I have this code for estimating pi using Monte Carlo method:
typedef float sFloat;
typedef int64_t s64Int;
#define MAX64 0x7FFFFFFFFFFFFFFF
__host__ __device__ s64Int xorshift64star(s64Int x) {
x ^= x >> 12; // a
x ^= x << 25; // b
x ^= x >> 27; // c
return x * UINT64_C(2685821657736338717);
__global__ void pikernel(s64Int samples, s64Int* nIn, s64Int* nOut) {
s64Int i;
sFloat xx, yy;
s64Int ni = 0; // points inside the circle
s64Int no = 0; // points outside the circle
int tid = blockIdx.x * blockDim.x + threadIdx.x;
// initialize the random generator (non-zero)
s64Int offset = tid * samples;
s64Int x = 12345678 + offset * 89482311;
s64Int y = 87654321 + offset + 12345678;
// generate points and count
for(i = 0; i < samples; i++) {
x = xorshift64star(x);
y = xorshift64star(y);
xx = ((sFloat)x)/(sFloat)MAX64;
yy = ((sFloat)y)/(sFloat)MAX64;
if (xx * xx + yy * yy > 1.0)
no++;
else
ni++;
// update output
nIn[tid] = ni;
nOut[tid] = no;
Surprisingly, running it on Jetson TX1 takes longer than running it on Jetson TK1. When I increase GPU frequency using the method described here https://devtalk.nvidia.com/default/topic/952478/maximize-tx1-performance/, I get better results, but still worse than TK1. Moreover, profiling results show that TX1 GPU IPC is much lower compared to TK1’s GPU, independent of the frequency. These is a summary of the results:
Jetson TX1 System
Device “NVIDIA Tegra X1 (0)”
CUDA toolkit 8.0
g++ 5.4.0
Kernel: pikernel(long, long*, long*)
Output using default GPU frequency
Using 2 blocks and 512 threads per block
Estimated value of Pi is 3.141437
Estimation took 2,909,335 usec
Output using GPU frequency of 998400000 Hz
Estimation took 1,016,859 usec
nvprof summary
Invocations Metric Name Metric Description Min Max Avg
1 ipc Executed IPC 0.435372 0.435372 0.435372
1 flop_sp_efficiency FLOP Efficiency(Peak Single) 0.61% 0.61% 0.61%
1 sm_efficiency Multiprocessor Activity 99.94% 99.94% 99.94%
1 warp_execution_efficiency Warp Execution Efficiency 95.42% 95.42% 95.42%
Jetson TK1 System
Device “GK20A (0)”
CUDA toolkit 6.5
g++ 4.8.4
Kernel: pikernel(__int64, __int64*, __int64*)
Output
Estimation took 915,394 usec
nvprof summary
1 ipc Executed IPC 1.948358 1.948358 1.948358
1 flop_sp_efficiency FLOP Efficiency(Peak Single) 2.18% 2.18% 2.18%
1 sm_efficiency Multiprocessor Activity 12.10% 12.10% 12.10%
1 warp_execution_efficiency Warp Execution Efficiency 98.02% 98.02% 98.02%
Does anyone have any idea why the IPC is lower on TX1?
