Hi SND,
So do all hosts connecting to same IB switch show the same outputs of “iblinkinfo” and “ibnetdiscover” ?
Answer - yes,maybe in a different order, but the data is the same
As in host-1 isn’t going to link a port to a different host then host-2 would?
Answer - same as above - the data should the same, the order may be different
I dug up some old explanation that I did for the output of iblinkinfo, hopefully this will make it more clear:
Description of each column in the output:
Switch
Switch name:
Switch type and model:
Switch 0x0002c90200430e20 MF0;SUPP-5100:IS5100/L01/U1:
Switch
LID
Port Number
Width
Speed
Logical
state
Physical State
LID of connected device
Physical Port in the connected device
for voltaire chassis - the external port number if external
Name of connected device
Type of connected device
4 1 ==( Down/ Polling)==> “” ( )
4 2 ==( Down/ Polling)==> “” ( )
4 3 ==( 4X 10.0 Gbps Active/ LinkUp)==> 13 1 “supp102 HCA-1” ( )
4 4 ==( Down/ Polling)==> “” ( )
4 5 ==( Down/ Polling)==> “” ( )
4 6 ==( Down/ Polling)==> “” ( )
4 7 ==( Down/ Polling)==> “” ( )
4 8 ==( Down/ Polling)==> “” ( )
4 9 ==( Down/ Polling)==> “” ( )
4 10 ==( Down/ Polling)==> “” ( )
4 11 ==( Down/ Polling)==> “” ( )
4 12 ==( 4X 10.0 Gbps Active/ LinkUp)==> 22 1 “supp100 HCA-2” ( )
4 13 ==( Down/ Polling)==> “” ( )
4 14 ==( Down/ Polling)==> “” ( )
4 15 ==( Down/ Polling)==> “” ( )
4 16 ==( 4X 10.0 Gbps Active/ LinkUp)==> 14 34[16] “Voltaire sLB-4018 Line 4 Chip 1 4700 #4700-SUPPORT” ( )
4 17 ==( 4X 10.0 Gbps Active/ LinkUp)==> 14 35[17] “Voltaire sLB-4018 Line 4 Chip 1 4700 #4700-SUPPORT” ( )
4 18 ==( Down/Disabled)==> “” ( )
4 19 ==( 4X 10.0 Gbps Active/ LinkUp)==> 15 1 “MF0;SUPP-5100:IS5100/S01/U1” ( )
4 20 ==( 4X 10.0 Gbps Active/ LinkUp)==> 15 2 “MF0;SUPP-5100:IS5100/S01/U1” ( )
4 21 ==( 4X 10.0 Gbps Active/ LinkUp)==> 15 3 “MF0;SUPP-5100:IS5100/S01/U1” ( )
4 22 ==( 4X 10.0 Gbps Active/ LinkUp)==> 15 4 “MF0;SUPP-5100:IS5100/S01/U1” ( )
4 23 ==( 4X 10.0 Gbps Active/ LinkUp)==> 15 5 “MF0;SUPP-5100:IS5100/S01/U1” ( )
4 24 ==( 4X 10.0 Gbps Active/ LinkUp)==> 15 6 “MF0;SUPP-5100:IS5100/S01/U1” ( )
4 25 ==( 4X 10.0 Gbps Active/ LinkUp)==> 2 1 “MF0;SUPP-5100:IS5100/S02/U1” ( )
4 26 ==( 4X 10.0 Gbps Active/ LinkUp)==> 2 2 “MF0;SUPP-5100:IS5100/S02/U1” ( )
4 27 ==( 4X 10.0 Gbps Active/ LinkUp)==> 2 3 “MF0;SUPP-5100:IS5100/S02/U1” ( )
4 28 ==( 4X 10.0 Gbps Active/ LinkUp)==> 2 4 “MF0;SUPP-5100:IS5100/S02/U1” ( )
4 29 ==( 4X 10.0 Gbps Active/ LinkUp)==> 2 5 “MF0;SUPP-5100:IS5100/S02/U1” ( )
4 30 ==( 4X 10.0 Gbps Active/ LinkUp)==> 2 6 “MF0;SUPP-5100:IS5100/S02/U1” ( )
4 31 ==( 4X 10.0 Gbps Active/ LinkUp)==> 19 1 “MF0;SUPP-5100:IS5100/S03/U1” ( )
4 32 ==( 4X 10.0 Gbps Active/ LinkUp)==> 19 2 “MF0;SUPP-5100:IS5100/S03/U1” ( )
4 33 ==( 4X 10.0 Gbps Active/ LinkUp)==> 19 3 “MF0;SUPP-5100:IS5100/S03/U1” ( )
4 34 ==( 4X 10.0 Gbps Active/ LinkUp)==> 19 4 “MF0;SUPP-5100:IS5100/S03/U1” ( )
4 35 ==( 4X 10.0 Gbps Active/ LinkUp)==> 19 5 “MF0;SUPP-5100:IS5100/S03/U1” ( )
4 36 ==( 4X 10.0 Gbps Active/ LinkUp)==> 19 6 “MF0;SUPP-5100:IS5100/S03/U1” ( )
