Lprnet: Failed to run the tensorrt engine verification
• Hardware (T4/V100/Xavier/Nano/etc) : A100 PCIe
• Network Type (Detectnet_v2/Faster_rcnn/Yolo_v4/LPRnet/Mask_rcnn/Classification/etc) : lprnet
• TLT Version (Please run “tlt info --verbose” and share “docker_tag” here): v3.0-py3.0
• Training spec file(If have, please share here): Use the “tutorial_spec.txt” on sample code.
• How to reproduce the issue ? (This is for errors. Please share the command line and the detailed log here.)
It just run the following code after “Export in FP32 mode”.
!tlt lprnet export --gpu_index=$GPU_INDEX -m $USER_EXPERIMENT_DIR/experiment_dir_unpruned/weights/lprnet_epoch-24.tlt \
                   -k $KEY \
                   -e $SPECS_DIR/tutorial_spec.txt \
                   -o $USER_EXPERIMENT_DIR/export/lprnet_epoch-24.etlt \
                   --data_type fp32 \
                   --engine_file $USER_EXPERIMENT_DIR/export/lprnet_epoch-24.engine
    Using TensorFlow backend.
    WARNING:tensorflow:Deprecation warnings have been disabled. Set TF_ENABLE_DEPRECATION_WARNINGS=1 to re-enable them.
    2021-07-26 05:12:06,714 [INFO] iva.common.export.keras_exporter: Using input nodes: ['image_input']
    2021-07-26 05:12:06,714 [INFO] iva.common.export.keras_exporter: Using output nodes: ['tf_op_layer_ArgMax', 'tf_op_layer_Max']
    2021-07-26 05:12:06,714 [INFO] iva.lprnet.utils.spec_loader: Merging specification from /workspace/data/lprnet/specs/tutorial_spec.txt
    The ONNX operator number change on the optimization: 132 -> 61
    2021-07-26 05:12:18,205 [INFO] keras2onnx: The ONNX operator number change on the optimization: 132 -> 61
      File "/opt/tlt/.cache/dazel/_dazel_tlt/2b81a5aac84a1d3b7a324f2a7a6f400b/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/lprnet/scripts/export.py", line 215, in <module>
      File "/opt/tlt/.cache/dazel/_dazel_tlt/2b81a5aac84a1d3b7a324f2a7a6f400b/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/lprnet/scripts/export.py", line 142, in main
      File "/opt/tlt/.cache/dazel/_dazel_tlt/2b81a5aac84a1d3b7a324f2a7a6f400b/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/lprnet/scripts/export.py", line 211, in run_export
      File "/opt/tlt/.cache/dazel/_dazel_tlt/2b81a5aac84a1d3b7a324f2a7a6f400b/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/common/export/keras_exporter.py", line 371, in export
    TypeError: set_data_preprocessing_parameters() got an unexpected keyword argument 'image_mean'
It showed the error but actually, the notebook was created the “lprnet_epoch-24.etlt”.
So, I ignored this error but I met the another error at the next evaluate step on notebook.
# Verify the tensorrt engine accuracy on the validation dataset
!tlt lprnet evaluate --gpu_index=$GPU_INDEX -e $SPECS_DIR/tutorial_spec.txt \
                     -m $USER_EXPERIMENT_DIR/export/lprnet_epoch-24.engine \
                     --trt
    2021-07-26 05:16:47,074 [INFO] iva.lprnet.utils.spec_loader: Merging specification from /workspace/data/lprnet/specs/tutorial_spec.txt
      File "/opt/tlt/.cache/dazel/_dazel_tlt/2b81a5aac84a1d3b7a324f2a7a6f400b/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/lprnet/scripts/evaluate.py", line 152, in <module>
      File "/opt/tlt/.cache/dazel/_dazel_tlt/2b81a5aac84a1d3b7a324f2a7a6f400b/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/lprnet/scripts/evaluate.py", line 148, in main
      File "/opt/tlt/.cache/dazel/_dazel_tlt/2b81a5aac84a1d3b7a324f2a7a6f400b/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/lprnet/scripts/evaluate.py", line 105, in evaluate
      File "/opt/tlt/.cache/dazel/_dazel_tlt/2b81a5aac84a1d3b7a324f2a7a6f400b/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/common/inferencer/trt_inferencer.py", line 31, in __init__
      File "/opt/tlt/.cache/dazel/_dazel_tlt/2b81a5aac84a1d3b7a324f2a7a6f400b/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/common/inferencer/engine.py", line 113, in load_engine
    FileNotFoundError: [Errno 2] No such file or directory: '/workspace/data/lprnet/export/lprnet_epoch-24.engine'
    Exception ignored in: <bound method TRTInferencer.__del__ of <iva.common.inferencer.trt_inferencer.TRTInferencer object at 0x7fdb63ddc518>>
      File "/opt/tlt/.cache/dazel/_dazel_tlt/2b81a5aac84a1d3b7a324f2a7a6f400b/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/common/inferencer/trt_inferencer.py", line 139, in __del__
      File "/opt/tlt/.cache/dazel/_dazel_tlt/2b81a5aac84a1d3b7a324f2a7a6f400b/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/common/inferencer/trt_inferencer.py", line 96, in clear_trt_session
    AttributeError: 'TRTInferencer' object has no attribute 'context'
It seems that the model name was not match on example. So, I modified the model name at “-m” option like below but not fixed the issue.
                     -m $USER_EXPERIMENT_DIR/export/lprnet_epoch-24.etlt \
                     --trt
    2021-07-26 06:49:57,938 [INFO] iva.lprnet.utils.spec_loader: Merging specification from /workspace/data/lprnet/specs/tutorial_spec.txt
    [TensorRT] ERROR: coreReadArchive.cpp (32) - Serialization Error in verifyHeader: 0 (Magic tag does not match)
    [TensorRT] ERROR: INVALID_STATE: std::exception
    [TensorRT] ERROR: INVALID_CONFIG: Deserialize the cuda engine failed.
      File "/opt/tlt/.cache/dazel/_dazel_tlt/2b81a5aac84a1d3b7a324f2a7a6f400b/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/common/inferencer/trt_inferencer.py", line 32, in __init__
    AttributeError: 'NoneType' object has no attribute 'max_batch_size'
    Exception ignored in: <bound method TRTInferencer.__del__ of <iva.common.inferencer.trt_inferencer.TRTInferencer object at 0x7f13cb431550>>
If you have any questions, please let me know.
Best reagrds.
Kaka
Please debug with below command in terminal instead of jupyter notebook.
$ tlt lprnet run ls /workspace/data/lprnet/export/lprnet_epoch-24.engine
If not available, please check your ~/.tlt_mounts.json file.
And login the docker to find where is the engine.
$ tlt lprnet run /bin/bash
Thank you for your quick response.
It did not present the ”lprnet_epoch-24.engine” on the specified path at docker container. And I could not find this file on docker container.
Which step will create it?
Best regards.
Kaka
According to your log, the engine should be generated in
-k $KEY
–data_type fp32
–engine_file $USER_EXPERIMENT_DIR/export/lprnet_epoch-24.engine
Please check if it is available.
For debug use, you can run below and generate the file inside the docker.
# lprnet export --gpu_index=$GPU_INDEX -m $USER_EXPERIMENT_DIR/experiment_dir_unpruned/weights/lprnet_epoch-24.tlt
-k $KEY
–data_type fp32
I see. I tried the export command on docker container but the engine file did not generate by the following command.
!lprnet export --gpu_index=$GPU_INDEX -m $USER_EXPERIMENT_DIR/experiment_dir_unpruned/weights/lprnet_epoch-24.tlt \
                   -k $KEY \
                   --data_type fp32 \
    2021-07-26 08:04:12,033 [INFO] iva.common.export.keras_exporter: Using input nodes: ['image_input']
    2021-07-26 08:04:12,033 [INFO] iva.common.export.keras_exporter: Using output nodes: ['tf_op_layer_ArgMax', 'tf_op_layer_Max']
    2021-07-26 08:04:12,033 [INFO] iva.lprnet.utils.spec_loader: Merging specification from /workspace/data/lprnet/specs/tutorial_spec.txt
    2021-07-26 08:04:23,676 [INFO] keras2onnx: The ONNX operator number change on the optimization: 132 -> 61
Regarding to another thread, you explained that we could ignore this error. But it seems that it failed to create this engine file by this command.
If you have any question, please let me know.
Best regards
Kaka
Yes, it is an issue.
For workaround, please use tlt-converter to generate trt engine for lprnet.
See GitHub - NVIDIA-AI-IOT/deepstream_lpr_app: Sample app code for LPR deployment on DeepStream
For example,
 ./tlt-converter -k nvidia_tlt -p image_input,1x3x48x96,4x3x48x96,16x3x48x96 \
           models/LP/LPR/us_lprnet_baseline18_deployable.etlt -t fp16 -e models/LP/LPR/lpr_us_onnx_b16.engine
Hi
I am confusing… Does the following export command the same as the tlt-converter command?
                   -k $KEY \
                   --data_type fp32 \
JFYI.
Regarding to the below “tlt-converter” command, it passed without any issue.
!tlt tlt-converter $USER_EXPERIMENT_DIR/export/lprnet_epoch-24.etlt \
                   -k $KEY \
                   -t fp16 \
                   -e $USER_EXPERIMENT_DIR/export/lprnet_epoch-24_dynamic_batch.engine
Best reagrds.
Kaka
No, it is not the same.
The tlt-converter will generate trt engine based on etlt model.
The “export” will generate etlt model based on tlt model. In lprnet, it can generate trt enigne too.
