LSTM ONNX to TensorRT mismatched outputs
Description
I have simple two layer LSTMCell model followed by 4 dense layers for 4 outputs. I get expected outputs with ONNXruntime. So, I proceed for the TensorRT conversion using the ONNX parser. The model is successfully converted to tensorrt ( i have attached to logs below ) but I see different outputs for the same input and now I have no idea whats going wrong maybe some op is not supported in tensorrt I wonder?
Environment
TensorRT Version: 8.4.3.1
GPU Type: RTX 2080Ti
Nvidia Driver Version: 460.73.01
CUDA Version: 11.2
CUDNN Version: 8
Operating System + Version: ubuntu 20.04
Python Version (if applicable):
TensorFlow Version (if applicable):
PyTorch Version (if applicable):
Baremetal or Container (if container which image + tag):
Relevant Files
ONNX model
model_static.onnx (98.1 KB)
script to convert to tensorrt
import os
import argparse
import time
import numpy as np
import tensorrt as trt
import pycuda.autoinit  # noqa # pylint: disable=unused-import
import pycuda.driver as cuda
def parse_args():
    """Parse input arguments."""
    parser = argparse.ArgumentParser(description='train_network')
    parser.add_argument('--onnx_path', dest='onnx_path', help='path to onnx model',
                        default="/opt/vineet-workspace/lstm_tracker/evaluater/model_static.engine/")
    parser.add_argument('--trt_path', dest='trt_path', help='path to trt engine',
                        default="/opt/vineet-workspace/lstm_tracker/evaluater/model_fp32.engine/")
    arguments = parser.parse_args()
    return arguments
def convert(onnx_path, trt_engine_path, fp16=False):
    """Convert ONNX to TensorRT.
    # pylint: disable=no-member
    # Checks if onnx path exists.
    if not os.path.exists(onnx_path):
        raise FileNotFoundError(
            f"[Error] {onnx_path} does not exists.")
    # Check if onnx_path is valid.
    if ".onnx" not in onnx_path:
        raise TypeError(
            f"[Error] Expected onnx weight file, instead {onnx_path} is given."
    # Specify that the network should be created with an explicit batch dimension.
    batch_size = 1 << (int)(
        trt.NetworkDefinitionCreationFlag.EXPLICIT_BATCH)
    trt_logger = trt.Logger(trt.Logger.INFO)
    # Build and serialize engine.
    with trt.Builder(trt_logger) as builder, \
         builder.create_network(batch_size) as network, \
         trt.OnnxParser(network, trt_logger) as parser:
        # Setup builder config.
        config = builder.create_builder_config()
        config.max_workspace_size = 512 *  1 << 20  # 512 MB
        builder.max_batch_size = 1
        # FP16 quantization.
        if builder.platform_has_fast_fp16 and fp16:
            print("[INFO] Setting fp16 to true.")
            trt_engine_path = trt_engine_path.replace('.engine', '_fp16.engine')
            config.flags = 1 << (int)(trt.BuilderFlag.FP16)
        else:
            trt_engine_path = trt_engine_path.replace('.engine', '_fp32.engine')
        if os.path.exists(trt_engine_path):
            print(f"{trt_engine_path} already exists.",
            f"if you wish to regenerate Please delete or change trt_path with --trt_path \"your_engine_file_path.engine\"")
            return None
        # Parse onnx model.
        with open(onnx_path, 'rb') as onnx_file:
            if not parser.parse(onnx_file.read()):
                for error in range(parser.num_errors):
                    print(parser.get_error(error))
        print(network.get_input(0).shape)
        # optimization progile
        # profile = builder.create_optimization_profile()
        # profile.set_shape("input_tensor", (1, 10, 13), (1, 10, 13), (1, 10, 13))
        # config.add_optimization_profile(profile)
        # Build engine.
        engine = builder.build_engine(network, config)
        with open(trt_engine_path, 'wb') as trt_engine_file:
            trt_engine_file.write(engine.serialize())
        print("[INFO] Engine serialized and saved !")
        return engine
class LSTMTrackerTensorRT:
    def __init__(self, trt_path, is_fp16=False):
        # Create a Context on this device,
        self._ctx = cuda.Device(0).make_context()
        self._logger = trt.Logger(trt.Logger.INFO)
        self._stream = cuda.Stream()
        self._is_fp16 = is_fp16
        self.trt_engine_path = trt_path
        # initiate engine related class attributes
        self._engine = None
        self._context = None
        self._inputs = None
        self._outputs = None
        self._bindings = None
        self._load_model(trt_path)
        self._allocate_buffers()
    def _deserialize_engine(self, trt_engine_path):
        """Deserialize TensorRT Cuda Engine
        Args:
            trt_engine_path (str): path to engine file
        Returns:
            trt.tensorrt.ICudaEngine: deserialized engine
        with open(trt_engine_path, 'rb') as engine_file:
            with trt.Runtime(self._logger) as runtime:
                engine = runtime.deserialize_cuda_engine(engine_file.read())
        return engine
    def _allocate_buffers(self) -> None:
        """Allocates memory for inference using TensorRT engine.
        inputs, outputs, bindings = [], [], []
        for binding in self._engine:
            size = trt.volume(self._engine.get_binding_shape(binding))
            dtype = trt.nptype(self._engine.get_binding_dtype(binding))
            host_mem = cuda.pagelocked_empty(size, dtype)
            device_mem = cuda.mem_alloc(host_mem.nbytes)
            bindings.append(int(device_mem))
            if self._engine.binding_is_input(binding):
                inputs.append({'host': host_mem, 'device': device_mem})
            else:
                outputs.append({'host': host_mem, 'device': device_mem})
        # set buffers
        self._inputs = inputs
        self._outputs = outputs
        self._bindings = bindings
    def _load_model(self, engine_path):
        print("[INFO] Deserializing TensorRT engine ...")
        # build engine with given configs and load it
        if not os.path.exists(engine_path):
            raise FileNotFoundError(f"[Error]TensorRT engine does not exist {engine_path}.")
        # deserialize and load engine
        self._engine = self._deserialize_engine(engine_path)\
        if not self._engine:
            raise Exception("[Error] Couldn't deserialize engine successfully !")
        # create execution context
        self._context = self._engine.create_execution_context()
        if not self._context:
            raise Exception(
                "[Error] Couldn't create execution context from engine successfully !")
    def __call__(self, inputs):
        if len(inputs.shape) < 3:
            inputs= np.expand_dims(inputs, axis=0).astype(np.float32)
        if inputs.shape != (1,10,13):
            raise ValueError(f"[Error] Expected inputs with shape (1,10,13)" \
            f"Instead got {inputs.shape}.")
        print(inputs)
        self._inputs[0]['host'] = inputs
        # transfer data to the gpu
        t1 = time.time()
        cuda.memcpy_htod_async(
            self._inputs[0]['device'], self._inputs[0]['host'], self._stream)
        # run inference
        self._context.execute_async_v2(bindings=self._bindings,
                                       stream_handle=self._stream.handle)
        # fetch outputs from gpu
        for out in self._outputs:
            cuda.memcpy_dtoh_async(out['host'], out['device'], self._stream)
        t2 = time.time()
        # synchronize stream
        self._stream.synchronize()
        self._ctx.pop()
        return [out['host'] for out in self._outputs], t2 - t1
    def postprocess(self, outputs):
        pass
    def destroy(self):
        """Destroy if any context in the stack.
        try:
            self._ctx.pop()
        except Exception as exception:
            pass
if __name__=="__main__":
    args = parse_args()
    convert(onnx_path=args.onnx_path trt_engine_path='model.engine')
    lstm_trt = LSTMTrackerTensorRT('./model_fp32.engine')
    x = np.array([[0.97263074, 0.51486486, 0.05135135, 0.00735294, 0., 1., 0., 0., 0., 0., 0., 0., 0. ],
                    [0.96936274, 0.51351351, 0.04864865, 0.0122549, 0., 1., 0., 0., 0., 0., 0., 0., 0. ],
                    [0.96486926, 0.50810808, 0.03783784, 0.01470588,0., 1., 0., 0., 0., 0., 0., 0., 0. ],
                    [0.96119279, 0.51351351, 0.04864865, 0.02859477,0., 1., 0., 0., 0., 0., 0., 0., 0. ],
                    [0.95710784, 0.50810808, 0.03783784, 0.03022876,0., 1., 0., 0., 0., 0., 0., 0., 0. ],
                    [0.95710784, 0.51756757, 0.05675676, 0.04166667,0., 1., 0., 0., 0., 0., 0., 0., 0. ],
                    [0.95465684, 0.51891893, 0.05945946, 0.04820262,0., 1., 0., 0., 0., 0., 0., 0., 0. ],
                    [0.94934642, 0.51081079, 0.04324324, 0.04901961,0., 1., 0., 0., 0., 0., 0., 0., 0. ],
                    [0.95629084, 0.54459459, 0.11081081, 0.0759804, 0., 1., 0., 0., 0., 0., 0., 0., 0. ],
                    [0.95343137, 0.54459459, 0.11081081, 0.08169935, 0., 1., 0., 0., 0., 0., 0., 0., 0. ]])
    x = np.ascontiguousarray(x, dtype=np.float32)
    outputs = lstm_trt(x)
    pred = np.array([out for out in outputs[0]])
    predictions = np.expand_dims(pred, axis=0)
    print(predictions)
output with onnxruntime & original tensorflow model
[[[-3.8089973e+01  1.0527807e+00 -1.1312099e+01 -4.7424686e+01
   -1.6849737e+01 -1.8623383e+00 -2.0075350e-03 -7.0134908e-02
    7.3413447e-02 -8.2136042e-02]
  [-3.0445314e+01  1.3442774e+01 -1.9049225e+01 -5.7058174e+01
   -3.4950836e+01  1.4261748e-01  5.4409849e-03  9.4003871e-02
    1.0161684e+00  1.0353836e+00]
  [-3.1522646e+01  9.7168951e+00 -8.3950176e+00 -3.7055126e+01
   -5.4838821e+01  3.2517239e-01 -5.6228298e-04 -7.6879263e-02
   -1.4470614e+00 -8.8311404e-01]
  [-3.3481293e+01  1.5044321e+01 -1.2752264e+01 -3.4801022e+01
   -3.4844067e+01  1.0599079e+00  1.6894076e-02 -1.9138572e-01
   -1.6254437e+00  5.1925839e-03]]]
output with tensorrt inference script.
[[[ 5.54971956e-03  2.59425223e-01 -1.08758863e-02  5.15959859e-01
   -2.51265216e+00 -1.77742504e-02  1.25943532e-03 -8.10287893e-02
    7.69704580e-02  0.00000000e+00]
  [-2.47224450e+00 -1.42135555e-02 -3.17309201e-01  2.47923434e-01
    2.52945334e-01  0.00000000e+00  3.70394462e-03  1.72122329e-01
    1.76020004e-02  1.38143199e-02]
  [-2.19900131e+00  2.62142438e-02  3.06411609e-02 -2.21815658e+00
   -2.19525838e+00  0.00000000e+00 -3.10053700e-04  5.26212975e-02
    0.00000000e+00  0.00000000e+00]
  [ 1.04971834e-01  5.76606728e-02  2.09427029e-01 -2.57200122e+00
    6.33783340e-01  3.11132912e-02 -1.61380402e-03  2.08504926e-02
    0.00000000e+00 -3.66387353e-03]]]
Steps To Reproduce
  • to build and run inference with tensorrt just run the script given above.
I have seen that people have faced this issue in the past with LSTMs. hoping to get some pointers to take this forward.
Thanks in advance.
Request you to share the ONNX model and the script if not shared already so that we can assist you better.
Alongside you can try few things:
  1. validating your model with the below snippet
check_model.py
import sys
import onnx
filename = yourONNXmodel
model = onnx.load(filename)
onnx.checker.check_model(model).
2) Try running your model with trtexec command.
In case you are still facing issue, request you to share the trtexec “”–verbose"" log for further debugging
@NVES I have already shared the ONNX model. onnx checker doesnt show any issues with the model.
trtexec is not available with the pip install tensorrt. can you share some way to install trtexec with pip. do I need to install the whole tensorrt package from scratch without pip to use trtexec?
We recommend you to please checkout a similar issue.
Thank you.
