log for sudo dmesg --follow when connect to other host ubuntu22 computer with type-c wired
NV_OR_board.txt (1.9 KB)
reference:
https://jetsonhacks.com/2019/04/19/jetson-nano-serial-console/
https://forums.developer.nvidia.com/t/the-orin-nx-fails-to-flash/298049/3
https://forums.developer.nvidia.com/t/after-apt-dist-upgrade-to-jetpack-4-6-5-emc-freq-dropped-to-204-mhz-instead-of-1600-mhz/299398/3?u=jiuzou
https://forums.developer.nvidia.com/t/jp6-has-no-ip-over-usb-192-168-55-1-anymore/296062/6?u=jiuzou
https://forums.developer.nvidia.com/t/the-jetson-nano-cannot-burn-the-system-using-the-sdk/316605/19?u=jiuzou
I think it is a NV, because it’s handbook let me use SDK-manager or using https://developer.nvidia.com/embedded/jetson-linux-r3640
jiahan@jiahan-desktop:~$ cat /etc/nv_tegra_release
(# R36 (release), REVISION: 4.3, GCID: 38968081, BOARD: generic, EABI: aarch64, DATE: Wed Jan 8 01:49:37 UTC 2025
(# KERNEL_VARIANT: oot
TARGET_USERSPACE_LIB_DIR=nvidia
TARGET_USERSPACE_LIB_DIR_PATH=usr/lib/aarch64-linux-gnu/nvidia
