cache directory: /root/.cache/vllm/torch_compile_cache/1c5fbe4478/rank_0_0/backbone for vLLM's torch.compile
(EngineCore_DP0 pid=1336) (RayWorkerWrapper pid=1459) INFO 03-01 15:08:44 [backends.py:704] Dynamo bytecode transform time: 1.20 s
(EngineCore_DP0 pid=1336) ERROR 03-01 15:08:53 [core.py:900] EngineCore failed to start.
(EngineCore_DP0 pid=1336) ERROR 03-01 15:08:53 [core.py:900] Traceback (most recent call last):
(EngineCore_DP0 pid=1336) ERROR 03-01 15:08:53 [core.py:900]   File "/usr/local/lib/python3.12/dist-packages/vllm/v1/engine/core.py", line 891, in run_engine_core
(EngineCore_DP0 pid=1336) ERROR 03-01 15:08:53 [core.py:900]     engine_core = EngineCoreProc(*args, engine_index=dp_rank, **kwargs)
(EngineCore_DP0 pid=1336) ERROR 03-01 15:08:53 [core.py:900]                   ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
(EngineCore_DP0 pid=1336) ERROR 03-01 15:08:53 [core.py:900]   File "/usr/local/lib/python3.12/dist-packages/vllm/v1/engine/core.py", line 656, in __init__
(EngineCore_DP0 pid=1336) ERROR 03-01 15:08:53 [core.py:900]     super().__init__(
(EngineCore_DP0 pid=1336) ERROR 03-01 15:08:53 [core.py:900]   File "/usr/local/lib/python3.12/dist-packages/vllm/v1/engine/core.py", line 112, in __init__
(EngineCore_DP0 pid=1336) ERROR 03-01 15:08:53 [core.py:900]     num_gpu_blocks, num_cpu_blocks, kv_cache_config = self._initialize_kv_caches(
(EngineCore_DP0 pid=1336) ERROR 03-01 15:08:53 [core.py:900]   File "/usr/local/lib/python3.12/dist-packages/vllm/v1/engine/core.py", line 243, in _initialize_kv_caches
(EngineCore_DP0 pid=1336) ERROR 03-01 15:08:53 [core.py:900]     available_gpu_memory = self.model_executor.determine_available_memory()
(EngineCore_DP0 pid=1336) ERROR 03-01 15:08:53 [core.py:900]   File "/usr/local/lib/python3.12/dist-packages/vllm/v1/executor/abstract.py", line 126, in determine_available_memory
(EngineCore_DP0 pid=1336) ERROR 03-01 15:08:53 [core.py:900]     return self.collective_rpc("determine_available_memory")
(EngineCore_DP0 pid=1336) ERROR 03-01 15:08:53 [core.py:900]   File "/usr/local/lib/python3.12/dist-packages/vllm/v1/executor/ray_executor.py", line 490, in collective_rpc
(EngineCore_DP0 pid=1336) ERROR 03-01 15:08:53 [core.py:900]     return ray.get(ray_worker_outputs, timeout=timeout)
(EngineCore_DP0 pid=1336) ERROR 03-01 15:08:53 [core.py:900]   File "/usr/local/lib/python3.12/dist-packages/ray/_private/auto_init_hook.py", line 22, in auto_init_wrapper
(EngineCore_DP0 pid=1336) ERROR 03-01 15:08:53 [core.py:900]     return fn(*args, **kwargs)
(EngineCore_DP0 pid=1336) ERROR 03-01 15:08:53 [core.py:900]   File "/usr/local/lib/python3.12/dist-packages/ray/_private/client_mode_hook.py", line 104, in wrapper
(EngineCore_DP0 pid=1336) ERROR 03-01 15:08:53 [core.py:900]     return func(*args, **kwargs)
(EngineCore_DP0 pid=1336) ERROR 03-01 15:08:53 [core.py:900]   File "/usr/local/lib/python3.12/dist-packages/ray/_private/worker.py", line 2981, in get
(EngineCore_DP0 pid=1336) ERROR 03-01 15:08:53 [core.py:900]     values, debugger_breakpoint = worker.get_objects(
(EngineCore_DP0 pid=1336) ERROR 03-01 15:08:53 [core.py:900]   File "/usr/local/lib/python3.12/dist-packages/ray/_private/worker.py", line 1012, in get_objects
(EngineCore_DP0 pid=1336) ERROR 03-01 15:08:53 [core.py:900]     raise value.as_instanceof_cause()
(EngineCore_DP0 pid=1336) ERROR 03-01 15:08:53 [core.py:900] ray.exceptions.RayTaskError(RuntimeError): ray::RayWorkerWrapper.execute_method() (pid=1459, ip=192.168.177.11, actor_id=04131c44ceb9ffd2e878146401000000, repr=<vllm.v1.executor.ray_utils.RayWorkerWrapper object at 0xe90d36aa17c0>)
(EngineCore_DP0 pid=1336) ERROR 03-01 15:08:53 [core.py:900]   File "/usr/local/lib/python3.12/dist-packages/vllm/v1/worker/worker_base.py", line 339, in execute_method
(EngineCore_DP0 pid=1336) ERROR 03-01 15:08:53 [core.py:900]     raise e
(EngineCore_DP0 pid=1336) ERROR 03-01 15:08:53 [core.py:900]   File "/usr/local/lib/python3.12/dist-packages/vllm/v1/worker/worker_base.py", line 328, in execute_method
(EngineCore_DP0 pid=1336) ERROR 03-01 15:08:53 [core.py:900]     return run_method(self, method, args, kwargs)
(EngineCore_DP0 pid=1336) ERROR 03-01 15:08:53 [core.py:900]   File "/usr/local/lib/python3.12/dist-packages/vllm/v1/serial_utils.py", line 461, in run_method
(EngineCore_DP0 pid=1336) ERROR 03-01 15:08:53 [core.py:900]   File "/usr/local/lib/python3.12/dist-packages/torch/utils/_contextlib.py", line 124, in decorate_context
(EngineCore_DP0 pid=1336) ERROR 03-01 15:08:53 [core.py:900]   File "/usr/local/lib/python3.12/dist-packages/vllm/v1/worker/gpu_worker.py", line 322, in determine_available_memory
(EngineCore_DP0 pid=1336) ERROR 03-01 15:08:53 [core.py:900]     self.model_runner.profile_run()
(EngineCore_DP0 pid=1336) ERROR 03-01 15:08:53 [core.py:900]   File "/usr/local/lib/python3.12/dist-packages/vllm/v1/worker/gpu_model_runner.py", line 4750, in profile_run
(EngineCore_DP0 pid=1336) ERROR 03-01 15:08:53 [core.py:900]     output = self._dummy_sampler_run(last_hidden_states)
(EngineCore_DP0 pid=1336) ERROR 03-01 15:08:53 [core.py:900]   File "/usr/local/lib/python3.12/dist-packages/vllm/v1/worker/gpu_model_runner.py", line 4545, in _dummy_sampler_run
(EngineCore_DP0 pid=1336) ERROR 03-01 15:08:53 [core.py:900]     logits = self.model.compute_logits(hidden_states)
(EngineCore_DP0 pid=1336) ERROR 03-01 15:08:53 [core.py:900]   File "/usr/local/lib/python3.12/dist-packages/vllm/model_executor/models/gpt_oss.py", line 726, in compute_logits
(EngineCore_DP0 pid=1336) ERROR 03-01 15:08:53 [core.py:900]     logits = self.logits_processor(self.lm_head, hidden_states)
(EngineCore_DP0 pid=1336) ERROR 03-01 15:08:53 [core.py:900]   File "/usr/local/lib/python3.12/dist-packages/torch/nn/modules/module.py", line 1776, in _wrapped_call_impl
(EngineCore_DP0 pid=1336) ERROR 03-01 15:08:53 [core.py:900]     return self._call_impl(*args, **kwargs)
(EngineCore_DP0 pid=1336) ERROR 03-01 15:08:53 [core.py:900]   File "/usr/local/lib/python3.12/dist-packages/torch/nn/modules/module.py", line 1787, in _call_impl
(EngineCore_DP0 pid=1336) ERROR 03-01 15:08:53 [core.py:900]     return forward_call(*args, **kwargs)
(EngineCore_DP0 pid=1336) ERROR 03-01 15:08:53 [core.py:900]   File "/usr/local/lib/python3.12/dist-packages/vllm/model_executor/layers/logits_processor.py", line 60, in forward
(EngineCore_DP0 pid=1336) ERROR 03-01 15:08:53 [core.py:900]     logits = self._get_logits(hidden_states, lm_head, embedding_bias)
(EngineCore_DP0 pid=1336) ERROR 03-01 15:08:53 [core.py:900]              ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
(EngineCore_DP0 pid=1336) ERROR 03-01 15:08:53 [core.py:900]   File "/usr/local/lib/python3.12/dist-packages/vllm/model_executor/layers/logits_processor.py", line 92, in _get_logits
(EngineCore_DP0 pid=1336) ERROR 03-01 15:08:53 [core.py:900]     logits = lm_head.quant_method.apply(lm_head, hidden_states, bias=embedding_bias)
(EngineCore_DP0 pid=1336) ERROR 03-01 15:08:53 [core.py:900]              ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
(EngineCore_DP0 pid=1336) ERROR 03-01 15:08:53 [core.py:900]   File "/usr/local/lib/python3.12/dist-packages/vllm/model_executor/layers/quantization/mxfp4.py", line 828, in apply
(EngineCore_DP0 pid=1336) ERROR 03-01 15:08:53 [core.py:900]     return apply_fp4_marlin_linear(
(EngineCore_DP0 pid=1336) ERROR 03-01 15:08:53 [core.py:900]   File "/usr/local/lib/python3.12/dist-packages/vllm/model_executor/layers/quantization/utils/marlin_utils_fp4.py", line 123, in apply_fp4_marlin_linear
(EngineCore_DP0 pid=1336) ERROR 03-01 15:08:53 [core.py:900]     output = ops.gptq_marlin_gemm(
(EngineCore_DP0 pid=1336) ERROR 03-01 15:08:53 [core.py:900]   File "/usr/local/lib/python3.12/dist-packages/vllm/_custom_ops.py", line 1348, in gptq_marlin_gemm
(EngineCore_DP0 pid=1336) ERROR 03-01 15:08:53 [core.py:900]     return torch.ops._C.gptq_marlin_gemm(
(EngineCore_DP0 pid=1336) ERROR 03-01 15:08:53 [core.py:900]   File "/usr/local/lib/python3.12/dist-packages/torch/_ops.py", line 1205, in __call__
(EngineCore_DP0 pid=1336) ERROR 03-01 15:08:53 [core.py:900]     return self._op(*args, **kwargs)
(EngineCore_DP0 pid=1336) ERROR 03-01 15:08:53 [core.py:900] RuntimeError: Invalid thread config: thread_m_blocks = 1, thread_k = -1, thread_n = -1, num_threads = -1 for MKN = [256, 2880, 100544] and num_bits = 4, prob_m_split = 256, group_size = 32, has_act_order = 0, is_k_full = 1, has_zp = 0, is_zp_float = 0, stages = 4, max_shared_mem_new = 101376
(EngineCore_DP0 pid=1336) Process EngineCore_DP0:
(EngineCore_DP0 pid=1336) Traceback (most recent call last):
(EngineCore_DP0 pid=1336)   File "/usr/lib/python3.12/multiprocessing/process.py", line 314, in _bootstrap
(EngineCore_DP0 pid=1336)     self.run()
(EngineCore_DP0 pid=1336)   File "/usr/lib/python3.12/multiprocessing/process.py", line 108, in run
(EngineCore_DP0 pid=1336)     self._target(*self._args, **self._kwargs)
(EngineCore_DP0 pid=1336)   File "/usr/local/lib/python3.12/dist-packages/vllm/v1/engine/core.py", line 904, in run_engine_core
(EngineCore_DP0 pid=1336)     raise e
(EngineCore_DP0 pid=1336)   File "/usr/local/lib/python3.12/dist-packages/vllm/v1/engine/core.py", line 891, in run_engine_core
(EngineCore_DP0 pid=1336)     engine_core = EngineCoreProc(*args, engine_index=dp_rank, **kwargs)
(EngineCore_DP0 pid=1336)                   ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
(EngineCore_DP0 pid=1336)   File "/usr/local/lib/python3.12/dist-packages/vllm/v1/engine/core.py", line 656, in __init__
(EngineCore_DP0 pid=1336)     super().__init__(
(EngineCore_DP0 pid=1336)   File "/usr/local/lib/python3.12/dist-packages/vllm/v1/engine/core.py", line 112, in __init__
(EngineCore_DP0 pid=1336)     num_gpu_blocks, num_cpu_blocks, kv_cache_config = self._initialize_kv_caches(
(EngineCore_DP0 pid=1336)   File "/usr/local/lib/python3.12/dist-packages/vllm/v1/engine/core.py", line 243, in _initialize_kv_caches
(EngineCore_DP0 pid=1336)     available_gpu_memory = self.model_executor.determine_available_memory()
(EngineCore_DP0 pid=1336)   File "/usr/local/lib/python3.12/dist-packages/vllm/v1/executor/abstract.py", line 126, in determine_available_memory
(EngineCore_DP0 pid=1336)     return self.collective_rpc("determine_available_memory")
(EngineCore_DP0 pid=1336)   File "/usr/local/lib/python3.12/dist-packages/vllm/v1/executor/ray_executor.py", line 490, in collective_rpc
(EngineCore_DP0 pid=1336)     return ray.get(ray_worker_outputs, timeout=timeout)
(EngineCore_DP0 pid=1336)   File "/usr/local/lib/python3.12/dist-packages/ray/_private/auto_init_hook.py", line 22, in auto_init_wrapper
(EngineCore_DP0 pid=1336)     return fn(*args, **kwargs)
(EngineCore_DP0 pid=1336)   File "/usr/local/lib/python3.12/dist-packages/ray/_private/client_mode_hook.py", line 104, in wrapper
(EngineCore_DP0 pid=1336)     return func(*args, **kwargs)
(EngineCore_DP0 pid=1336)   File "/usr/local/lib/python3.12/dist-packages/ray/_private/worker.py", line 2981, in get
(EngineCore_DP0 pid=1336)     values, debugger_breakpoint = worker.get_objects(
(EngineCore_DP0 pid=1336)   File "/usr/local/lib/python3.12/dist-packages/ray/_private/worker.py", line 1012, in get_objects
(EngineCore_DP0 pid=1336)     raise value.as_instanceof_cause()
(EngineCore_DP0 pid=1336) ray.exceptions.RayTaskError(RuntimeError): ray::RayWorkerWrapper.execute_method() (pid=1459, ip=192.168.177.11, actor_id=04131c44ceb9ffd2e878146401000000, repr=<vllm.v1.executor.ray_utils.RayWorkerWrapper object at 0xe90d36aa17c0>)
(EngineCore_DP0 pid=1336)   File "/usr/local/lib/python3.12/dist-packages/vllm/v1/worker/worker_base.py", line 339, in execute_method
(EngineCore_DP0 pid=1336)   File "/usr/local/lib/python3.12/dist-packages/vllm/v1/worker/worker_base.py", line 328, in execute_method
(EngineCore_DP0 pid=1336)     return run_method(self, method, args, kwargs)
(EngineCore_DP0 pid=1336)   File "/usr/local/lib/python3.12/dist-packages/vllm/v1/serial_utils.py", line 461, in run_method
(EngineCore_DP0 pid=1336)   File "/usr/local/lib/python3.12/dist-packages/torch/utils/_contextlib.py", line 124, in decorate_context
(EngineCore_DP0 pid=1336)   File "/usr/local/lib/python3.12/dist-packages/vllm/v1/worker/gpu_worker.py", line 322, in determine_available_memory
(EngineCore_DP0 pid=1336)     self.model_runner.profile_run()
(EngineCore_DP0 pid=1336)   File "/usr/local/lib/python3.12/dist-packages/vllm/v1/worker/gpu_model_runner.py", line 4750, in profile_run
(EngineCore_DP0 pid=1336)     output = self._dummy_sampler_run(last_hidden_states)
(EngineCore_DP0 pid=1336)   File "/usr/local/lib/python3.12/dist-packages/vllm/v1/worker/gpu_model_runner.py", line 4545, in _dummy_sampler_run
(EngineCore_DP0 pid=1336)     logits = self.model.compute_logits(hidden_states)
(EngineCore_DP0 pid=1336)   File "/usr/local/lib/python3.12/dist-packages/vllm/model_executor/models/gpt_oss.py", line 726, in compute_logits
(EngineCore_DP0 pid=1336)     logits = self.logits_processor(self.lm_head, hidden_states)
(EngineCore_DP0 pid=1336)   File "/usr/local/lib/python3.12/dist-packages/torch/nn/modules/module.py", line 1776, in _wrapped_call_impl
(EngineCore_DP0 pid=1336)     return self._call_impl(*args, **kwargs)
(EngineCore_DP0 pid=1336)   File "/usr/local/lib/python3.12/dist-packages/torch/nn/modules/module.py", line 1787, in _call_impl
(EngineCore_DP0 pid=1336)     return forward_call(*args, **kwargs)
(EngineCore_DP0 pid=1336)   File "/usr/local/lib/python3.12/dist-packages/vllm/model_executor/layers/logits_processor.py", line 60, in forward
(EngineCore_DP0 pid=1336)     logits = self._get_logits(hidden_states, lm_head, embedding_bias)
(EngineCore_DP0 pid=1336)              ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
(EngineCore_DP0 pid=1336)   File "/usr/local/lib/python3.12/dist-packages/vllm/model_executor/layers/logits_processor.py", line 92, in _get_logits
(EngineCore_DP0 pid=1336)     logits = lm_head.quant_method.apply(lm_head, hidden_states, bias=embedding_bias)
(EngineCore_DP0 pid=1336)              ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
(EngineCore_DP0 pid=1336)   File "/usr/local/lib/python3.12/dist-packages/vllm/model_executor/layers/quantization/mxfp4.py", line 828, in apply
(EngineCore_DP0 pid=1336)     return apply_fp4_marlin_linear(
(EngineCore_DP0 pid=1336)   File "/usr/local/lib/python3.12/dist-packages/vllm/model_executor/layers/quantization/utils/marlin_utils_fp4.py", line 123, in apply_fp4_marlin_linear
(EngineCore_DP0 pid=1336)     output = ops.gptq_marlin_gemm(
(EngineCore_DP0 pid=1336)   File "/usr/local/lib/python3.12/dist-packages/vllm/_custom_ops.py", line 1348, in gptq_marlin_gemm
(EngineCore_DP0 pid=1336)     return torch.ops._C.gptq_marlin_gemm(
(EngineCore_DP0 pid=1336)   File "/usr/local/lib/python3.12/dist-packages/torch/_ops.py", line 1205, in __call__
(EngineCore_DP0 pid=1336)     return self._op(*args, **kwargs)
(EngineCore_DP0 pid=1336) RuntimeError: Invalid thread config: thread_m_blocks = 1, thread_k = -1, thread_n = -1, num_threads = -1 for MKN = [256, 2880, 100544] and num_bits = 4, prob_m_split = 256, group_size = 32, has_act_order = 0, is_k_full = 1, has_zp = 0, is_zp_float = 0, stages = 4, max_shared_mem_new = 101376
(EngineCore_DP0 pid=1336) INFO 03-01 15:08:53 [ray_executor.py:121] Shutting down Ray distributed executor. If you see error log from logging.cc regarding SIGTERM received, please ignore because this is the expected termination process in Ray.
(EngineCore_DP0 pid=1336) 2026-03-01 15:08:53,026       ERROR worker.py:439 -- Unhandled error (suppress with 'RAY_IGNORE_UNHANDLED_ERRORS=1'): ray::RayWorkerWrapper.execute_method() (pid=385, ip=192.168.177.12, actor_id=5fbcb749f51c18921b4f26f401000000, repr=<vllm.v1.executor.ray_utils.RayWorkerWrapper object at 0xe244ec4df470>)
(EngineCore_DP0 pid=1336) (RayWorkerWrapper pid=1459) INFO 03-01 15:08:52 [backends.py:226] Directly load the compiled graph(s) for compile range (1, 8192) from the cache, took 6.811 s
(EngineCore_DP0 pid=1336) (RayWorkerWrapper pid=1459) INFO 03-01 15:08:52 [monitor.py:34] torch.compile takes 8.01 s in total
(EngineCore_DP0 pid=1336) (RayWorkerWrapper pid=1459) ERROR 03-01 15:08:53 [worker_base.py:338] Error executing method 'determine_available_memory'. This might cause deadlock in distributed execution.
(EngineCore_DP0 pid=1336) (RayWorkerWrapper pid=1459) ERROR 03-01 15:08:53 [worker_base.py:338] Traceback (most recent call last):
(EngineCore_DP0 pid=1336) (RayWorkerWrapper pid=1459) ERROR 03-01 15:08:53 [worker_base.py:338]   File "/usr/local/lib/python3.12/dist-packages/vllm/v1/worker/worker_base.py", line 328, in execute_method
(EngineCore_DP0 pid=1336) (RayWorkerWrapper pid=1459) ERROR 03-01 15:08:53 [worker_base.py:338]     return run_method(self, method, args, kwargs)
(EngineCore_DP0 pid=1336) (RayWorkerWrapper pid=1459) ERROR 03-01 15:08:53 [worker_base.py:338]            ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
(EngineCore_DP0 pid=1336) (RayWorkerWrapper pid=1459) ERROR 03-01 15:08:53 [worker_base.py:338]   File "/usr/local/lib/python3.12/dist-packages/vllm/v1/serial_utils.py", line 461, in run_method
(EngineCore_DP0 pid=1336) (RayWorkerWrapper pid=1459) ERROR 03-01 15:08:53 [worker_base.py:338]     return func(*args, **kwargs)
(EngineCore_DP0 pid=1336) (RayWorkerWrapper pid=1459) ERROR 03-01 15:08:53 [worker_base.py:338]   File "/usr/local/lib/python3.12/dist-packages/torch/utils/_contextlib.py", line 124, in decorate_context
(EngineCore_DP0 pid=1336) (RayWorkerWrapper pid=1459) ERROR 03-01 15:08:53 [worker_base.py:338]   File "/usr/local/lib/python3.12/dist-packages/vllm/v1/worker/gpu_worker.py", line 322, in determine_available_memory
(EngineCore_DP0 pid=1336) (RayWorkerWrapper pid=1459) ERROR 03-01 15:08:53 [worker_base.py:338]     self.model_runner.profile_run()
(EngineCore_DP0 pid=1336) (RayWorkerWrapper pid=1459) ERROR 03-01 15:08:53 [worker_base.py:338]   File "/usr/local/lib/python3.12/dist-packages/vllm/v1/worker/gpu_model_runner.py", line 4750, in profile_run
(EngineCore_DP0 pid=1336) (RayWorkerWrapper pid=1459) ERROR 03-01 15:08:53 [worker_base.py:338]     output = self._dummy_sampler_run(last_hidden_states)
(EngineCore_DP0 pid=1336) (RayWorkerWrapper pid=1459) ERROR 03-01 15:08:53 [worker_base.py:338]              ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
(EngineCore_DP0 pid=1336) (RayWorkerWrapper pid=1459) ERROR 03-01 15:08:53 [worker_base.py:338]   File "/usr/local/lib/python3.12/dist-packages/vllm/v1/worker/gpu_model_runner.py", line 4545, in _dummy_sampler_run
(EngineCore_DP0 pid=1336) (RayWorkerWrapper pid=1459) ERROR 03-01 15:08:53 [worker_base.py:338]     logits = self.model.compute_logits(hidden_states)
(EngineCore_DP0 pid=1336) (RayWorkerWrapper pid=1459) ERROR 03-01 15:08:53 [worker_base.py:338]   File "/usr/local/lib/python3.12/dist-packages/vllm/model_executor/models/gpt_oss.py", line 726, in compute_logits
(EngineCore_DP0 pid=1336) (RayWorkerWrapper pid=1459) ERROR 03-01 15:08:53 [worker_base.py:338]     logits = self.logits_processor(self.lm_head, hidden_states)
(EngineCore_DP0 pid=1336) (RayWorkerWrapper pid=1459) ERROR 03-01 15:08:53 [worker_base.py:338]              ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
(EngineCore_DP0 pid=1336) (RayWorkerWrapper pid=1459) ERROR 03-01 15:08:53 [worker_base.py:338]   File "/usr/local/lib/python3.12/dist-packages/torch/nn/modules/module.py", line 1776, in _wrapped_call_impl
(EngineCore_DP0 pid=1336) (RayWorkerWrapper pid=1459) ERROR 03-01 15:08:53 [worker_base.py:338]     return self._call_impl(*args, **kwargs)
(EngineCore_DP0 pid=1336) (RayWorkerWrapper pid=1459) ERROR 03-01 15:08:53 [worker_base.py:338]   File "/usr/local/lib/python3.12/dist-packages/torch/nn/modules/module.py", line 1787, in _call_impl
(EngineCore_DP0 pid=1336) (RayWorkerWrapper pid=1459) ERROR 03-01 15:08:53 [worker_base.py:338]     return forward_call(*args, **kwargs)
(EngineCore_DP0 pid=1336) (RayWorkerWrapper pid=1459) ERROR 03-01 15:08:53 [worker_base.py:338]   File "/usr/local/lib/python3.12/dist-packages/vllm/model_executor/layers/logits_processor.py", line 60, in forward
(EngineCore_DP0 pid=1336) (RayWorkerWrapper pid=1459) ERROR 03-01 15:08:53 [worker_base.py:338]     logits = self._get_logits(hidden_states, lm_head, embedding_bias)
(EngineCore_DP0 pid=1336) (RayWorkerWrapper pid=1459) ERROR 03-01 15:08:53 [worker_base.py:338]              ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
(EngineCore_DP0 pid=1336) (RayWorkerWrapper pid=1459) ERROR 03-01 15:08:53 [worker_base.py:338]   File "/usr/local/lib/python3.12/dist-packages/vllm/model_executor/layers/logits_processor.py", line 92, in _get_logits
(EngineCore_DP0 pid=1336) (RayWorkerWrapper pid=1459) ERROR 03-01 15:08:53 [worker_base.py:338]     logits = lm_head.quant_method.apply(lm_head, hidden_states, bias=embedding_bias)
(EngineCore_DP0 pid=1336) (RayWorkerWrapper pid=1459) ERROR 03-01 15:08:53 [worker_base.py:338]              ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
(EngineCore_DP0 pid=1336) (RayWorkerWrapper pid=1459) ERROR 03-01 15:08:53 [worker_base.py:338]   File "/usr/local/lib/python3.12/dist-packages/vllm/model_executor/layers/quantization/mxfp4.py", line 828, in apply
(EngineCore_DP0 pid=1336) (RayWorkerWrapper pid=1459) ERROR 03-01 15:08:53 [worker_base.py:338]     return apply_fp4_marlin_linear(
(EngineCore_DP0 pid=1336) (RayWorkerWrapper pid=1459) ERROR 03-01 15:08:53 [worker_base.py:338]   File "/usr/local/lib/python3.12/dist-packages/vllm/model_executor/layers/quantization/utils/marlin_utils_fp4.py", line 123, in apply_fp4_marlin_linear
(EngineCore_DP0 pid=1336) (RayWorkerWrapper pid=1459) ERROR 03-01 15:08:53 [worker_base.py:338]     output = ops.gptq_marlin_gemm(
(EngineCore_DP0 pid=1336) (RayWorkerWrapper pid=1459) ERROR 03-01 15:08:53 [worker_base.py:338]   File "/usr/local/lib/python3.12/dist-packages/vllm/_custom_ops.py", line 1348, in gptq_marlin_gemm
(EngineCore_DP0 pid=1336) (RayWorkerWrapper pid=1459) ERROR 03-01 15:08:53 [worker_base.py:338]     return torch.ops._C.gptq_marlin_gemm(
(EngineCore_DP0 pid=1336) (RayWorkerWrapper pid=1459) ERROR 03-01 15:08:53 [worker_base.py:338]   File "/usr/local/lib/python3.12/dist-packages/torch/_ops.py", line 1205, in __call__
(EngineCore_DP0 pid=1336) (RayWorkerWrapper pid=1459) ERROR 03-01 15:08:53 [worker_base.py:338]     return self._op(*args, **kwargs)
(EngineCore_DP0 pid=1336) (RayWorkerWrapper pid=1459) ERROR 03-01 15:08:53 [worker_base.py:338] RuntimeError: Invalid thread config: thread_m_blocks = 1, thread_k = -1, thread_n = -1, num_threads = -1 for MKN = [256, 2880, 100544] and num_bits = 4, prob_m_split = 256, group_size = 32, has_act_order = 0, is_k_full = 1, has_zp = 0, is_zp_float = 0, stages = 4, max_shared_mem_new = 101376
(EngineCore_DP0 pid=1336) (RayWorkerWrapper pid=1459) INFO 03-01 15:08:41 [default_loader.py:291] Loading weights took 36.76 seconds
(EngineCore_DP0 pid=1336) (RayWorkerWrapper pid=385, ip=192.168.177.12) INFO 03-01 15:08:42 [mxfp4.py:803] [MXFP4] lm_head quantized: torch.Size([100544, 2880]) BF16 -> torch.Size([100544, 1440]) FP4 (4x smaller)
(EngineCore_DP0 pid=1336) (RayWorkerWrapper pid=385, ip=192.168.177.12) INFO 03-01 15:08:42 [gpu_model_runner.py:3901] Model loading took 31.9972 GiB memory and 50.095736 seconds
(EngineCore_DP0 pid=1336) (RayWorkerWrapper pid=385, ip=192.168.177.12) INFO 03-01 15:08:43 [decorators.py:432] Directly load AOT compilation from path /root/.cache/vllm/torch_aot_compile/fb5f1d6fe83b24616726df86c6bc4bca2d951023b09c3197cd61ac41306ddb9d/rank_1_0/model
(EngineCore_DP0 pid=1336) (RayWorkerWrapper pid=385, ip=192.168.177.12) INFO 03-01 15:08:45 [backends.py:644] Using cache directory: /root/.cache/vllm/torch_compile_cache/1c5fbe4478/rank_1_0/backbone for vLLM's torch.compile
(EngineCore_DP0 pid=1336) (RayWorkerWrapper pid=385, ip=192.168.177.12) INFO 03-01 15:08:45 [backends.py:704] Dynamo bytecode transform time: 2.22 s
(EngineCore_DP0 pid=1336) (RayWorkerWrapper pid=385, ip=192.168.177.12) INFO 03-01 15:08:52 [backends.py:226] Directly load the compiled graph(s) for compile range (1, 8192) from the cache, took 6.239 s
(EngineCore_DP0 pid=1336) (RayWorkerWrapper pid=385, ip=192.168.177.12) INFO 03-01 15:08:52 [monitor.py:34] torch.compile takes 8.46 s in total
(EngineCore_DP0 pid=1336) (RayWorkerWrapper pid=385, ip=192.168.177.12) ERROR 03-01 15:08:53 [worker_base.py:338] Error executing method 'determine_available_memory'. This might cause deadlock in distributed execution.
(EngineCore_DP0 pid=1336) (RayWorkerWrapper pid=385, ip=192.168.177.12) ERROR 03-01 15:08:53 [worker_base.py:338] Traceback (most recent call last):
(EngineCore_DP0 pid=1336) (RayWorkerWrapper pid=385, ip=192.168.177.12) ERROR 03-01 15:08:53 [worker_base.py:338]   File "/usr/local/lib/python3.12/dist-packages/vllm/v1/worker/worker_base.py", line 328, in execute_method
(EngineCore_DP0 pid=1336) (RayWorkerWrapper pid=385, ip=192.168.177.12) ERROR 03-01 15:08:53 [worker_base.py:338]     return run_method(self, method, args, kwargs)
(EngineCore_DP0 pid=1336) (RayWorkerWrapper pid=385, ip=192.168.177.12) ERROR 03-01 15:08:53 [worker_base.py:338]            ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
(EngineCore_DP0 pid=1336) (RayWorkerWrapper pid=385, ip=192.168.177.12) ERROR 03-01 15:08:53 [worker_base.py:338]   File "/usr/local/lib/python3.12/dist-packages/vllm/v1/serial_utils.py", line 461, in run_method
(EngineCore_DP0 pid=1336) (RayWorkerWrapper pid=385, ip=192.168.177.12) ERROR 03-01 15:08:53 [worker_base.py:338]     return func(*args, **kwargs) [repeated 3x across cluster] (Ray deduplicates logs by default. Set RAY_DEDUP_LOGS=0 to disable log deduplication, or see https://docs.ray.io/en/master/ray-observability/user-guides/configure-logging.html#log-deduplication for more options.)
(EngineCore_DP0 pid=1336) (RayWorkerWrapper pid=385, ip=192.168.177.12) ERROR 03-01 15:08:53 [worker_base.py:338]              ^^^^^^^^^^^^^^^^^^^^^ [repeated 4x across cluster]
(EngineCore_DP0 pid=1336) (RayWorkerWrapper pid=385, ip=192.168.177.12) ERROR 03-01 15:08:53 [worker_base.py:338]   File "/usr/local/lib/python3.12/dist-packages/torch/utils/_contextlib.py", line 124, in decorate_context [repeated 2x across cluster]
(EngineCore_DP0 pid=1336) (RayWorkerWrapper pid=385, ip=192.168.177.12) ERROR 03-01 15:08:53 [worker_base.py:338]   File "/usr/local/lib/python3.12/dist-packages/vllm/v1/worker/gpu_worker.py", line 322, in determine_available_memory
(EngineCore_DP0 pid=1336) (RayWorkerWrapper pid=385, ip=192.168.177.12) ERROR 03-01 15:08:53 [worker_base.py:338]     self.model_runner.profile_run()
(EngineCore_DP0 pid=1336) (RayWorkerWrapper pid=385, ip=192.168.177.12) ERROR 03-01 15:08:53 [worker_base.py:338]   File "/usr/local/lib/python3.12/dist-packages/vllm/v1/worker/gpu_model_runner.py", line 4750, in profile_run
(EngineCore_DP0 pid=1336) (RayWorkerWrapper pid=385, ip=192.168.177.12) ERROR 03-01 15:08:53 [worker_base.py:338]     output = self._dummy_sampler_run(last_hidden_states)
(EngineCore_DP0 pid=1336) (RayWorkerWrapper pid=385, ip=192.168.177.12) ERROR 03-01 15:08:53 [worker_base.py:338]              ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
(EngineCore_DP0 pid=1336) (RayWorkerWrapper pid=385, ip=192.168.177.12) ERROR 03-01 15:08:53 [worker_base.py:338]   File "/usr/local/lib/python3.12/dist-packages/vllm/v1/worker/gpu_model_runner.py", line 4545, in _dummy_sampler_run
(EngineCore_DP0 pid=1336) (RayWorkerWrapper pid=385, ip=192.168.177.12) ERROR 03-01 15:08:53 [worker_base.py:338]     logits = self.model.compute_logits(hidden_states)
(EngineCore_DP0 pid=1336) (RayWorkerWrapper pid=385, ip=192.168.177.12) ERROR 03-01 15:08:53 [worker_base.py:338]   File "/usr/local/lib/python3.12/dist-packages/vllm/model_executor/models/gpt_oss.py", line 726, in compute_logits
(EngineCore_DP0 pid=1336) (RayWorkerWrapper pid=385, ip=192.168.177.12) ERROR 03-01 15:08:53 [worker_base.py:338]     logits = self.logits_processor(self.lm_head, hidden_states)
(EngineCore_DP0 pid=1336) (RayWorkerWrapper pid=385, ip=192.168.177.12) ERROR 03-01 15:08:53 [worker_base.py:338]              ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
(EngineCore_DP0 pid=1336) (RayWorkerWrapper pid=385, ip=192.168.177.12) ERROR 03-01 15:08:53 [worker_base.py:338]   File "/usr/local/lib/python3.12/dist-packages/torch/nn/modules/module.py", line 1776, in _wrapped_call_impl
(EngineCore_DP0 pid=1336) (RayWorkerWrapper pid=385, ip=192.168.177.12) ERROR 03-01 15:08:53 [worker_base.py:338]     return self._call_impl(*args, **kwargs)
(EngineCore_DP0 pid=1336) (RayWorkerWrapper pid=385, ip=192.168.177.12) ERROR 03-01 15:08:53 [worker_base.py:338]   File "/usr/local/lib/python3.12/dist-packages/torch/nn/modules/module.py", line 1787, in _call_impl
(EngineCore_DP0 pid=1336) (RayWorkerWrapper pid=385, ip=192.168.177.12) ERROR 03-01 15:08:53 [worker_base.py:338]     return forward_call(*args, **kwargs)
(EngineCore_DP0 pid=1336) (RayWorkerWrapper pid=385, ip=192.168.177.12) ERROR 03-01 15:08:53 [worker_base.py:338]   File "/usr/local/lib/python3.12/dist-packages/vllm/model_executor/layers/logits_processor.py", line 60, in forward
(EngineCore_DP0 pid=1336) (RayWorkerWrapper pid=385, ip=192.168.177.12) ERROR 03-01 15:08:53 [worker_base.py:338]     logits = self._get_logits(hidden_states, lm_head, embedding_bias)
(EngineCore_DP0 pid=1336) (RayWorkerWrapper pid=385, ip=192.168.177.12) ERROR 03-01 15:08:53 [worker_base.py:338]              ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
(EngineCore_DP0 pid=1336) (RayWorkerWrapper pid=385, ip=192.168.177.12) ERROR 03-01 15:08:53 [worker_base.py:338]   File "/usr/local/lib/python3.12/dist-packages/vllm/model_executor/layers/logits_processor.py", line 92, in _get_logits
(EngineCore_DP0 pid=1336) (RayWorkerWrapper pid=385, ip=192.168.177.12) ERROR 03-01 15:08:53 [worker_base.py:338]     logits = lm_head.quant_method.apply(lm_head, hidden_states, bias=embedding_bias)
(EngineCore_DP0 pid=1336) (RayWorkerWrapper pid=385, ip=192.168.177.12) ERROR 03-01 15:08:53 [worker_base.py:338]              ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
(EngineCore_DP0 pid=1336) (RayWorkerWrapper pid=385, ip=192.168.177.12) ERROR 03-01 15:08:53 [worker_base.py:338]   File "/usr/local/lib/python3.12/dist-packages/vllm/model_executor/layers/quantization/mxfp4.py", line 828, in apply
(EngineCore_DP0 pid=1336) (RayWorkerWrapper pid=385, ip=192.168.177.12) ERROR 03-01 15:08:53 [worker_base.py:338]     return apply_fp4_marlin_linear(
(EngineCore_DP0 pid=1336) (RayWorkerWrapper pid=385, ip=192.168.177.12) ERROR 03-01 15:08:53 [worker_base.py:338]   File "/usr/local/lib/python3.12/dist-packages/vllm/model_executor/layers/quantization/utils/marlin_utils_fp4.py", line 123, in apply_fp4_marlin_linear
(EngineCore_DP0 pid=1336) (RayWorkerWrapper pid=385, ip=192.168.177.12) ERROR 03-01 15:08:53 [worker_base.py:338]     output = ops.gptq_marlin_gemm(
(EngineCore_DP0 pid=1336) (RayWorkerWrapper pid=385, ip=192.168.177.12) ERROR 03-01 15:08:53 [worker_base.py:338]   File "/usr/local/lib/python3.12/dist-packages/vllm/_custom_ops.py", line 1348, in gptq_marlin_gemm
(EngineCore_DP0 pid=1336) (RayWorkerWrapper pid=385, ip=192.168.177.12) ERROR 03-01 15:08:53 [worker_base.py:338]     return torch.ops._C.gptq_marlin_gemm(
(EngineCore_DP0 pid=1336) (RayWorkerWrapper pid=385, ip=192.168.177.12) ERROR 03-01 15:08:53 [worker_base.py:338]   File "/usr/local/lib/python3.12/dist-packages/torch/_ops.py", line 1205, in __call__
(EngineCore_DP0 pid=1336) (RayWorkerWrapper pid=385, ip=192.168.177.12) ERROR 03-01 15:08:53 [worker_base.py:338]     return self._op(*args, **kwargs)
(EngineCore_DP0 pid=1336) (RayWorkerWrapper pid=385, ip=192.168.177.12) ERROR 03-01 15:08:53 [worker_base.py:338] RuntimeError: Invalid thread config: thread_m_blocks = 1, thread_k = -1, thread_n = -1, num_threads = -1 for MKN = [256, 2880, 100544] and num_bits = 4, prob_m_split = 256, group_size = 32, has_act_order = 0, is_k_full = 1, has_zp = 0, is_zp_float = 0, stages = 4, max_shared_mem_new = 101376
(APIServer pid=1229) Traceback (most recent call last):
(APIServer pid=1229)   File "/usr/local/bin/vllm", line 10, in <module>
(APIServer pid=1229)     sys.exit(main())
(APIServer pid=1229)              ^^^^^^
(APIServer pid=1229)   File "/usr/local/lib/python3.12/dist-packages/vllm/entrypoints/cli/main.py", line 73, in main
(APIServer pid=1229)     args.dispatch_function(args)
(APIServer pid=1229)   File "/usr/local/lib/python3.12/dist-packages/vllm/entrypoints/cli/serve.py", line 60, in cmd
(APIServer pid=1229)     uvloop.run(run_server(args))
(APIServer pid=1229)   File "/usr/local/lib/python3.12/dist-packages/uvloop/__init__.py", line 96, in run
(APIServer pid=1229)     return __asyncio.run(
(APIServer pid=1229)            ^^^^^^^^^^^^^^
(APIServer pid=1229)   File "/usr/lib/python3.12/asyncio/runners.py", line 194, in run
(APIServer pid=1229)     return runner.run(main)
(APIServer pid=1229)            ^^^^^^^^^^^^^^^^
(APIServer pid=1229)   File "/usr/lib/python3.12/asyncio/runners.py", line 118, in run
(APIServer pid=1229)     return self._loop.run_until_complete(task)
(APIServer pid=1229)            ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
(APIServer pid=1229)   File "uvloop/loop.pyx", line 1518, in uvloop.loop.Loop.run_until_complete
(APIServer pid=1229)   File "/usr/local/lib/python3.12/dist-packages/uvloop/__init__.py", line 48, in wrapper
(APIServer pid=1229)     return await main
(APIServer pid=1229)   File "/usr/local/lib/python3.12/dist-packages/vllm/entrypoints/openai/api_server.py", line 1325, in run_server
(APIServer pid=1229)     await run_server_worker(listen_address, sock, args, **uvicorn_kwargs)
(APIServer pid=1229)   File "/usr/local/lib/python3.12/dist-packages/vllm/entrypoints/openai/api_server.py", line 1344, in run_server_worker
(APIServer pid=1229)     async with build_async_engine_client(
(APIServer pid=1229)   File "/usr/lib/python3.12/contextlib.py", line 210, in __aenter__
(APIServer pid=1229)     return await anext(self.gen)
(APIServer pid=1229)   File "/usr/local/lib/python3.12/dist-packages/vllm/entrypoints/openai/api_server.py", line 171, in build_async_engine_client
(APIServer pid=1229)     async with build_async_engine_client_from_engine_args(
(APIServer pid=1229)   File "/usr/local/lib/python3.12/dist-packages/vllm/entrypoints/openai/api_server.py", line 212, in build_async_engine_client_from_engine_args
(APIServer pid=1229)     async_llm = AsyncLLM.from_vllm_config(
(APIServer pid=1229)   File "/usr/local/lib/python3.12/dist-packages/vllm/v1/engine/async_llm.py", line 207, in from_vllm_config
(APIServer pid=1229)     return cls(
(APIServer pid=1229)   File "/usr/local/lib/python3.12/dist-packages/vllm/v1/engine/async_llm.py", line 134, in __init__
(APIServer pid=1229)     self.engine_core = EngineCoreClient.make_async_mp_client(
(APIServer pid=1229)                        ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
(APIServer pid=1229)   File "/usr/local/lib/python3.12/dist-packages/vllm/v1/engine/core_client.py", line 122, in make_async_mp_client
(APIServer pid=1229)     return AsyncMPClient(*client_args)
(APIServer pid=1229)   File "/usr/local/lib/python3.12/dist-packages/vllm/v1/engine/core_client.py", line 824, in __init__
(APIServer pid=1229)     super().__init__(
(APIServer pid=1229)   File "/usr/local/lib/python3.12/dist-packages/vllm/v1/engine/core_client.py", line 479, in __init__
(APIServer pid=1229)     with launch_core_engines(vllm_config, executor_class, log_stats) as (
(APIServer pid=1229)   File "/usr/lib/python3.12/contextlib.py", line 144, in __exit__
(APIServer pid=1229)     next(self.gen)
(APIServer pid=1229)   File "/usr/local/lib/python3.12/dist-packages/vllm/v1/engine/utils.py", line 921, in launch_core_engines
(APIServer pid=1229)     wait_for_engine_startup(
(APIServer pid=1229)   File "/usr/local/lib/python3.12/dist-packages/vllm/v1/engine/utils.py", line 980, in wait_for_engine_startup
(APIServer pid=1229)     raise RuntimeError(
(APIServer pid=1229) RuntimeError: Engine core initialization failed. See root cause above. Failed core proc(s): {}
Yes, the upstream repo is currently broken, the author is fixing it. It should still work with --solo on a single node though.
