Loading Structure Data Efficiently Example
I want to learn more about Loading Data Structures in CUDA, especially loading 2D arrays examples and came across a PDF on loading structured data by Nvidia
“Loading Structured Data Efficiently With Cuda”
[url=“http://developer.download.nvidia.com/compute/cuda/sdk/website/projects/vectorLoads/doc/vectorLoads.pdf”]http://developer.download.nvidia.com/compu...vectorLoads.pdf[/url]
But I couldn’t find the vectorLoad examples in the SDK.
Does anyone know where i can find it,
Hy!
it is in the 1.0 SDK examples, the last one!
regards.
btw,
When you want to load an array of structures from global memory to shared memory:
Just use integer pointers to cast the src and destination and load the array of structures as array of integers into shared memory(no matter what data-types the structure carries)! Now, u got all coalescing in place!
The only restriction is that “n*sizeof(struct)” has to be a multiple of sizeof(int) – you can always pad it to get it!
Once you are in shared memory - it does NOT matter much (as much as global memory)
:smile2:
what’s the name of that project example…?
My SDK is 1.1 … External Media .
