LPD training model not OK
• Hardware Platform (Jetson )
• DeepStream Version:6.0
• TensorRT Version
I use detectnet_v2 to train lpd with my own data, In tao verify model, it is ok, such as:
But this model did not work when I deploy it in deepstream, my lpd config is:
[property]
#gpu-id=0
net-scale-factor=0.0039215697906911373
model-color-format=0
labelfile-path=/opt/nvidia/deepstream/deepstream-6.0/samples/models/Secondary_PlateDetc/ccpd_label.txt
tlt-encoded-model=/opt/nvidia/deepstream/deepstream-6.0/samples/models/Secondary_PlateDetc/ccpd_pruned.etlt
model-engine-file = /opt/nvidia/deepstream/deepstream-6.0/samples/models/Secondary_PlateDetc/ccpd_pruned.etlt_b4_gpu0_int8.engine
int8-calib-file=/opt/nvidia/deepstream/deepstream-6.0/samples/models/Secondary_PlateDetc/ccpd_cal.bin
tlt-model-key=tlt_encode
infer-dims=3;384;1248
#uff-input-dims=3;384;1248;0
uff-input-blob-name=input_1
batch-size = 4
## 0=FP32, 1=INT8, 2=FP16 mode
network-mode=1
num-detected-classes=1
##1 Primary 2 Secondary
process-mode=2
interval=0
# 0 detector 1 classifier 2 segmentatio 3 instance segmentation
network-type=0
#no cluster
cluster-mode=3
output-blob-names=output_bbox/BiasAdd;output_cov/Sigmoid
# 4096*2160=450*350    2560*1440=250*150
input-object-min-width=250
input-object-min-height=150
#GPU:1  VIC:2(Jetson only)
scaling-compute-hw=1
#enable-dla=1
[class-attrs-all]
pre-cluster-threshold=0.3
roi-top-offset=0
roi-bottom-offset=0
detected-min-w=66
detected-min-h=22
detected-max-w=0
detected-max-h=0
Plesase help me, thank you.
Does the “not work” mean cannot detect the plate at all? Please share more information about deepstream config and pipeline, thanks.
Yes, it can not detect plate.
The deepstream is:
input: two rtsp streams, resolution:4096X2160
streammux: 2560X1440
primary detect: detect car, person and etc.
The deepstream main config is:
[application]
enable-perf-measurement = 1
perf-measurement-interval-sec = 5
[tiled-display]
enable = 0
rows = 2
columns = 2
width = 2560
height = 1440
gpu-id = 0
nvbuf-memory-type = 0
[source0]
enable = 1
type = 4
uri = rtsp://192.168.170.63:8554/mystream9
intra-decode-enable = 0
num-extra-surfaces = 4
camera-id = 0
drop-frame-interval = 3
select-rtp-protocol = 4
rtsp-reconnect-interval-sec = 10
rtsp-reconnect-attempts = 10
[source1]
enable = 1
type = 4
uri = rtsp://192.168.170.63:8554/mystream10
camera-id = 1
[streammux]
live-source = 1
buffer-pool-size = 4
batch-size = 2
batched-push-timeout = 40000
width = 2560
height = 1440
compute-hw = 1
enable-padding = 1
attach-sys-ts-as-ntp = 0
[primary-gie]
enable = 1
config-file = pgie_yolo_cfg.txt
batch-size = 2
gie-unique-id = 1
interval = 0
input-tensor-meta = 0
bbox-border-color0 = 0;1;0;1
bbox-border-color1 = 0;1;1;1
bbox-border-color2 = 0;0;1;1
bbox-border-color3 = 1;0;1;1
bbox-border-color4 = 1;0;0;1
bbox-border-color5 = 1;0;0;1
bbox-border-color6 = 1;0;0;1
bbox-border-color7 = 0;1;0;1
bbox-border-color8 = 1;0;0;1
bbox-border-color9 = 0;1;0;1
bbox-border-color10 = 1;1;0;1
The primary detect config is:
[property]
num-detected-classes=80
#batch-size=4
#tensor-meta-pool-size=8
model-engine-file=/opt/nvidia/deepstream/ds-app/ds-engine/vehicle.engine
labelfile-path=/opt/nvidia/deepstream/deepstream-6.0/samples/models/Primary_Detector/labels_rgl.txt
gie-unique-id=1
#interval=2
network-mode=2
output-blob-names=prob
parse-bbox-func-name=NvDsInferParseCustomYoloV5
custom-lib-path=/opt/nvidia/deepstream/deepstream-6.0/lib/libnvdsinfer_custom_impl_Yolo_traffic_parti.so
# Integer 0: RGB 1: BGR 2: GRAY
# Integer 1=Primary 2=Secondary
process-mode=1
#classifier-threshold=0.4
# Integer  0: Detector  1: Classifier  2: Segmentation  3: Instance Segmentation
network-type=0
maintain-aspect-ratio=1
#symmetric-padding=1
force-implicit-batch-dim=1
## 1=DBSCAN, 2=NMS, 3= DBSCAN+NMS Hybrid, 4 = None(No clustering)
#cluster-mode=2
#scaling-filter=0
# Integer 0: Platform default – GPU (dGPU), VIC (Jetson) 1: GPU 2: VIC (Jetson only)
# Integer 0:NCHW 1:NHWC
#network-input-order=1
#Use the config params below for dbscan clustering mode
#[class-attrs-all]
#detected-min-w=4
#detected-min-h=4
#minBoxes=3
#Use the config params below for NMS clustering mode
[class-attrs-all]
topk=20
nms-iou-threshold=0.35
pre-cluster-threshold=0.35
## Per class configurations
[class-attrs-0]
topk=20
nms-iou-threshold=0.5
pre-cluster-threshold=0.4
#[class-attrs-1]
#pre-cluster-threshold=0.05
#eps=0.7
#dbscan-min-score=0.5
#[class-attrs-2]
#pre-cluster-threshold=0.1
#eps=0.6
#dbscan-min-score=0.95
#[class-attrs-3]
#eps=0.7
[class-attrs-7]
topk=20
Thank you very much.
Could you give some advice?
Hi @huihui308 , In your deepstream main config, I cannot see the osd plugin. We use osd plugin to draw the bbox. So could you have a try to add this plugin to your config file? Thanks
I forget to put osd config to paste,
[application]
[tiled-display]
enable = 0
rows = 2
columns = 2
width = 2560
height = 1440
gpu-id = 0
[source0]
enable = 1
type = 4
camera-id = 0
[source1]
enable = 1
type = 4
camera-id = 1
[streammux]
live-source = 1
batch-size = 2
width = 2560
height = 1440
compute-hw = 1
enable-padding = 1
[primary-gie]
enable = 1
batch-size = 2
gie-unique-id = 1
interval = 0
[osd]
enable = 1
border-width = 2
text-size = 20
text-color = 1;1;1;1;
text-bg-color = 0.3;0.3;0.3;1
show-clock = 1
clock-text-size = 32
clock-x-offset = 60
clock-y-offset = 70
font = Serif
clock-color = 1;0;0;0
display-text = 1
display-bbox = 1
display-mask = 0
The cars have bbox.
Your config file has no SGIE. You can refer this for a correct config. Thanks
https://github.com/NVIDIA-AI-IOT/deepstream_lpr_app
I am ver sorry, I forget to paste it.
[application]
[tiled-display]
enable = 0
rows = 2
columns = 2
width = 2560
height = 1440
gpu-id = 0
[source0]
enable = 1
type = 4
camera-id = 0
[source1]
enable = 1
type = 4
camera-id = 1
[streammux]
live-source = 1
batch-size = 2
width = 2560
height = 1440
compute-hw = 1
enable-padding = 1
[primary-gie]
enable = 1
batch-size = 2
gie-unique-id = 1
interval = 0
[secondary-gie0]
enable = 1
config-file = sgie0_lpd_cfg.txt
gie-unique-id = 2
operate-on-gie-id = 1
operate-on-class-ids = 4;5;6
gpu-id=0
batch-size=16
[osd]
enable = 1
border-width = 2
text-size = 20
show-clock = 1
clock-x-offset = 60
clock-y-offset = 70
font = Serif
display-text = 1
display-bbox = 1
display-mask = 0
When I use ccpd pruned 1.0 model from ‘GPU-optimized AI, Machine Learning, & HPC Software | NVIDIA NGC | NVIDIA NGC’, th lpd work well, but when I use my train model, it do not work. but this model inference well in tao.
Anyone can help you?thank you.
Hi @huihui308 , How do you run in TAO with your model?
Also, You can try these ways below first:
1.run the demo below in your env, and see if it works well:
2.use the model in the demo, and see if it works well in deepstream.
In tao, when I finished traing, it can inference testing image by training model, lpd works well.
When I use ccpd pruned 1.0 model from ‘LPDNet | NVIDIA NGC’, th lpd work well, but when I use my train model, it do not work. but this model inference well in tao.
Hi @huihui308 , Yeah, cause your model is trained by TAO. It should work well in deepstream.
I think your problem is that you are not very familiar with deepstream. You can read the guide below to learn how to use source, streamux, infer, tracker, pgie, sgie to do a test. Thanks
https://docs.nvidia.com/metropolis/deepstream/dev-guide/text/DS_ref_app_deepstream.html
Also, you can refer the config file that our code provided, and just change the source and config file path, model to your own:
/opt/nvidia/deepstream/deepstream-X.X/samples/configs/deepstream-app/source4_1080p_dec_infer-resnet_tracker_sgie_tiled_display_int8.txt
My deepstream work well when I use ‘LPDNet | NVIDIA NGC’ lpd, but when I only replace etlt and int8-calib-file, lpd do not work.
But this etlt and int8-calib-file work well in tao, this is my question.
Did you write the config file by the guide License Plate Detection (LPDNet) Model Card. I don’t see a tracker in your config file.
Or can you attach your whole files (config file, our model that can work well, your model that cannot work well) and all the commands you have used.
OK, I think tracker is not impossible for the lpd.
My deepstream main config is:
[application]
[tiled-display]
enable = 0
rows = 2
columns = 2
width = 2560
height = 1440
gpu-id = 0
[source0]
enable = 1
type = 4
camera-id = 0
[source1]
enable = 1
type = 4
camera-id = 1
[source2]
enable = 0
type = 4
uri = rtsp://192.168.170.63:8554/mystream11
camera-id = 2
[source3]
enable = 0
type = 4
uri = rtsp://192.168.170.63:8554/mystream12
camera-id = 3
[source4]
enable = 0
type = 4
uri = rtsp://192.168.170.63:8554/mystream204
camera-id = 4
#drop-frame-interval = 2
[source5]
enable = 0
type = 4
uri = rtsp://192.168.170.63:8554/mystream205
camera-id = 5
[source6]
enable = 0
type = 4
uri = rtsp://192.168.170.63:8554/mystream206
camera-id = 6
[source7]
enable = 0
type = 4
uri = rtsp://192.168.170.63:8554/mystream201
camera-id = 7
[streammux]
live-source = 1
batch-size = 2
width = 2560
height = 1440
compute-hw = 1
enable-padding = 1
[pre-process]
enable = 0
config-file = preprocess_cfg.txt
[primary-gie]
enable = 1
batch-size = 2
gie-unique-id = 1
interval = 0
[tracker]
enable = 0
tracker-width = 960
tracker-height = 544
ll-config-file = config_tracker_NvDCF_max_perf.yml
ll-lib-file = /opt/nvidia/deepstream/deepstream-6.0/lib/libnvds_nvmultiobjecttracker.so
enable-batch-process = 1
enable-past-frame = 1
display-tracking-id = 1
tracking-id-reset-mode = 3
[nvds-analytics]
enable = 0
config-file = config_nvdsanalytics.txt
[secondary-gie0]
enable = 1
gie-unique-id = 2
[secondary-gie1]
enable = 0
config-file = sgie1_lpr_cfg.txt
gie-unique-id = 3
operate-on-gie-id = 2
operate-on-class-ids = 0
[secondary-gie2]
enable = 0
config-file = sgie2_carcolor_cfg.txt
gie-unique-id = 4
[secondary-gie3]
enable = 0
config-file = sgie3_carmake_cfg.txt
gie-unique-id = 5
[secondary-gie4]
enable = 0
config-file = sgie4_vehicletypes_cfg.txt
gie-unique-id = 6
[osd]
enable = 1
border-width = 2
text-size = 20
show-clock = 1
clock-x-offset = 60
clock-y-offset = 70
font = Serif
display-text = 1
display-bbox = 1
display-mask = 0
[sink0]
enable = 1
type = 8
qos = 0
codec = 1
source-id = 0
enc-type = 0
sync = 0
bitrate = 15000000
profile = 0
link-to-demux = 0
output-file = rtmp://localhost/live/stream-0
width = 1920
height = 1080
[sink1]
enable = 1
type = 8
qos = 0
codec = 1
source-id = 1
enc-type = 0
sync = 0
bitrate = 15000000
profile = 0
link-to-demux = 0
output-file = rtmp://localhost/live/stream-1
width = 1920
height = 1080
[sink2]
enable = 1
type = 8
qos = 0
codec = 1
source-id = 2
enc-type = 0
sync = 0
bitrate = 15000000
profile = 0
link-to-demux = 0
output-file = rtmp://localhost/live/stream-2
width = 1920
height = 1080
[sink3]
enable = 1
type = 8
qos = 0
codec = 1
source-id = 3
enc-type = 0
sync = 0
bitrate = 15000000
profile = 0
link-to-demux = 0
output-file = rtmp://localhost/live/stream-3
width = 1920
height = 1080
[sink4]
enable = 1
type = 8
qos = 0
codec = 1
source-id = 4
enc-type = 0
sync = 0
bitrate = 15000000
profile = 0
link-to-demux = 0
output-file = rtmp://localhost/live/stream-4
width = 1920
height = 1080
[sink5]
enable = 1
type = 8
qos = 0
codec = 1
source-id = 5
enc-type = 0
sync = 0
bitrate = 15000000
profile = 0
link-to-demux = 0
output-file = rtmp://localhost/live/stream-5
width = 1920
height = 1080
[sink6]
enable = 1
type = 8
qos = 0
codec = 1
source-id = 6
enc-type = 0
sync = 0
bitrate = 15000000
profile = 0
link-to-demux = 0
output-file = rtmp://localhost/live/stream-6
width = 1920
height = 1080
[sink7]
enable = 1
type = 8
qos = 0
codec = 1
source-id = 7
enc-type = 0
sync = 0
bitrate = 15000000
profile = 0
link-to-demux = 0
output-file = rtmp://localhost/live/stream-7
width = 1920
height = 1080
[sink8]
enable = 1
type = 7
qos = 0
source-id = 0
enc-type = 0
profile = 0
msg-conv-config = dstest5_msgconv_sample_config.txt
msg-broker-proto-lib = /opt/nvidia/deepstream/deepstream-6.0/lib/libqf_nnmsg_proto.so
msg-broker-conn-str = tcp://0.0.0.0:9020
topic = data_test6
msg-conv-payload-type = 0
msg-conv-msg2p-new-api = 1
msg-conv-frame-interval = 1
[sink9]
enable = 1
type = 7
qos = 0
source-id = 1
enc-type = 0
profile = 0
msg-broker-conn-str = tcp://0.0.0.0:9021
topic = data_test7
[sink10]
enable = 1
type = 7
qos = 0
source-id = 2
enc-type = 0
profile = 0
msg-broker-conn-str = tcp://0.0.0.0:9022
topic = data_test8
[sink11]
enable = 1
type = 7
qos = 0
source-id = 3
enc-type = 0
profile = 0
msg-broker-conn-str = tcp://0.0.0.0:9023
topic = data_test9
[sink12]
enable = 1
type = 7
qos = 0
source-id = 4
enc-type = 0
profile = 0
msg-broker-conn-str = tcp://0.0.0.0:9024
topic = data_test10
[sink13]
enable = 1
type = 7
qos = 0
source-id = 5
enc-type = 0
profile = 0
msg-broker-conn-str = tcp://0.0.0.0:9025
topic = data_test11
[sink14]
enable = 1
type = 7
qos = 0
source-id = 6
enc-type = 0
profile = 0
msg-broker-conn-str = tcp://0.0.0.0:9026
topic = data_test12
[sink15]
enable = 1
type = 7
qos = 0
source-id = 7
enc-type = 0
profile = 0
msg-broker-conn-str = tcp://0.0.0.0:9027
topic = data_test13
[sink16]
enable = 0
type = 3
qos = 0
container = 1
codec = 1
enc-type = 0
sync = 0
bitrate = 15000000
profile = 0
output-file = out.mp4
source-id = 1
width = 1920
height = 1080
[tests]
file-loop = 0
[debug]
gst-debug = 3
OK, What you mean is that you can run “deepstream_app -c this_configfile” with our guide model, but when you change our model to you own model only, it cannot work well? Are you sure you changed the model only?
Cause I don’t have your rtsp stream source, model, and GIE config files, tracker config files. I cannot run your demo.
You can try the following methods by yourself:
1.You can run a simple demo firstly with one source and one sink.
2.I still recommand that you can run our lpr demo below to familiar with deepstream, and then you can use your own model.
