I have this code that runs perfectly fine on the CPU, however it does compute results on the GPU. It does compile for the GPU and it does not throw a segmentation fault it just doesn’t do its job.
The CPU testfile:
[codebox] /*
Dominik Gothe
overlapArea.cu
Compute the overlapArea of two polygons and smile : )
ASSUMPTIONS ==== ASSUMPTIONS ==== ASSUMPTIONS ====
Polygon 1 is to the right of Polygon 0
Both poygons have the same number of sides nv_g
Will calculate convex hull of overlap, assume concave is not possible
overlapping verticies have not been adressed
the point (0,0) is illegitimate
dug says they can do dot and cross real fast
#include<stdio.h>
#include<math.h>
//#include <cutil_inline.h> // cutilSafeCall
#include // pow( float base, float exp);
using namespace std;
float invalid = 6546746146874; // This serves to illimina
float *xval_0; float *yval_0; // Polygon 0
float *xval_1; float *yval_1; // Polygon 1
float *xval_n; float *yval_n; // Newly Created Polygon
float *overlapArea; // Area of New Polygon
int nv_g; // Number of Verticies of Input Polygons
int nv_n = 0; // Number of verticies of New Polygon
float *angle; // device can’t allocate memory
void FindIntersections() { // ============================================================
// stupid ass computer can't deal with infinity nor does he understant the line x=2; freakin dumbass nvidea piece o crap
float infinitio = 10e20;
for(int i = 0; i<nv_g; i++){
int j = (i+1)%nv_g;
for(int k = 0; k<nv_g; k++){
int l=(k+1)%nv_g;
float ris_0 = yval_0[j] - yval_0[i];
float run_0 = xval_0[j] - xval_0[i];
float sloap_0 = infinitio;
float inter_0 = 0;
float ris_1 = yval_1[k] - yval_1[l];
float run_1 = xval_1[k] - xval_1[l];
float sloap_1 = infinitio;
float inter_1 = 0;
if( run_0 != 0 ){sloap_0 = ris_0/run_0;}
if( run_1 != 0 ){sloap_1 = ris_1/run_1;}
inter_0 = yval_0[i] - xval_0[i]*sloap_0;
inter_1 = yval_1[k] - xval_1[k]*sloap_1;
if( ( sloap_0 - sloap_1 != 0 ) && sloap_0 < infinitio && sloap_1 < infinitio ){
xval_n[i+k*4] = ( inter_0 - inter_1 ) / ( sloap_1 - sloap_0 );
yval_n[i+k*4] = xval_n[i]*sloap_0+inter_0;
} else if( ( sloap_0 < infinitio ) && !( sloap_1 < infinitio ) ){
xval_n[i+k*4] = xval_1[k];
yval_n[i+k*4] = xval_1[l]*sloap_0+inter_0;
} else if( ( sloap_1 < infinitio ) && !( sloap_0 < infinitio ) ){
xval_n[i+k*4] = xval_0[i];
yval_n[i+k*4] = xval_0[j]*sloap_1+inter_1;
} // the parralell case?? mhh do nothing
if(
( ( (xval_n[i+k*4] >= xval_0[i]) && (yval_n[i+k*4] >= yval_0[i]) )
&& ( (xval_n[i+k*4] <= xval_0[j]) && (yval_n[i+k*4] <= yval_0[j]) )
( ( (xval_n[i+k*4] >= xval_0[i]) && (yval_n[i+k*4] <= yval_0[i]) )
&& ( (xval_n[i+k*4] <= xval_0[j]) && (yval_n[i+k*4] >= yval_0[j]) )
( ( (xval_n[i+k*4] <= xval_0[i]) && (yval_n[i+k*4] >= yval_0[i]) )
&& ( (xval_n[i+k*4] >= xval_0[j]) && (yval_n[i+k*4] <= yval_0[j]) )
( ( (xval_n[i+k*4] <= xval_0[i]) && (yval_n[i+k*4] <= yval_0[i]) )
&& ( (xval_n[i+k*4] >= xval_0[j]) && (yval_n[i+k*4] >= yval_0[j]) )
( (xval_n[i+k*4] >= xval_1[k]) && (yval_n[i+k*4] >= yval_1[k]) )
&& ( (xval_n[i+k*4] <= xval_1[l]) && (yval_n[i+k*4] <= yval_1[l]) )
( (xval_n[i+k*4] >= xval_1[k]) && (yval_n[i+k*4] <= yval_1[k]) )
&& ( (xval_n[i+k*4] <= xval_1[l]) && (yval_n[i+k*4] >= yval_1[l]) )
( (xval_n[i+k*4] <= xval_1[k]) && (yval_n[i+k*4] >= yval_1[k]) )
&& ( (xval_n[i+k*4] >= xval_1[l]) && (yval_n[i+k*4] <= yval_1[l]) )
( (xval_n[i+k*4] <= xval_1[k]) && (yval_n[i+k*4] <= yval_1[k]) )
&& ( (xval_n[i+k*4] >= xval_1[l]) && (yval_n[i+k*4] >= yval_1[l]) )
) { nv_n++; }
else { xval_n[i+k*4] = invalid; yval_n[i+k*4] = invalid; }
int main(){
nv_g = 4;
xval_0 = (float*) malloc( sizeof(float)*nv_g );
yval_0 = (float*) malloc( sizeof(float)*nv_g );
// Allocate memory for Polygon_1 on the _host;
xval_1 = (float*) malloc( sizeof(float)*nv_g );
yval_1 = (float*) malloc( sizeof(float)*nv_g );
// Create the polygon_0 on _host
xval_0[0] = -.5; yval_0[0] = -.5;
xval_0[1] = .5; yval_0[1] = -.5;
xval_0[2] = .5; yval_0[2] = .5;
xval_0[3] = -.5; yval_0[3] = .5;
// Create the polygon_1 on _host
xval_1[0] = 0; yval_1[0] = -0.707106781;
xval_1[1] = 0.707106781; yval_1[1] = 0;
xval_1[2] = 0; yval_1[2] = 0.707106781;
xval_1[3] = -0.707106781; yval_1[3] = 0;
xval_n = (float*) malloc( sizeof(float)*nv_g*nv_g );
yval_n = (float*) malloc( sizeof(float)*nv_g*nv_g );
FindIntersections();
for(int i = 0; i < 4; i++){
for(int j = 0; j < 4; j++){
cout<<"("<<i<<","<<j<<"): ";
cout.precision(2);
cout.setf(ios::fixed,ios::floatfield);
if(xval_n[i+j*4] != invalid || true){cout<<xval_n[i+j*4]<<" , "<<yval_n[i+j*4];}
cout<<endl;
}[/codebox]
The same on the GPU:
[codebox] /*
Dominik Gothe
overlapArea.cu
- This pipeline can be easily adjusted to recive pointers or values
Ofcourse a pointer to the storage area for the Overlap is necessary
- define invalid point, a point that can not possibly occur
- The Overlap Area is Convex
- Both poygons have the same number of sides nv_g
- overlapping verticies have not been adressed ???
#include <stdio.h>
#include <math.h>
device float invalid = 6416415;
device float *xval_0; device float *yval_0; // Polygon 0
device float *xval_1; device float *yval_1; // Polygon 1
device float *xval_n; device float *yval_n; // Newly Created Polygon
device float *overlapArea; // Area of New Polygon
device int nv_g; // Number of Verticies of Input Polygons
device int nv_n = 0; // Number of verticies of New Polygon
device float *angle; // device can’t allocate memory
device void FindIntersections() { // ============================================================
int j = (i+1)%nv_g;
int l=(k+1)%nv_g;
float inter_0 = 0;
float inter_1 = 0;
if(
) { nv_n++; }
global void ComputeOverlap( //float *xval_0_p, float *yval_0_p,
//float *xval_1_p, float *yval_1_p,
float *xval_n_p, float *yval_n_p,
int nv_g_p,
float *overlapArea_p,
float *angle_p ){ // =========================================================
//xval_0 = xval_0_p; yval_0 = yval_0_p;
//xval_1 = xval_1_p; yval_1 = yval_1_p;
xval_n = xval_n_p; yval_n = yval_n_p;
overlapArea = overlapArea_p;
nv_g = nv_g_p;
angle = angle_p;
// RemoveInvalids();
// Merge();
// Order();
// PolyArea();
int main(){
// Create the Polygon on _host and copy to _device =============================
const int nv_g_h = 4; // number of verticies for each polygon (global)
// Allocate memory for Polygon_0 on the _host;
float *xval_0_h; cudaMallocHost ( (void**)&xval_0_h, sizeof(float)*nv_g_h );
float *yval_0_h; cudaMallocHost ( (void**)&yval_0_h, sizeof(float)*nv_g_h );
float *xval_1_h; cudaMallocHost ( (void**)&xval_1_h, sizeof(float)*nv_g_h );
float *yval_1_h; cudaMallocHost ( (void**)&yval_1_h, sizeof(float)*nv_g_h );
float *xval_n_h; cudaMallocHost ( (void**)&xval_n_h, sizeof(float)*nv_g_h*nv_g_h );
float *yval_n_h; cudaMallocHost ( (void**)&yval_n_h, sizeof(float)*nv_g_h*nv_g_h );
// Allocate memory for Polygon_0 on the _device;
float *xval_0_d; cudaMalloc ( (void**)&xval_0_d, sizeof(float)*nv_g_h );
float *yval_0_d; cudaMalloc ( (void**)&yval_0_d, sizeof(float)*nv_g_h );
// Allocate memory for Polygon_1 on the _device;
float *xval_1_d; cudaMalloc ( (void**)&xval_1_d, sizeof(float)*nv_g_h );
float *yval_1_d; cudaMalloc ( (void**)&yval_1_d, sizeof(float)*nv_g_h );
float *xval_n_d; cudaMalloc ( (void**)&xval_n_d, sizeof(float)*nv_g_h*nv_g_h );
float *yval_n_d; cudaMalloc ( (void**)&yval_n_d, sizeof(float)*nv_g_h*nv_g_h );
// Allocate memory for the Overlap Area on the host
float *overlap_h; cudaMallocHost ( (void**)&overlap_h, sizeof(float) );
// Allocate memory for the Overlap Area on the device
float *overlap_d; cudaMalloc ( (void**)&overlap_d, sizeof(float) );
xval_0_h[0] = -.5; yval_0_h[0] = -.5;
xval_0_h[1] = .5; yval_0_h[1] = -.5;
xval_0_h[2] = .5; yval_0_h[2] = .5;
xval_0_h[3] = -.5; yval_0_h[3] = .5;
xval_1_h[0] = 0; yval_1_h[0] = -0.707106781;
xval_1_h[1] = 0.707106781; yval_1_h[1] = 0;
xval_1_h[2] = 0; yval_1_h[2] = 0.707106781;
xval_1_h[3] = -0.707106781; yval_1_h[3] = 0;
// Initilize the new polygon to zero
for(int i = 0; i < nv_g_h*nv_g_h; i++){
xval_n_h[i] = 0;
yval_n_h[i] = 0;
cutilSafeCall( cudaMemcpy( xval_n_d, xval_n_h, sizeof(float)*nv_g_h*nv_g_h, cudaMemcpyHostToDevice ) );
cutilSafeCall( cudaMemcpy( yval_n_d, yval_n_h, sizeof(float)*nv_g_h*nv_g_h, cudaMemcpyHostToDevice ) );
// Initilize the overlap area
overlap_h[0] = 0;
cutilSafeCall( cudaMemcpy( overlap_d, overlap_h, sizeof(float)*nv_g_h*nv_g_h, cudaMemcpyHostToDevice ) );
// Create the Angle array that is needed for the device
float *angle_d; cudaMalloc ( (void**)&angle_d, sizeof(float)*nv_g*nv_g );
ComputeOverlap<<<1,1>>>(
xval_0_d, yval_0_d,
xval_1_d, yval_1_d,
xval_n_d, yval_n_d,
nv_g_h,
overlap_d,
angle_d );
cutilSafeCall( cudaMemcpy( overlap_h, overlap_d, sizeof(float), cudaMemcpyDeviceToHost ) );
cout<<overlap_h[0]<<endl<<endl;
// BEGIN DEBUG
cutilSafeCall( cudaMemcpy( xval_n_h, xval_n_d, sizeof(float)*nv_g_h*nv_g_h, cudaMemcpyDeviceToHost ) );
cutilSafeCall( cudaMemcpy( yval_n_h, yval_n_d, sizeof(float)*nv_g_h*nv_g_h, cudaMemcpyDeviceToHost ) );
cout.precision(2);
cout<<xval_n_h[i]<<" , "<<yval_n_h[i]<<endl;
// END DEBUG
// END DEBUG
}[/codebox]
please help, coffee no longer does :wacko:
my suspects are either copying crap back and forth from the device or the the fact that I declared global variables in my kernal.
thanks
thanks - Dominik Gothe
