Low latency wireless video streaming with gstreamer
I have a Jetson Nano and a RaspberryPi v2 camera. I have built a balancing robot and I want to mount the Jetson Nano on it in order to live-stream video wirelessly from the robot to other computers so I will be able to control it remotely by looking through its camera.
I used gstreamer and first tried encoding the video as jpeg. The latency was virtually zero but when I moved to settings higher than 1280x720 over 30fps it just didn’t catch up (unless I lowered the compression quality). Below are the pipelines I used:
Jetson Nano:
gst-launch-1.0 nvarguscamerasrc ! 'video/x-raw(memory:NVMM), format=(string)NV12, width=(int)1280, height=(int)720, framerate=30/1' ! nvjpegenc ! tcpserversink host=0.0.0.0 port=5000
Laptop:
gst-launch-1.0 -e -vvvv tcpclientsrc host=yinon-jetson port=5000 ! jpegdec ! autovideosink
I understood that jpeg encoding is only intra-frame and does not rely on other frames and therefore it compresses video poorly. Therefore, I tried encoding the video as h265. Indeed it worked better in terms of reaching settings such as 1280x720 over 60fps and 1920x1080 over 30fps but there was always a latency of about 300ms (which may be fine for many applications, but for controlling a robot remotely it is a royal pain in the a$$). Even if I lowered the setting to 352x240 over 60fps this latency persisted. Below are the pipelines I used:
Jetson Nano:
gst-launch-1.0 nvarguscamerasrc ! 'video/x-raw(memory:NVMM), format=(string)NV12, width=(int)1280, height=(int)720, framerate=30/1' ! omx2h265enc ! mpegtsmux ! tcpserversink host=0.0.0.0 port=5000
Laptop:
gst-launch-1.0 -e -vvvv tcpclientsrc host=yinon-jetson port=5000 ! queue ! tsdemux ! h265parse ! libde265dec ! autovideosink
I tried tweaking some of the parameters of the omxh265enc but none of them removed this annoying latency.
Therefore I want to ask the following:
  • Is there any way to tune the h265 encoder in order to reduce latency?
  • If not, is there a more suitable encoder/decoder?
Thanks,
Yinon
libde265dec looks to be an software decoder. Are you able to set up another Jetson Nano and try omxh265dec?
I set the iframeinterval property to lower values between 1 to 10 and it seemed to solve the latency issue. As far as I understood , this interval determines the number of frames between each generated I-frame. I have seen that in omxh265enc, the default value for the iframeinterval is 0 - what does it do when it is 0?
About setting up another Jetson Nano: As a hobbyist, unfortunately, I don’t have an army of Jetsons so I am not able to set up another Jetson Nano. However, I think that my laptop has an NVIDIA GPU which is also CUDA-enabled. Is there a possibility to install an h265 decoder for gstreamer which will utilize this GPU?
By default I frame interval is 30.
On desktop GPUs, we have VIDEO CODEC SDK https://developer.nvidia.com/nvidia-video-codec-sdk
However, it is supported on ffmpeg frameworks but not gstreamer.
We suspected that latency is due to using software decoder, but you have figured out it it due to I frame interval. It should be good to use libde265dec.
