I am using SSD mobilenet caffe model to run object detection. The Tegrastats shows the following while running the model…
RAM 2891/7846MB (lfb 266x4MB) CPU [87%@2035,69%@2035,96%@2035,87%@2035,78%@2035,82%@2035] BCPU@42.5C MCPU@42.5C GPU@38.5C PLL@42.5C Tboard@35C Tdiode@37.25C PMIC@100C thermal@40.6C VDD_IN 10133/10079 VDD_CPU 5652/5473 VDD_GPU 382/378 VDD_SOC 993/1043 VDD_WIFI 38/44 VDD_DDR 1651/1660
- The RAM is not utilized fully. How to make sure full RAM capacity is used.
- How can I increase the GPU usage.
I am just getting 5 FPS on the Jetson TX2.
Opencv - 3.4.1
Model - MobileNetSSD_deploy.caffemodel
Hi AastaLLL,
I dont want to use the TensorRT for the ssdmobilenet caffe model as it is known to have problems with certain nodes.
- Is there any way I can see the GPU/CPU utilization graph plot to know how the GPU is loaded ?
- Do you recommend multi-threading for a larger batch size ? Or is there any other way I can increase the batchsize value ?
- Will I be able to define and use the GPU for certain tasks ?
Also, is there any way of know if the GPU is active and being used on the Jetson TX2 ?
1. You can check CPU/GPU utilization by tegrastats.
sudo ./tegrastats
2. Just set batch size > 1.
3. Sure. All the GPU tasks are required to implement with CUDA. Otherwise, it is a CPU job.
4. Check tegrastats for the information.
Thanks for the reply !
The batch size has to be set in the .prototxt file ?
