[MAJOR] KDE Plasma Desktop Frameskip/Lag issues on driver 555
There seems to have been some changes in driver 555 which have resulted in the same issue as reported in my github for open source to also affect the proprietary driver now:
EDIT: The solution was to add NVreg_EnableGpuFirmware=0 to the kernel load and all issues were fixed!
P.S. Firstly, sorry for the ping but would like to thank to all nvidia developers for making explicit sync happen, wayland has been fully resolved! You guys are amazing and put a big effort thank you all!
Hello. Could you please confirm if I’m correct: NVreg_EnableGpuFirmware=0 would go into /boot/loader/entries/{entryName}.conf under options (for systemd-boot)? At least that’s what I understood by add to the kernel load, but it didn’t seem to work for me. My picture still has significant frame drops (tho not necessarily when opening apps so maybe a different issue?). I move a window around and one moment it will be smooth and the next it will be really choppy (the same with scrolling etc.). I thank you in advance, I was waiting for proper Wayland support for so long and now that I have it it still works worse than 535.
I put it in my /etc/kernel/cmdline as nvidia.NVreg_EnableGpuFirmware=0 and then ran sudo reinstall-kernels.
For grub system it should be in /etc/default/grub and then in the GRUB_CMDLINE_LINUX_DEFAULT="quiet splash nvidia.NVreg_EnableGpuFirmware=0" after which run the update-grub or the grub-mkconfig command to rebuild kernels.
Oh my god, nvidia.NVreg_EnableGpuFirmware=0, why didn’t I think of that. I feel like such a dumbass. Thank you very much! Works great now. I hope you have a pleasant day/night!
Weird tho’, I’ve ran NVreg_EnableGpuFirmware=1 previously and had no issues, I don’t think 550 have this problem (the proprietary module).
Ohh i posted on the 555 bug topic, but here also just in case.
Having major framespikes with firmware enabled on RTX 3080, MATE Desktop, X11
Thank you! This made my system so much smoother.
Hi All,
Please help to test with latest release driver 555.58.02 and share the feedback.
It still hasn’t been resolved, I did file a bug report here with 555.58 - [MAJOR] KDE Plasma Wayland & X11 poor performance & frame drops when opening apps · Issue #538 · NVIDIA/open-gpu-kernel-modules · GitHub
The issue still persists with this driver across the KDE desktop, most prominent when dragging around GTK apps. This does not mean QT apps are smooth either. They are until i open a GTK app like firefox. Disabling GSP Firmware fixes this issue.
@kodatarule Can you please add nvidia. infront of the NVreg_EnableGpuFirmware=0 in your solution portion as that is the correct entry? This will make it easier for new users who access this forum.
I have - [MAJOR] KDE Plasma Desktop Frameskip/Lag issues on driver 555 - #3 by kodatarule
Unfortunately it doesn’t allow me to edit the OG post.
Update: The GSP issues as well as the open kernel module are fully fixed in 570.124.04
