Looking for testers: open source live dashboard for GPU + vLLM inference metrics
Hello everyone,
I built an open source live dashboard for LLM inference rigs and I’m looking for fellow DGX Spark owners to test it.
It’s a showcase / live-view tool, not a production metrics stack. One screen combining Nvidia GPU telemetry (NVML) with vLLM inference metrics, so you don’t have to juggle nvidia-smi and vLLM’s /metrics endpoint in separate terminals.
Shows:
  • GPU: utilization, VRAM, power, temps, clocks
  • vLLM: tokens/sec, TTFT, ITL, queue depth, active/waiting requests, KV cache, prefix cache hits
  • Works with vLLM on host or in Docker
  • Auto-detects multiple vLLM instances
It was developed on my own Spark, so I’d like to validate it on other units before calling it done. Spark-specific things I’d especially like checked:
  • Unified memory reporting on GB10
  • vLLM configs typical for Spark (FP8 / NVFP4, MoE, TP on unified memory)
  • Docker setups with the Nvidia container runtime
Repo: https://github.com/niklasfrick/spark-dashboard
Feedback welcome here or as GitHub issues. Thanks to anyone who gives it a try.
Sorry, it took me a while to come back to this, get it compiled and installed.
  • I use rust on my mac, but not on the DGX spark, so had to get all that up and running to install it.
  • Also had to install Nvidia Container Toolkit – which might be worth mentioning in your README.
  • Otherwise it looks good.
2 Questions?
  1. Service Level Objectives (SLO Goodput) - I am not hitting any of these. Are there settings you would recommend for the DGX Spark?
  2. Its only available on localhost. Is there a way to set host to 0.0.0.0 so I can access it over the local subnet on other computrers?
Requests
  • MTP Acceptance rates (you could add it under cache)
I like your dashboard, the design is clean, I wish it can connect and get hardware info from each spark in a spark cluster. I use your dashboard in combination with sparkrun cluster monitor so I can see instantaneous PP/TG and temperature / power usage in each spark.
How do you achieved 224 t/s? Is this single spark setup?
Concurrency. Parallel inference tasks. Its hard to design the orchestration, but when you do the payoff is huge. I see peaks at 300+ t/s typically across 16 concurrent tasks. If you look closely you will see that one was running 21 tasks. 27b has lots of headroom.
Yes – 1 DGX Spark.
Thanks for the review and feedback! I will add the NCT requirement to the README.
To your questions:
  1. The defaults are loose “industry standard” interactive-serving targets calibrated for datacenter GPUs at high concurrency — not a verdict on your Spark. They’re a reference, not a goal. The card is fully customizable, so set the values for your model and workload.
Quick context: TTFT scales with prompt length (long context will always blow past 500 ms — expected). ITL and TPOT are basically the same metric, and decode on the GB10 is memory-bandwidth bound. E2E = TTFT + (ITL × output tokens), so a 5 s cap assumes short generations.
For a realistic single-user / low-concurrency interactive profile on a 30B-class MoE:
Metric Default Suggested for Spark
ITL ≤ 50 ms ≤ 100 ms
TPOT ≤ 50 ms ≤ 100 ms
TTFT ≤ 500 ms ≤ 1500 ms (short) / ≤ 4000 ms (long context)
E2E ≤ 5 s ≤ 20 s
Set targets just slightly looser than what you reliably measure — close enough to catch regressions, loose enough that normal variance doesn’t trip them. If you want tighter numbers, the levers are speculative decoding (MTP), FP8 quant, and a modest max_num_seqs.
  1. It runs on port 3000 and is accessible if you have access. Does it not work for you?
To your request regarding MTP:
  • As I am too tinkering around with spec decoding this is very high on my priority list. So it will come soon :)
Thanks! Glad you like it.
As I am not the lucky owner of multiple sparks this is something that makes it harder for me to work on as I cannot reliably test it. But always glad if someone wants to help… ;)
Your monitor has really helped me fine tune model performance in real time, with real world data rather than relying on benchmarks – which often don’t tell the full story. The results have been outstanding.
The new Prefix Hit monitor makes this all the monitor I need now for inference.
Thanks a bunch!
It didn’t seem to when I first set it up, but now it does – probably operator error ;).
Really glad to hear it! this and the showcasing are exactly the use cases I built it for.
I’m glad accessing the dashboard remotely works for you now!
Thanks for the kind words!
I like it! I created one based on pain points and usage as well, but I set it up to just pull data on refresh, as it can be a resource hog and built with Rust as well.
Layered, L1 tech on top, L2 software uptime and L3 installed versions.
Feel free to add in any of these into your dashboard :-)
Speculative decoding metrics are available now in the latest (v0.11.0) release! ;)
As well as a docker-based deployment making it easier to deploy & upgrade in the future.
