[u]What approach is recommended to achieve low camera latency with Jetson Nano?
[/u]
For vision based robot driving I would like that the camera latency approaches 10ms.
I used the examples at https://www.jetsonhacks.com/2019/04/02/jetson-nano-raspberry-pi-camera/ which are based on gstreamer and IX219 camera.
The latency I measured is in 100-200ms range (taking image of stopwatch and a window showing the recorded stopwatch).
I am under assumption that CSI cameras can reach better latency than USB cameras. As reference I know that Raspi based vision system using OV5647 or similar with CSI interface (https://limelightvision.io) approaches 25ms total latency (incl opencv based object recognition).
I could not identify options in gst-inspect-1.0 nvarguscamerasrc that lower latency significantly.
I tested with:
cap = cv2.VideoCapture(gstreamer_pipeline(), cv2.CAP_GSTREAMER)
def gstreamer_pipeline(
capture_width=1920, capture_height=1080,
display_width=1280, display_height=720,
framerate=30, exposure_time= 5, # ms
flip_method=0):
exposure_time = exposure_time * 1000000 #ms to ns
exp_time_str = '"' + str(exposure_time) + ' ' + str(exposure_time) + '"'
return (
'nvarguscamerasrc '
'name="NanoCam" '
'do-timestamp=true '
'timeout=0 ' # 0 - 2147483647
'blocksize=-1 ' # block size in bytes
'num-buffers=-1 ' # -1..2147483647 (-1=ulimited) num buf before sending EOS
'sensor-mode=-1 ' # -1..255, IX279 0(3264x2464,21fps),1 (3264x1848,28),2(1080p.30),3(720p,60),4(=720p,120)
'tnr-strength=-1 ' # -1..1
'tnr-mode=1 ' # 0,1,2
# 'ee-mode=0' # 0,1,2
# 'ee-strength=-1 ' # -1..1
'aeantibanding=1 ' # 0..3, off,auto,50,60Hz
'bufapi-version=false ' # new buffer api
'maxperf=true ' # max performance
'silent=true ' # verbose output
'saturation=1 ' # 0..2
'wbmode=1 ' # white balance mode, 0..9 0=off 1=auto
'awblock=false ' # auto white balance lock
'aelock=true ' # auto exposure lock
'exposurecompensation=0 ' # -2..2
'exposuretimerange=%s ' # "13000 683709000"
'gainrange="1.0 10.625" ' # "1.0 10.625"
'ispdigitalgainrange="1 8" ' # "1 8"
'! video/x-raw(memory:NVMM), '
'width=(int)%d, '
'height=(int)%d, '
'format=(string)NV12, '
'framerate=(fraction)%d/1 '
'! nvvidconv flip-method=%d '
'! video/x-raw, width=(int)%d, height=(int)%d, format=(string)BGRx '
'! videoconvert '
'! video/x-raw, format=(string)BGR '
'! appsink'
exp_time_str,
capture_width,
capture_height,
framerate,
flip_method,
display_width,
display_height,
