I consistently use the “kernels” around fortran array syntax, but it seems that when I do so with some array operations, I get strange compiler comments and it is not parallelized.
Example:
This code:
!$acc kernels default(present)
pres=he_p*rho*temp/he_rho
!$acc end kernels
yields this output:
setp_acc:
0, Accelerator kernel generated
Generating Tesla code
45208, Accelerator scalar kernel generated
Generating implicit present(pres$f(:,:,:),pres$f,temp(:,:,:),rho(:,:,:),pres(:,:,:))
45209, Loop carried dependence due to exposed use of pres$f(:,:,:) prevents parallelization
Parallelization requires privatization of pres$f as well as last value
Loop is parallelizable
Loop carried reuse of pres prevents parallelization
Inner sequential loop scheduled on accelerator
45209, !$acc loop seq
In this code segment, temp, rho, and pres are all allocatable, form the same module, and on the device.
The scalars are stored in a different module.
Any ideas on why this is happening? What does it mean “pres$f?”.
Per the Fortran standard when using array syntax, the right hand side needs to be fully evaluated before assignment to the left hand side. If there isn’t a dependency between the right and left-hand side, then the compiler can often ignore this rule. Though if there is a dependency, then it needs to first create a temp array to hold the results of the right hand side and copy the temp array results to the left hand side. The “pres$f” is this temporary array.
Is “he_p” or any of the other variables a pointer? If so, then this is most likely the problem. If there is a pointer and that pointer could potentially point at pres, then the temp array will need to be created since this creates a potential dependency.
The workaround would be to make this an explicit loop since the above rule only applies to array syntax or forall loops.
In this case, he_p and he_rho are simple real*8 scalars.
rho and temp are arrays declared as pointers but I was under the impression that in fortran, all pointers are assumed to be pointing to unique data (i.e. that there is no fortran equivalent to the C “restrict” keyword).
Is there a way to impose the equivalent of “restrict” for fortran pointers?
It’s valid Fortran to have multiple pointers point to the same target.
