Section 4.2.2.4 says that an automatic variable declared in “device code” will be placed in a register. HOwever, if the variable is a big array, the compiler would place it in local-memory.
So, What is local-memory? Is there where the GPU instructions sit? It never finds a place when memory hierarchies and fastness are concerned?
Is this local-memory per core OR Is it shard across all cores in a multi-processor???
The local memory is part of global device memory, local memory is ‘local’ to individual thread, that is, it is accessible only by the thread that declare it.
Hmm… Haa… If that were the case, the local memory has to be reallllly slow and I would expect a word of caution in NVIDIA manual. But no such reference is found in the manual.
Are you sure about this aspect of local memory?
What I thought was "Each core has to execute instructions, right? Where do they reside? They have to reside near the CORE, right? I thought that memory is what is called “Local Memory” by the CUDA manual.
see the 4th line from the bottom of page 13 in the programming guide, ‘The local and global memory spaces are implemented as read-write regions of device memory and are not cached.’
I also made a mistake in the previous reply, the local memory is part of device memory, but is NOT part of global memory. :">
How do you say “Local Memory” is per-thread. It is not documented in the manual, right? I just want to know what you base your answers on. Because I dont find these info in the manual. Sorry for being paranoid.
And true – the fact about indexing is OK. If I have a local array and then say array[i] – the compiler cannot generate code to do it via registers – Note that array[5] could be generated using “registers”. Only if you index via a non-constant will the compiler move it to local memory. THis part is quite clear.
Ok, Can some1 tell me where the instructions for the multi-processor are stored ??? Is there a special memory inside the multi-processor for this?
The same answer was posted by “fatgarfield” in this same thread. Can you kindly look a few posts above your post? But what we decided was that “device memory” need NOT really be a “global memory”.
If it were, the manual would explicitly caution about “slowness” of this memory and would probably discourage people from using it.
What part of “not cached” fails to indicate “slowness”? It is true that the performance guidelines section 5.2.1 lacks a description of how to get the best performance out of local memory, but since you really have no control over how the compiler uses it I don’t see it as a big loss. You just have to hope that the compiler generates memory reads that are coalesced.
The truth of the matter is, if your kernel is using local memory for ANY reason it is going to be slow. Plus, it will be better for you to move that into global memory and manage it explicitly to ensure that your access pattern is coalesced. Device memory bandwidth is very precious and it should not be wasted with random uncoalesced reads. Better yet, depending on your access pattern, constant, shared, or even textures may be better options.
The programming guide uses “device” and “global” almost as synonyms. If you want to be absolutely picky about it, “global memory” refers to a pointer to “device memory” alocated by cudaMalloc or declared device (see what I mean about synonyms, you declare a “global memory” with device !, if you don’t believe me look at 5.1.2.1 in the CUDA 1.1 guide).
There are fast on-chip memories in many setups that are NOT cached. But that does NOT mean that they are slow. It depends on how close you r to the processor. Probably the local memory are so close to the ALUs that they dont need caching. It could be that way too, right?
I agree moving to the global memory part and the coalescing part. But still I would like to see an explicit mention in the CUDA manual regarding where exactly local memory is. It says the memory is accessed using “ld.local” and “st.local” instructions. I need to see a PTX manual to know what these means.
Yeah, device is a broad qualifier. You then refine it further by saying whether it is “shared” or “constant” and so on. If you dont further qualify it, it is a global memory as you say. This one is clearly stated in the manual.
Figure 3 in the following PDF may of help in understanding “Local Memory”
From experience in my own code and reading these forums for months, a vast majority of kernels never need to use local memory. Those few that do use local memory are usually posts asking “why is this kernel so slow”. So please, let us stop bickering over semantics or what “could have been” in the hardware design. Just believe us when we tell you that it is slow. When you come across a kernel in your work that uses local memory (and will no doubt be slow), you are welcome to post it here for pointers on improving it.
Sven’s post indicates that Local memory is a typical memory with a “cache” on it. So, Why would it be slow??? Because – it prevents multi-processor from executing WARPs simultaneously – It is like the “If” statement based on Thread-Id that caues WARPs to diverge and re-join later…
Could be so… Just a thought… It would be gr8 if an NVIDIA person answers this local-memory thing
Sven, Thanks a lot for pointing out the “local memory” thing from the PDF.
Looks like – This PDF is installed as a part of “CUDA” Toolkit. C:\CUDA\DOC has it in my machine. I installed the CUDA kit on "C:". So, I think the PDF is authentic.
Local memory is just like global memory, but local to a thread. And it has the same latency and other properties. It can thus be considered very slow, compared to constant memory, shared memory and registers. The fast memories don’t need a cache because they are as fast as registers. In which case a cache would only be harmful.
About local memory being cached, I doubt it, there is nowhere mention of a ‘local memory cache’, and there is of the ‘constant cache’…
